[MOAB-dev] r1890 - in MOAB/trunk: . refiner
dcthomp at mcs.anl.gov dcthomp at mcs.anl.gov
Tue Jun 10 20:14:43 CDT 2008
Author: dcthomp
Date: 2008-06-10 20:14:43 -0500 (Tue, 10 Jun 2008)
New Revision: 1890
Added:
   MOAB/trunk/refiner/test_mesh_refiner.cpp
Removed:
   MOAB/trunk/test_mesh_refiner.cpp
Modified:
   MOAB/trunk/CMakeLists.txt
   MOAB/trunk/refiner/CMakeLists.txt
Log:
STYLE: Move the refiner test into the refiner subdirectory.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt	2008-06-11 00:00:51 UTC (rev 1889)
+++ MOAB/trunk/CMakeLists.txt	2008-06-11 01:14:43 UTC (rev 1890)
@@ -355,12 +355,6 @@
   target_link_libraries( tqdcfr MOAB )
   add_test( TestTQDCFR ${EXECUTABLE_OUTPUT_PATH}/tqdcfr )
-  add_executable( test_mesh_refiner test_mesh_refiner.cpp )
-  set_source_files_properties( test_mesh_refiner.cpp
-    COMPILE_FLAGS "-DTEST ${MOAB_DEFINES}" )
-  target_link_libraries( test_mesh_refiner MOAB )
-  add_test( TestMeshRefiner ${EXECUTABLE_OUTPUT_PATH}/test_mesh_refiner )
   add_executable( bsp_tree_test bsp_tree_test.cpp )
   set_source_files_properties( bsp_tree_test.cpp
Modified: MOAB/trunk/refiner/CMakeLists.txt
--- MOAB/trunk/refiner/CMakeLists.txt	2008-06-11 00:00:51 UTC (rev 1889)
+++ MOAB/trunk/refiner/CMakeLists.txt	2008-06-11 01:14:43 UTC (rev 1890)
@@ -11,3 +11,11 @@
   ${MOAB_REFINER_SRCS}
+enable_testing()
+add_executable( test_mesh_refiner test_mesh_refiner.cpp )
+set_source_files_properties( test_mesh_refiner.cpp
+  COMPILE_FLAGS "-DTEST ${MOAB_DEFINES}" )
+target_link_libraries( test_mesh_refiner MOAB MOABrefiner )
+add_test( TestMeshRefiner ${EXECUTABLE_OUTPUT_PATH}/test_mesh_refiner )
Copied: MOAB/trunk/refiner/test_mesh_refiner.cpp (from rev 1889, MOAB/trunk/test_mesh_refiner.cpp)
--- MOAB/trunk/refiner/test_mesh_refiner.cpp	                        (rev 0)
+++ MOAB/trunk/refiner/test_mesh_refiner.cpp	2008-06-11 01:14:43 UTC (rev 1890)
@@ -0,0 +1,265 @@
+#include "MBCore.hpp"
+#include "MBEdgeSizeSimpleImplicit.hpp"
+#include "MBSimplexTemplateRefiner.hpp"
+#include "MBInterface.hpp"
+#include "MBParallelConventions.h"
+#ifdef USE_MPI
+#include "MBParallelComm.hpp"
+#include "mpi.h"
+#endif // USE_MPI
+#include <iostream>
+class MBTestOutputFunctor : public MBEntityRefinerOutputFunctor
+public:
+  typedef std::vector<MBEntityHandle> node_list_t;
+  typedef std::pair<MBEntityHandle,MBEntityHandle> node_pair_t;
+  typedef std::map<MBEntityHandle,MBEntityHandle> node_hash_t;
+  typedef std::map<node_pair_t,MBEntityHandle> edge_hash_t;
+  MBInterface* mesh;
+  bool input_is_output;
+  node_hash_t node_hash;
+  edge_hash_t edge_hash;
+  node_list_t elem_vert;
+  void print_vert_crud( MBEntityHandle vout, int nvhash, MBEntityHandle* vhash, const double* vcoords, const void* vtags )
+    std::cout << "+ {";
+    for ( int i = 0; i < nvhash; ++ i )
+      std::cout << " " << vhash[i];
+    std::cout << " } -> " << vout << " ";
+    std::cout << "[ " << vcoords[0];
+    for ( int i = 1; i < 6; ++i )
+      std::cout << ", " << vcoords[i];
+    std::cout << " ] ";
+    double* x = (double*)vtags;
+    int* m = (int*)( (char*)vtags + 2 * sizeof( double ) );
+    std::cout << "< " << x[0]
+              << ", " << x[1];
+    for ( int i = 0; i < 4; ++i )
+      std::cout << ", " << m[i];
+    std::cout << " >\n";
+  virtual MBEntityHandle operator () ( MBEntityHandle vhash, const double* vcoords, const void* vtags )
+    if ( this->input_is_output )
+      { // Don't copy the original vertex!
