[MOAB-dev] r1851 - MOAB/trunk
kraftche at mcs.anl.gov
Tue May 27 17:48:52 CDT 2008
Author: kraftche
Date: 2008-05-27 17:48:52 -0500 (Tue, 27 May 2008)
New Revision: 1851
Modified:
MOAB/trunk/kd_tree_tool.cpp
Log:
support building trees from any element type
Modified: MOAB/trunk/kd_tree_tool.cpp
--- MOAB/trunk/kd_tree_tool.cpp 2008-05-27 22:48:24 UTC (rev 1850)
+++ MOAB/trunk/kd_tree_tool.cpp 2008-05-27 22:48:52 UTC (rev 1851)
@@ -18,7 +18,7 @@
std::string clock_to_string( clock_t t );
std::string mem_to_string( unsigned long mem );
-void build_tree( MBInterface* interface,
+void build_tree( MBInterface* interface, const MBRange& elems,
MBAdaptiveKDTree::Settings settings,
unsigned meshset_flags );
void build_grid( MBInterface* iface,
@@ -27,7 +27,7 @@
const double dims[3] );
void delete_existing_tree( MBInterface* interface );
void print_stats( MBInterface* interface );
-void tag_triangles( MBInterface* interface );
+void tag_elements( MBInterface* interface );
void tag_vertices( MBInterface* interface );
void write_tree_blocks( MBInterface* interface, const char* file );
@@ -42,25 +42,27 @@
static void usage( bool err = true )
std::ostream& s = err ? std::cerr : std::cout;
- s << "kd_tree_tool [-s|-S] [-d <int>] [-n <int>] [-u|-p|-m|-v] [-N <int>] <input file> <output file>" << std::endl
- << "kd_tree_tool [-s|-S] [-d <int>] -G <dims> <output file>" << std::endl
+ s << "kd_tree_tool [-d <int>] [-2|-3] [-n <int>] [-u|-p|-m|-v] [-N <int>] [-s|-S] <input file> <output file>" << std::endl
+ << "kd_tree_tool [-d <int>] -G <dims> [-s|-S] <output file>" << std::endl
<< "kd_tree_tool [-h]" << std::endl;
if (!err) {
MBAdaptiveKDTree::Settings st;
- s << "Tool to build adaptive kd-Tree from triangles" << std::endl;
- s << " -s Use range-based sets for tree nodes" << std::endl
- << " -S Use vector-based sets for tree nodes" << std::endl
- << " -d <int> Specify maximum depth for tree. Default: " << st.maxTreeDepth << std::endl
+ s << "Tool to build adaptive kd-Tree" << std::endl;
+ s << " -d <int> Specify maximum depth for tree. Default: " << st.maxTreeDepth << std::endl
<< " -n <int> Specify maximum entities per leaf. Default: " << st.maxEntPerLeaf << std::endl
+ << " -2 Build tree from surface elements. Default: yes" << std::endl
+ << " -3 Build tree from volume elements. Default: yes" << std::endl
<< " -u Use 'SUBDIVISION' scheme for tree construction" << ds(MBAdaptiveKDTree::SUBDIVISION) << std::endl
<< " -p Use 'SUBDIVISION_SNAP' tree construction algorithm." << ds(MBAdaptiveKDTree::SUBDIVISION_SNAP) << std::endl
<< " -m Use 'VERTEX_MEDIAN' tree construction algorithm." << ds(MBAdaptiveKDTree::VERTEX_MEDIAN) << std::endl
<< " -v Use 'VERTEX_SAMPLE' tree construction algorithm." << ds(MBAdaptiveKDTree::VERTEX_SAMPLE) << std::endl
<< " -N <int> Specify candidate split planes per axis. Default: " << st.candidateSplitsPerDir << std::endl
- << " -t Tag triangles will tree cell number." << std::endl
+ << " -t Tag elements will tree cell number." << std::endl
<< " -T Write tree boxes to file." << std::endl
- << " -G <dims> Generate grid - no input triangles. Dims must be " << std::endl
+ << " -G <dims> Generate grid - no input elements. Dims must be " << std::endl
<< " HxWxD or H." << std::endl
+ << " -s Use range-based sets for tree nodes" << std::endl
+ << " -S Use vector-based sets for tree nodes" << std::endl
<< std::endl;
exit( err );
@@ -145,12 +147,13 @@
int main( int argc, char* argv[] )
+ bool surf_elems = false, vol_elems = false;
const char* input_file = 0;
