[MOAB-dev] running pcomm_unit
de Almeida, Valmor F.
dealmeidav at ornl.gov
Mon Jun 16 23:07:03 CDT 2008
Tim/Jason,
Am I supposed to get these results or run the moab parallel checks this
way?
Valmor
->mpiexec -np 1 pcomm_unit
Running test_pack_vertices ...
Running test_pack_elements ...
Running test_pack_higher_order ...
Running test_pack_poly ...
Running test_pack_sets_simple ...
Running test_pack_set_contents ...
Running test_pack_sets_of_sets ...
Running test_pack_set_parent_child ...
Running test_pack_tag_data ...
Running test_pack_variable_length_tag ...
Running test_pack_tag_handle_data ...
->mpirun -np 2 pcomm_unit
MBErrorCode Test Failed: MB_SUCCESS == rval
at line 86 of 'pcomm_unit.cpp'
Expected value: Success (0)
Actual value: Memory Alloc. Failed (3)
test_pack_vertices: FAILED
test_pack_elements: FAILED
test_pack_higher_order: FAILED
test_pack_poly: FAILED
test_pack_sets_simple: FAILED
test_pack_set_contents: FAILED
test_pack_tag_data: FAILED
test_pack_variable_length_tag: FAILED
test_pack_tag_handle_data: FAILED
