[MOAB-dev] r1889 - in MOAB/trunk: . refiner
dcthomp at mcs.anl.gov dcthomp at mcs.anl.gov
Tue Jun 10 19:00:51 CDT 2008
Author: dcthomp
Date: 2008-06-10 19:00:51 -0500 (Tue, 10 Jun 2008)
New Revision: 1889
Modified:
   MOAB/trunk/refiner/MBEntityRefiner.cpp
   MOAB/trunk/refiner/MBEntityRefiner.hpp
   MOAB/trunk/refiner/MBMeshRefiner.cpp
   MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
   MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
   MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.cpp
   MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.hpp
   MOAB/trunk/test_mesh_refiner.cpp
Log:
BUG: edge_code in refine_3_simplex should be an int, not a bool
ENH: Vertices are now created at the time evaluate_edge_size is called instead of
     at the time a simplex referring to them is created.
ENH: Since we now have vertex handles as we recurse, the interface can be simplified.
Modified: MOAB/trunk/refiner/MBEntityRefiner.cpp
--- MOAB/trunk/refiner/MBEntityRefiner.cpp	2008-06-10 20:20:16 UTC (rev 1888)
+++ MOAB/trunk/refiner/MBEntityRefiner.cpp	2008-06-11 00:00:51 UTC (rev 1889)
@@ -157,7 +157,6 @@
     unsigned long m = this->edge_size_evaluator->get_vertex_tag_size();
     this->tag_heap.resize( m * n );
-  this->hash_heap.resize( 2 * n * this->maximum_number_of_subdivisions + 1 );
 /**\brief Subclasses should call this on entry to refine_entity().
@@ -169,7 +168,6 @@
   this->current_coord = this->coord_heap.begin();
   this->current_tag = this->tag_heap.begin();
-  this->current_hash = this->hash_heap.begin();
 /**\brief Return a pointer to temporary storage for edge midpoint vertex coordinates inside refine_entity().
@@ -211,60 +209,3 @@
   return rval;
-/**\brief Return a pointer to temporary storage for vertex hash vectors inside refine_entity().
-  * The returned pointer references enough bytes to store all the hashes for a vertex.
-  * @param[in] h0 The pre-existing vertex hash for the first endpoint
-  * @param[in] h1 The pre-existing vertex hash for the second endpoint
-  * @retval       The hash, filled in with values from h0 and h1 and null-terminated.
-MBEntityHandle* MBEntityRefiner::heap_hash_storage( MBEntityHandle* h0, MBEntityHandle* h1 )
-  MBEntityHandle* rval;
-  if ( this->edge_size_evaluator && this->current_hash != this->hash_heap.end() )
-    rval = (MBEntityHandle*) &(*this->current_hash);
-    MBEntityHandle* h2 = rval;
-    while ( *h0 )
-      *h2 = *h0;
-      ++h0; ++h2;
-      ++this->current_hash;
-    while ( *h1 )
-      *h2 = *h1;
-      ++h1; ++h2;
-    *h2 = 0; // NULL terminator
-  else
-    rval = 0;
-  return rval;
-  * @param[in] sz The number of vertex handles to use as a hash, not including the NULL terminator.
-  * @retval       A pointer to the hash storage, uninitialized but NULL-terminated.
