[MOAB-dev] r1931 - in MOAB/trunk: . parallel tools/mbcoupler
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Jun 26 09:55:10 CDT 2008
Author: tautges
Date: 2008-06-26 09:55:10 -0500 (Thu, 26 Jun 2008)
New Revision: 1931
Modified:
   MOAB/trunk/MBGeomUtil.hpp
   MOAB/trunk/mbparallelcomm_test.cpp
   MOAB/trunk/parallel/MBParallelComm.cpp
   MOAB/trunk/parallel/MBParallelComm.hpp
   MOAB/trunk/tools/mbcoupler/MBCoupler.cpp
   MOAB/trunk/tools/mbcoupler/MBCoupler.hpp
   MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp
   MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp
   MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
Log:
- short-circuiting MBElemUtil::nat_coords_trilinear_hex with .5, .5,
.5 for now (doesn't work at vertex locations)
- revising MBCoupler functions to make them compile and (eventually?)
work
- adding calls to coupler in mbcouplercomm_test
- adding MBParallelComm::get_part_entities to get partition entities
of specified dimension on this parallelcomm
- adding a few more diagnostics to mbparallelcomm_test
Modified: MOAB/trunk/MBGeomUtil.hpp
--- MOAB/trunk/MBGeomUtil.hpp	2008-06-26 00:34:42 UTC (rev 1930)
+++ MOAB/trunk/MBGeomUtil.hpp	2008-06-26 14:55:10 UTC (rev 1931)
@@ -256,7 +256,7 @@
 // and checks if each are between +/-1.  If anyone is outside the range
 // the function returns false, otherwise it returns true.
-bool point_in_trilinear_hex(MBCartVect hex[8],
+bool point_in_trilinear_hex(MBCartVect *hex,
                             MBCartVect xyz,
                             double etol);
@@ -267,7 +267,7 @@
 // test above except that it gets a bounding box as arguments to filter
 // the test for acceleration.
                             MBCartVect xyz,
                             MBCartVect box_min, MBCartVect box_max,
                             double etol);
Modified: MOAB/trunk/mbparallelcomm_test.cpp
--- MOAB/trunk/mbparallelcomm_test.cpp	2008-06-26 00:34:42 UTC (rev 1930)
+++ MOAB/trunk/mbparallelcomm_test.cpp	2008-06-26 14:55:10 UTC (rev 1931)
@@ -176,18 +176,23 @@
       MBParallelComm *pcomm = MBParallelComm::get_pcomm(mbImpl, 0);
       assert(pcomm);
-      MBRange iface_ents[6];
+      MBRange iface_ents[7];
       for (int i = 0; i < 4; i++) {
         tmp_result = pcomm->get_iface_entities(-1, i, iface_ents[i]);
         if (MB_SUCCESS != tmp_result) {
           std::cerr << "get_iface_entities returned error on proc "
                     << rank << "; message: " << std::endl;
-          PRINT_LAST_ERROR
-              result = tmp_result;
+          PRINT_LAST_ERROR;
+          result = tmp_result;
         if (0 != i) iface_ents[4].merge(iface_ents[i]);
+      result = pcomm->get_part_entities(iface_ents[6], -1);
+      PRINT_LAST_ERROR;
+      std::cerr << "Proc " << rank << " partition entities:" << std::endl;
+      iface_ents[6].print("   ");
       if (0 == rank) setime = MPI_Wtime();
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2008-06-26 00:34:42 UTC (rev 1930)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2008-06-26 14:55:10 UTC (rev 1931)
@@ -3421,6 +3421,26 @@
   return pc_array[index];
+  //! return all the entities in parts owned locally
+MBErrorCode MBParallelComm::get_part_entities(MBRange &ents, int dim)
+  MBErrorCode result;
+  for (MBRange::iterator rit = partitionSets.begin();
+       rit != partitionSets.end(); rit++) {
+    MBRange tmp_ents;
+    if (-1 == dim)
+      result = mbImpl->get_entities_by_handle(*rit, tmp_ents, true);
+    else
+      result = mbImpl->get_entities_by_dimension(*rit, dim, tmp_ents, true);
+    if (MB_SUCCESS != result) return result;
+    ents.merge(tmp_ents);
+  return MB_SUCCESS;
 #ifdef TEST_PARALLELCOMM
 #include <iostream>
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp	2008-06-26 00:34:42 UTC (rev 1930)
+++ MOAB/trunk/parallel/MBParallelComm.hpp	2008-06-26 14:55:10 UTC (rev 1931)
@@ -294,6 +294,9 @@
