[MOAB-dev] r1888 - in MOAB/trunk: . parallel test tools/iMesh
tautges at mcs.anl.gov
Tue Jun 10 15:20:17 CDT 2008
Author: tautges
Date: 2008-06-10 15:20:16 -0500 (Tue, 10 Jun 2008)
New Revision: 1888
Added:
MOAB/trunk/tools/iMesh/iMeshP.h
MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
MOAB/trunk/tools/iMesh/iMeshP_f.h
MOAB/trunk/tools/iMesh/iMeshP_protos.h
Modified:
MOAB/trunk/MBParallelConventions.h
MOAB/trunk/configure.in
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelComm.hpp
MOAB/trunk/parallel/ReadParallel.cpp
MOAB/trunk/test/brick_cubit10.cub
MOAB/trunk/tools/iMesh/Makefile.am
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
First crack at implementing (some of) the ITAPS parallel interface
iMeshP, along with a few other things.
iMesh_MOAB.cpp: move several things within the extern "C" braces.
Indent this file to account for those braces.
tools/iMesh/Makefile.am: add iMeshP stuff
configure.in: make mcnpmit off by default
MBParallelConventions.h: changing the PSTATUS tag definitions a bit.
parallel/MBParallelComm.?pp: Moving around some of the functionality,
mostly to make the interface closer to something usable to others
parallel/ReadParallel.cpp: fixing typo in variable name for ghost
option
Modified: MOAB/trunk/MBParallelConventions.h
--- MOAB/trunk/MBParallelConventions.h 2008-06-10 19:34:51 UTC (rev 1887)
+++ MOAB/trunk/MBParallelConventions.h 2008-06-10 20:20:16 UTC (rev 1888)
@@ -54,17 +54,19 @@
/** \brief Tag storing parallel status (as bits in this tag)
* This tag stores various aspects of parallel status in bits; see also
- * #define's following, to be used in bit mask operations
+ * #define's following, to be used in bit mask operations. If an entity is
+ * not shared with any other processors, the pstatus is 0, otherwise it's > 0
- * bit 0: shared (0=not shared, 1=shared)
- * bit 1: !owned (0=owned, 1=not owned)
+ * bit 0: !owned (0=owned, 1=not owned)
+ * bit 1: interface (0=not interface, 1=interface)
* bit 2: ghost (0=not ghost, 1=ghost)
#define PARALLEL_STATUS_TAG_NAME "PARALLEL_STATUS"
-#define PSTATUS_SHARED 0x1
-#define PSTATUS_NOT_OWNED 0x2
-#define PSTATUS_GHOST 0x4
+#define PSTATUS_NOT_OWNED 0x0
+#define PSTATUS_SHARED 0x2
+#define PSTATUS_INTERFACE 0x4
+#define PSTATUS_GHOST 0x8
/** \brief Tag storing interface sets
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in 2008-06-10 19:34:51 UTC (rev 1887)
+++ MOAB/trunk/configure.in 2008-06-10 20:20:16 UTC (rev 1888)
@@ -242,7 +242,7 @@
MB_OPTIONAL_TOOL([mbsize], [yes])
MB_OPTIONAL_TOOL([mbskin], [yes])
MB_OPTIONAL_TOOL([mbtagprop], [yes])
-MB_OPTIONAL_TOOL([mcnpmit], [yes])
+MB_OPTIONAL_TOOL([mcnpmit], [no])
MB_OPTIONAL_TOOL([mbcoupler], [$ENABLE_mcnpmit] )
MB_OPTIONAL_TOOL([spheredecomp], [yes])
MB_OPTIONAL_TOOL([mbsurfplot], [yes])
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-06-10 19:34:51 UTC (rev 1887)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-06-10 20:20:16 UTC (rev 1888)
@@ -2197,10 +2197,9 @@
MBRange proc_ents;
// get the entities in the partition sets
MBRange part_sets;
- MBTag part_tag = partition_tag();
- result = mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, &part_tag,
- NULL, 1, part_sets);
- if (MB_SUCCESS != result) return result;
+ result = get_partition_sets(part_sets);
+ RRA(" ");
for (MBRange::iterator rit = part_sets.begin(); rit != part_sets.end(); rit++) {
MBRange tmp_ents;
result = mbImpl->get_entities_by_handle(*rit, tmp_ents, true);
@@ -2428,6 +2427,41 @@
return result;
+MBErrorCode MBParallelComm::set_pstatus_entities(MBRange &pstatus_ents,
+ unsigned char pstatus_val,
+ bool lower_dim_ents,
+ bool verts_too,
+ int operation)
+ std::vector<unsigned char> pstatus_vals(pstatus_ents.size());
+ MBRange all_ents, *range_ptr = &pstatus_ents;
+ MBErrorCode result;
+ if (lower_dim_ents || verts_too) {
+ all_ents = pstatus_ents;
+ range_ptr = &all_ents;
+ int start_dim = (lower_dim_ents ? mbImpl->dimension_from_handle(*pstatus_ents.rbegin())-1 : 0);
+ for (; start_dim >= 0; start_dim--) {
+ result = mbImpl->get_adjacencies(all_ents, start_dim, true, all_ents,
+ MBInterface::UNION);
+ RRA(" ");
+ if (MBInterface::UNION == operation) {
+ result = mbImpl->tag_get_data(pstatus_tag(), *range_ptr, &pstatus_vals[0]);
+ RRA("Couldn't get pstatus tag value.");
+ for (unsigned int i = pstatus_ents.size()-1; i >= 0; i--)
+ pstatus_vals[i] |= pstatus_val;
+ else {
+ pstatus_vals[i] = pstatus_val;
+ result = mbImpl->tag_set_data(pstatus_tag(), *range_ptr, &pstatus_vals[0]);
+ RRA("Couldn't set pstatus tag value.");
+ return MB_SUCCESS;
MBErrorCode MBParallelComm::create_interface_sets(std::map<std::vector<int>, MBRange> &proc_nranges,
int resolve_dim, int shared_dim,
MBRange *iface_sets_ptr)
@@ -2480,7 +2514,7 @@
// get the owning proc, then set the pstatus tag on iface set
int min_proc = ((*mit).first)[0];
- unsigned char pstatus = PSTATUS_SHARED;
+ unsigned char pstatus = (PSTATUS_SHARED | PSTATUS_INTERFACE);
if (min_proc < (int) procConfig.proc_rank()) pstatus |= PSTATUS_NOT_OWNED;
result = mbImpl->tag_set_data(pstatus_tag, &new_set, 1, &pstatus);
RRA("Failed to tag interface set with pstatus.");
@@ -2757,7 +2791,7 @@
MBRange iface_sets;
std::vector<int> iface_procs;
- MBErrorCode result = get_iface_sets_procs(iface_sets, iface_procs);
+ MBErrorCode result = get_interface_sets_procs(iface_sets, iface_procs);
RRA("Failed to get iface sets/procs.");
for (MBRange::iterator rit = iface_sets.begin(); rit != iface_sets.end(); rit++) {
@@ -2771,6 +2805,82 @@
return MB_SUCCESS;
+ //! return partition sets; if tag_name is input, gets sets with
+ //! that tag name, otherwise uses PARALLEL_PARTITION tag
+MBErrorCode MBParallelComm::get_partition_sets(MBRange &part_sets,
+ const char *tag_name)
+ if (NULL != tag_name) {
+ result = MB_NOT_IMPLEMENTED;
+ RRA("Specified tag name not yet implemented.");
+ MBTag part_tag = partition_tag();
+ result = mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, &part_tag,
+ NULL, 1, part_sets);
+ return result;
+ //! get communication interface sets and the processors with which
+ //! this processor communicates; sets are sorted by processor
+MBErrorCode MBParallelComm::get_interface_sets_procs(MBRange &iface_sets,
+ std::vector<int> &iface_procs)
+ MBTag iface_tag = iface_sets_tag();
+ if (0 == iface_tag) return MB_FAILURE;
+ // make sure the sharing procs vector is empty
+ iface_procs.clear();
+ // get the iface sets, which are stored on the instance
+ int tag_sz;
+ MBErrorCode result = mbImpl->tag_get_size(iface_tag, tag_sz);
+ RRA("Failed to get iface tag size.");
+ tag_sz /= sizeof(MBEntityHandle);
+ std::vector<MBEntityHandle> iface_sets_vec(tag_sz);
+ result = mbImpl->tag_get_data(iface_tag, NULL, 0, &iface_sets_vec[0]);
+ RRA("Failed to find iface tag.");
+ // can do a straight copy because ranges don't keep 0-values
+ std::copy(iface_sets_vec.begin(), iface_sets_vec.end(),
+ mb_range_inserter(iface_sets));
+ // pre-load vector of single-proc tag values
+ unsigned int i, j;
+ std::vector<int> iface_proc(iface_sets.size());
+ result = mbImpl->tag_get_data(sharedp_tag(), iface_sets, &iface_proc[0]);
+ RRA("Failed to get iface_proc for iface sets.");
+ // get sharing procs either from single-proc vector or by getting
+ // multi-proc tag value
+ int tmp_iface_procs[MAX_SHARING_PROCS];
+ std::set<int> procs_set;
+ std::fill(tmp_iface_procs, tmp_iface_procs+MAX_SHARING_PROCS, -1);
+ MBRange::iterator rit;
+ for (rit = iface_sets.begin(), i = 0; rit != iface_sets.end(); rit++, i++) {
+ if (-1 != iface_proc[i]) procs_set.insert(iface_proc[i]);
+ else {
+ // get the sharing_procs tag
+ result = mbImpl->tag_get_data(sharedps_tag(), &(*rit), 1,
+ tmp_iface_procs);
+ RRA("Failed to get iface_procs for iface set.");
+ for (j = 0; j < MAX_SHARING_PROCS; j++) {
+ if (-1 != tmp_iface_procs[j]) procs_set.insert(tmp_iface_procs[j]);
+ else {
+ std::fill(tmp_iface_procs, tmp_iface_procs+j, -1);
+ break;
+ // now put the set contents into the vector
