[MOAB-dev] r1854 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Wed May 28 17:02:45 CDT 2008
Author: kraftche
Date: 2008-05-28 17:02:45 -0500 (Wed, 28 May 2008)
New Revision: 1854
Modified:
   MOAB/trunk/MBGeomUtil.cpp
Log:
Replace MBGeomUtil::box_hex_overlap with new code derived from the
more general MBGeomUtil::box_linear_elem_overlap.  Specializing
box_linear_elem_overlap for hexes seems to reduce the CPU time by
about half without big changes to the code.  I assume gcc is doing
a better job of optimizing the code when it contains fewer variables.
For the test case described below, this change reduced the time to
build a kD-tree from hexes by 79%.
Test case:
MOAB configure options: --enable-optimize --enable-debug
Resulting CXXFLAGS:     -g -O2 -NDEBUG
Input mesh:             100x100x100 block divided into 99x99x99 hexes with
                        a constant edge length of 1.  970,299 total hexes.
Tree construction:      SUBDIVISION w/ 5 candidate splits per axis.
Resulting Stats (new code):
tree volume:      970299.000000
total elements:   970299
number of leaves: 941192
number of nodes:  1882383
volume ratio:     100.00%
surface ratio:    9800.00%
memory:           used  amortized
elements         82 MB      82 MB
sets (total)    187 MB     187 MB
sets            158 MB     158 MB
set tags         29 MB      29 MB
total real      297 MB     315 MB
leaf stats:        min        avg        rms        max    std.dev
depth               19       21.1       21.1         22       0.80
elements             8        8.0        8.0          8       0.00
volume           0.017          1        1.4        3.7       0.96
surf. area         0.4        6.1          7         14        3.5
Writing file... Wrote tree.h5m
Times:      Load   Build   Stats   Write
           0.11s 178.77s   0.54s  11.44s
real	3m12.746s
user	3m9.500s
sys	0m0.912s
Resulting Stats (old code):
sets            158 MB     158 MB
triangles            8        8.0        8.0          8       0.00
           0.13s 853.41s   0.57s  11.57s
real	14m27.875s
user	14m24.146s
sys	0m1.032s
Modified: MOAB/trunk/MBGeomUtil.cpp
--- MOAB/trunk/MBGeomUtil.cpp	2008-05-28 20:29:35 UTC (rev 1853)
+++ MOAB/trunk/MBGeomUtil.cpp	2008-05-28 22:02:45 UTC (rev 1854)
@@ -489,8 +489,185 @@
   return true;
+bool box_hex_overlap( const MBCartVect *elem_corners,
+                      const MBCartVect& center,
+                      const MBCartVect& dims )
+    // Do Separating Axis Theorem:
+    // If the element and the box overlap, then the 1D projections
+    // onto at least one of the axes in the following three sets
+    // must overlap (assuming convex polyhedral element).
+    // 1) The normals of the faces of the box (the principal axes)
+    // 2) The crossproduct of each element edge with each box edge
+    //    (crossproduct of each edge with each principal axis)
+    // 3) The normals of the faces of the element
+  unsigned i, e, f;             // loop counters
+  bool all_less, all_greater;   // track overlap (or lack thereof)
+  double dot, cross[2], tmp;
+  MBCartVect norm;
+  const MBCartVect corners[8] = { elem_corners[0] - center,
+                                  elem_corners[1] - center,
+                                  elem_corners[2] - center,
+                                  elem_corners[4] - center,
+                                  elem_corners[5] - center,
+                                  elem_corners[6] - center,
+                                  elem_corners[7] - center };
+    // test box face normals (principal axes)
+  int not_less[3] = { 8, 8, 8 };
+  int not_greater[3] = { 8, 8, 8 };
+  int not_inside;
+  for (i = 0; i < 8; ++i) { // for each element corner
+    not_inside = 3;
+    if (corners[i][0] < -dims[0])
+      --not_less[0];
+    else if (corners[i][0] > dims[0])
+      --not_greater[0];
+    else
+      --not_inside;
+    if (corners[i][1] < -dims[1])
+      --not_less[1];
+    else if (corners[i][1] > dims[1])
+      --not_greater[1];
+    else
+      --not_inside;
+    if (corners[i][2] < -dims[2])
+      --not_less[2];
+    else if (corners[i][2] > dims[2])
+      --not_greater[2];
+    else
+      --not_inside;
+    if (!not_inside)
+      return true;
+    // If all points less than min_x of box, then
+    // not_less[0] == 0, and therfore
+    // the following product is zero.
+  if (not_greater[0] * not_greater[1] * not_greater[2] *
+         not_less[0] *    not_less[1] *    not_less[2] == 0)
+    return false;
+    // Test edge-edge crossproducts
+  const unsigned edges[12][2] = { { 0, 1 }, { 0, 4 }, { 0, 3 },
+                                  { 2, 3 }, { 2, 1 }, { 2, 6 },
+                                  { 5, 6 }, { 5, 1 }, { 5, 4 },
+                                  { 7, 4 }, { 7, 3 }, { 7, 6 } };
+    // Edge directions for box are principal axis, so
+    // for each element edge, check along the cross-product
+    // of that edge with each of the tree principal axes.