     //! return partitions set tag
   MBTag partition_tag();
+  MBErrorCode get_part_entities(MBRange &ents, int dim = -1);
 private:
Modified: MOAB/trunk/tools/mbcoupler/MBCoupler.cpp
--- MOAB/trunk/tools/mbcoupler/MBCoupler.cpp	2008-06-26 00:34:42 UTC (rev 1930)
+++ MOAB/trunk/tools/mbcoupler/MBCoupler.cpp	2008-06-26 14:55:10 UTC (rev 1931)
@@ -1,11 +1,20 @@
 #include "MBCoupler.hpp"
 #include "MBParallelComm.hpp"
+#include "MBAdaptiveKDTree.hpp"
+#include "MBGeomUtil.hpp"
+#include "MBElemUtil.hpp"
+#include "MBCN.hpp"
+#include "iostream"
+extern "C"
 #include "types.h"
 #include "errmem.h"
 #include "minmax.h"
 #include "sort.h"
 #include "tuple_list.h"
 #include "transfer.h"
 #include "assert.h"
@@ -13,17 +22,20 @@
                      MBParallelComm *pc,
                      MBRange &local_elems,
                      int coupler_id,
-                     bool init_tree)
+                     bool init_tree)
     : mbImpl(impl), myPc(pc), myId(coupler_id)
   assert(NULL != impl && NULL != myPc);
     // keep track of the local points, at least for now
   myRange = local_elems;
     // now initialize the tree
   if (init_tree) initialize_tree();
     // initialize tuple lists to indicate not initialized
   mappedPts = NULL;
   targetPts = NULL;
@@ -31,40 +43,99 @@
   /* destructor
-MBCoupler::~MBCoupler()
+MBCoupler::~MBCoupler()
+MBErrorCode MBCoupler::initialize_tree()
+  MBRange local_ents;
+  MBAdaptiveKDTree::Settings settings;
+  allBoxes.resize(6*myPc->proc_config().proc_size());
+    //get entities on the local part
+  MBErrorCode result = myPc->get_part_entities(local_ents, 3);
+  if (MB_SUCCESS != result) {
+    std::cout << "Problems getting entities by dimension" << std::endl;
+    return result;
+    // build the tree for local processor
+  myTree = new MBAdaptiveKDTree(mbImpl);
+  result = myTree->build_tree(local_ents, localRoot, &settings);
+    std::cout << "Problems building tree" << std::endl;
+    return result;
+    // get the bounding box for local tree
+  unsigned int my_rank = myPc->proc_config().proc_rank();
+  result = myTree->get_tree_box(localRoot, &allBoxes[6*my_rank], &allBoxes[6*my_rank+3]);
+    // now communicate to get all boxes
+  int mpi_err = MPI_Allgather(&allBoxes[6*my_rank], 6, MPI_DOUBLE,
+                              &allBoxes[0], 6, MPI_DOUBLE,
+                              myPc->proc_config().proc_comm());
+  if (MPI_SUCCESS == mpi_err) return MB_SUCCESS;
+  else return MB_FAILURE;
 MBErrorCode MBCoupler::locate_points(double *xyz, int num_points,
                                      tuple_list *tl,
-                                     bool store_local)
+                                     bool store_local)
   assert(tl || store_local);
     // allocate tuple_list to hold point data: (p, i, , xyz), i = point index
   tuple_list target_pts;
   tuple_list_init_max(&target_pts, 2, 0, 0, 3, 3*num_points);
-    // for each point, find box(es) containing the point,
-    // appending results to tuple_list;
+    // initialize source_pts and local_pts
+  tuple_list source_pts;
+  mappedPts = new tuple_list;
+  tuple_list_init_max(&source_pts, 3, 0, 0, 0, target_pts.n);
+  tuple_list_init_max(mappedPts, 0, 0, 1, 3, target_pts.n);
+  mappedPts->n = 0;
+  source_pts.n = 0;
+    // for each point, find box(es) containing the point,
+    // appending results to tuple_list;
     // keep local points separately, in local_pts, which has pairs
     // of <local_index, mapped_index>, where mapped_index is the index
+    // of <local_index, mapped_index>, where mapped_index is the index
     // into the mappedPts tuple list
-  int threen = 0;
-  for (int i = 0; i < 3*num_points; i+=3) {
-    for (;;/*  <marco - loop over boxes> */ ) {
-      if (/* marco - test point i/3 in box j */ false) {
-          // check size, grow if we're at max
-        if (target_pts.n == target_pts.max)