+ std::copy(procs_set.begin(), procs_set.end(), std::back_inserter(iface_procs));
MBErrorCode MBParallelComm::get_pstatus_entities(int dim,
MBRange &pstatus_ents)
@@ -2787,11 +2897,19 @@
RRA("Couldn't get pastatus tag.");
MBRange::iterator rit = ents.begin();
int i = 0;
- for (; rit != ents.end(); i++, rit++)
- if (pstatus[i]&pstatus_val &&
- (-1 == dim || mbImpl->dimension_from_handle(*rit) == dim))
- pstatus_ents.insert(*rit);
+ if (pstatus_val) {
+ for (; rit != ents.end(); i++, rit++)
+ if (pstatus[i]&pstatus_val &&
+ (-1 == dim || mbImpl->dimension_from_handle(*rit) == dim))
+ pstatus_ents.insert(*rit);
+ else {
+ if (!pstatus[i] &&
return MB_SUCCESS;
@@ -2857,62 +2975,6 @@
return MB_SUCCESS;
-MBErrorCode MBParallelComm::get_iface_sets_procs(MBRange &iface_sets,
- std::vector<int> &sharing_procs)
- MBTag iface_tag = iface_sets_tag();
- if (0 == iface_tag) return MB_FAILURE;
- // make sure the sharing procs vector is empty
- sharing_procs.clear();
- // get the iface sets, which are stored on the instance
- int tag_sz;
- MBErrorCode result = mbImpl->tag_get_size(iface_tag, tag_sz);
- RRA("Failed to get iface tag size.");
- tag_sz /= sizeof(MBEntityHandle);
- std::vector<MBEntityHandle> iface_sets_vec(tag_sz);
- result = mbImpl->tag_get_data(iface_tag, NULL, 0, &iface_sets_vec[0]);
- RRA("Failed to find iface tag.");
- // can do a straight copy because ranges don't keep 0-values
- std::copy(iface_sets_vec.begin(), iface_sets_vec.end(),
- mb_range_inserter(iface_sets));
- // pre-load vector of single-proc tag values
- unsigned int i, j;
- std::vector<int> iface_proc(iface_sets.size());
- result = mbImpl->tag_get_data(sharedp_tag(), iface_sets, &iface_proc[0]);
- RRA("Failed to get iface_proc for iface sets.");
- // get sharing procs either from single-proc vector or by getting
- // multi-proc tag value
- int iface_procs[MAX_SHARING_PROCS];
- std::set<int> procs_set;
- std::fill(iface_procs, iface_procs+MAX_SHARING_PROCS, -1);
- MBRange::iterator rit;
- for (rit = iface_sets.begin(), i = 0; rit != iface_sets.end(); rit++, i++) {
- if (-1 != iface_proc[i]) procs_set.insert(iface_proc[i]);
- else {
- // get the sharing_procs tag
- result = mbImpl->tag_get_data(sharedps_tag(), &(*rit), 1,
- &iface_procs[0]);
- RRA("Failed to get iface_procs for iface set.");
- for (j = 0; j < MAX_SHARING_PROCS; j++) {
- if (-1 != iface_procs[j]) procs_set.insert(iface_procs[j]);
- else {
- std::fill(iface_procs, iface_procs+j, -1);
- break;
- // now put the set contents into the vector
- std::copy(procs_set.begin(), procs_set.end(), std::back_inserter(sharing_procs));
- return MB_SUCCESS;
bool MBParallelComm::is_iface_proc(MBEntityHandle this_set,
int to_proc)
@@ -2998,7 +3060,7 @@
// get all procs interfacing to this proc
MBRange iface_sets;
- result = get_iface_sets_procs(iface_sets, iface_procs);
+ result = get_interface_sets_procs(iface_sets, iface_procs);
RRA("Failed to get iface sets, procs");
// post ghost irecv's for all interface procs
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2008-06-10 19:34:51 UTC (rev 1887)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2008-06-10 20:20:16 UTC (rev 1888)
@@ -26,6 +26,7 @@
#define MB_PARALLEL_COMM_HPP
#include "MBForward.hpp"
+#include "MBInterface.hpp"
#include "MBRange.hpp"
#include "MBProcConfig.hpp"
#include <map>
@@ -191,6 +192,22 @@
MBRange &pstatus_ents);
+ /** \brief Set pstatus values on entities
+ * \param pstatus_ents Entities to be set
+ * \param pstatus_val Pstatus value to be set
+ * \param lower_dim_ents If true, lower-dimensional ents (incl. vertices) set too
+ * (and created if they don't exist)
+ * \param verts_too If true, vertices also set
+ * \param operation If UNION, pstatus_val is OR-d with existing value, otherwise
+ * existing value is over-written
+ MBErrorCode set_pstatus_entities(MBRange &pstatus_ents,
+ bool lower_dim_ents = false,
+ bool verts_too = true,
+ int operation = MBInterface::UNION);
/** \brief Get entities on an inter-processor interface and of specified dimension
* If other_proc is -1, any interface entities are returned. If dim is -1,
* entities of all dimensions on interface are returned.
@@ -202,6 +219,16 @@
int dim,
MBRange &iface_ents);
+ MBErrorCode get_partition_sets(MBRange &part_sets,
+ const char *tag_name = NULL);
+ MBErrorCode get_interface_sets_procs(MBRange &iface_sets,
+ std::vector<int> &iface_procs);
//! pack the buffer with ALL data for orig_ents; return entities actually
//! packed (including reference sub-entities) in final_ents
MBErrorCode pack_buffer(MBRange &orig_ents,
@@ -482,10 +509,6 @@
int remote_proc,
MBEntityHandle remote_handle);
- //! returns the interface sets and union of sharing procs
- MBErrorCode get_iface_sets_procs(MBRange &iface_sets,
- std::vector<int> &sharing_procs);
//! MB interface associated with this writer
MBInterface *mbImpl;
@@ -514,16 +537,6 @@
//! tags used to save sharing procs and handles
MBTag sharedpTag, sharedpsTag, sharedhTag, sharedhsTag, pstatusTag,
ifaceSetsTag, partitionTag;
- //! interface sets, one set per unique combination of procs
- MBRange ifaceSets;
- //! ghost sets (sets of ghost entities), one set per unique combination of procs
- MBRange ghostSets;
- //! ghosted sets (sets of ghosted entities), one set per unique combination of procs
- MBRange ghostedSets;
inline MBErrorCode MBParallelComm::get_shared_proc_tags(MBTag &sharedp,
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2008-06-10 19:34:51 UTC (rev 1887)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2008-06-10 20:20:16 UTC (rev 1888)
@@ -106,7 +106,7 @@
else if (MB_SUCCESS == result) {
int num_fields =
- sscanf(ghost_str.c_str(), "%d.%d", &resolve_dim, &shared_dim);
+ sscanf(shared_str.c_str(), "%d.%d", &resolve_dim, &shared_dim);
if (2 != num_fields) {
merror->set_last_error( "Didn't read 2 fields from PARALLEL_RESOLVE_SHARED_ENTS string\n" );
return MB_FAILURE;
Modified: MOAB/trunk/test/brick_cubit10.cub
(Binary files differ)
Modified: MOAB/trunk/tools/iMesh/Makefile.am
--- MOAB/trunk/tools/iMesh/Makefile.am 2008-06-10 19:34:51 UTC (rev 1887)
+++ MOAB/trunk/tools/iMesh/Makefile.am 2008-06-10 20:20:16 UTC (rev 1888)
@@ -16,18 +16,12 @@
check_PROGRAMS = testc_cbind
testc_cbind_SOURCES = testc_cbind.c
-if PARALLEL
- check_PROGRAMS += partest
- partest_SOURCES = partest.cpp
- partest_DEPENDENCIES = libiMesh.la $(top_builddir)/libMOAB.la
-endif
LDADD = libiMesh.la $(top_builddir)/libMOAB.la ${MOAB_CXX_LDFLAGS} ${MOAB_CXX_LIBS}
testc_cbind_DEPENDENCIES = libiMesh.la $(top_builddir)/libMOAB.la
libiMesh_la_SOURCES = \
iMesh_MOAB.cpp
libiMesh_la_include_HEADERS = iMesh.h \
iMesh_extensions.h \
iMesh_extensions_protos.h \
@@ -36,6 +30,15 @@
iBase.h \
iBase_f.h
+if PARALLEL
+ libiMesh_la_SOURCES += iMeshP_MOAB.cpp
+ libiMesh_la_include_HEADERS += iMeshP.h iMeshP_f.h iMeshP_protos.h
+ INCLUDES += -I$(top_srcdir)/parallel
+ check_PROGRAMS += partest
+ partest_SOURCES = partest.cpp
+ partest_DEPENDENCIES = libiMesh.la $(top_builddir)/libMOAB.la
+endif
lib_LTLIBRARIES = libiMesh.la
libiMesh_la_includedir = $(includedir)
Added: MOAB/trunk/tools/iMesh/iMeshP.h
--- MOAB/trunk/tools/iMesh/iMeshP.h (rev 0)
+++ MOAB/trunk/tools/iMesh/iMeshP.h 2008-06-10 20:20:16 UTC (rev 1888)
@@ -0,0 +1,191 @@
+#ifndef IMESHP_H__
+#define IMESHP_H__
+ /** \mainpage The ITAPS Parallel Mesh Interface iMesh
+#ifndef ITAPS
+#define ITAPS
+#endif
+#include "iMesh_extensions.h"
+#include "iMeshP_protos.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+ /**\brief Type used to store a part handle
+ * Type used to store a part handle
+ typedef void* iMeshP_PartHandle;
+ /**\brief Type used to store a partition handle
+ * Type used to store a partition handle
+ typedef void* iMeshP_PartitionHandle;
+ const int iMeshP_INTERNAL = 0;
+ const int iMeshP_BOUNDARY = 1;
+ const int iMeshP_GHOST = 2;
+// Given a partition handle, return the total global number of parts
+// in the partition.