-MBEntityHandle* MBEntityRefiner::heap_hash_storage( int sz )
-    rval[sz] = 0;
-    this->current_hash += sz + 1;
-  else
-    rval = 0;
-  return rval;
Modified: MOAB/trunk/refiner/MBEntityRefiner.hpp
--- MOAB/trunk/refiner/MBEntityRefiner.hpp	2008-06-10 20:20:16 UTC (rev 1888)
+++ MOAB/trunk/refiner/MBEntityRefiner.hpp	2008-06-11 00:00:51 UTC (rev 1889)
@@ -70,7 +70,24 @@
 public:
   virtual ~MBEntityRefinerOutputFunctor() { }
-  virtual void operator () ( const double* vcoords, const void* vtags, MBEntityHandle* vhash ) = 0;
+  virtual MBEntityHandle operator () ( MBEntityHandle vhash, const double* vcoords, const void* vtags ) = 0;
+  MBEntityHandle operator () ( MBEntityHandle h0, MBEntityHandle h1, const double* vcoords, const void* vtags )
+    MBEntityHandle harr[2];
+    harr[0] = h0;
+    harr[1] = h1;
+    return (*this)( 2, harr, vcoords, vtags );
+  virtual MBEntityHandle operator () ( MBEntityHandle h0, MBEntityHandle h1, MBEntityHandle h2, const double* vcoords, const void* vtags )
+    MBEntityHandle harr[3];
+    harr[0] = h0;
+    harr[1] = h1;
+    harr[2] = h2;
+    return (*this)( 3, harr, vcoords, vtags );
+  virtual MBEntityHandle operator () ( int nhash, MBEntityHandle* hash, const double* vcoords, const void* vtags ) = 0;
+  virtual void operator () ( MBEntityHandle vhash ) = 0;
   virtual void operator () ( MBEntityType etyp ) = 0;
@@ -107,15 +124,11 @@
   std::vector<double>::iterator current_coord;
   std::vector<char> tag_heap;
   std::vector<char>::iterator current_tag;
-  std::vector<MBEntityHandle> hash_heap;
-  std::vector<MBEntityHandle>::iterator current_hash;
   void update_heap_size();
   void reset_heap_pointers();
   double* heap_coord_storage();
   void* heap_tag_storage();
-  MBEntityHandle* heap_hash_storage( MBEntityHandle* h0, MBEntityHandle* h1 );
-  MBEntityHandle* heap_hash_storage( int sz );
 #endif // MB_ENTITYREFINER_H
Modified: MOAB/trunk/refiner/MBMeshRefiner.cpp
--- MOAB/trunk/refiner/MBMeshRefiner.cpp	2008-06-10 20:20:16 UTC (rev 1888)
+++ MOAB/trunk/refiner/MBMeshRefiner.cpp	2008-06-11 00:00:51 UTC (rev 1889)
@@ -98,18 +98,17 @@
     this->edge_size_evaluator = es;
   virtual ~MBMeshRefinerOutputFunctor() { }
-  virtual void operator () ( const double* vcoords, const void* vtags, MBEntityHandle* hash )
+  /// Insert a new vertex into the mesh and set its tag values. This has no effect when output_is_input is true.
+  virtual MBEntityHandle operator () ( MBEntityHandle hash, const double* vcoords, const void* vtags )
-    if ( ! hash[1] && this->output_is_input )
+    if ( this->output_is_input )
       // Don't insert vertices that already exist in the output
-      this->vertex_accum.push_back( hash[0] );
-      return;
+      return hash;
     MBEntityHandle vertex_handle;
     this->mesh->create_vertex( vcoords + 3, vertex_handle );
-    this->vertex_accum.push_back( vertex_handle );
     MBTag tag_handle;
     int tag_offset;
     for ( int i = 0; i < num_tags; ++i )
@@ -117,7 +116,34 @@
       this->edge_size_evaluator->get_vertex_tag( i, tag_handle, tag_offset );
       this->mesh->tag_set_data( tag_handle, &vertex_handle, 1, (char*)vtags + tag_offset );
+    return vertex_handle;
+  /// Insert a new n-way hashed vertex into the mesh and set its tag values.
+    // First, see if we've already created this vertex
+    MBEntityHandle hv;
+    if ( this->find_hashed_vertex( hv, nhash, hash ) )
+      return hv;
+    this->mesh->create_vertex( vcoords + 3, hv );
+    MBTag tag_handle;
+    int tag_offset;
+    for ( int i = 0; i < num_tags; ++i )
+      this->edge_size_evaluator->get_vertex_tag( i, tag_handle, tag_offset );
+      this->mesh->tag_set_data( tag_handle, &hv, 1, (char*)vtags + tag_offset );
+    return hv;
+  /// Accumulate a vertex for use in the connectivity record of an element.