+  for (e = 0; e < 12; ++e) { // for each element edge
+      // get which element vertices bound the edge
+    const MBCartVect& v0 = corners[ edges[e][0] ];
+    const MBCartVect& v1 = corners[ edges[e][1] ];
+      // X-Axis
+      // calculate crossproduct: axis x (v1 - v0),
+      // where v1 and v0 are edge vertices.
+    cross[0] = v0[2] - v1[2];
+    cross[1] = v1[1] - v0[1];
+      // skip if orthogonal
+    if ((cross[0]*cross[0] + cross[1]*cross[1]) >= std::numeric_limits<double>::epsilon()) {
+      dot = fabs(cross[0] * dims[1]) + fabs(cross[1] * dims[2]);
+      all_less = all_greater = true;
+      for (i = (edges[e][0]+1)%8; i != edges[e][0]; i = (i+1)%8) { // for each element corner
+        tmp = cross[0] * corners[i][1] + cross[1] * corners[i][2];
+        if (tmp > -dot)
+          all_less = false;
+        if (tmp < dot)
+          all_greater = false;
+      if (all_less || all_greater)
+        return false;
+      // Y-Axis
+    cross[0] = v0[0] - v1[0];
+    cross[1] = v1[2] - v0[2];
+      dot = fabs(cross[0] * dims[2]) + fabs(cross[1] * dims[0]);
+        tmp = cross[0] * corners[i][2] + cross[1] * corners[i][0];
+        if (tmp > -dot)
+          all_less = false;
+        if (tmp < dot)
+        return false;
+      // Z-Axis
+    cross[0] = v0[1] - v1[1];
+    cross[1] = v1[0] - v0[0];
+      dot = fabs(cross[0] * dims[0]) + fabs(cross[1] * dims[1]);
+        tmp = cross[0] * corners[i][0] + cross[1] * corners[i][1];
+        if (tmp > -dot)
+          all_less = false;
+        if (tmp < dot)
+        return false;
+    // test element face normals
+  const unsigned faces[6][4] = { { 0, 1, 2, 3 },
+                                 { 0, 1, 5, 4 },
+                                 { 1, 2, 6, 5 },
+                                 { 2, 6, 7, 3 },
+                                 { 3, 7, 4, 0 },
+                                 { 7, 4, 5, 6 } };
+  for (f = 0; f < 6; ++f) {
+    norm = quad_norm( corners[faces[f][0]],
+                      corners[faces[f][1]],
+                      corners[faces[f][2]],
+                      corners[faces[f][3]] );
+    dot = fabs(norm[0] * dims[0]) + fabs(norm[1] * dims[1]) + fabs(norm[2] * dims[2]);
+    // for each element vertex
+      tmp = norm % corners[i];
+      if (tmp > -dot)
+        all_less = false;
+      if (tmp < dot)
+      return false;
+    // Overlap on all tested axes.
+  return true;
 //from: http://www.geometrictools.com/Documentation/DistancePoint3Triangle3.pdf#search=%22closest%20point%20on%20triangle%22
 /*       t
  *   \(2)^
@@ -762,155 +939,6 @@
   return closest % closest < tolerance * tolerance;
-bool box_hex_overlap( const MBCartVect hex_vertices[8],
-                      const MBCartVect& box_center,
-                      const MBCartVect& box_dims)
-      // Mapping of vertices to each face on MBHEX
-      const unsigned int facids[] = {0, 1, 5, 4,   1, 2, 6, 5,   2, 3, 7, 6,
-                                     3, 0, 4, 7,   3, 2, 1, 0,   4, 5, 6, 7};
-      // Mapping of vertices to each edge on MBHEX
-      const unsigned int edgids[] = {0, 1,   1, 2,   2, 3,   3, 0,
-                                     0, 4,   1, 5,   2, 6,   3, 7,
-                                     4, 5,   5, 6,   6, 7,   7, 4};
-      const double eps = 1.e-10;
-      // Center the hex such that origin located at the box
-      MBCartVect hexv[8];
-      for (unsigned int i=0; i < 8; i++) {
-            hexv[i] = hex_vertices[i] - box_center;
-      // Check hex against box normals...
-      // Need to check both positive and negative faces
-      double       t;
-      unsigned int positive = 0, negative = 0;
-      unsigned int out_plus = 0, out_minus = 0, inside = 0;
-      bool         test;
-      // Negative face, loop over all vertices in hex
-      for (unsigned int i=0; i < 3; i++) {
-            // vxyz = box_center[i] + box_dims[i];
-            out_plus = 0; out_minus = 0; inside = 0;
-            // Test each vertex on hex...