+// COMMUNICATION: None++.
+ void iMeshP_getNumParts(iMesh_Instance instance,
+ const iMeshP_PartitionHandle partition_handle,
+ int *num_global_part,
+ int *err);
+// Map from parts to processes:
+// Given a partition handle and a part handle, return the rank of the
+// process that owns the part.
+// The part_handle may be local or remote.
+ void iMeshP_getRankOfPart(iMesh_Instance instance,
+ /*in*/ const iMeshP_PartHandle part_handle,
+ /*out*/ int *rank,
+ int *err);
+ void iMeshP_getRankOfPartArr(iMesh_Instance instance,
+ /*in*/ const iMeshP_PartHandle *part_handle,
+ /*in*/ const int part_handle_size,
+ /*inout*/ int **rank,
+ /*inout*/ int *rank_allocated,
+ int *err);
+// Map from processes to parts:
+// Given a partition handle and a process rank,
+// return the part handles owned by the process.
+ void iMeshP_getPartsOnRank(iMesh_Instance instance,
+ /*in*/ const int rank,
+ /*inout*/ iMeshP_PartHandle **part_handles,
+ /*inout*/ int *part_handles_allocated,
+ /*out*/ int *part_handles_size,
+ int *err);
+ void iMeshP_getPartsArrOnRank(iMesh_Instance instance,
+ /*in*/ const int *rank,
+ /*in*/ const int rank_size,
+ int *err);
+// Provide global mesh information about a partition.
+// Note that these functions may require communication and, thus,
+// would have to be called by all processes in the partition handle.
+// Given a mesh instance and partition handle, return the
+// total number of entities with given type or topology in the partition.
+// COMMUNICATION: Collective.
+ void iMeshP_getNumOfTypeAll(iMesh_Instance instance,
+ const iBase_EntitySetHandle entity_set_handle,
+ const int entity_type, int *num_type, int *err);
+ void iMeshP_getNumOfTopoAll(iMesh_Instance instance,
+ const int entity_topology, int *num_topo, int *err);
+// Given a partition handle and a part handle, test whether the part
+// handle refers to a local or remote part, and whether it is valid.
+ void iMeshP_testPart(iMesh_Instance instance,
+ /* in */ iMeshP_PartitionHandle partition_handle,
+ /* in */ iMeshP_PartHandle part_handle,
+ /* out */ int *part_status, /* LOCAL, REMOTE, INVALID */
+ int *err);
+// Provide part information about an entity: Given an entity and a
+// partition handle, return the part handle of the part that owns the entity.
+// Return an error code if an entity is not in the partition.
+ void iMeshP_getEntOwnerPart(iMesh_Instance instance,
+ /*in*/ const iMeshP_PartitionHandle partition_handle,
+ /*in*/ iBase_EntityHandle entity_handle,
+ /*out*/ iMeshP_PartHandle *part_handle,
+ int* err);
+ void iMeshP_getEntOwnerPartArr(iMesh_Instance instance,
+ /*in*/ iBase_EntityHandle *entity_handles,
+ /*in*/ int entity_handles_size,
+ int* err);
+// Provide entity categorization within part.
+// Given a partition handle, a part handle, and an entity handle, return a
+// flag indicating whether the entity is owned by the part.
+// If part_handle is remote, an error is returned.
+// COMMUNICATION: None.
+ void iMeshP_isEntOwner(iMesh_Instance instance,
+ /*in*/ const iBase_EntityHandle entity_handle,
+ /*out*/ int* is_owner,
+ int *err);
+ void iMeshP_isEntOwnerArr(iMesh_Instance instance,
+ /*in*/ const iBase_EntityHandle *entity_handles,
+ /*in*/ const int entity_handles_size,
+ /*inout*/ int** is_owner,
+ /*inout*/ int* is_owner_allocated,
+ /*inout*/ int* is_owner_size,
+ int *err);
+// flag indicating whether the entity is strictly internal, on a
+// boundary, or a ghost.
+ void iMeshP_getEntStatus(iMesh_Instance instance,
+ /*out*/ int* par_status, // Values=INTERNAL,BOUNDARY,GHOST
+ int *err);
+ void iMeshP_getEntStatusArr(iMesh_Instance instance,
+ /*inout*/ int** par_status, // Values=INTERNAL,BOUNDARY,GHOST
+ /*inout*/ int* par_status_allocated,
+ /*inout*/ int* par_status_size,
+ int *err);
+// Provide information about copies of entities.
+// All these functions should work on the local process as well as
+// remote processes; entity handles returned are likely but not
+// necessarily remote.
+// Given a partition handle and an entity handle, return the number
+// of copies of the entity in the partition.
+ void iMeshP_getNumCopies(iMesh_Instance instance,
+ /*out*/ int *num_copies_ent,
+ int *err);
+// Given a partition handle and an entity handle, return (remote) entity
+// handles and part handles of all copies of the entity.
+ void iMeshP_getCopies(iMesh_Instance instance,
+ /*inout*/ iBase_EntityHandle **copies_entity_handles,
+ /*inout*/ int *copies_entity_handles_allocated,
+ /*inout*/ int *copies_entity_handles_size,
+ int *err);
+#ifdef __cplusplus
+#endif
+#endif
Added: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp (rev 0)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2008-06-10 20:20:16 UTC (rev 1888)
@@ -0,0 +1,343 @@
+#include "iMeshP.h"
+#include "MBCore.hpp"
+#include "MBRange.hpp"
+#include "MBCN.hpp"
+#include "MeshTopoUtil.hpp"
+#include "FileOptions.hpp"
+#include "MBParallelComm.hpp"
+#include "MBParallelConventions.h"
+#ifdef USE_MPI
+#include "mpi.h"
+#endif
+#define MBI reinterpret_cast<MBInterface*>(instance)
+#define RETURN(a) {iMesh_LAST_ERROR.error_type = a; *err = a;return;}
+#define iMesh_processError(a, b) {sprintf(iMesh_LAST_ERROR.description, "%s", b); iMesh_LAST_ERROR.error_type = a; *err = a;}
+#define CHECK_SIZE(array, allocated, size, type, retval) \
+ if (0 != allocated && NULL != array && allocated < (size)) {\
+ iMesh_processError(iBase_MEMORY_ALLOCATION_FAILED, \
+ "Allocated array not large enough to hold returned contents.");\
+ RETURN(iBase_MEMORY_ALLOCATION_FAILED);\
+ if (allocated == 0 || NULL == array) {\
+ array = (type*)malloc((size)*sizeof(type));\
+ allocated=(size);\
+ if (NULL == array) {iMesh_processError(iBase_MEMORY_ALLOCATION_FAILED, \
+ "Couldn't allocate array.");RETURN(iBase_MEMORY_ALLOCATION_FAILED); }\
+// TAG_CHECK_SIZE is like CHECK_SIZE except it checks for and makes the allocated memory
+// size a multiple of sizeof(void*), and the pointer is assumed to be type char*
+#define TAG_CHECK_SIZE(array, allocated, size) \
+ if (NULL == array || allocated == 0) {\
+ allocated=(size); \
+ if (allocated%sizeof(void*) != 0) allocated=((size)/sizeof(void*)+1)*sizeof(void*);\
+ array = (char*)malloc(allocated); \
+#define HANDLE_ARRAY_PTR(array) reinterpret_cast<MBEntityHandle*>(array)
+#define CONST_HANDLE_ARRAY_PTR(array) reinterpret_cast<const MBEntityHandle*>(array)
+#define TAG_HANDLE(handle) reinterpret_cast<MBTag>(handle)
+#define CONST_TAG_HANDLE(handle) static_cast<const MBTag>(handle)
+#define ENTITY_HANDLE(handle) reinterpret_cast<MBEntityHandle>(handle)
+#define CONST_ENTITY_HANDLE(handle) reinterpret_cast<const MBEntityHandle>(handle)
+#define RANGE_ITERATOR(it) reinterpret_cast<RangeIterator*>(it)
+#define CAST_TO_VOID(ptr) reinterpret_cast<void*>(ptr)
+const iBase_ErrorType iBase_ERROR_MAP[] =
+ iBase_SUCCESS, // MB_SUCCESS = 0,
+ iBase_INVALID_ENTITY_HANDLE, // MB_INDEX_OUT_OF_RANGE,
+ iBase_INVALID_ENTITY_TYPE, // MB_TYPE_OUT_OF_RANGE,
+ iBase_MEMORY_ALLOCATION_FAILED, // MB_MEMORY_ALLOCATION_FAILED,
+ iBase_INVALID_ENTITY_HANDLE, // MB_ENTITY_NOT_FOUND,
+ iBase_NOT_SUPPORTED, // MB_MULTIPLE_ENTITIES_FOUND,
+ iBase_TAG_NOT_FOUND, // MB_TAG_NOT_FOUND,
+ iBase_FILE_NOT_FOUND, // MB_FILE_DOES_NOT_EXIST,
+ iBase_FILE_WRITE_ERROR, // MB_FILE_WRITE_ERROR,
+ iBase_NOT_SUPPORTED, // MB_NOT_IMPLEMENTED,
+ iBase_TAG_ALREADY_EXISTS, // MB_ALREADY_ALLOCATED,