-          tuple_list_grow(&target_pts);
+  for (int i = 0; i < 3*num_points; i+=3)
+    for (unsigned int j = 0; j < myPc->proc_config().proc_size(); j++)
+        // test if point is in box
+      if (allBoxes[6*j] <= xyz[i] && xyz[i] <= allBoxes[6*j+3] &&
+          allBoxes[6*j+1] <= xyz[i+1] && xyz[i+1] <= allBoxes[6*j+4] &&
+          allBoxes[6*j+2] <= xyz[i+2] && xyz[i+2] <= allBoxes[6*j+5])
+        if (j == myPc->proc_config().proc_rank())
+          result = test_local_box(xyz+i, j, i/3, i/3);
+        else {
+            // check size, grow if we're at max
+          if (target_pts.n == target_pts.max)
+            tuple_list_grow(&target_pts);
-        target_pts.vi[2*target_pts.n] = -1 /* <marco - proc rank j> */;
-        target_pts.vi[2*target_pts.n+1] = i/3;
-        target_pts.vr[threen] = xyz[i];
-        target_pts.vr[threen] = xyz[i+1];
-        target_pts.vr[threen] = xyz[i+2];
-        target_pts.n++;
-        threen += 3;
+	target_pts.n++;
+          target_pts.vi[2*target_pts.n] = j;
+          target_pts.vi[2*target_pts.n+1] = i/3;
+          target_pts.vr[3*target_pts.n] = xyz[i];
+          target_pts.vr[3*target_pts.n+1] = xyz[i+1];
+          target_pts.vr[3*target_pts.n+2] = xyz[i+2];
@@ -72,12 +143,12 @@
     // perform scatter/gather, to gather points to source mesh procs
   gs_transfer(1, &target_pts, 0, myPc->proc_config().crystal_router());
-    // after scatter/gather:
+    // after scatter/gather:
     // target_pts.n = # points local proc has to map
     // target_pts.vi[2*i] = proc sending point i
     // target_pts.vi[2*i+1] = index of point i on sending proc
     // target_pts.vr[3*i..3*i+2] = xyz of point i
     // Mapping builds the tuple list:
     // source_pts.n = target_pts.n
     // source_pts.vi[3*i] = target_pts.vi[2*i] = sending proc
@@ -89,148 +160,270 @@
     // mappedPts->vul[i] = local handle of mapped entity
     // mappedPts->vr[3*i..3*i+2] = natural coordinates in mapped entity
-    // initialize source_pts and local_pts
-  tuple_list source_pts;
-  mappedPts = new tuple_list;
-  tuple_list_init_max(&source_pts, 3, 0, 0, 0, target_pts.n);
-  tuple_list_init_max(mappedPts, 0, 0, 1, 3, target_pts.n);
-  for (unsigned i = 0; i < target_pts.n; i++) {
-      // find leaf node(s) in local kdtree containing point i
-      // <marco...>
-      // find natural coordinates of point in element(s) in that leaf
-      // <marco...>
-      // for any point/element with nat coords within bounds, store
-      // handle/nat coords in mappedPts, and proc/index in outgoing tuple
-      // (-1 for index if no elements containing that point)
-      // <marco...>
+  for (unsigned i = 0; i < target_pts.n; i++)
+    result = test_local_box(target_pts.vr+3*i,
+                            target_pts.vi[3*i], target_pts.vi[3*i+1], i,
+                            &source_pts);
-    // no longer need target_pts
+  // no longer need target_pts
   tuple_list_free(&target_pts);
-    // perform scatter/gather to send proc/index tuples back to procs
+  // perform scatter/gather to send proc/index tuples back to procs
   gs_transfer(1, &source_pts, 0, myPc->proc_config().crystal_router());
-    // store proc/index tuples in targetPts, and/or pass back to application;
-    // the tuple this gets stored to looks like:
-    // tl.n = # mapped points
-    // tl.vi[3*i] = remote proc mapping point
-    // tl.vi[3*i+1] = local index of mapped point
-    // tl.vi[3*i+2] = remote index of mapped point
-    // Local index is mapped into either myRange, holding the handles of
-    // local mapped entities, or myXyz, holding locations of mapped pts
+  // store proc/index tuples in targetPts, and/or pass back to application;
+  // the tuple this gets stored to looks like:
+  // tl.n = # mapped points
+  // tl.vi[3*i] = remote proc mapping point
+  // tl.vi[3*i+1] = local index of mapped point
+  // tl.vi[3*i+2] = remote index of mapped point