+  virtual void operator () ( MBEntityHandle hash )
+    this->vertex_accum.push_back( hash );
+  /// Create an element from all the accumulated vertices since the last element was created.
     if ( ! this->vertex_accum.size() )
@@ -127,6 +153,13 @@
     this->mesh->create_element( etyp, &this->vertex_accum[0], this->vertex_accum.size(), elem_handle );
     this->vertex_accum.clear();
+  bool find_hashed_vertex( MBEntityHandle& vout, int nhash, MBEntityHandle* hash )
+    return false;
+  void hash_vertex( MBEntityHandle vout, int nhash, MBEntityHandle* hash )
 MBMeshRefiner::MBMeshRefiner( MBInterface* parent_mesh )
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp	2008-06-10 20:20:16 UTC (rev 1888)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp	2008-06-11 00:00:51 UTC (rev 1889)
@@ -57,12 +57,9 @@
   MBTag tag_handle;
   int tag_offset;
   void* tag_data;
-  MBEntityHandle* tag_vhandle;
   for ( int n = 0; n < num_nodes; ++ n )
-    tag_vhandle = this->heap_hash_storage( 1 );
-    tag_vhandle[0] = conn[n];
-    this->corner_handles[n] = tag_vhandle;
+    this->corner_handles[n] = conn[n];
     if ( this->mesh->get_coords( &conn[n], 1, &corner_coords[6 * n + 3] ) != MB_SUCCESS )
       return false;
@@ -193,9 +190,14 @@
   * in space and vertices as degrees-of-freedom in a mesh (i.e. a vertex that is
   * treated as a lumped-parameter model).
-void MBSimplexTemplateRefiner::refine_0_simplex( const double* v0, const void* t0, MBEntityHandle* h0 )
+void MBSimplexTemplateRefiner::refine_0_simplex( const double* v0, const void* t0, MBEntityHandle h0 )
-  (*this->output_functor)( v0, t0, h0 );
+  // Ignore these arguments... the caller is responsible for calling the output functor to ensure the
+  // vertex exists on the output.
+  (void) v0;
+  (void) t0;
+  (*this->output_functor)( h0 );
   (*this->output_functor)( MBVERTEX );
@@ -203,8 +205,8 @@
 bool MBSimplexTemplateRefiner::refine_1_simplex(
   int max_depth,
-  const double* v0, const void* t0, MBEntityHandle* h0,
-  const double* v1, const void* t1, MBEntityHandle* h1 )
+  const double* v0, const void* t0, MBEntityHandle h0,
+  const double* v1, const void* t1, MBEntityHandle h1 )
   bool edge_code = false;
@@ -212,8 +214,7 @@
   void* midptt;
   // NB: If support for multiple recursive subdivisions (without a merge in between) is required,
   //     this will have to change as it assumes that h0 and h1 have only a single entry.
-  MBEntityHandle midpth[3];
-  midpth[0] = h0[0]; midpth[1] = h1[0]; midpth[2] = 0;
+  MBEntityHandle midpth = 0;
   if ( max_depth-- > 0 )
@@ -227,14 +228,18 @@
     (*this->tag_assigner)( v0, t0, h0, midptc, midptt, v1, t1, h1 );
     edge_code = this->edge_size_evaluator->evaluate_edge( v0, t0, midptc, midptt, v1, t1 );
+    if ( edge_code )
+      midpth = (*this->output_functor)( h0, h1, midptc, midptt );
   switch ( edge_code )
     // No edges to subdivide
   case 0:
-    (*this->output_functor)( v1, t1, h1 );
+    (*this->output_functor)( h1 );
     (*this->output_functor)( MBEDGE );
     break ;
@@ -252,9 +257,9 @@
 bool MBSimplexTemplateRefiner::refine_2_simplex(
   int max_depth, int move,
-  const double* v1, const void* t1, MBEntityHandle* h1,
-  const double* v2, const void* t2, MBEntityHandle* h2 )
+  const double* v1, const void* t1, MBEntityHandle h1,