+ iBase_FAILURE // MB_FAILURE};
+extern iBase_Error iMesh_LAST_ERROR;
+#ifdef __cplusplus
+extern "C" {
+#endif
+ int *err)
+ MBParallelComm pc(MBI);
+ unsigned char pstatus;
+ MBErrorCode result = MBI->tag_get_data(pc.pstatus_tag(),
+ CONST_HANDLE_ARRAY_PTR(&entity_handle), 1,
+ &pstatus);
+ if (MB_SUCCESS != result) RETURN(result);
+ *par_status = iMeshP_INTERNAL;
+ if (pstatus & PSTATUS_GHOST) *par_status = iMeshP_GHOST;
+ else if (pstatus & PSTATUS_INTERFACE) *par_status = iMeshP_BOUNDARY;
+ RETURN(iBase_SUCCESS);
+ int *err)
+ std::vector<unsigned char> pstatus(entity_handles_size);
+ CONST_HANDLE_ARRAY_PTR(entity_handles),
+ entity_handles_size,
+ &pstatus[0]);
+ *par_status_size = entity_handles_size;
+ CHECK_SIZE(*par_status, *par_status_allocated, *par_status_size, int, );
+ for (int i = 0; i < entity_handles_size; i++) {
+ if (!pstatus[i]) (*par_status)[i] = iMeshP_INTERNAL;
+ else if (pstatus[i] & PSTATUS_GHOST) (*par_status)[i] = iMeshP_GHOST;
+ else if (pstatus[i] & PSTATUS_INTERFACE) (*par_status)[i] = iMeshP_BOUNDARY;
+ int *err)
+ MBRange part_sets;
+ MBErrorCode result = pc.get_partition_sets(part_sets);
+ if (MB_SUCCESS != result) RETURN(iBase_ERROR_MAP[result]);
+ *part_handles_size = part_sets.size();
+ CHECK_SIZE(*part_handles, *part_handles_allocated, *part_handles_size, iMeshP_PartHandle,);
+ int i;
+ for (i = 0, rit = part_sets.begin(); rit != part_sets.end(); rit++, i++)
+ (*part_handles)[i] = CAST_TO_VOID(*rit);
+ int *err)
+ if (rank[0] != MBI->proc_rank() || rank_size > 1) {
+ RETURN(iBase_ERROR_MAP[MB_NOT_IMPLEMENTED]);
+ iMeshP_getPartsOnRank(instance, partition_handle, rank[0],
+ part_handles, part_handles_allocated, part_handles_size,
+ err);
+ int *err)
+ &pstatus);
+ if (pstatus & PSTATUS_NOT_OWNED) *is_owner = 1;
+ else *is_owner = 0;
+ int *err)
+ &pstatus[0]);
+ *is_owner_size = entity_handles_size;
+ CHECK_SIZE(*is_owner, *is_owner_allocated, *is_owner_size, int, );
+ if (pstatus[i] & PSTATUS_NOT_OWNED) (*is_owner)[i] = 1;
+ else (*is_owner)[i] = 0;
+ int *err)
+ int shared_proc;
+ MBErrorCode result = MBI->tag_get_data(pc.sharedp_tag(),
+ &shared_proc);
+ if (MB_SUCCESS != result) {
+ RETURN(iBase_ERROR_MAP[result]);
+ if (-1 != shared_proc) {
+ *num_copies_ent = 1;
+ static int tag_size = 0;
+ if (!tag_size) {
+ result = MBI->tag_get_size(pc.sharedps_tag(), tag_size);
+ static std::vector<int> shared_procs(tag_size);
+ result = MBI->tag_get_data(pc.sharedps_tag(),
+ &shared_procs[0]);
+ *num_copies_ent = std::find(shared_procs.begin(), shared_procs.end(), -1) - shared_procs.begin();
+ int *err)
+ MBEntityHandle shared_handle;
+ MBErrorCode result = MBI->tag_get_data(pc.sharedh_tag(),
+ &shared_handle);
+ if (0 != shared_handle) {
+ *part_handles_size = 1;
+ *copies_entity_handles_size = 1;
+ iMeshP_PartHandle, );
+ CHECK_SIZE(*copies_entity_handles, *copies_entity_handles_allocated,
+ *copies_entity_handles_size, iBase_EntityHandle, );
+ (*part_handles)[0] = 0;
+ (*copies_entity_handles)[0] = CAST_TO_VOID(shared_handle);
+ if (!tag_size) {
+ result = MBI->tag_get_size(pc.sharedhs_tag(), tag_size);
+ static std::vector<MBEntityHandle> shared_handles(tag_size);
+ result = MBI->tag_get_data(pc.sharedhs_tag(),
+ &shared_handles[0]);
+ int index = std::find(shared_handles.begin(), shared_handles.end(), -1) - shared_handles.begin();
+ *part_handles_size = index+1;
+ *copies_entity_handles_size = index+1;
+ *copies_entity_handles_size, iMeshP_PartHandle, );
+ std::copy(&shared_handles[0], &shared_handles[index],
+ HANDLE_ARRAY_PTR(*copies_entity_handles));
+ std::fill(*part_handles, *part_handles+index, CAST_TO_VOID(0));
+#ifdef __cplusplus
+} // extern "C"
+#endif
Added: MOAB/trunk/tools/iMesh/iMeshP_f.h
--- MOAB/trunk/tools/iMesh/iMeshP_f.h (rev 0)
+++ MOAB/trunk/tools/iMesh/iMeshP_f.h 2008-06-10 20:20:16 UTC (rev 1888)
@@ -0,0 +1,25 @@
+#ifndef IMESHP_F_H
+#define IMESHP_F_H
+#define iMeshP_PartitionHandle integer
+#define iMeshP_PartHandle integer
+#endif
+#include "iMesh_f.h"
+ integer iMeshP_LOCAL
+ integer iMeshP_REMOTE
+ integer iMeshP_INVALID
+ integer iMeshP_INTERNAL
+ integer iMeshP_BOUNDARY
+ integer iMeshP_GHOST
+ parameter (iMeshP_LOCAL = 0)
+ parameter (iMeshP_REMOTE = 1)
+ parameter (iMeshP_INVALID = 2)
+ parameter (iMeshP_INTERNAL = 0)
+ parameter (iMeshP_BOUNDARY = 1)
+ parameter (iMeshP_GHOST = 2)
Added: MOAB/trunk/tools/iMesh/iMeshP_protos.h
--- MOAB/trunk/tools/iMesh/iMeshP_protos.h (rev 0)
+++ MOAB/trunk/tools/iMesh/iMeshP_protos.h 2008-06-10 20:20:16 UTC (rev 1888)
@@ -0,0 +1,25 @@
+#include "MBCN_FCDefs.h"
+#ifdef FC_FUNC_
+#define iMesh_getErrorType FC_FUNC_(imesh_geterrortype, IMESH_GETERRORTYPE)
+#define iMeshP_getNumParts FC_FUNC_(imeshp_getnumparts, IMESHP_GETNUMPARTS)
+#define iMeshP_getRankOfPart FC_FUNC_(imeshp_getrankofpart, IMESHP_GETRANKOFPART)
+#define iMeshP_getRankOfPartArr FC_FUNC_(imeshp_getrankofpartarr, IMESHP_GETRANKOFPARTARR)
+#define iMeshP_getPartsOnRank FC_FUNC_(imeshp_getpartsonrank, IMESHP_GETPARTSONRANK)
+#define iMeshP_getPartsArrOnRank FC_FUNC_(imeshp_getpartsarronrank, IMESHP_GETPARTSARRONRANK)
+#define iMeshP_getNumOfTypeAll FC_FUNC_(imeshp_getnumoftypeall, IMESHP_GETNUMOFTYPEALL)
+#define iMeshP_getNumOfTopoAll FC_FUNC_(imeshp_getnumoftopoall, IMESHP_GETNUMOFTOPOALL)
+#define iMeshP_testPart FC_FUNC_(imeshp_testpart, IMESHP_TESTPART)
+#define iMeshP_getEntOwnerPart FC_FUNC_(imeshp_getentownerpart, IMESHP_GETENTOWNERPART)
+#define iMeshP_getEntOwnerPartArr FC_FUNC_(imeshp_getentownerpartarr, IMESHP_GETENTOWNERPARTARR)
+#define iMeshP_isEntOwner FC_FUNC_(imeshp_isentowner, IMESHP_ISENTOWNER)
+#define iMeshP_isEntOwnerArr FC_FUNC_(imeshp_isentownerarr, IMESHP_ISENTOWNERARR)
+#define iMeshP_getEntStatus FC_FUNC_(imeshp_getentstatus, IMESHP_GETENTSTATUS)
+#define iMeshP_getEntStatusArr FC_FUNC_(imeshp_getentstatusarr, IMESHP_GETENTSTATUSARR)
+#define iMeshP_getNumCopies FC_FUNC_(imeshp_getnumcopies, IMESHP_GETNUMCOPIES)
+#define iMeshP_getCopies FC_FUNC_(imeshp_getcopies, IMESHP_GETCOPIES)
+#endif
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-06-10 19:34:51 UTC (rev 1887)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-06-10 20:20:16 UTC (rev 1888)
@@ -195,2508 +195,2425 @@
extern "C" {
#endif
-void eatwhitespace(std::string &this_string);
+ void eatwhitespace(std::string &this_string);
-MBErrorCode iMesh_tag_set_vertices(iMesh_Instance instance,
- MBEntityHandle in_set,
- const int req_dimension,
- const MBEntityType req_type,
- MBTag &tag, MBRange &req_entities,
- int &num_verts, int *err);
+ MBErrorCode iMesh_tag_set_vertices(iMesh_Instance instance,
+ MBEntityHandle in_set,
+ const int req_dimension,
+ const MBEntityType req_type,
+ MBTag &tag, MBRange &req_entities,
+ int &num_verts, int *err);
-iBase_Error iMesh_LAST_ERROR;
+ iBase_Error iMesh_LAST_ERROR;
-void iMesh_getErrorType(iMesh_Instance instance,
- int *error_type, int *err)
- *error_type = iMesh_LAST_ERROR.error_type;
- RETURN(iBase_SUCCESS);
+ void iMesh_getErrorType(iMesh_Instance instance,
+ int *error_type, int *err)
+ *error_type = iMesh_LAST_ERROR.error_type;
-void iMesh_getDescription(iMesh_Instance instance,
- char *descr, int *err, int descr_len)
- unsigned int len = MIN(strlen(iMesh_LAST_ERROR.description), ((unsigned int) descr_len));
- strncpy(descr, iMesh_LAST_ERROR.description, len);
- descr[len] = '\0';
+ void iMesh_getDescription(iMesh_Instance instance,