const char* output_file = 0;
const char* tree_file = 0;
MBAdaptiveKDTree::Settings settings;
unsigned meshset_flags = MESHSET_SET;
- bool tag_tris = false;
+ bool tag_elems = false;
clock_t load_time, build_time, stat_time, tag_time, write_time, block_time;
bool make_grid = false;
double dims[3];
@@ -170,8 +173,10 @@
usage();
switch (argv[i][1]) {
+ case '2': surf_elems = true; break;
+ case '3': vol_elems = true; break;
+ case 'S': meshset_flags = MESHSET_ORDERED; break;
case 's': meshset_flags = MESHSET_SET; break;
- case 'S': meshset_flags = MESHSET_ORDERED; break;
case 'd': settings.maxTreeDepth = parseint( i, argc, argv ); break;
case 'n': settings.maxEntPerLeaf = parseint( i, argc, argv ); break;
case 'u': settings.candidatePlaneSet = MBAdaptiveKDTree::SUBDIVISION; break;
@@ -179,7 +184,7 @@
case 'm': settings.candidatePlaneSet = MBAdaptiveKDTree::VERTEX_MEDIAN; break;
case 'v': settings.candidatePlaneSet = MBAdaptiveKDTree::VERTEX_SAMPLE; break;
case 'N': settings.candidateSplitsPerDir = parseint( i, argc, argv ); break;
- case 't': tag_tris = true; break;
+ case 't': tag_elems = true; break;
case 'T': tree_file = argv[++i]; break;
case 'G': make_grid = true; parsedims( i, argc, argv, dims ); break;
case 'h': usage(false);
@@ -190,6 +195,10 @@
if (make_grid != !output_file)
usage();
+ // default to both
+ if (!surf_elems && !vol_elems)
+ surf_elems = vol_elems = true;
MBErrorCode rval;
MBCore moab_core;
MBInterface* interface = &moab_core;
@@ -216,7 +225,20 @@
std::cout << "Building tree..." << std::endl;
build_time = clock();
- build_tree( interface, settings, meshset_flags );
+ MBRange elems;
+ if (!surf_elems) {
+ interface->get_entities_by_dimension( 0, 3, elems );
+ else {
+ interface->get_entities_by_dimension( 0, 2, elems );
+ if (vol_elems) {
+ MBRange tmp;
+ interface->get_entities_by_dimension( 0, 3, tmp );
+ elems.merge( tmp );
+ build_tree( interface, elems, settings, meshset_flags );
build_time = clock() - build_time;
@@ -224,9 +246,9 @@
print_stats( interface );
stat_time = clock() - build_time;
- if (tag_tris) {
+ if (tag_elems) {
std::cout << "Tagging tree..." << std::endl;
- tag_triangles( interface );
+ tag_elements( interface );
tag_vertices( interface );
tag_time = clock() - stat_time;
@@ -252,7 +274,7 @@
<< " Build"
<< " Stats"
<< " Write";
- if (tag_tris)
+ if (tag_elems)
std::cout << "Tag Sets";
if (tree_file)
std::cout << "Block ";
@@ -263,7 +285,7 @@
<< std::setw(8) << clock_to_string(build_time)
<< std::setw(8) << clock_to_string(stat_time)
<< std::setw(8) << clock_to_string(write_time);
- if (tag_tris)
+ if (tag_elems)
std::cout << std::setw(8) << clock_to_string(tag_time);
if (tree_file)
std::cout << std::setw(8) << clock_to_string(block_time);
@@ -292,22 +314,21 @@
+ const MBRange& elems,
MBErrorCode rval;
MBEntityHandle root = 0;
- MBRange triangles;
- rval = interface->get_entities_by_type( 0, MBTRI, triangles );
- if (MB_SUCCESS != rval || triangles.empty()) {
- std::cerr << "No triangles from which to build tree." << std::endl;
+ if (elems.empty()) {
+ std::cerr << "No elements from which to build tree." << std::endl;
exit(4);
MBAdaptiveKDTree tool(interface, 0, meshset_flags);
- rval = tool.build_tree( triangles, root, &settings );
+ rval = tool.build_tree( elems, root, &settings );
if (MB_SUCCESS != rval || !root) {
std::cerr << "Tree construction failed." << std::endl;
exit(4);
@@ -444,25 +465,30 @@
root = *range.begin();
range.clear();
- MBRange tree_sets, triangles, verts;