-            for (unsigned int j=0; j < 8; j++) {
-                  const double bxd = box_dims[i] + eps;
-                  if (hexv[j][i] > bxd )  out_plus++;
-                  else if (hexv[j][i] < -bxd )  out_minus++;
-                  else inside++;
-                  test = ((inside) || ( out_plus && out_minus ));
-                  if (test) break;
-            if (!test) return false;
-      // Construct the vertices of the box...
-      MBCartVect boxv[8];
-      boxv[0][0] = -box_dims[0]; boxv[0][1] = -box_dims[1]; boxv[0][2] = -box_dims[2];
-      boxv[1][0] =  box_dims[0]; boxv[1][1] = -box_dims[1]; boxv[1][2] = -box_dims[2];
-      boxv[2][0] =  box_dims[0]; boxv[2][1] =  box_dims[1]; boxv[2][2] = -box_dims[2];
-      boxv[3][0] = -box_dims[0]; boxv[3][1] =  box_dims[1]; boxv[3][2] = -box_dims[2];
-      boxv[4][0] = -box_dims[0]; boxv[4][1] = -box_dims[1]; boxv[4][2] =  box_dims[2];
-      boxv[5][0] =  box_dims[0]; boxv[5][1] = -box_dims[1]; boxv[5][2] =  box_dims[2];
-      boxv[6][0] =  box_dims[0]; boxv[6][1] =  box_dims[1]; boxv[6][2] =  box_dims[2];
-      boxv[7][0] = -box_dims[0]; boxv[7][1] =  box_dims[1]; boxv[7][2] =  box_dims[2];
-      // Check box against hex normals ...
-      // Loop over each face of hex
-      for (unsigned int i = 0; i < 6; i++ ) {
-            // Compute the normal
-        const MBCartVect midpt1 = 0.5 * (( hexv[(facids[4*i+2])] + hexv[(facids[4*i+3])] )
-                                    - ( hexv[(facids[4*i])]   + hexv[(facids[4*i+1])] ));
-        const MBCartVect midpt2 = 0.5 * (( hexv[(facids[4*i+3])] + hexv[(facids[4*i])]   )
-                                    - ( hexv[(facids[4*i+1])] + hexv[(facids[4*i+2])] ));
-        const MBCartVect normal = midpt1 * midpt2;
-        // Loop over each vertex in the box
-        positive = 0; negative = 0;
-          // Take dot product of the vector and normal
-          t = ( boxv[j] - hexv[(facids[4*i])] ) % normal;
-          // Do the comparison
-          if (t > eps )  positive++;
-          else           negative++;
-          if (positive && negative) break;
-        // std::cout << positive << "  " << negative << std::endl;
-        test = ( (positive && !negative) ? false : true );
-      // Edge check ...
-      // For box, only need to check three edges due to orthogonality
-      int side1, side2;
-      MBCartVect edge_cross;
-      for (unsigned int d = 0; d < 3; d++ ) {
-        // const unsigned int d0 = d % 3;
-        const unsigned int d1 = (d + 1) % 3;
-        const unsigned int d2 = (d + 2) % 3;
-        for (unsigned int i = 0; i < 12; i++) {
-          // edge_cross[d0] = 0.;
-          edge_cross[d1] = hexv[(edgids[2*i])][d2] - hexv[(edgids[2*i+1])][d2];
-          edge_cross[d2] = hexv[(edgids[2*i+1])][d1] - hexv[(edgids[2*i])][d1];
-          if ((edge_cross[d1]*edge_cross[d1] + edge_cross[d2]*edge_cross[d2]) < eps) continue;
-          side1 = side2 = 0;
-          // Hex edge and box vertex tests
-          positive = 0; negative = 0; test = false;
-          for (unsigned int j = 0; j < 8; j++) {
-            // t = edge_cross % ( boxv[j] - hexv[(edgids[2*i])] );
-            t =  edge_cross[d1] * ( boxv[j][d1] - hexv[(edgids[2*i])][d1] )
-               + edge_cross[d2] * ( boxv[j][d2] - hexv[(edgids[2*i])][d2] );
-            if (t > eps) positive++;
-            else if (t < -eps) negative++;
-            if (positive && negative) {
-              test = true;
-              break;
-          if (!test) side1 = ( (positive && !negative) ? +1 : -1 );
-          if (side1 == 0) continue;
-          // Hex edge and hex vertex tests
-            // t = edge_cross % ( hexv[j] - hexv[(edgids[2*i])] );
-              test = true;
-              break;
-          if (!test) side2 = ( (positive && !negative) ? +1 : -1 );
-          if (side2 == 0) continue;
-          // Test if on opposite sides
-          if (side1 * side2 < 0 ) return false;
-      // All possibilities exhausted, must overlap ...
-      return true;
 bool point_in_trilinear_hex(MBCartVect hex[8],
                             MBCartVect xyz,
                             double etol)