+ char *descr, int *err, int descr_len)
+ unsigned int len = MIN(strlen(iMesh_LAST_ERROR.description), ((unsigned int) descr_len));
+ strncpy(descr, iMesh_LAST_ERROR.description, len);
+ descr[len] = '\0';
-void iMesh_setError(iMesh_Instance instance,
- int err_type, char *descr, int *err, int descr_len)
- iMesh_LAST_ERROR.error_type = static_cast<iBase_ErrorType>(err_type);
- strncpy(iMesh_LAST_ERROR.description, descr, descr_len);
+ void iMesh_setError(iMesh_Instance instance,
+ int err_type, char *descr, int *err, int descr_len)
+ iMesh_LAST_ERROR.error_type = static_cast<iBase_ErrorType>(err_type);
+ strncpy(iMesh_LAST_ERROR.description, descr, descr_len);
-void iMesh_getError(iMesh_Instance instance,
- int *err_type, char *descr, int *err, int descr_len)
- *err_type = iMesh_LAST_ERROR.error_type;
- MIN(strlen(iMesh_LAST_ERROR.description), (unsigned int)descr_len));
+ void iMesh_getError(iMesh_Instance instance,
+ int *err_type, char *descr, int *err, int descr_len)
+ *err_type = iMesh_LAST_ERROR.error_type;
+ MIN(strlen(iMesh_LAST_ERROR.description), (unsigned int)descr_len));
-void iMesh_newMesh(const char *options,
- iMesh_Instance *instance, int *err, int options_len)
- std::string tmp_options(options, options_len);
- FileOptions opts(tmp_options.c_str());
+ void iMesh_newMesh(const char *options,
+ iMesh_Instance *instance, int *err, int options_len)
+ std::string tmp_options(options, options_len);
+ FileOptions opts(tmp_options.c_str());
- MBInterface* core;
+ MBInterface* core;
- MBErrorCode result = opts.get_null_option("PARALLEL");
- if (MB_SUCCESS == result) {
+ MBErrorCode result = opts.get_null_option("PARALLEL");
+ if (MB_SUCCESS == result) {
#ifdef USE_MPI
- int rank, size;
- MPI_Comm_rank(MPI_COMM_WORLD, &rank);
- MPI_Comm_size(MPI_COMM_WORLD, &size);
- core = new MBiMesh(rank, size);
+ int rank, size;
+ MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+ MPI_Comm_size(MPI_COMM_WORLD, &size);
+ core = new MBiMesh(rank, size);
#else
- //mError->set_last_error( "PARALLEL option not valid, this instance"
- // " compiled for serial execution.\n" );
- *err = MB_NOT_IMPLEMENTED;
- return;
+ //mError->set_last_error( "PARALLEL option not valid, this instance"
+ // " compiled for serial execution.\n" );
+ *err = MB_NOT_IMPLEMENTED;
+ return;
#endif
- else core = new MBiMesh();
+ else core = new MBiMesh();
- *instance = reinterpret_cast<iMesh_Instance>(core);
- if (0 == *instance) {
- iMesh_processError(iBase_FAILURE, "Failed to instantiate mesh instance.");
- RETURN(iBase_FAILURE);
+ *instance = reinterpret_cast<iMesh_Instance>(core);
+ if (0 == *instance) {
+ iMesh_processError(iBase_FAILURE, "Failed to instantiate mesh instance.");
+ RETURN(iBase_FAILURE);
- if (0 != options_len) {
- iMesh_processError(iBase_NOT_SUPPORTED, "No options for iMesh factory have been implemented.");
- RETURN(iBase_NOT_SUPPORTED);
+ if (0 != options_len) {
+ iMesh_processError(iBase_NOT_SUPPORTED, "No options for iMesh factory have been implemented.");
+ RETURN(iBase_NOT_SUPPORTED);
-void iMesh_dtor(iMesh_Instance instance, int *err)
- delete MBI;
+ void iMesh_dtor(iMesh_Instance instance, int *err)
+ delete MBI;
-void iMesh_load(iMesh_Instance instance,
- const iBase_EntityHandle handle,
- const char *name, const char *options,
- int *err, int name_len, int options_len)
- // get filename, option & null-terminate
- std::string tmp_filename(name, name_len),
- tmp_options(options, options_len);
+ void iMesh_load(iMesh_Instance instance,
+ const iBase_EntityHandle handle,
+ const char *name, const char *options,
+ int *err, int name_len, int options_len)
+ // get filename, option & null-terminate
+ std::string tmp_filename(name, name_len),
+ tmp_options(options, options_len);
- eatwhitespace(tmp_filename);
- eatwhitespace(tmp_options);
+ eatwhitespace(tmp_filename);
+ eatwhitespace(tmp_options);
- MBEntityHandle file_set;
+ MBEntityHandle file_set;
- MBErrorCode result = MBI->load_file(tmp_filename.c_str(), file_set,
- tmp_options.c_str());
+ MBErrorCode result = MBI->load_file(tmp_filename.c_str(), file_set,
+ tmp_options.c_str());
- if (MB_SUCCESS != result) {
- std::string msg("iMesh_load:ERROR loading a mesh, with error type: ");
- msg += MBI->get_error_string(result);
- iMesh_processError(iBase_ERROR_MAP[result], msg.c_str());
+ std::string msg("iMesh_load:ERROR loading a mesh, with error type: ");
+ msg += MBI->get_error_string(result);
+ iMesh_processError(iBase_ERROR_MAP[result], msg.c_str());
- RETURN(iBase_ERROR_MAP[result]);
+ void iMesh_save(iMesh_Instance instance,
+ int *err, const int name_len, int options_len)
+ // get filename & attempt to NULL-terminate
+ std::string tmp_filename( name, name_len ), tmp_options(options, options_len);
-void iMesh_save(iMesh_Instance instance,
- int *err, const int name_len, int options_len)
- // get filename & attempt to NULL-terminate
- std::string tmp_filename( name, name_len ), tmp_options(options, options_len);
- MBErrorCode result = MBI->write_file(tmp_filename.c_str(), NULL, tmp_options.c_str(),
- CONST_HANDLE_ARRAY_PTR(&handle), 1);
+ MBErrorCode result = MBI->write_file(tmp_filename.c_str(), NULL, tmp_options.c_str(),
+ CONST_HANDLE_ARRAY_PTR(&handle), 1);
- std::string msg("iMesh_save:ERROR saving a mesh, with error type: ");
+ std::string msg("iMesh_save:ERROR saving a mesh, with error type: ");
-void iMesh_getRootSet(iMesh_Instance instance,
- iBase_EntitySetHandle *root_set, int *err)
- *root_set = 0;
- //return CAST_TO_VOID(MBI->get_root_set());
+ void iMesh_getRootSet(iMesh_Instance instance,
+ iBase_EntitySetHandle *root_set, int *err)
+ *root_set = 0;
+ //return CAST_TO_VOID(MBI->get_root_set());
-void iMesh_getGeometricDimension(iMesh_Instance instance,
- int *geom_dim, int *err)
- MBI->get_dimension(*geom_dim);
+ void iMesh_getGeometricDimension(iMesh_Instance instance,
+ int *geom_dim, int *err)
+ MBI->get_dimension(*geom_dim);
-void iMesh_getDfltStorage(iMesh_Instance instance,
- int *order, int *err)
- *order = iBase_BLOCKED;
+ void iMesh_getDfltStorage(iMesh_Instance instance,
+ int *order, int *err)
+ *order = iBase_BLOCKED;
-void iMesh_getAdjTable (iMesh_Instance instance,
- int** adjacency_table,
- /*inout*/ int* adjacency_table_allocated,
- /*out*/ int* adjacency_table_size, int *err)
- *adjacency_table_allocated = 0;
- *adjacency_table_size = 0;
- *adjacency_table = NULL;
- RETURN(iBase_ERROR_MAP[MB_SUCCESS]);
+ void iMesh_getAdjTable (iMesh_Instance instance,
+ int** adjacency_table,
+ /*inout*/ int* adjacency_table_allocated,
+ /*out*/ int* adjacency_table_size, int *err)
+ *adjacency_table_allocated = 0;
+ *adjacency_table_size = 0;
+ *adjacency_table = NULL;
+ RETURN(iBase_ERROR_MAP[MB_SUCCESS]);
-void iMesh_getNumOfType(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set_handle,
- /*in*/ const int entity_type,
- int *num_type, int *err)
- iMesh_getNumOfTypeRec(instance, entity_set_handle, entity_type, false,
- num_type, err);
+ void iMesh_getNumOfType(iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle entity_set_handle,
+ /*in*/ const int entity_type,
+ int *num_type, int *err)
+ iMesh_getNumOfTypeRec(instance, entity_set_handle, entity_type, false,
+ num_type, err);
-void iMesh_getNumOfTopo(iMesh_Instance instance,
- /*in*/ const int entity_topology,
- int *num_topo, int *err)
- iMesh_getNumOfTopoRec(instance, entity_set_handle, entity_topology,