+  // Local index is mapped into either myRange, holding the handles of
+  // local mapped entities, or myXyz, holding locations of mapped pts
-    // go through and count non-negatives
+  // go through and count non-negatives
   int num_pts = 0;
-  for (unsigned int i = 0; i < source_pts.n; i++)
+  for (unsigned int i = 0; i < source_pts.n; i++)
     if (-1 != source_pts.vi[3*i+2]) num_pts++;
   targetPts = new tuple_list;
   tuple_list *tl_tmp = targetPts;
   if (!store_local) tl_tmp = tl;
   tuple_list_init_max(tl_tmp, 3, 0, 0, 1, num_pts);
-  tl_tmp->n = num_pts;
   for (unsigned int i = 0; i < source_pts.n; i++) {
     if (-1 != source_pts.vi[3*i+2]) {
+      tl_tmp->n++;
       tl_tmp->vi[3*i] = source_pts.vi[3*i];
       tl_tmp->vi[3*i+1] = source_pts.vi[3*i+1];
       tl_tmp->vi[3*i+2] = source_pts.vi[3*i+2];
     // no longer need source_pts
   tuple_list_free(&source_pts);
     // copy into tl if passed in and storing locally
   if (tl && store_local) {
     tuple_list_init_max(tl, 3, 0, 0, 1, num_pts);
-    memcpy(tl->vi, tl_tmp->vi, 3*num_pts*sizeof(int));
+    memcpy(tl->vi, tl_tmp->vi, 3*tl_tmp->n*sizeof(int));
     tl->n = tl_tmp->n;
     // done
   return MB_SUCCESS;
+MBErrorCode MBCoupler::test_local_box(double *xyz,
+                                      int from_proc, int remote_index, int index,
+                                      tuple_list *tl)
+  std::vector<MBEntityHandle> entities;
+  std::vector<MBCartVect> nat_coords;
+  MBErrorCode result = nat_param(xyz, entities, nat_coords);
+  if (entities.empty()) return MB_SUCCESS;
+    // grow if we know we'll exceed size
+  if (mappedPts->n+entities.size() >= mappedPts->max)
+    tuple_list_grow(mappedPts);
+  if (entities.empty() && tl) {
+    tl->vi[3*index] = from_proc;
+    tl->vi[3*index+1] = remote_index;
+    tl->vi[3*index+2] = -1;
+  std::vector<MBEntityHandle>::iterator eit = entities.begin();
+  std::vector<MBCartVect>::iterator ncit = nat_coords.begin();
+  for (; eit != entities.end(); eit++, ncit++) {
+      // store in tuple mappedPts
+    mappedPts->n++;
+    mappedPts->vr[3*mappedPts->n] = (*ncit)[0];
+    mappedPts->vr[3*mappedPts->n+1] = (*ncit)[1];
+    mappedPts->vr[3*mappedPts->n+2] = (*ncit)[2];
+    mappedPts->vul[mappedPts->n] = *eit;
+      // also store local point, mapped point indices
+    if (tl)
+      if (tl->n == tl->max) tuple_list_grow(tl);
+        // store in tuple source_pts
+      tl->n++;
+      tl->vi[3*tl->n] = from_proc;
+      tl->vi[3*tl->n+1] = remote_index;
+      tl->vi[3*tl->n+2] = mappedPts->n;
+    else {
+      localMappedPts.push_back(index);
+      localMappedPts.push_back(mappedPts->n);
 MBErrorCode MBCoupler::interpolate(MBCoupler::Method method,
+                                   std::string &interp_tag,
+                                   double *interp_vals,
+                                   tuple_list *tl,
+                                   bool normalize)
+  MBTag tag;
+  MBErrorCode result = mbImpl->tag_get_handle(interp_tag.c_str(), tag);
+  return interpolate(method, tag, interp_vals, tl, normalize);
+MBErrorCode MBCoupler::interpolate(MBCoupler::Method method,
                                    MBTag tag,
                                    tuple_list *tl,
-                                   bool normalize)
+                                   bool normalize)
   if (LINEAR_FE != method) return MB_FAILURE;
   tuple_list *tl_tmp = (tl ? tl : targetPts);
+    // remote pts first
     // scatter/gather interpolation points
   gs_transfer(1, tl_tmp, 0, myPc->proc_config().crystal_router());
     // perform interpolation on local source mesh; put results into
     // tl_tmp->vr[i]
-    // interpolate locally mapped points too, putting results directly
-    // into interp_vals
-    // normalize interpolation
+  for (unsigned int i = 0; i < tl_tmp->n; i++) {
+    int mindex = tl_tmp->vi[3*i+2];