+      this->print_vert_crud( vhash, 1, &vhash, vcoords, vtags );
+      return vhash;
+    MBEntityHandle vertex_handle;
+    if ( this->mesh->create_vertex( vcoords + 3, vertex_handle ) != MB_SUCCESS )
+      std::cerr << "Could not insert mid-edge vertex!\n";
+    this->print_vert_crud( vertex_handle, 1, &vhash, vcoords, vtags );
+    return vertex_handle;
+  virtual MBEntityHandle operator () ( int nvhash, MBEntityHandle* vhash, const double* vcoords, const void* vtags )
+    if ( nvhash == 1 )
+      vertex_handle = (*this)( *vhash, vcoords, vtags );
+    else if ( nvhash == 2 )
+      node_pair_t pr;
+      if ( vhash[0] < vhash[1] )
+        pr.first = vhash[0];
+        pr.second = vhash[1];
+      else
+        pr.first = vhash[1];
+        pr.second = vhash[0];
+      edge_hash_t::iterator it = this->edge_hash.find( pr );
+      if ( it == this->edge_hash.end() )
+        this->edge_hash[pr] = vertex_handle;
+      else
+        vertex_handle = it->second;
+      this->print_vert_crud( vertex_handle, 2, vhash, vcoords, vtags );
+    else
+      vertex_handle = -1;
+      std::cerr << "Not handling mid-face vertices yet.\n";
+      // FIXME: Handle face midpoint.
+  virtual void operator () ( MBEntityHandle h )
+    std::cout << h << " ";
+    this->elem_vert.push_back( h );
+  virtual void operator () ( MBEntityType etyp )
+    MBEntityHandle elem_handle;
+    if ( this->mesh->create_element( etyp, &this->elem_vert[0], this->elem_vert.size(), elem_handle ) == MB_FAILURE )
+      std::cerr << " *** ";
+    this->elem_vert.clear();
+    std::cout << "---------> " << elem_handle << " ( " << etyp << " )\n\n";
+int TestMeshRefiner( int argc, char* argv[] )
+  int nprocs, rank;
+#ifdef USE_MPI
+  int err = MPI_Init( &argc, &argv );
+  err = MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+  err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+  std::cout << "Rank: " << ( rank + 1 ) << " of: " << nprocs << "\n";
+#else // USE_MPI
+  nprocs = 1;
+  rank = 0;
+#endif // USE_MPI
+  MBInterface* iface = new MBCore;
+  MBEdgeSizeSimpleImplicit* eval = new MBEdgeSizeSimpleImplicit( iface );
+  double p0[6] = { 0.0, 0.0, 0.0,  0.0, 0.0, 0.0 };
+  double p1[6] = { 0.5, 0.0, 0.0,  0.5, 0.0, 0.0 };
+  double p2[6] = { 1.0, 0.0, 0.0,  1.0, 0.0, 0.0 };
+  double p3[6] = { 0.6, 2.0, 0.0,  0.6, 2.0, 0.0 };
+  double coords[][6] = {
+    {  0. ,  0.0,  0. ,  0. ,  0.0,  0.  }, // 0
+    { -1. ,  0.0,  0.5, -1. ,  0.0,  0.5 }, // 1
+    { -0.5, -1.0,  0.5, -0.5, -1.0,  0.5 }, // 2