- false, num_topo, err);
-void iMesh_areEHValid( iMesh_Instance instance,
- int doReset,
- int* areHandlesInvarient,
- int* err )
- MBiMesh* mbi = dynamic_cast<MBiMesh*>(MBI);
- if (!mbi) {
+ void iMesh_getNumOfTopo(iMesh_Instance instance,
+ /*in*/ const int entity_topology,
+ int *num_topo, int *err)
+ iMesh_getNumOfTopoRec(instance, entity_set_handle, entity_topology,
+ false, num_topo, err);
+ void iMesh_areEHValid( iMesh_Instance instance,
+ int doReset,
+ int* areHandlesInvarient,
+ int* err )
+ MBiMesh* mbi = dynamic_cast<MBiMesh*>(MBI);
+ if (!mbi) {
- *areHandlesInvarient = !mbi->have_deleted_ents( !!doReset );
+ *areHandlesInvarient = !mbi->have_deleted_ents( !!doReset );
-void iMesh_getAllVtxCoords (iMesh_Instance instance,
- /*inout*/ double** coordinates,
- /*inout*/ int* coordinates_allocated,
- /*out*/ int* coordinates_size,
- /*inout*/ int** in_entity_set,
- /*inout*/ int* in_entity_set_allocated,
- /*out*/ int* in_entity_set_size,
- /*inout*/ int* storage_order, int *err)
- MBEntityHandle in_set = ENTITY_HANDLE(entity_set_handle);
+ void iMesh_getAllVtxCoords (iMesh_Instance instance,
+ /*inout*/ double** coordinates,
+ /*inout*/ int* coordinates_allocated,
+ /*out*/ int* coordinates_size,
+ /*inout*/ int** in_entity_set,
+ /*inout*/ int* in_entity_set_allocated,
+ /*out*/ int* in_entity_set_size,
+ /*inout*/ int* storage_order, int *err)
+ MBEntityHandle in_set = ENTITY_HANDLE(entity_set_handle);
- // get all the entities then vertices
- MBRange entities, vertices;
- MBErrorCode result = MBI->get_entities_by_handle(in_set, entities, false);
- std::string msg("iMesh_entitysetGetVertexCoordinates: getting entities didn't succeed, "
- "with error type: ");
+ // get all the entities then vertices
+ MBRange entities, vertices;
+ MBErrorCode result = MBI->get_entities_by_handle(in_set, entities, false);
+ std::string msg("iMesh_entitysetGetVertexCoordinates: getting entities didn't succeed, "
+ "with error type: ");
- // remove any sets
- entities.erase(entities.lower_bound(MBENTITYSET),
- entities.upper_bound(MBENTITYSET));
+ // remove any sets
+ entities.erase(entities.lower_bound(MBENTITYSET),
+ entities.upper_bound(MBENTITYSET));
- // get all the vertices
- result = MBI->get_adjacencies(entities, 0, false, vertices,
- MBInterface::UNION);
- std::string msg("iMesh_entitysetGetVertexCoordinates: getting vertices didn't succeed, "
+ // get all the vertices
+ result = MBI->get_adjacencies(entities, 0, false, vertices,
+ std::string msg("iMesh_entitysetGetVertexCoordinates: getting vertices didn't succeed, "
- // now get all the coordinates
- CHECK_SIZE(*coordinates, *coordinates_allocated,
- (int)(3*vertices.size()), double, iBase_MEMORY_ALLOCATION_FAILED);
- CHECK_SIZE(*in_entity_set, *in_entity_set_allocated,
- (int)vertices.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
+ // now get all the coordinates
+ CHECK_SIZE(*coordinates, *coordinates_allocated,
+ (int)(3*vertices.size()), double, iBase_MEMORY_ALLOCATION_FAILED);
+ CHECK_SIZE(*in_entity_set, *in_entity_set_allocated,
+ (int)vertices.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
- // coords will come back interleaved by default
- MBRange::iterator vit;
- if (*storage_order == iBase_INTERLEAVED || *storage_order == iBase_UNDETERMINED) {
- result = MBI->get_coords(vertices, *coordinates);
- *storage_order = iBase_INTERLEAVED;
+ // coords will come back interleaved by default
+ MBRange::iterator vit;
+ if (*storage_order == iBase_INTERLEAVED || *storage_order == iBase_UNDETERMINED) {
+ result = MBI->get_coords(vertices, *coordinates);
+ *storage_order = iBase_INTERLEAVED;
- else {
- double *dum_coords = new double[3*vertices.size()];
- result = MBI->get_coords(vertices, dum_coords);
- unsigned int offset = vertices.size();
- for (unsigned int i= 0; i < offset; i++) {
- (*coordinates)[i]= dum_coords[3*i];
- (*coordinates)[offset+i] = dum_coords[3*i+1];
- (*coordinates)[2*offset+i] = dum_coords[3*i+2];
+ else {
+ double *dum_coords = new double[3*vertices.size()];
+ result = MBI->get_coords(vertices, dum_coords);
+ unsigned int offset = vertices.size();
+ for (unsigned int i= 0; i < offset; i++) {
+ (*coordinates)[i]= dum_coords[3*i];
+ (*coordinates)[offset+i] = dum_coords[3*i+1];
+ (*coordinates)[2*offset+i] = dum_coords[3*i+2];
+ delete [] dum_coords;
- delete [] dum_coords;
- std::string msg("iMesh_entitysetGetVertexCoordinates: problem getting vertex coords, "
+ std::string msg("iMesh_entitysetGetVertexCoordinates: problem getting vertex coords, "
- // now fill the in_entity_set array
- MBRange::iterator endr = entities.end();
- int i;
- for (i = 0, vit = vertices.begin(); vit != vertices.end(); vit++, i++) {
- if (0 == in_set || entities.find(*vit) != endr)
- (*in_entity_set)[i] = 1;
- else
- (*in_entity_set)[i] = 0;
+ // now fill the in_entity_set array
+ MBRange::iterator endr = entities.end();
+ int i;
+ for (i = 0, vit = vertices.begin(); vit != vertices.end(); vit++, i++) {
+ if (0 == in_set || entities.find(*vit) != endr)
+ (*in_entity_set)[i] = 1;
+ else
+ (*in_entity_set)[i] = 0;
- *coordinates_size = 3*vertices.size();
- *in_entity_set_size = vertices.size();
+ *coordinates_size = 3*vertices.size();
+ *in_entity_set_size = vertices.size();
-void iMesh_getVtxCoordIndex (iMesh_Instance instance,
- /*in*/ const int requested_entity_type,
- /*in*/ const int requested_entity_topology,
- /*in*/ const int entity_adjacency_type,
- /*inout*/ int** offset,
- /*inout*/ int* offset_allocated,
- /*out*/ int* offset_size,
- /*inout*/ int** index,
- /*inout*/ int* index_allocated,
- /*out*/ int* index_size,
- /*inout*/ int** entity_topologies,
- /*inout*/ int* entity_topologies_allocated,
- /*out*/ int* entity_topologies_size, int *err)
- MBEntityType req_type = mb_topology_table[requested_entity_topology];
- int req_dimension = (req_type == MBMAXTYPE ? (int) requested_entity_type : -1);
+ void iMesh_getVtxCoordIndex (iMesh_Instance instance,
+ /*in*/ const int requested_entity_type,
+ /*in*/ const int requested_entity_topology,
+ /*in*/ const int entity_adjacency_type,
+ /*inout*/ int** offset,
+ /*inout*/ int* offset_allocated,
+ /*out*/ int* offset_size,
+ /*inout*/ int** index,
+ /*inout*/ int* index_allocated,
+ /*out*/ int* index_size,
+ /*inout*/ int** entity_topologies,
+ /*inout*/ int* entity_topologies_allocated,
+ /*out*/ int* entity_topologies_size, int *err)
+ MBEntityType req_type = mb_topology_table[requested_entity_topology];
+ int req_dimension = (req_type == MBMAXTYPE ? (int) requested_entity_type : -1);
- MBTag pos_tag = 0;
- MBRange req_entities;
- int num_verts;
- iMesh_tag_set_vertices(instance, in_set,
- req_dimension, req_type,
- pos_tag, req_entities, num_verts, err);
- RETURN(iMesh_LAST_ERROR.error_type);
+ MBTag pos_tag = 0;
+ MBRange req_entities;
+ int num_verts;
+ iMesh_tag_set_vertices(instance, in_set,
+ req_dimension, req_type,
+ pos_tag, req_entities, num_verts, err);
+ RETURN(iMesh_LAST_ERROR.error_type);
- if (0 == pos_tag || req_entities.empty()) {
- *offset_size = 0;
- *index_size = 0;
- *entity_topologies_size = 0;
+ if (0 == pos_tag || req_entities.empty()) {
+ *offset_size = 0;
+ *index_size = 0;
+ *entity_topologies_size = 0;
- // now get the connectivity; get it all in one vector before setting indices, so that
- // we can check size of or allocate index vector; but, we can check and allocate
- // count vector