+    result = interp_field_for_hex(mappedPts->vul[mindex],
+                                  MBCartVect(mappedPts->vr+3*mindex),
+                                              tag, tl_tmp->vr[i]);
     // scatter/gather interpolation data
-  for (unsigned int i = 0; i < tl_tmp->n; i++)
-    interp_vals[tl_tmp->vi[3*i+1]] = tl_tmp->vr[i];
+  if (!tl) {
+      // mapped whole targetPts tuple; put into proper place in interp_vals
+      interp_vals[tl_tmp->vi[3*i+1]] = tl_tmp->vr[i];
+      // now do locally-contained pts, since we're mapping everything
+    for (std::vector<unsigned int>::iterator vit = localMappedPts.begin();
+         vit != localMappedPts.end(); vit += 2) {
+      int mindex = *(vit+1);
+                                    tag, interp_vals[*vit]);
     // done
   return MB_SUCCESS;
-MBErrorCode MBCoupler::interpolate(MBCoupler::Method method,
-                                   const char *tag_name,
-                                   double *interp_vals,
-                                   tuple_list *tl,
-                                   bool normalize)
+MBErrorCode MBCoupler::nat_param(double xyz[3],
+                                 std::vector<MBEntityHandle> &entities,
+                                 std::vector<MBCartVect> &nat_coords)
-  MBTag this_tag;
-  MBErrorCode result = mbImpl->tag_get_handle(tag_name, this_tag);
-  if (MB_SUCCESS != result) return result;
+  MBAdaptiveKDTreeIter treeiter;
+  MBErrorCode result = myTree->get_tree_iterator(localRoot, treeiter);
+    std::cout << "Problems getting iterator" << std::endl;
+    return result;
+  result = myTree->leaf_containing_point(localRoot, xyz, treeiter);
+    std::cout << "Problems getting leaf " << std::endl;
+    return result;
+    // find natural coordinates of point in element(s) in that leaf
+  MBCartVect tmp_nat_coords;
+  MBRange range_leaf;
+  result = mbImpl->get_entities_by_dimension(treeiter.handle(), 3, range_leaf, false);
+  if(result != MB_SUCCESS) std::cout << "Problem getting leaf in a range" << std::endl;
+    // loop over the range_leaf
+  for(MBRange::iterator iter = range_leaf.begin(); iter != range_leaf.end(); iter++)
+    const MBEntityHandle *connect;
+    int num_connect;
+      //get connectivity
+    result = mbImpl->get_connectivity(*iter, connect, num_connect, true);
+      //get coordinates of the vertices
+    std::vector<MBCartVect> coords_vert(num_connect);
+    std::vector<double> coords(3*num_connect);
+    result = mbImpl->get_coords(connect, num_connect, &coords[0]);
+    for(int j = 0; j < num_connect; j++)
+      coords_vert[j][0] = coords[3*j];
+      coords_vert[j][1] = coords[3*j+1];
+      coords_vert[j][2] = coords[3*j+2];
+      //test to find out in which hex the point is
+      // get natural coordinates
+    MBElemUtil::nat_coords_trilinear_hex(&coords_vert[0], MBCartVect(xyz),
+                                         tmp_nat_coords, 1e-10);
+    if (-1.0 <= tmp_nat_coords[0] && tmp_nat_coords[0] <= 1.0 &&
+        -1.0 <= tmp_nat_coords[1] && tmp_nat_coords[1] <= 1.0 &&
+        -1.0 <= tmp_nat_coords[2] && tmp_nat_coords[2] <= 1.0) {
+      entities.push_back(*iter);
+      nat_coords.push_back(tmp_nat_coords);
-  return interpolate(method, this_tag, interp_vals, tl, normalize);
-MBErrorCode MBCoupler::locate_points(MBRange &ents,
-                                     tuple_list *tl,
-                                     bool store_local)
+MBErrorCode MBCoupler::interp_field_for_hex(MBEntityHandle elem,
+                                            MBCartVect nat_coord,
+                                            MBTag tag,
+                                            double &field)
-    // only do vertices for now
-  MBRange verts = ents.subset_by_type(MBVERTEX);
-  if (verts.size() != ents.size()) return MB_FAILURE;
-    // get coordinates
-  std::vector<double> coords(3*verts.size());
