[MOAB-dev] running pcomm_unit
Tim Tautges tautges at mcs.anl.gov
Tue Jun 17 09:55:36 CDT 2008
You shouldn't be getting these results.  Right now I'm working on a
deadline that'll be challenging, but I'll try to check this out.  One
thing you can try to verify parallel functionality is build & run
mbparallelcomm_test, in the main source directory:
make mbparallelcomm_test
mpirun -n 4 mbparallelcomm_test 0 3 test/partest.cub
That will pick up test/partest.cub, use the MATERIAL_SET entity sets as
the decomposition, read and distribute the mesh, delete the non-owned
mesh, and establish shared interfaces.  I'm pretty sure this doesn't
work at the moment because of a commit I did last week though.
- tim
de Almeida, Valmor F. wrote:
> Tim/Jason,
> Am I supposed to get these results or run the moab parallel checks this
> way?
> Thanks,
> Valmor
> ->mpiexec -np 1 pcomm_unit
> Running test_pack_vertices ...
> Running test_pack_elements ...
> Running test_pack_higher_order ...
> Running test_pack_poly ...
> Running test_pack_sets_simple ...
> Running test_pack_set_contents ...
> Running test_pack_sets_of_sets ...
> Running test_pack_set_parent_child ...
> Running test_pack_tag_data ...
> Running test_pack_variable_length_tag ...
> Running test_pack_tag_handle_data ...
> ->mpirun -np 2 pcomm_unit
> MBErrorCode Test Failed: MB_SUCCESS == rval
>   at line 86 of 'pcomm_unit.cpp'
>   Expected value: Success (0)
>   Actual value:   Memory Alloc. Failed (3)
>   test_pack_vertices: FAILED
>   test_pack_elements: FAILED
>   test_pack_higher_order: FAILED
>   test_pack_poly: FAILED
>   test_pack_sets_simple: FAILED
>   test_pack_set_contents: FAILED
>   test_pack_tag_data: FAILED
>   test_pack_variable_length_tag: FAILED
>   test_pack_tag_handle_data: FAILED
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
