[MOAB-dev] r1932 - in MOAB/trunk: parallel tools/mbcoupler
tautges at mcs.anl.gov
Thu Jun 26 13:39:15 CDT 2008
Author: tautges
Date: 2008-06-26 13:39:15 -0500 (Thu, 26 Jun 2008)
New Revision: 1932
Modified:
MOAB/trunk/parallel/tuple_list.h
MOAB/trunk/tools/mbcoupler/MBCoupler.cpp
MOAB/trunk/tools/mbcoupler/MBCoupler.hpp
Log:
Modified tuple_list to not try to allocate zero-sized memory.
Don't try to map remotely if a locally containing element is found.
Fixed a few bad dimensions of tuple lists and other assorted bugs.
Modified: MOAB/trunk/parallel/tuple_list.h
--- MOAB/trunk/parallel/tuple_list.h 2008-06-26 14:55:10 UTC (rev 1931)
+++ MOAB/trunk/parallel/tuple_list.h 2008-06-26 18:39:15 UTC (rev 1932)
@@ -36,10 +36,10 @@
tl->n=0; tl->max=max;
tl->mi=mi,tl->ml=ml,tl->mul=mul,tl->mr=mr;
- tl->vi=tmalloc(sint, max*mi);
- tl->vl=tmalloc(slong,max*ml);
- tl->vul=tmalloc(ulong,max*mul);
- tl->vr=tmalloc(real, max*mr);
+ tl->vi=(max ? tmalloc(sint, max*mi) : 0);
+ tl->vl=(max ? tmalloc(slong,max*ml) : 0);
+ tl->vul=(max ? tmalloc(ulong,max*mul) : 0);
+ tl->vr=(max ? tmalloc(real, max*mr) : 0);
static void tuple_list_free(tuple_list *tl) {
@@ -57,7 +57,7 @@
static void tuple_list_grow(tuple_list *tl)
- tuple_list_resize(tl,tl->max+tl->max/2+1);
+ tuple_list_resize(tl,(tl->max ? tl->max+tl->max/2+1 : 2));
void tuple_list_permute(tuple_list *tl, uint *perm, void *work);
Modified: MOAB/trunk/tools/mbcoupler/MBCoupler.cpp
--- MOAB/trunk/tools/mbcoupler/MBCoupler.cpp 2008-06-26 14:55:10 UTC (rev 1931)
+++ MOAB/trunk/tools/mbcoupler/MBCoupler.cpp 2008-06-26 18:39:15 UTC (rev 1932)
@@ -90,52 +90,62 @@
// allocate tuple_list to hold point data: (p, i, , xyz), i = point index
tuple_list target_pts;
- tuple_list_init_max(&target_pts, 2, 0, 0, 3, 3*num_points);
+ tuple_list_init_max(&target_pts, 2, 0, 0, 3, num_points);
// initialize source_pts and local_pts
tuple_list source_pts;
mappedPts = new tuple_list;
- tuple_list_init_max(&source_pts, 3, 0, 0, 0, target_pts.n);
- tuple_list_init_max(mappedPts, 0, 0, 1, 3, target_pts.n);
+ tuple_list_init_max(&source_pts, 3, 0, 0, 0, target_pts.max);
+ tuple_list_init_max(mappedPts, 0, 0, 1, 3, target_pts.max);
mappedPts->n = 0;
source_pts.n = 0;
MBErrorCode result;
+ // keep track of which points have been located
+ std::vector<unsigned char> located_pts(num_points, 0);
// for each point, find box(es) containing the point,
// appending results to tuple_list;
// keep local points separately, in local_pts, which has pairs
// of <local_index, mapped_index>, where mapped_index is the index
// into the mappedPts tuple list
+ unsigned int my_rank = myPc->proc_config().proc_rank();
+ bool point_located;
for (int i = 0; i < 3*num_points; i+=3)
+ // test point locally first
+ result = test_local_box(xyz+i, my_rank, i/3, i/3, point_located);
+ if (MB_SUCCESS != result) return result;
+ if (point_located) {
+ located_pts[i/3] = 0x1;
+ continue;
+ // if not located locally, test other procs' boxes
for (unsigned int j = 0; j < myPc->proc_config().proc_size(); j++)
- // test if point is in box
+ if (j == my_rank) continue;
+ // test if point is in proc's box
if (allBoxes[6*j] <= xyz[i] && xyz[i] <= allBoxes[6*j+3] &&
allBoxes[6*j+1] <= xyz[i+1] && xyz[i+1] <= allBoxes[6*j+4] &&
allBoxes[6*j+2] <= xyz[i+2] && xyz[i+2] <= allBoxes[6*j+5])
- if (j == myPc->proc_config().proc_rank())
- result = test_local_box(xyz+i, j, i/3, i/3);
- else {
- // check size, grow if we're at max
- if (target_pts.n == target_pts.max)
- tuple_list_grow(&target_pts);
- target_pts.n++;
+ // if in this proc's box, will send to proc to test further
+ // check size, grow if we're at max
+ if (target_pts.n == target_pts.max)
+ tuple_list_grow(&target_pts);
- target_pts.vi[2*target_pts.n] = j;
- target_pts.vi[2*target_pts.n+1] = i/3;
- target_pts.vr[3*target_pts.n] = xyz[i];