-  MBErrorCode result = mbImpl->get_coords(verts, &coords[0]);
+    //set the vertices coordinates in the natural system
+  const double xi[8] = {-1,1,1,-1,-1,1,1,-1};
+  const double etha[8] = {-1,-1,1,1,-1,-1,1,1};
+  const double mu[8] = {-1,-1,-1,-1,1,1,1,1};
+  double vfields[MB_MAX_SUB_ENTITIES*MB_MAX_SUB_ENTITY_VERTICES];
+    // get the tag values at the vertices
+  int num_connect;
+  MBErrorCode result = mbImpl->get_connectivity(elem, connect, num_connect);
+  result = mbImpl->tag_get_data(tag, connect, num_connect, vfields);
-  return locate_points(&coords[0], verts.size(), tl, store_local);
-MBErrorCode MBCoupler::initialize_tree()
-    // initialize the tree for the local mesh
+    //function for the interpolation
+  field = 0;
-    // allocate box extents storage array
-  allBoxes = new double[6*myPc->proc_config().proc_size()];
+    //calculate the field
+    // just hexes for now
+  assert(num_connect <= 8);
-    // read local tree minimum/maximum vectors into array starting at
-    // allBoxes[6*myPc->proc_rank()], allBoxes[6*myPc->proc_rank()+3]
+  for(int i = 0; i < num_connect; i++)
+    field += 0.125 * vfields[i] *
+      (1+xi[i]*nat_coord[0]) * (1+etha[i]*nat_coord[1]) * (1+mu[i]*nat_coord[2]);
-    // now allgather so each proc has copy of box minima/maxima
-  int mpi_err = MPI_Allgather(allBoxes+6*myPc->proc_config().proc_rank(), 6, MPI_DOUBLE,
-                              allBoxes, 6, MPI_DOUBLE, myPc->proc_config().proc_comm());
-  if (MPI_SUCCESS == mpi_err) return MB_SUCCESS;
-  else return MB_FAILURE;
Modified: MOAB/trunk/tools/mbcoupler/MBCoupler.hpp
--- MOAB/trunk/tools/mbcoupler/MBCoupler.hpp	2008-06-26 00:34:42 UTC (rev 1930)
+++ MOAB/trunk/tools/mbcoupler/MBCoupler.hpp	2008-06-26 14:55:10 UTC (rev 1931)
@@ -28,11 +28,15 @@
 #include "MBRange.hpp"
 #include "MBInterface.hpp"
+#include "MBCartVect.hpp"
 extern "C"
   struct tuple_list;
+class MBAdaptiveKDTree;
 class MBCoupler
 public:
@@ -119,13 +123,28 @@
      * \param normalize If true, normalization is done according to method
   MBErrorCode interpolate(MBCoupler::Method method,
-                          const char* tag_name,
+                          std::string &tag_name,
                           tuple_list *tl = NULL,
                           bool normalize = true);
 private:
+    // given a coordinate position, find all entities containing
+    // the point and the natural coords in those ents
+  MBErrorCode nat_param(double xyz[3],
+                        std::vector<MBCartVect> &nat_coords);
+  MBErrorCode interp_field_for_hex(MBEntityHandle elem,
+                                   MBTag tag,
+                                   double &field);
+  MBErrorCode test_local_box(double *xyz,
+                             tuple_list *tl = NULL);
     /* \brief MOAB instance
   MBInterface *mbImpl;
@@ -134,9 +153,17 @@
   MBErrorCode initialize_tree();
+    /* \brief Kdtree for local mesh
+  MBAdaptiveKDTree *myTree;
+    /* \brief Local root of the kdtree
+  MBEntityHandle localRoot;
     /* \brief Min/max bounding boxes for all proc tree roots
-  double *allBoxes;
+  std::vector<double> allBoxes;
     /* \brief MBParallelComm object for this coupler
Modified: MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp
--- MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp	2008-06-26 00:34:42 UTC (rev 1930)
+++ MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp	2008-06-26 14:55:10 UTC (rev 1931)
@@ -12,12 +12,16 @@
 // coordinates {0, 0, 0} and calculating new coordinates based on the
 // ones just calculated.
-void MBElemUtil::nat_coords_trilinear_hex(MBCartVect hex[8],
+void MBElemUtil::nat_coords_trilinear_hex(MBCartVect *hex,
                                           MBCartVect xyz,
                                           MBCartVect &ncoords,
                                           double etol)
+    // short-circuit for now...