+    {  0. ,  0. ,  1. ,  0. ,  0. ,  1.  }, // 3
+    {  0.5,  0.5,  0.5,  0.5,  0.5,  0.5 }, // 4
+    {  0.5, -0.5,  0.5,  0.5, -0.5,  0.5 }  // 5
+  double default_floatular[2] = {
+     38.7,   104. };
+  double floatular_values[][2] = {
+    {  38.7,   104.,    }, // 0
+    {   3.141,   2.718, }, // 1
+    { 123.456, 789.012, }, // 2
+    {   0.,      1.,    }, // 3
+    {   1.,      0.,    }, // 4
+    {  -1.,      1.,    }  // 5
+  int default_intular[4] = {
+     7, 11, 24,  7 };
+  int intular_values[][4] = {
+    {  7, 11, 24,  7, }, // 0
+    { 10,  4, 10, 20, }, // 1
+    {  1,  2,  3,  4, }, // 2
+    { 13, 17, 19, 23, }, // 3
+    {  3,  3,  0,  6, }, // 4
+    {  5,  4,  3,  2  }  // 5
+  int default_gid[] = { -1 };
+  int gid_values[] = {
+    0, 1, 2, 3, 4, 5, // vertices
+    6, 7, 8, 9        // tetrahedra
+  // List of vertices resident on each node.
+  int proc_nodes[4][4] = {
+    { 0, 2, 3, 1 },
+    { 0, 1, 3, 4 },
+    { 0, 4, 3, 5 },
+    { 0, 5, 3, 2 },
+  // List of nodes with a copy of each vertex (first entry is owner)
+  int node_procs[6][4] = {
+    { 0,  1,  2,  3 }, // 0
+    { 0,  1, -1, -1 }, // 1
+    { 0,  3, -1, -1 }, // 2
+    { 0,  1,  2,  3 }, // 3
+    { 1,  2, -1, -1 }, // 4
+    { 2,  3, -1, -1 }  // 5
+  eval->set_ratio( 2. );
+  MBEntityHandle node_handles[4];
+  MBEntityHandle tet_handle;
+  MBEntityHandle tri_handle;
+  MBTag tag_floatular;
+  iface->tag_create( "floatular", 2 * sizeof( double ), MB_TAG_DENSE, MB_TYPE_DOUBLE, tag_floatular, default_floatular );
+  MBTag tag_intular;
+  iface->tag_create( "intular", 4 * sizeof( int ), MB_TAG_DENSE, MB_TYPE_INTEGER, tag_intular, default_intular );
+  MBTag tag_gid;
+  iface->tag_create( PARALLEL_GID_TAG_NAME, sizeof( int ), MB_TAG_DENSE, MB_TYPE_INTEGER, tag_gid, default_gid );
+  void const* iptrs[4];
+  void const* fptrs[4];
+  void const* gptrs[4];
+  for ( int i = 0; i < 4; ++ i )
+    iface->create_vertex( coords[proc_nodes[rank][i]], node_handles[i] );
+    iptrs[i] = (void const*) intular_values[proc_nodes[rank][i]];
+    fptrs[i] = (void const*) floatular_values[proc_nodes[rank][i]];
+    gptrs[i] = (void const*) &gid_values[proc_nodes[rank][i]];
+  iface->tag_set_data( tag_floatular, node_handles, 4, fptrs, 0 );
+  eval->add_vertex_tag( tag_floatular );
+  iface->tag_set_data( tag_intular, node_handles, 4, iptrs, 0 );
+  eval->add_vertex_tag( tag_intular );
+  iface->tag_set_data( tag_gid, node_handles, 4, gptrs, 0 );
+  iface->create_element( MBTET, node_handles, 4, tet_handle );