- const MBEntityHandle *tmp_connect;
- int num_connect;
- std::vector<MBEntityHandle> connect;
- CHECK_SIZE(*offset, *offset_allocated,
- (int)req_entities.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
- CHECK_SIZE(*entity_topologies, *entity_topologies_allocated,
+ // now get the connectivity; get it all in one vector before setting indices, so that
+ // we can check size of or allocate index vector; but, we can check and allocate
+ // count vector
+ const MBEntityHandle *tmp_connect;
+ int num_connect;
+ std::vector<MBEntityHandle> connect;
+ CHECK_SIZE(*offset, *offset_allocated,
+ (int)req_entities.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
+ CHECK_SIZE(*entity_topologies, *entity_topologies_allocated,
- MBRange::iterator ent_it;
- int curr_offset = 0;
- int i;
- for (ent_it = req_entities.begin(), i = 0; ent_it != req_entities.end();
- ent_it++, i++) {
- MBErrorCode result = MBI->get_connectivity(*ent_it, tmp_connect, num_connect, true);
+ MBRange::iterator ent_it;
+ int curr_offset = 0;
+ int i;
+ for (ent_it = req_entities.begin(), i = 0; ent_it != req_entities.end();
+ ent_it++, i++) {
+ MBErrorCode result = MBI->get_connectivity(*ent_it, tmp_connect, num_connect, true);
+ std::string msg("iMesh_getVtxCoordIndex: couldn't get connectivity, with error type: ");
+ std::copy(tmp_connect, tmp_connect+num_connect, std::back_inserter(connect));
+ MBEntityType this_type = MBI->type_from_handle(*ent_it);
+ (*entity_topologies)[i] = tstt_topology_table[this_type];
+ (*offset)[i] = curr_offset;
+ curr_offset += num_connect;
+ // now check size of, allocate, and assign index vector
+ CHECK_SIZE(*index, *index_allocated,
+ (int)connect.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
+ // get the tags all at once, it's more efficient
+ result = MBI->tag_get_data(pos_tag, &connect[0],
+ connect.size(), *index);
- std::string msg("iMesh_getVtxCoordIndex: couldn't get connectivity, with error type: ");
+ std::string msg("iMesh_getVtxCoordIndex: couldn't get index tag, with error type: ");
- std::copy(tmp_connect, tmp_connect+num_connect, std::back_inserter(connect));
- MBEntityType this_type = MBI->type_from_handle(*ent_it);
- (*entity_topologies)[i] = tstt_topology_table[this_type];
- (*offset)[i] = curr_offset;
- curr_offset += num_connect;
- // now check size of, allocate, and assign index vector
- CHECK_SIZE(*index, *index_allocated,
- (int)connect.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
- // get the tags all at once, it's more efficient
- result = MBI->tag_get_data(pos_tag, &connect[0],
- connect.size(), *index);
- std::string msg("iMesh_getVtxCoordIndex: couldn't get index tag, with error type: ");
- // don't need the tag any more
- result = MBI->tag_delete(pos_tag);
- std::string msg("iMesh_getVtxCoordIndex: error deleting tag, with error type: ");
+ // don't need the tag any more
+ result = MBI->tag_delete(pos_tag);
+ std::string msg("iMesh_getVtxCoordIndex: error deleting tag, with error type: ");
- *offset_size = req_entities.size();
- *entity_topologies_size = req_entities.size();
- *index_size = connect.size();
+ *offset_size = req_entities.size();
+ *entity_topologies_size = req_entities.size();
+ *index_size = connect.size();
-void iMesh_getEntities(iMesh_Instance instance,
- /*inout*/ iBase_EntityHandle** entity_handles,
- /*inout*/ int* entity_handles_allocated,
- /*out*/ int* entity_handles_size,
- int *err)
- iMesh_getEntitiesRec(instance, entity_set_handle, entity_type,
- entity_topology, false,
- entity_handles, entity_handles_allocated, entity_handles_size,
- err);
+ void iMesh_getEntities(iMesh_Instance instance,
+ /*inout*/ iBase_EntityHandle** entity_handles,
+ /*inout*/ int* entity_handles_allocated,
+ /*out*/ int* entity_handles_size,
+ int *err)
+ iMesh_getEntitiesRec(instance, entity_set_handle, entity_type,
+ entity_topology, false,
+ entity_handles, entity_handles_allocated, entity_handles_size,
+ err);
-void iMesh_getVtxArrCoords (iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle* vertex_handles,
- /*in*/ const int vertex_handles_size,
- /*inout*/ double** coords,
- /*inout*/ int* coords_allocated,
- /*out*/ int* coords_size, int *err)
+ void iMesh_getVtxArrCoords (iMesh_Instance instance,
+ /*in*/ const iBase_EntityHandle* vertex_handles,
+ /*in*/ const int vertex_handles_size,
+ /*inout*/ double** coords,
+ /*inout*/ int* coords_allocated,
+ /*out*/ int* coords_size, int *err)
- // make sure we can hold them all
- CHECK_SIZE(*coords, *coords_allocated, 3*vertex_handles_size, double, iBase_MEMORY_ALLOCATION_FAILED);
+ // make sure we can hold them all
+ CHECK_SIZE(*coords, *coords_allocated, 3*vertex_handles_size, double, iBase_MEMORY_ALLOCATION_FAILED);
- MBErrorCode result;
- result = MBI->get_coords(CONST_HANDLE_ARRAY_PTR(vertex_handles),
- vertex_handles_size, *coords);
+ result = MBI->get_coords(CONST_HANDLE_ARRAY_PTR(vertex_handles),
+ vertex_handles_size, *coords);
- else {
- std::vector<double> dum_coords(3*vertex_handles_size);
- &dum_coords[0]);
- int i;
- double *x = *coords;
- double *y = *coords+vertex_handles_size;
- double *z = *coords+2*vertex_handles_size;
- std::vector<double>::const_iterator c_iter = dum_coords.begin();
- for (i = 0; i < vertex_handles_size; i++) {
- *x = *c_iter; ++x; ++c_iter;
- *y = *c_iter; ++y; ++c_iter;
- *z = *c_iter; ++z; ++c_iter;
+ else {
+ std::vector<double> dum_coords(3*vertex_handles_size);
+ &dum_coords[0]);
+ int i;
+ double *x = *coords;
+ double *y = *coords+vertex_handles_size;
+ double *z = *coords+2*vertex_handles_size;
+ std::vector<double>::const_iterator c_iter = dum_coords.begin();
+ for (i = 0; i < vertex_handles_size; i++) {
+ *x = *c_iter; ++x; ++c_iter;
+ *y = *c_iter; ++y; ++c_iter;
+ *z = *c_iter; ++z; ++c_iter;
- std::string msg("iMesh_getVtxArrCoords: problem getting vertex coords, with error type: ");
+ std::string msg("iMesh_getVtxArrCoords: problem getting vertex coords, with error type: ");
- *coords_size = 3*vertex_handles_size;
+ *coords_size = 3*vertex_handles_size;
-void iMesh_getAdjEntities(iMesh_Instance instance,
- /*in*/ const int entity_type_requestor,
- /*in*/ const int entity_topology_requestor,
- /*in*/ const int entity_type_requested,
- /*inout*/ iBase_EntityHandle** adj_entity_handles,
- /*inout*/ int* adj_entity_handles_allocated,
- /*out*/ int* adj_entity_handles_size,
- /*out*/ int* in_entity_set_size, int *err)
- MBRange entities;
- MBEntityType requestor_type = mb_topology_table[entity_topology_requestor];
+ void iMesh_getAdjEntities(iMesh_Instance instance,
+ /*in*/ const int entity_type_requestor,
+ /*in*/ const int entity_topology_requestor,
+ /*in*/ const int entity_type_requested,
+ /*inout*/ iBase_EntityHandle** adj_entity_handles,
+ /*inout*/ int* adj_entity_handles_allocated,
+ /*out*/ int* adj_entity_handles_size,
+ /*out*/ int* in_entity_set_size, int *err)
+ MBRange entities;
+ MBEntityType requestor_type = mb_topology_table[entity_topology_requestor];
- if (entity_type_requestor == iBase_ALL_TYPES &&
- entity_topology_requestor == iMesh_ALL_TOPOLOGIES )
- result = MBI->get_entities_by_handle( in_set, entities );
- else if (requestor_type == MBMAXTYPE)
- result = MBI->get_entities_by_dimension
- (in_set, entity_type_requestor, entities);
- else if (entity_topology_requestor == iMesh_SEPTAHEDRON)
- result = MB_SUCCESS; // MOAB doesn't do septahedrons, so there are never any of them.