+  ncoords[0] = ncoords[1] = ncoords[2] = 0.5;
+  return;
       MBCartVect nat(0.);
       double A[8]; double B[8]; double C[8]; double D[8];
       double Ax, By, Cz;
@@ -27,7 +31,7 @@
       double nxi, neta, nmu;
       double pxi, peta, pmu;
       double tmp;
       // Iterative estimate of natural coordinates
       while ( err > etol ) {
@@ -45,9 +49,10 @@
             for (unsigned int i = 0; i < 8; i++) {
                   Ax = Ax + A[i]*hex[i][0];
-            nat[0] = (8*xyz[0] - Ax ) /
-                     (-A[0]*hex[0][0] + A[1]*hex[1][0] + A[2]*hex[2][0] - A[3]*hex[3][0]
-                      -A[4]*hex[4][0] + A[5]*hex[5][0] + A[6]*hex[6][0] - A[7]*hex[7][0]);
+            double tmp_d = -A[0]*hex[0][0] + A[1]*hex[1][0] + A[2]*hex[2][0] - A[3]*hex[3][0]
+              -A[4]*hex[4][0] + A[5]*hex[5][0] + A[6]*hex[6][0] - A[7]*hex[7][0];
+            if (0.0 == tmp_d) nat[0] = 2.0;
+            else nat[0] = (8*xyz[0] - Ax ) / tmp_d;
             // Estimate the eta-coordinate
             B[0] = (1 - nat[0]) * (1 - nat[2]);
@@ -63,9 +68,11 @@
                   By = By + B[i]*hex[i][1];
-            nat[1] = (8*xyz[1] - By ) /
-                     (-B[0]*hex[0][1] - B[1]*hex[1][1] + B[2]*hex[2][1] + B[3]*hex[3][1]
-                      -B[4]*hex[4][1] - B[5]*hex[5][1] + B[6]*hex[6][1] + B[7]*hex[7][1]);
+            tmp_d = -B[0]*hex[0][1] - B[1]*hex[1][1] + B[2]*hex[2][1] + B[3]*hex[3][1]
+              -B[4]*hex[4][1] - B[5]*hex[5][1] + B[6]*hex[6][1] + B[7]*hex[7][1];
+            if (0.0 == tmp_d) nat[1] = 2.0;
+            else nat[1] = (8*xyz[1] - By ) / tmp_d;
             // Estimate the mu-coordinate
             C[0] = (1 - nat[0]) * (1 - nat[1]);
@@ -81,10 +88,11 @@
                   Cz = Cz + C[i]*hex[i][2];
-            nat[2] = (8*xyz[2] - Cz ) /
-                     (-C[0]*hex[0][2] - C[1]*hex[1][2] - C[2]*hex[2][2] - C[3]*hex[3][2]
-                      +C[4]*hex[4][2] + C[5]*hex[5][2] + C[6]*hex[6][2] + C[7]*hex[7][2]);
+            tmp_d = -C[0]*hex[0][2] - C[1]*hex[1][2] - C[2]*hex[2][2] - C[3]*hex[3][2]
+              +C[4]*hex[4][2] + C[5]*hex[5][2] + C[6]*hex[6][2] + C[7]*hex[7][2];
+            if (0.0 == tmp_d) nat[2] = 2.0;
+            else nat[2] = (8*xyz[2] - Cz ) / tmp_d;
             // Shortcut variables...
             nxi  = 1 - nat[0];
@@ -132,7 +140,7 @@
-bool MBElemUtil::point_in_trilinear_hex(MBCartVect hex[8],
+bool MBElemUtil::point_in_trilinear_hex(MBCartVect *hex,
                                         MBCartVect xyz,
                                         double etol)
@@ -151,7 +159,7 @@
                                         MBCartVect xyz,
                                         double etol)
Modified: MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp
--- MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp	2008-06-26 00:34:42 UTC (rev 1930)
+++ MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp	2008-06-26 14:55:10 UTC (rev 1931)
@@ -5,15 +5,15 @@
 public:
-  static void nat_coords_trilinear_hex(MBCartVect[8],
+  static void nat_coords_trilinear_hex(MBCartVect*,
                                        MBCartVect,
                                        MBCartVect&,
                                        double);
-  static bool point_in_trilinear_hex(MBCartVect hex[8],
+  static bool point_in_trilinear_hex(MBCartVect *hex,
                                      MBCartVect xyz,
                                      double etol);
                                      MBCartVect xyz,
                                      MBCartVect box_min,
                                      MBCartVect box_max,
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-26 00:34:42 UTC (rev 1930)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2008-06-26 14:55:10 UTC (rev 1931)
@@ -1,7 +1,9 @@
+#include "MBParallelConventions.h"
 #include "MBCore.hpp"
 #include "FileOptions.hpp"
 #include "ReadParallel.hpp"
+#include "MBCoupler.hpp"
 #include "mpi.h"
 #include <iostream>
 #include <sstream>
@@ -13,13 +15,27 @@
       dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(tmp_str.c_str()); \
       return result;}
+#define PRINT_LAST_ERROR \
+    if (MB_SUCCESS != result) {\
+      std::string tmp_str;\
+      std::cout << "Failure; message:" << std::endl;\
+      std::cout << mbImpl->get_last_error(tmp_str) << std::endl;\
+      return result;\
 MBErrorCode get_file_options(int argc, char **argv,
                              std::vector<const char *> &filenames,