+ MBRange tree_sets, elem2d, elem3d, verts, all;
//interface->get_child_meshsets( root, tree_sets, 0 );
interface->get_entities_by_type( 0, MBENTITYSET, tree_sets );
tree_sets.erase( tree_sets.begin(), MBRange::lower_bound( tree_sets.begin(), tree_sets.end(), root ) );
- interface->get_entities_by_type( 0, MBTRI, triangles );
+ interface->get_entities_by_dimension( 0, 2, elem2d );
+ interface->get_entities_by_dimension( 0, 3, elem3d );
interface->get_entities_by_type( 0, MBVERTEX, verts );
- triangles.merge( verts );
+ all.clear();
+ all.merge( verts );
+ all.merge( elem2d );
+ all.merge( elem3d );
tree_sets.insert( root );
unsigned long set_used, set_amortized, set_store_used, set_store_amortized,
- set_tag_used, set_tag_amortized, tri_used, tri_amortized;
+ set_tag_used, set_tag_amortized, elem_used, elem_amortized;
interface->estimated_memory_use( tree_sets,
&set_used, &set_amortized,
&set_store_used, &set_store_amortized,
0, 0, 0, 0,
&set_tag_used, &set_tag_amortized );
- interface->estimated_memory_use( triangles, &tri_used, &tri_amortized );
+ interface->estimated_memory_use( all, &elem_used, &elem_amortized );
- int num_tri = 0;
- interface->get_number_entities_by_type( 0, MBTRI, num_tri );
+ int num_2d = 0, num_3d = 0;;
+ interface->get_number_entities_by_dimension( 0, 2, num_2d );
+ interface->get_number_entities_by_dimension( 0, 3, num_3d );
double min[3] = {0,0,0}, max[3] = {0,0,0};
tool.get_tree_box( root, min, max );
@@ -478,9 +504,9 @@
do {
depth.add( iter.depth() );
- int num_leaf_tri;
- interface->get_number_entities_by_type( iter.handle(), MBTRI, num_leaf_tri );
- size.add(num_leaf_tri);
+ int num_leaf_elem;
+ interface->get_number_entities_by_handle( iter.handle(), num_leaf_elem );
+ size.add(num_leaf_elem);
const double* n = iter.box_min();
const double* x = iter.box_max();
@@ -499,14 +525,14 @@
printf("------------------------------------------------------------------\n");
printf("tree volume: %f\n", tree_vol );
- printf("total triangles: %d\n", num_tri );
+ printf("total elements: %d\n", num_2d + num_3d );
printf("number of leaves: %lu\n", (unsigned long)depth.count );
printf("number of nodes: %lu\n", (unsigned long)tree_sets.size() );
printf("volume ratio: %0.2f%%\n", 100*(vol.sum / tree_vol));
printf("surface ratio: %0.2f%%\n", 100*(surf.sum / tree_surf_area));
printf("\nmemory: used amortized\n");
printf(" ---------- ----------\n");
- printf("triangles %10s %10s\n",mem_to_string(tri_used).c_str(), mem_to_string(tri_amortized).c_str());
+ printf("elements %10s %10s\n",mem_to_string(elem_used).c_str(), mem_to_string(elem_amortized).c_str());
printf("sets (total)%10s %10s\n",mem_to_string(set_used).c_str(), mem_to_string(set_amortized).c_str());
printf("sets %10s %10s\n",mem_to_string(set_store_used).c_str(), mem_to_string(set_store_amortized).c_str());
printf("set tags %10s %10s\n",mem_to_string(set_tag_used).c_str(), mem_to_string(set_tag_amortized).c_str());
@@ -527,7 +553,7 @@
return (int)((h * 13 + 7) % MAX_TAG_VALUE) + 1;
-void tag_triangles( MBInterface* moab )
+void tag_elements( MBInterface* moab )
MBEntityHandle root;
MBRange range;
@@ -555,7 +581,7 @@
std::vector<int> tag_vals;
do {
range.clear();
- moab->get_entities_by_type( iter.handle(), MBTRI, range );
+ moab->get_entities_by_handle( iter.handle(), range );
tag_vals.clear();
tag_vals.resize( range.size(), hash_handle(iter.handle()) );
moab->tag_set_data( tag, range, &tag_vals[0] );
@@ -589,7 +615,7 @@
do {
range.clear();
int tag_val = hash_handle(iter.handle());
MBRange verts;