+  const double* v2, const void* t2, MBEntityHandle h2 )
   int edge_code = 0;
@@ -264,9 +269,9 @@
   void* midpt0t;
   void* midpt1t;
   void* midpt2t;
-  MBEntityHandle* midpt0h;
-  MBEntityHandle* midpt1h;
-  MBEntityHandle* midpt2h;
+  MBEntityHandle midpt0h;
+  MBEntityHandle midpt1h;
+  MBEntityHandle midpt2h;
@@ -277,9 +282,9 @@
     midpt0t = this->heap_tag_storage();
     midpt1t = this->heap_tag_storage();
     midpt2t = this->heap_tag_storage();
-    midpt0h = this->heap_hash_storage( h0, h1 );
-    midpt1h = this->heap_hash_storage( h1, h2 );
-    midpt2h = this->heap_hash_storage( h2, h0 );
+    midpt0h = 0;
+    midpt1h = 0;
+    midpt2h = 0;
     for ( i = 0; i < 6; ++i )
       midpt0c[i] = ( v0[i] + v1[i] ) / 2.;
@@ -290,20 +295,29 @@
     (*this->tag_assigner)( v1, t1, h1, midpt1c, midpt1t, v2, t2, h2 );
     (*this->tag_assigner)( v2, t2, h2, midpt2c, midpt2t, v0, t0, h0 );
     if ( ( move & 1 ) && this->edge_size_evaluator->evaluate_edge( v0, t0, midpt0c, midpt0t, v1, t1 ) )
       edge_code += 1;
+      midpt0h = (*this->output_functor)( h0, h1, midpt0c, midpt0t );
     if ( ( move & 2 ) && this->edge_size_evaluator->evaluate_edge( v1, t1, midpt1c, midpt1t, v2, t2 ) )
       edge_code += 2;
+      midpt1h = (*this->output_functor)( h1, h2, midpt1c, midpt1t );
     if ( ( move & 4 ) && this->edge_size_evaluator->evaluate_edge( v2, t2, midpt2c, midpt2t, v0, t0 ) )
       edge_code += 4;
+      midpt2h = (*this->output_functor)( h2, h0, midpt2c, midpt2t );
   case 0:
-    (*this->output_functor)( v2, t2, h2 );
+    (*this->output_functor)( h2 );
     (*this->output_functor)( MBTRI );
     break ;
@@ -378,12 +392,12 @@
 bool MBSimplexTemplateRefiner::refine_3_simplex(
   int max_depth,
-  double* v0, void* t0, MBEntityHandle* h0,
-  double* v1, void* t1, MBEntityHandle* h1,
-  double* v2, void* t2, MBEntityHandle* h2,
-  double* v3, void* t3, MBEntityHandle* h3 )
+  double* v0, void* t0, MBEntityHandle h0,
+  double* v1, void* t1, MBEntityHandle h1,
+  double* v2, void* t2, MBEntityHandle h2,
+  double* v3, void* t3, MBEntityHandle h3 )
-  bool edge_code = false;
+  int edge_code = 0;
   double* midpt0c;
   double* midpt1c;
@@ -399,12 +413,12 @@
   void* midpt4t;
   void* midpt5t;
-  MBEntityHandle* midpt3h;
-  MBEntityHandle* midpt4h;
-  MBEntityHandle* midpt5h;
+  MBEntityHandle midpt3h;
+  MBEntityHandle midpt4h;
+  MBEntityHandle midpt5h;
@@ -422,13 +436,6 @@
     midpt4t = this->heap_tag_storage();
     midpt5t = this->heap_tag_storage();
-    midpt3h = this->heap_hash_storage( h0, h3 );
-    midpt4h = this->heap_hash_storage( h1, h3 );
-    midpt5h = this->heap_hash_storage( h2, h3 );
     for ( int i = 0; i < 6; ++ i )
       midpt0c[i] = ( v0[i] + v1[i] ) * .5;
@@ -447,27 +454,40 @@
     (*this->tag_assigner)( v2, t2, h2, midpt5c, midpt5t, v3, t3, h3 );
     if ( this->edge_size_evaluator->evaluate_edge( v0, t0, midpt0c, midpt0t, v1, t1 ) )
       edge_code |=  1;
     if ( this->edge_size_evaluator->evaluate_edge( v1, t1, midpt1c, midpt1t, v2, t2 ) )
       edge_code |=  2;
     if ( this->edge_size_evaluator->evaluate_edge( v2, t2, midpt2c, midpt2t, v0, t0 ) )
       edge_code |=  4;
     if ( this->edge_size_evaluator->evaluate_edge( v0, t0, midpt3c, midpt3t, v3, t3 ) )
       edge_code |=  8;