- target_pts.vr[3*target_pts.n+1] = xyz[i+1];
- target_pts.vr[3*target_pts.n+2] = xyz[i+2];
+ target_pts.vi[2*target_pts.n] = j;
+ target_pts.vi[2*target_pts.n+1] = i/3;
+ target_pts.vr[3*target_pts.n] = xyz[i];
+ target_pts.vr[3*target_pts.n+1] = xyz[i+1];
+ target_pts.vr[3*target_pts.n+2] = xyz[i+2];
+ target_pts.n++;
@@ -160,18 +170,19 @@
// mappedPts->vul[i] = local handle of mapped entity
// mappedPts->vr[3*i..3*i+2] = natural coordinates in mapped entity
+ // test target points against my elements
for (unsigned i = 0; i < target_pts.n; i++)
result = test_local_box(target_pts.vr+3*i,
- target_pts.vi[3*i], target_pts.vi[3*i+1], i,
- &source_pts);
+ target_pts.vi[2*i], target_pts.vi[2*i+1], i,
+ point_located, &source_pts);
// no longer need target_pts
tuple_list_free(&target_pts);
- // perform scatter/gather to send proc/index tuples back to procs
+ // send target points back to target procs
gs_transfer(1, &source_pts, 0, myPc->proc_config().crystal_router());
// store proc/index tuples in targetPts, and/or pass back to application;
@@ -184,24 +195,27 @@
// Local index is mapped into either myRange, holding the handles of
// local mapped entities, or myXyz, holding locations of mapped pts
- // go through and count non-negatives
+ // count non-negatives
int num_pts = 0;
for (unsigned int i = 0; i < source_pts.n; i++)
if (-1 != source_pts.vi[3*i+2]) num_pts++;
+ // store information about located points
targetPts = new tuple_list;
tuple_list *tl_tmp = targetPts;
if (!store_local) tl_tmp = tl;
tuple_list_init_max(tl_tmp, 3, 0, 0, 1, num_pts);
for (unsigned int i = 0; i < source_pts.n; i++) {
- if (-1 != source_pts.vi[3*i+2]) {
- tl_tmp->n++;
+ if (-1 != source_pts.vi[3*i+2] && !located_pts[3*i+1]) {
tl_tmp->vi[3*i] = source_pts.vi[3*i];
tl_tmp->vi[3*i+1] = source_pts.vi[3*i+1];
tl_tmp->vi[3*i+2] = source_pts.vi[3*i+2];
+ tl_tmp->n++;
+ assert(tl_tmp->n + localMappedPts.size()/2 == (unsigned int) num_points);
// no longer need source_pts
tuple_list_free(&source_pts);
@@ -218,6 +232,7 @@
MBErrorCode MBCoupler::test_local_box(double *xyz,
int from_proc, int remote_index, int index,
+ bool &point_located,
tuple_list *tl)
@@ -227,8 +242,6 @@
MBErrorCode result = nat_param(xyz, entities, nat_coords);
- if (entities.empty()) return MB_SUCCESS;
// grow if we know we'll exceed size
if (mappedPts->n+entities.size() >= mappedPts->max)
tuple_list_grow(mappedPts);
@@ -237,6 +250,7 @@
tl->vi[3*index] = from_proc;
tl->vi[3*index+1] = remote_index;
tl->vi[3*index+2] = -1;
+ point_located = false;
return MB_SUCCESS;
@@ -244,11 +258,11 @@
std::vector<MBCartVect>::iterator ncit = nat_coords.begin();
for (; eit != entities.end(); eit++, ncit++) {
// store in tuple mappedPts
- mappedPts->n++;
mappedPts->vr[3*mappedPts->n] = (*ncit)[0];
mappedPts->vr[3*mappedPts->n+1] = (*ncit)[1];
mappedPts->vr[3*mappedPts->n+2] = (*ncit)[2];
mappedPts->vul[mappedPts->n] = *eit;
+ mappedPts->n++;
// also store local point, mapped point indices
if (tl)
@@ -256,16 +270,18 @@
if (tl->n == tl->max) tuple_list_grow(tl);
// store in tuple source_pts
- tl->n++;
tl->vi[3*tl->n] = from_proc;
tl->vi[3*tl->n+1] = remote_index;
tl->vi[3*tl->n+2] = mappedPts->n;
+ tl->n++;
else {
localMappedPts.push_back(index);
localMappedPts.push_back(mappedPts->n);
+ point_located = true;
return MB_SUCCESS;
@@ -385,6 +401,7 @@
-1.0 <= tmp_nat_coords[2] && tmp_nat_coords[2] <= 1.0) {
entities.push_back(*iter);
nat_coords.push_back(tmp_nat_coords);
+ return MB_SUCCESS;
Modified: MOAB/trunk/tools/mbcoupler/MBCoupler.hpp
--- MOAB/trunk/tools/mbcoupler/MBCoupler.hpp 2008-06-26 14:55:10 UTC (rev 1931)
+++ MOAB/trunk/tools/mbcoupler/MBCoupler.hpp 2008-06-26 18:39:15 UTC (rev 1932)
@@ -143,6 +143,7 @@
MBErrorCode test_local_box(double *xyz,
tuple_list *tl = NULL);
/* \brief MOAB instance