+  iface->tag_set_data( tag_gid, &tet_handle, 1, gid_values + 6 + rank );
+  iface->list_entities( 0, 1 );
+  MBSimplexTemplateRefiner eref( iface );
+  MBTestOutputFunctor* ofunc = new MBTestOutputFunctor;
+  ofunc->input_is_output = ( argc > 1 && ! strcmp( argv[1], "-new-mesh" ) ) ? false : true;
+  ofunc->mesh = ofunc->input_is_output ? iface : new MBCore;
+  eref.set_edge_size_evaluator( eval );
+  eref.set_output_functor( ofunc );
+  eref.refine_entity( tet_handle );
+  ofunc->mesh->list_entities( 0, 1 );
+  if ( ! ofunc->input_is_output )
+    delete ofunc->mesh;
+  delete iface;
+#ifdef USE_MPI
+  err = MPI_Barrier( MPI_COMM_WORLD );
+  err = MPI_Finalize();
+#endif // USE_MPI
+  return 0;
+int main( int argc, char* argv[] )
+  return TestMeshRefiner( argc, argv );
Deleted: MOAB/trunk/test_mesh_refiner.cpp
--- MOAB/trunk/test_mesh_refiner.cpp	2008-06-11 00:00:51 UTC (rev 1889)
+++ MOAB/trunk/test_mesh_refiner.cpp	2008-06-11 01:14:43 UTC (rev 1890)
@@ -1,265 +0,0 @@
-#include "MBCore.hpp"
-#include "MBEdgeSizeSimpleImplicit.hpp"
-#include "MBSimplexTemplateRefiner.hpp"
-#include "MBInterface.hpp"
-#include "MBParallelConventions.h"
-#ifdef USE_MPI
-#include "MBParallelComm.hpp"
-#include "mpi.h"
-#endif // USE_MPI
-#include <iostream>
-class MBTestOutputFunctor : public MBEntityRefinerOutputFunctor
-public:
-  typedef std::vector<MBEntityHandle> node_list_t;
-  typedef std::pair<MBEntityHandle,MBEntityHandle> node_pair_t;
-  typedef std::map<MBEntityHandle,MBEntityHandle> node_hash_t;
-  typedef std::map<node_pair_t,MBEntityHandle> edge_hash_t;
-  MBInterface* mesh;
-  bool input_is_output;
-  node_hash_t node_hash;
-  edge_hash_t edge_hash;
-  node_list_t elem_vert;
-  void print_vert_crud( MBEntityHandle vout, int nvhash, MBEntityHandle* vhash, const double* vcoords, const void* vtags )
-    std::cout << "+ {";
-    for ( int i = 0; i < nvhash; ++ i )
-      std::cout << " " << vhash[i];
-    std::cout << " } -> " << vout << " ";
-    std::cout << "[ " << vcoords[0];
-    for ( int i = 1; i < 6; ++i )
-      std::cout << ", " << vcoords[i];
-    std::cout << " ] ";
-    double* x = (double*)vtags;
-    int* m = (int*)( (char*)vtags + 2 * sizeof( double ) );
-    std::cout << "< " << x[0]
-              << ", " << x[1];
-    for ( int i = 0; i < 4; ++i )
-      std::cout << ", " << m[i];
-    std::cout << " >\n";
-  virtual MBEntityHandle operator () ( MBEntityHandle vhash, const double* vcoords, const void* vtags )
-    if ( this->input_is_output )
-      { // Don't copy the original vertex!