+      midpt3h = (*this->output_functor)( h0, h3, midpt3c, midpt3t );
     if ( this->edge_size_evaluator->evaluate_edge( v1, t1, midpt4c, midpt4t, v3, t3 ) )
       edge_code |= 16;
+      midpt4h = (*this->output_functor)( h1, h3, midpt4c, midpt4t );
     if ( this->edge_size_evaluator->evaluate_edge( v2, t2, midpt5c, midpt5t, v3, t3 ) )
       edge_code |= 32;
+      midpt5h = (*this->output_functor)( h2, h3, midpt5c, midpt5t );
   double edge_length2[6];
-  edge_length2[0]
-    = edge_length2[1]
-    = edge_length2[2]
-    = edge_length2[3]
-    = edge_length2[4]
-    = edge_length2[5]
-    = 0;
+  for ( int ei = 0; ei < 6; ++ ei )
+    edge_length2[ei] = 0.;
   for ( int c = 0; c < 3; ++ c )
@@ -489,10 +509,10 @@
   if ( ! edge_code )
-    (*this->output_functor)( v3, t3, h3 );
+    (*this->output_functor)( h3 );
     (*this->output_functor)( MBTET );
     return false;
@@ -524,28 +544,24 @@
     facept0t, facept1t, facept2t, facept3t
-  MBEntityHandle* facept0h = this->heap_hash_storage( 3 );
-  MBEntityHandle* facept1h = this->heap_hash_storage( 3 );
-  MBEntityHandle* facept2h = this->heap_hash_storage( 3 );
-  MBEntityHandle* facept3h = this->heap_hash_storage( 3 );
-  MBEntityHandle* vertex_hash[14] = {
+  MBEntityHandle vertex_hash[14] = {
     h0, h1, h2, h3,
     midpt0h, midpt1h, midpt2h,
     midpt3h, midpt4h, midpt5h,
-    facept0h, facept1h, facept2h, facept3h
+    0, 0, 0, 0
   // Generate tetrahedra that are compatible except when edge
   // lengths are equal on indeterminately subdivided faces.
   double* permuted_coords[14];
   void* permuted_tags[14];
-  MBEntityHandle* permuted_hash[14];
+  MBEntityHandle permuted_hash[14];
   double permlen[6]; // permuted edge lengths
   int C = MBSimplexTemplateRefiner::template_index[edge_code][0];
   int P = MBSimplexTemplateRefiner::template_index[edge_code][1];
   // 1. Permute the tetrahedron into our canonical configuration
-  for ( int i = 0; i < 4; ++ i )
+  for ( int i = 0; i < 14; ++ i )
     permuted_coords[i] = vertex_coords[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
     permuted_tags[i] = vertex_tags[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
@@ -554,25 +570,9 @@
   for ( int i = 4 ; i < 10; ++ i )
-    // permute edges too
-    permuted_coords[i] = vertex_coords[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
-    permuted_tags[i] = vertex_tags[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
-    permuted_hash[i] = vertex_hash[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
+    // permute edge lengths too
     permlen[i-4]  = edge_length2[MBSimplexTemplateRefiner::permutations_from_index[P][i] - 4];
-  // Add our local (heap) storage for face point coordinates to the list.
-  permuted_coords[10] = facept0c;
-  permuted_coords[11] = facept1c;
-  permuted_coords[12] = facept2c;
-  permuted_coords[13] = facept3c;
-  permuted_tags[10] = facept0t;
-  permuted_tags[11] = facept1t;
-  permuted_tags[12] = facept2t;
-  permuted_tags[13] = facept3t;
-  permuted_hash[10] = facept0h;
-  permuted_hash[11] = facept1h;
-  permuted_hash[12] = facept2h;
-  permuted_hash[13] = facept3h;
   int comparison_bits;
   std::stack<int*> output_tets;
@@ -603,7 +603,9 @@
           permuted_coords[10][i] = ( permuted_coords[0][i] + permuted_coords[2][i] ) * .375 + permuted_coords[1][i] * .25;
