[MOAB-dev] r1933 - MOAB/trunk/tools/mbcoupler
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Jun 26 14:09:38 CDT 2008
Author: tautges
Date: 2008-06-26 14:09:38 -0500 (Thu, 26 Jun 2008)
New Revision: 1933
Modified:
   MOAB/trunk/tools/mbcoupler/MBCoupler.cpp
   MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp
   MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp
   MOAB/trunk/tools/mbcoupler/findpt_test.cpp
   MOAB/trunk/tools/mbcoupler/types.h
Log:
Hooking up point interpolation from James Lottes' higher-order point location, from code written by Alvaro (thanks Alvaro!).  Point location looks to be working, at least in the case where all points are local.
Modified: MOAB/trunk/tools/mbcoupler/MBCoupler.cpp
--- MOAB/trunk/tools/mbcoupler/MBCoupler.cpp	2008-06-26 18:39:15 UTC (rev 1932)
+++ MOAB/trunk/tools/mbcoupler/MBCoupler.cpp	2008-06-26 19:09:38 UTC (rev 1933)
@@ -394,7 +394,7 @@
       //test to find out in which hex the point is
       // get natural coordinates
-    MBElemUtil::nat_coords_trilinear_hex(&coords_vert[0], MBCartVect(xyz),
+    MBElemUtil::nat_coords_trilinear_hex2(&coords_vert[0], MBCartVect(xyz),
                                          tmp_nat_coords, 1e-10);
     if (-1.0 <= tmp_nat_coords[0] && tmp_nat_coords[0] <= 1.0 &&
         -1.0 <= tmp_nat_coords[1] && tmp_nat_coords[1] <= 1.0 &&
Modified: MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp
--- MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp	2008-06-26 18:39:15 UTC (rev 1932)
+++ MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp	2008-06-26 19:09:38 UTC (rev 1933)
@@ -2,6 +2,7 @@
 #include <assert.h>
 #include "MBElemUtil.hpp"
+#include "types.h"
 // nat_coords_trilinear_hex
@@ -140,6 +141,49 @@
+// nat_coords_trilinear_hex2
+//  Duplicate functionality of nat_coords_trilinear_hex using hex_findpt
+void MBElemUtil::nat_coords_trilinear_hex2(MBCartVect hex[8],
+                                          MBCartVect xyz,
+                                          MBCartVect &ncoords,
+                                          double etol)
+  const int ndim = 3;
+  const int nverts = 8;
+  const int vertMap[nverts] = {0,1,3,2, 4,5,7,6}; //Map from nat to lex ordering
+  const int n = 2; //linear
+  real coords[ndim*nverts]; //buffer
+  real *xm[ndim];
+  for(int i=0; i<ndim; i++)
+    xm[i] = coords + i*nverts;
+  //stuff hex into coords
+  for(int i=0; i<nverts; i++){
+    real vcoord[ndim];
+    hex[i].get(vcoord);
+    for(int d=0; d<ndim; d++)
+      coords[d*nverts + vertMap[i]] = vcoord[d];
+  double dist = 0.0;
+  MBElemUtil::hex_findpt(xm, n, xyz, ncoords, dist);
+  if (3*EPS < dist) {
+      // outside element, set extremal values to something outside range
+    for (int j = 0; j < 3; j++) {
+      if (ncoords[j] < (-1.0-etol) || ncoords[j] > (1.0+etol))
+        ncoords[j] *= 10;
 bool MBElemUtil::point_in_trilinear_hex(MBCartVect *hex,
                                         MBCartVect xyz,
                                         double etol)
Modified: MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp
--- MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp	2008-06-26 18:39:15 UTC (rev 1932)
+++ MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp	2008-06-26 19:09:38 UTC (rev 1933)
@@ -19,7 +19,14 @@
                                      MBCartVect box_max,
                                      double etol);
+    //wrapper to hex_findpt
+  static void nat_coords_trilinear_hex2(MBCartVect*,
+                                        MBCartVect,
+                                        MBCartVect&,
+                                        double);
   static void hex_findpt(double *xm[3],
                          int n,
                          MBCartVect xyz,
Modified: MOAB/trunk/tools/mbcoupler/findpt_test.cpp
--- MOAB/trunk/tools/mbcoupler/findpt_test.cpp	2008-06-26 18:39:15 UTC (rev 1932)
+++ MOAB/trunk/tools/mbcoupler/findpt_test.cpp	2008-06-26 19:09:38 UTC (rev 1933)
@@ -6,9 +6,10 @@
 extern "C"{
 #include "errmem.h" //for tmalloc, convenient but not C++
+#include "types.h"
-int main()
+void test_hex_findpt()
     MBCartVect xyz(.5,.3,.4);
@@ -29,14 +30,14 @@
     //Stuff xm with sample data
     for(int k=0; k<n; k++){
       for(int j=0; j<n; j++){
-	for(int i=0; i<n; i++){
+        for(int i=0; i<n; i++){
-	  xm[0][node] = i*scale;
-	  xm[1][node] = j*scale;
-	  xm[2][node] = k*scale;
-	  node++;
+          xm[0][node] = i*scale;
+          xm[1][node] = j*scale;
+          xm[2][node] = k*scale;
+          node++;
@@ -47,3 +48,40 @@
       " distance: "<< dist << endl;
+void test_nat_coords_trilinear_hex2()
+  MBCartVect hex[8];
+  MBCartVect xyz(.5,.3,.4);
+  MBCartVect ncoords;;
+  double etol;
+  MBElemUtil u;
+  //Make our sample hex the unit cube [0,1]**3
+  hex[0] = MBCartVect(0,0,0);
+  hex[1] = MBCartVect(1,0,0);
+  hex[2] = MBCartVect(1,1,0);
+  hex[3] = MBCartVect(0,1,0);
+  hex[4] = MBCartVect(0,0,1);
+  hex[5] = MBCartVect(1,0,1);
+  hex[6] = MBCartVect(1,1,1);
+  hex[7] = MBCartVect(0,1,1);
+  etol = .1 ; //ignored by nat_coords
+  u.nat_coords_trilinear_hex2(hex, xyz, ncoords, etol);
+  cout << "Coords of " << xyz << " are:  "<< ncoords << endl;
+int main(){
+  test_nat_coords_trilinear_hex2();
+    //test_hex_findpt();
Modified: MOAB/trunk/tools/mbcoupler/types.h
--- MOAB/trunk/tools/mbcoupler/types.h	2008-06-26 18:39:15 UTC (rev 1932)
+++ MOAB/trunk/tools/mbcoupler/types.h	2008-06-26 19:09:38 UTC (rev 1933)
@@ -1,5 +1,6 @@
 #ifndef TYPES_H
 #define TYPES_H
+#include "float.h"
 /* integer type to use for everything */
 #if   defined(USE_LONG)