                              std::string &opts);
 MBErrorCode report_iface_ents(MBInterface *mbImpl,
                               std::vector<MBParallelComm *> &pcs);
+MBErrorCode test_interpolation(MBInterface *mbImpl,
+                               std::vector<MBParallelComm *> &pcs,
+                               std::vector<ReadParallel *> rps);
 int main(int argc, char **argv)
     // need to init MPI first, to tell how many procs and rank
@@ -27,9 +43,10 @@
   if (argc < 3) {
     std::cerr << "Usage: ";
-    std::cerr << argv[0] << " <nfiles> <fname1> ... <fnamen> [tag_name] [tag_val] [distrib] [with_ghosts]" << std::endl;
+    std::cerr << argv[0] << " <nfiles> <fname1> ... <fnamen> [interp_tag] [tag_name] [tag_val] [distrib] [with_ghosts]" << std::endl;
     std::cerr << "nfiles        : number of mesh files" << std::endl;
     std::cerr << "fname1..fnamen: mesh files" << std::endl;
+    std::cerr << "interp_tag    : name of tag interpolated to target mesh []" << std::endl;
     std::cerr << "tag_name      : name of tag used to define partitions [MATERIAL_SET]" << std::endl;
     std::cerr << "tag_val       : tag values denoting partition sets [--]" << std::endl;
     std::cerr << "distrib       : if non-zero, distribute the partition sets with tag_val round-robin" << std::endl;
@@ -55,8 +72,8 @@
   MBErrorCode result = MB_SUCCESS;
   std::vector<const char *> filenames;
-  std::string opts;
-  result = get_file_options(argc, argv, filenames, opts);
+  std::string opts, interp_tag;
+  result = get_file_options(argc, argv, filenames, interp_tag, opts);
     // read in mesh(es)
@@ -70,19 +87,22 @@
     result = rps[i]->load_file(filenames[i], filesets[i],
                                FileOptions(opts.c_str()), NULL, 0);
-    if (MB_SUCCESS != result) {
-      std::string tmp_str;
-      std::cout << "Failure; message:" << std::endl;
-      std::cout << mbImpl->get_last_error(tmp_str) << std::endl;
-      return 1;
+    PRINT_LAST_ERROR;
   result = report_iface_ents(mbImpl, pcs);
-    std::cout << "Failure." << std::endl;
-  else
-    std::cout << "Success." << std::endl;
+  PRINT_LAST_ERROR;
+    // test interpolation
+  result = test_interpolation(mbImpl, interp_tag, pcs, rps);
+  PRINT_LAST_ERROR;
+    // output mesh
+  result = mbImpl->write_file("output.h5m", NULL, NULL,
+                              pcs[1]->partition_sets());
+  PRINT_LAST_ERROR;
+  std::cout << "Success." << std::endl;
   err = MPI_Finalize();
   for (unsigned int i = 0; i < filenames.size(); i++) {
@@ -138,6 +158,7 @@
                              std::string &opts)
   int npos = 1;
@@ -146,6 +167,8 @@
     // get mesh filenames
   filenames.resize(nfiles);
   for (int i = 0; i < nfiles; i++) filenames[i] = argv[npos++];
+  if (npos < argc) interp_tag = argv[npos++];
     // get partition information
   const char *tag_name = "MATERIAL_SET";
@@ -177,3 +200,55 @@
   return MB_SUCCESS;
+    // source is 1st mesh, target is 2nd
+  MBRange src_elems, targ_elems;
+  MBErrorCode result = pcs[0]->get_part_entities(src_elems, 3);
+  PRINT_LAST_ERROR;
+    // instantiate a coupler, which also initializes the tree
+  MBCoupler mbc(mbImpl, pcs[0], src_elems, 0);
+    // get points from the target mesh to interpolate
+  MBRange targ_verts, tmp_verts;
+    // first get all vertices adj to partition entities in target mesh
+  result = pcs[1]->get_part_entities(targ_elems, 3);
+  result = mbImpl->get_adjacencies(targ_elems, 0, false, targ_verts,
+                                   MBInterface::UNION);
+  PRINT_LAST_ERROR;
+    // then get non-owned verts and subtract
+  result = pcs[1]->get_pstatus_entities(0, PSTATUS_NOT_OWNED, tmp_verts);
+  PRINT_LAST_ERROR;
+  targ_verts = targ_verts.subtract(tmp_verts);
+    // get position of these entities; these are the target points
+  std::vector<double> vpos(3*targ_verts.size());
+  result = mbImpl->get_coords(targ_verts, &vpos[0]);
+  PRINT_LAST_ERROR;
+    // locate those points in the source mesh
+  result = mbc.locate_points(&vpos[0], targ_verts.size());
+  PRINT_LAST_ERROR;
+    // now interpolate tag onto target points
+  std::vector<double> field(targ_verts.size());
+  result = mbc.interpolate(MBCoupler::LINEAR_FE, interp_tag, &field[0]);
+  PRINT_LAST_ERROR;
+    // set field values as tag on target vertices
+  MBTag tag;
+  result = mbImpl->tag_get_handle(interp_tag.c_str(), tag); PRINT_LAST_ERROR;
+  result = mbImpl->tag_set_data(tag, targ_verts, &field[0]); PRINT_LAST_ERROR;
+  int err = MPI_Finalize();
+    // done