-        (*this->tag_assigner)( t0, t2, t1, permuted_tags[10] );
+        (*this->tag_assigner)( permuted_tags[0], permuted_tags[2], permuted_tags[1], permuted_tags[10] );
+        permuted_hash[10] = (*this->output_functor)(
+          permuted_hash[0], permuted_hash[2], permuted_hash[1], permuted_coords[10], permuted_tags[10] );
       MB_TESSELLATOR_INCR_CASE_COUNT(1);
       output_tets.push( MBSimplexTemplateRefiner::templates + 9 );
@@ -652,7 +654,9 @@
           permuted_coords[11][i] = ( permuted_coords[1][i] + permuted_coords[3][i] ) * .375 + permuted_coords[0][i] * .25;
-        (*this->tag_assigner)( t1, t3, t0, permuted_tags[11] );
+        (*this->tag_assigner)( permuted_tags[1], permuted_tags[3], permuted_tags[0], permuted_tags[11] );
+        permuted_hash[11] = (*this->output_functor)(
+          permuted_hash[1], permuted_hash[3], permuted_hash[0], permuted_coords[11], permuted_tags[11] );
       if ( ( comparison_bits & 12 ) == 12 )
@@ -661,7 +665,9 @@
           permuted_coords[13][i] = ( permuted_coords[2][i] + permuted_coords[3][i] ) * .375 + permuted_coords[0][i] * .25;
-        (*this->tag_assigner)( t2, t3, t0, permuted_tags[13] );
+        (*this->tag_assigner)( permuted_tags[2], permuted_tags[3], permuted_tags[0], permuted_tags[13] );
+        permuted_hash[13] = (*this->output_functor)(
+          permuted_hash[2], permuted_hash[3], permuted_hash[0], permuted_coords[13], permuted_tags[13] );
       if ( ( comparison_bits & 48 ) == 48 )
@@ -670,7 +676,9 @@
           permuted_coords[10][i] = ( permuted_coords[1][i] + permuted_coords[2][i] ) * .375 + permuted_coords[0][i] * .25;
-        (*this->tag_assigner)( t1, t2, t0, permuted_tags[10] );
+        (*this->tag_assigner)( permuted_tags[1], permuted_tags[2], permuted_tags[0], permuted_tags[10] );
+          permuted_hash[1], permuted_hash[2], permuted_hash[0], permuted_coords[10] , permuted_tags[10] );
       MB_TESSELLATOR_INCR_CASE_COUNT(3);
       output_tets.push( MBSimplexTemplateRefiner::templates + 57 );
@@ -778,7 +786,9 @@
@@ -787,7 +797,9 @@
       MB_TESSELLATOR_INCR_CASE_COUNT(5);
       switch ( comparison_bits )
@@ -860,7 +872,9 @@
+          permuted_hash[1], permuted_hash[2], permuted_hash[0], permuted_coords[10], permuted_tags[10] );
@@ -869,7 +883,9 @@
           permuted_coords[11][i] = ( permuted_coords[0][i] + permuted_coords[3][i] ) * .375 + permuted_coords[1][i] * .25;
-        (*this->tag_assigner)( t0, t3, t1, permuted_tags[11] );
+        (*this->tag_assigner)( permuted_tags[0], permuted_tags[3], permuted_tags[1], permuted_tags[11] );
+          permuted_hash[0], permuted_hash[3], permuted_hash[1], permuted_coords[11], permuted_tags[11] );
       MB_TESSELLATOR_INCR_CASE_COUNT(6);
@@ -942,7 +958,9 @@
           permuted_coords[12][i] = ( permuted_coords[1][i] + permuted_coords[2][i] ) * .375 + permuted_coords[3][i] * .25;
-        (*this->tag_assigner)( t1, t2, t3, permuted_tags[12] );
+        (*this->tag_assigner)( permuted_tags[1], permuted_tags[2], permuted_tags[3], permuted_tags[12] );
+        permuted_hash[12] = (*this->output_functor)(
+          permuted_hash[1], permuted_hash[2], permuted_hash[3], permuted_coords[12], permuted_tags[12] );
@@ -951,7 +969,9 @@
           permuted_coords[11][i] = ( permuted_coords[0][i] + permuted_coords[1][i] ) * .375 + permuted_coords[3][i] * .25;