-      this->print_vert_crud( vhash, 1, &vhash, vcoords, vtags );
-      return vhash;
-    MBEntityHandle vertex_handle;
-    if ( this->mesh->create_vertex( vcoords + 3, vertex_handle ) != MB_SUCCESS )
-      std::cerr << "Could not insert mid-edge vertex!\n";
-    this->print_vert_crud( vertex_handle, 1, &vhash, vcoords, vtags );
-    return vertex_handle;
-  virtual MBEntityHandle operator () ( int nvhash, MBEntityHandle* vhash, const double* vcoords, const void* vtags )
-    if ( nvhash == 1 )
-      vertex_handle = (*this)( *vhash, vcoords, vtags );
-    else if ( nvhash == 2 )
-      node_pair_t pr;
-      if ( vhash[0] < vhash[1] )
-        pr.first = vhash[0];
-        pr.second = vhash[1];
-      else
-        pr.first = vhash[1];
-        pr.second = vhash[0];
-      edge_hash_t::iterator it = this->edge_hash.find( pr );
-      if ( it == this->edge_hash.end() )
-        this->edge_hash[pr] = vertex_handle;
-      else
-        vertex_handle = it->second;
-      this->print_vert_crud( vertex_handle, 2, vhash, vcoords, vtags );
-    else
-      vertex_handle = -1;
-      std::cerr << "Not handling mid-face vertices yet.\n";
-      // FIXME: Handle face midpoint.
-  virtual void operator () ( MBEntityHandle h )
-    std::cout << h << " ";
-    this->elem_vert.push_back( h );
-  virtual void operator () ( MBEntityType etyp )
-    MBEntityHandle elem_handle;
-    if ( this->mesh->create_element( etyp, &this->elem_vert[0], this->elem_vert.size(), elem_handle ) == MB_FAILURE )
-      std::cerr << " *** ";
-    this->elem_vert.clear();
-    std::cout << "---------> " << elem_handle << " ( " << etyp << " )\n\n";
-int TestMeshRefiner( int argc, char* argv[] )
-  int nprocs, rank;
-#ifdef USE_MPI
-  int err = MPI_Init( &argc, &argv );
-  err = MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
-  err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
-  std::cout << "Rank: " << ( rank + 1 ) << " of: " << nprocs << "\n";
-#else // USE_MPI
-  nprocs = 1;
-  rank = 0;
-#endif // USE_MPI
-  MBInterface* iface = new MBCore;
-  MBEdgeSizeSimpleImplicit* eval = new MBEdgeSizeSimpleImplicit( iface );
-  double p0[6] = { 0.0, 0.0, 0.0,  0.0, 0.0, 0.0 };
-  double p1[6] = { 0.5, 0.0, 0.0,  0.5, 0.0, 0.0 };
-  double p2[6] = { 1.0, 0.0, 0.0,  1.0, 0.0, 0.0 };
-  double p3[6] = { 0.6, 2.0, 0.0,  0.6, 2.0, 0.0 };
-  double coords[][6] = {
-    {  0. ,  0.0,  0. ,  0. ,  0.0,  0.  }, // 0
-    { -1. ,  0.0,  0.5, -1. ,  0.0,  0.5 }, // 1
-    { -0.5, -1.0,  0.5, -0.5, -1.0,  0.5 }, // 2
-    {  0. ,  0. ,  1. ,  0. ,  0. ,  1.  }, // 3
-    {  0.5,  0.5,  0.5,  0.5,  0.5,  0.5 }, // 4
-    {  0.5, -0.5,  0.5,  0.5, -0.5,  0.5 }  // 5
-  double default_floatular[2] = {
-     38.7,   104. };
-  double floatular_values[][2] = {
-    {  38.7,   104.,    }, // 0
-    {   3.141,   2.718, }, // 1
-    { 123.456, 789.012, }, // 2
-    {   0.,      1.,    }, // 3
-    {   1.,      0.,    }, // 4
-    {  -1.,      1.,    }  // 5
-  int default_intular[4] = {
-     7, 11, 24,  7 };
-  int intular_values[][4] = {
-    {  7, 11, 24,  7, }, // 0
-    { 10,  4, 10, 20, }, // 1
-    {  1,  2,  3,  4, }, // 2
-    { 13, 17, 19, 23, }, // 3
-    {  3,  3,  0,  6, }, // 4
-    {  5,  4,  3,  2  }  // 5
-  int default_gid[] = { -1 };
-  int gid_values[] = {
-    0, 1, 2, 3, 4, 5, // vertices
-    6, 7, 8, 9        // tetrahedra
-  // List of vertices resident on each node.
-  int proc_nodes[4][4] = {
-    { 0, 2, 3, 1 },
-    { 0, 1, 3, 4 },
-    { 0, 4, 3, 5 },
-    { 0, 5, 3, 2 },
-  // List of nodes with a copy of each vertex (first entry is owner)
-  int node_procs[6][4] = {
-    { 0,  1,  2,  3 }, // 0
-    { 0,  1, -1, -1 }, // 1
-    { 0,  3, -1, -1 }, // 2
-    { 0,  1,  2,  3 }, // 3
-    { 1,  2, -1, -1 }, // 4
-    { 2,  3, -1, -1 }  // 5
-  eval->set_ratio( 2. );
-  MBEntityHandle node_handles[4];
-  MBEntityHandle tet_handle;
-  MBEntityHandle tri_handle;
-  MBTag tag_floatular;
-  iface->tag_create( "floatular", 2 * sizeof( double ), MB_TAG_DENSE, MB_TYPE_DOUBLE, tag_floatular, default_floatular );
-  MBTag tag_intular;
-  iface->tag_create( "intular", 4 * sizeof( int ), MB_TAG_DENSE, MB_TYPE_INTEGER, tag_intular, default_intular );
-  MBTag tag_gid;
-  iface->tag_create( PARALLEL_GID_TAG_NAME, sizeof( int ), MB_TAG_DENSE, MB_TYPE_INTEGER, tag_gid, default_gid );
-  void const* iptrs[4];
-  void const* fptrs[4];
-  void const* gptrs[4];
-  for ( int i = 0; i < 4; ++ i )
-    iface->create_vertex( coords[proc_nodes[rank][i]], node_handles[i] );
-    iptrs[i] = (void const*) intular_values[proc_nodes[rank][i]];
-    fptrs[i] = (void const*) floatular_values[proc_nodes[rank][i]];
-    gptrs[i] = (void const*) &gid_values[proc_nodes[rank][i]];
-  iface->tag_set_data( tag_floatular, node_handles, 4, fptrs, 0 );
-  eval->add_vertex_tag( tag_floatular );
-  iface->tag_set_data( tag_intular, node_handles, 4, iptrs, 0 );
-  eval->add_vertex_tag( tag_intular );
-  iface->tag_set_data( tag_gid, node_handles, 4, gptrs, 0 );
-  iface->create_element( MBTET, node_handles, 4, tet_handle );
-  iface->tag_set_data( tag_gid, &tet_handle, 1, gid_values + 6 + rank );
-  iface->list_entities( 0, 1 );
-  MBSimplexTemplateRefiner eref( iface );
-  MBTestOutputFunctor* ofunc = new MBTestOutputFunctor;
-  ofunc->input_is_output = ( argc > 1 && ! strcmp( argv[1], "-new-mesh" ) ) ? false : true;
-  ofunc->mesh = ofunc->input_is_output ? iface : new MBCore;
-  eref.set_edge_size_evaluator( eval );
-  eref.set_output_functor( ofunc );
-  eref.refine_entity( tet_handle );
-  ofunc->mesh->list_entities( 0, 1 );
-  if ( ! ofunc->input_is_output )
-    delete ofunc->mesh;
-  delete iface;
-#ifdef USE_MPI
-  err = MPI_Barrier( MPI_COMM_WORLD );
-  err = MPI_Finalize();
-#endif // USE_MPI
-  return 0;
-int main( int argc, char* argv[] )
-  return TestMeshRefiner( argc, argv );