-        (*this->tag_assigner)( t0, t1, t3, permuted_tags[11] );
+        (*this->tag_assigner)( permuted_tags[0], permuted_tags[1], permuted_tags[3], permuted_tags[11] );
+          permuted_hash[0], permuted_hash[1], permuted_hash[3], permuted_coords[11], permuted_tags[11] );
       MB_TESSELLATOR_INCR_CASE_COUNT(7);
       output_tets.push( MBSimplexTemplateRefiner::templates + 545 );
@@ -1030,7 +1050,9 @@
           permuted_coords[10][i] = ( permuted_coords[1][i] + permuted_coords[0][i] ) * .375 + permuted_coords[2][i] * .25;
-        (*this->tag_assigner)( t1, t0, t2, permuted_tags[10] );
+        (*this->tag_assigner)( permuted_tags[1], permuted_tags[0], permuted_tags[2], permuted_tags[10] );
+          permuted_hash[1], permuted_hash[0], permuted_hash[2], permuted_coords[10], permuted_tags[10] );
@@ -1039,7 +1061,9 @@
@@ -1048,7 +1072,9 @@
       if ( ( comparison_bits & 192 ) == 192 )
@@ -1057,7 +1083,9 @@
           permuted_coords[12][i] = ( permuted_coords[2][i] + permuted_coords[3][i] ) * .375 + permuted_coords[1][i] * .25;
-        (*this->tag_assigner)( t2, t3, t1, permuted_tags[12] );
+        (*this->tag_assigner)( permuted_tags[2], permuted_tags[3], permuted_tags[1], permuted_tags[12] );
+          permuted_hash[2], permuted_hash[3], permuted_hash[1], permuted_coords[12], permuted_tags[12] );
       MB_TESSELLATOR_INCR_CASE_COUNT(8);
@@ -1394,7 +1422,9 @@
@@ -1403,7 +1433,9 @@
       MB_TESSELLATOR_INCR_CASE_COUNT(9);
       output_tets.push( MBSimplexTemplateRefiner::templates + 1107 );
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp	2008-06-10 20:20:16 UTC (rev 1888)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp	2008-06-11 00:00:51 UTC (rev 1889)
@@ -52,25 +52,25 @@
   MBSimplexTemplateTagAssigner* tag_assigner;
   std::vector<double> corner_coords;
   std::vector<void*> corner_tags;
-  std::vector<MBEntityHandle*> corner_handles;
+  std::vector<MBEntityHandle> corner_handles;
   static int template_index[64][2];
   static int permutations_from_index[24][14];
   static int templates[];
-  void refine_0_simplex( const double* v0, const void* t0, MBEntityHandle* h0 );
+  void refine_0_simplex( const double* v0, const void* t0, MBEntityHandle h0 );
   bool refine_1_simplex( int max_depth,
-                         const double* v1, const void* t1, MBEntityHandle* h1 );
+                         const double* v1, const void* t1, MBEntityHandle h1 );
   bool refine_2_simplex( int max_depth, int move,
-                         const double* v2, const void* t2, MBEntityHandle* h2 );
+                         const double* v2, const void* t2, MBEntityHandle h2 );
   bool refine_3_simplex( int max_depth,
-                         double* v3, void* t3, MBEntityHandle* h3 );
+                         double* v3, void* t3, MBEntityHandle h3 );
   int best_tets( int* alternates, double*[14], int, int ) { return alternates[0]; }
   void assign_parametric_coordinates( int num_nodes, const double* src, double* tgt );
Modified: MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.cpp	2008-06-10 20:20:16 UTC (rev 1888)
+++ MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.cpp	2008-06-11 00:00:51 UTC (rev 1889)
@@ -37,9 +37,9 @@
   * @param[in] t1 Pointer to endpoint 1 tag values.
 void MBSimplexTemplateTagAssigner::operator () (
-  const double* c0, const void* t0, MBEntityHandle* h0,
+  const double* c0, const void* t0, MBEntityHandle h0,
   const double* cm, void* tm,
-  const double* c1, const void* t1, MBEntityHandle* h1 )
+  const double* c1, const void* t1, MBEntityHandle h1 )
   double c0m_squared = 0.;
   double c01_squared = 0.;
@@ -78,7 +78,7 @@
         break;
       default:
-        memcpy( (char*)tm + tag_offset, (char*)( *h0 < *h1 ? t0 : t1 ) + tag_offset, tag_size );
+        memcpy( (char*)tm + tag_offset, (char*)( h0 < h1 ? t0 : t1 ) + tag_offset, tag_size );
         break;
Modified: MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.hpp
--- MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.hpp	2008-06-10 20:20:16 UTC (rev 1888)
+++ MOAB/trunk/refiner/MBSimplexTemplateTagAssigner.hpp	2008-06-11 00:00:51 UTC (rev 1889)
@@ -38,9 +38,9 @@
   MBSimplexTemplateTagAssigner( MBSimplexTemplateRefiner* );
   virtual ~MBSimplexTemplateTagAssigner();
-  virtual void operator () ( const double* c0, const void* t0, MBEntityHandle* h0,
+  virtual void operator () ( const double* c0, const void* t0, MBEntityHandle h0,
-                             const double* c1, const void* t1, MBEntityHandle* h1 );
+                             const double* c1, const void* t1, MBEntityHandle h1 );
   virtual void operator () ( const void* t0,
                              const void* t1,
                              const void* t2,
Modified: MOAB/trunk/test_mesh_refiner.cpp
--- MOAB/trunk/test_mesh_refiner.cpp	2008-06-10 20:20:16 UTC (rev 1888)
+++ MOAB/trunk/test_mesh_refiner.cpp	2008-06-11 00:00:51 UTC (rev 1889)
@@ -25,8 +25,13 @@
   edge_hash_t edge_hash;
   node_list_t elem_vert;
+  void print_vert_crud( MBEntityHandle vout, int nvhash, MBEntityHandle* vhash, const double* vcoords, const void* vtags )
+    std::cout << "+ {";
+    for ( int i = 0; i < nvhash; ++ i )
+      std::cout << " " << vhash[i];
+    std::cout << " } -> " << vout << " ";
     std::cout << "[ " << vcoords[0];
     for ( int i = 1; i < 6; ++i )
       std::cout << ", " << vcoords[i];
@@ -38,40 +43,33 @@
               << ", " << x[1];
     for ( int i = 0; i < 4; ++i )
       std::cout << ", " << m[i];
-    std::cout << " > { ";
-    MBEntityHandle* vin = vhash;
-    while ( *vin )
+    std::cout << " >\n";
+    if ( this->input_is_output )
+      { // Don't copy the original vertex!
+      this->print_vert_crud( vhash, 1, &vhash, vcoords, vtags );
+      return vhash;
+    MBEntityHandle vertex_handle;
+    if ( this->mesh->create_vertex( vcoords + 3, vertex_handle ) != MB_SUCCESS )
-      std::cout << *vin << " ";
-      ++ vin;
+      std::cerr << "Could not insert mid-edge vertex!\n";
-    std::cout << "}\n";
+    this->print_vert_crud( vertex_handle, 1, &vhash, vcoords, vtags );
+  virtual MBEntityHandle operator () ( int nvhash, MBEntityHandle* vhash, const double* vcoords, const void* vtags )
-    if ( ! vhash[1] )
+    if ( nvhash == 1 )
-      if ( this->input_is_output )
-        { // Don't copy the original vertex!
-        vertex_handle = vhash[0];
-      else
-        node_hash_t::iterator it = this->node_hash.find( vhash[0] );
-        if ( it == this->node_hash.end() )
-          if ( this->mesh->create_vertex( vcoords + 3, vertex_handle ) != MB_SUCCESS )
-            std::cerr << "Could not insert corner vertex!\n";
-          this->node_hash[vhash[0]] = vertex_handle;
-        else
-          vertex_handle = it->second;
+      vertex_handle = (*this)( *vhash, vcoords, vtags );
-    else if ( ! vhash[2] )
+    else if ( nvhash == 2 )
       node_pair_t pr;
       if ( vhash[0] < vhash[1] )
@@ -97,22 +95,32 @@
+      this->print_vert_crud( vertex_handle, 2, vhash, vcoords, vtags );
     else
+      vertex_handle = -1;
       std::cerr << "Not handling mid-face vertices yet.\n";
       // FIXME: Handle face midpoint.
-    std::cout << "        -> " << vertex_handle << "\n";
-    this->elem_vert.push_back( vertex_handle );
+  virtual void operator () ( MBEntityHandle h )
+    std::cout << h << " ";
+    this->elem_vert.push_back( h );
-    std::cout << "---------- " << etyp << "\n\n";
     MBEntityHandle elem_handle;
-    this->mesh->create_element( etyp, &this->elem_vert[0], this->elem_vert.size(), elem_handle );
+    if ( this->mesh->create_element( etyp, &this->elem_vert[0], this->elem_vert.size(), elem_handle ) == MB_FAILURE )
+      std::cerr << " *** ";
     this->elem_vert.clear();
+    std::cout << "---------> " << elem_handle << " ( " << etyp << " )\n\n";