- else
- result = MBI->get_entities_by_type(in_set, requestor_type, entities);
+ if (entity_type_requestor == iBase_ALL_TYPES &&
+ entity_topology_requestor == iMesh_ALL_TOPOLOGIES )
+ result = MBI->get_entities_by_handle( in_set, entities );
+ else if (requestor_type == MBMAXTYPE)
+ result = MBI->get_entities_by_dimension
+ (in_set, entity_type_requestor, entities);
+ else if (entity_topology_requestor == iMesh_SEPTAHEDRON)
+ result = MB_SUCCESS; // MOAB doesn't do septahedrons, so there are never any of them.
+ else
+ result = MBI->get_entities_by_type(in_set, requestor_type, entities);
- if (result != MB_SUCCESS) {
- std::string msg("iMesh_getAdjEntities: ERROR getting requestor entities in entityset, "
+ if (result != MB_SUCCESS) {
+ std::string msg("iMesh_getAdjEntities: ERROR getting requestor entities in entityset, "
- int num_entities = entities.size();
+ int num_entities = entities.size();
- if (num_entities == 0)
- *adj_entity_handles_size = *offset_size = *in_entity_set_size = 0;
+ if (num_entities == 0)
+ *adj_entity_handles_size = *offset_size = *in_entity_set_size = 0;
- // first, count the number of adjacent entities we'll have
- int num_sub = 0;
- int to_dim = entity_type_requested;
- if (to_dim == 0) {
- const MBEntityHandle *connect;
- int num_connect;
- for (MBRange::iterator rit = entities.begin(); rit != entities.end(); rit++) {
- result = MBI->get_connectivity(*rit, connect, num_connect);
- if (MB_SUCCESS != result) RETURN(iBase_ERROR_MAP[result]);
- num_sub += num_connect;
+ // first, count the number of adjacent entities we'll have
+ int num_sub = 0;
+ int to_dim = entity_type_requested;
+ if (to_dim == 0) {
+ const MBEntityHandle *connect;
+ int num_connect;
+ for (MBRange::iterator rit = entities.begin(); rit != entities.end(); rit++) {
+ result = MBI->get_connectivity(*rit, connect, num_connect);
+ num_sub += num_connect;
- else {
- MBRange tmp_adjs;
- result = MBI->get_adjacencies(&(*rit), 1, to_dim, false, tmp_adjs);
- num_sub += tmp_adjs.size();
- tmp_adjs.clear();
+ else {
+ MBRange tmp_adjs;
+ result = MBI->get_adjacencies(&(*rit), 1, to_dim, false, tmp_adjs);
+ num_sub += tmp_adjs.size();
+ tmp_adjs.clear();
- // allocate enough space for those adjacent entities
- CHECK_SIZE(*adj_entity_handles, *adj_entity_handles_allocated,
- num_sub, iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ // allocate enough space for those adjacent entities
+ CHECK_SIZE(*adj_entity_handles, *adj_entity_handles_allocated,
+ num_sub, iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
- (int)entities.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
+ (int)entities.size(), int, iBase_MEMORY_ALLOCATION_FAILED);
- num_sub, int, iBase_MEMORY_ALLOCATION_FAILED);
+ num_sub, int, iBase_MEMORY_ALLOCATION_FAILED);
- // now iterate over entities
- num_sub = 0;
- int i = 0;
- std::vector<MBEntityHandle> adj_ents;
- for (MBRange::iterator rit = entities.begin(); rit != endr; rit++) {
- adj_ents.clear();
- (*offset)[i] = num_sub;
+ // now iterate over entities
+ num_sub = 0;
+ int i = 0;
+ std::vector<MBEntityHandle> adj_ents;
+ for (MBRange::iterator rit = entities.begin(); rit != endr; rit++) {
+ adj_ents.clear();
+ (*offset)[i] = num_sub;
- result = MBI->get_adjacencies(&(*rit), 1, (int)entity_type_requested, false,
- adj_ents);
+ result = MBI->get_adjacencies(&(*rit), 1, (int)entity_type_requested, false,
+ adj_ents);
- std::string msg("iMesh_getAdjEntities: ERROR getting adjacencies of requested entities, "
+ std::string msg("iMesh_getAdjEntities: ERROR getting adjacencies of requested entities, "
- for (std::vector<MBEntityHandle>::iterator vit = adj_ents.begin();
- vit != adj_ents.end(); vit++) {
- (*adj_entity_handles)[num_sub] = (iBase_EntityHandle)*vit;
- (*in_entity_set)[num_sub] = 1;
- else
- (*in_entity_set)[num_sub] = 0;
+ for (std::vector<MBEntityHandle>::iterator vit = adj_ents.begin();
+ vit != adj_ents.end(); vit++) {
+ (*adj_entity_handles)[num_sub] = (iBase_EntityHandle)*vit;
+ (*in_entity_set)[num_sub] = 1;
+ else
+ (*in_entity_set)[num_sub] = 0;
- num_sub++;
+ num_sub++;
+ i++;
- i++;
+ *adj_entity_handles_size = num_sub;
+ *offset_size = entities.size();
+ *in_entity_set_size = num_sub;
- *adj_entity_handles_size = num_sub;
- *offset_size = entities.size();
- *in_entity_set_size = num_sub;
* Method: initEntArrIter[]
-void iMesh_initEntArrIter (iMesh_Instance instance,
- /*in*/ const int requested_array_size,
- /*out*/ iMesh_EntityIterator* entArr_iterator,
- int *err)
- RangeIterator *new_it = new RangeIterator;
- *entArr_iterator = reinterpret_cast<iMesh_EntityIterator>(new_it);
- new_it->requestedSize = requested_array_size;
+ void iMesh_initEntArrIter (iMesh_Instance instance,
+ /*in*/ const int requested_array_size,
+ /*out*/ iMesh_EntityIterator* entArr_iterator,
+ int *err)
+ RangeIterator *new_it = new RangeIterator;
+ *entArr_iterator = reinterpret_cast<iMesh_EntityIterator>(new_it);
+ new_it->requestedSize = requested_array_size;
- if (requested_entity_type == iBase_ALL_TYPES &&
- requested_entity_topology == iMesh_ALL_TOPOLOGIES)
- result = MBI->get_entities_by_handle( ENTITY_HANDLE(entity_set_handle),
- new_it->iteratorRange );
- else if (requested_entity_topology == iMesh_SEPTAHEDRON)
- result = MB_SUCCESS; // never any septahedrons because MOAB doesn't support them
- else if (MBMAXTYPE != req_type)
- result = MBI->get_entities_by_type(ENTITY_HANDLE(entity_set_handle),
- req_type,
- new_it->iteratorRange);
- else
- result = MBI->get_entities_by_dimension(ENTITY_HANDLE(entity_set_handle),
- req_dimension,
+ if (requested_entity_type == iBase_ALL_TYPES &&
+ requested_entity_topology == iMesh_ALL_TOPOLOGIES)
+ result = MBI->get_entities_by_handle( ENTITY_HANDLE(entity_set_handle),
+ new_it->iteratorRange );
+ else if (requested_entity_topology == iMesh_SEPTAHEDRON)
+ result = MB_SUCCESS; // never any septahedrons because MOAB doesn't support them
+ else if (MBMAXTYPE != req_type)
+ result = MBI->get_entities_by_type(ENTITY_HANDLE(entity_set_handle),
+ req_type,
+ new_it->iteratorRange);
+ else
+ result = MBI->get_entities_by_dimension(ENTITY_HANDLE(entity_set_handle),
+ req_dimension,
- std::string msg("iMesh_initEntArrIter: ERROR getting entities of proper type or topology, "
- iMesh_LAST_ERROR.error_type = iBase_ERROR_MAP[result];
+ std::string msg("iMesh_initEntArrIter: ERROR getting entities of proper type or topology, "
+ iMesh_LAST_ERROR.error_type = iBase_ERROR_MAP[result];
- new_it->currentPos = new_it->iteratorRange.begin();
- iMesh_LAST_ERROR.error_type = iBase_SUCCESS;
+ new_it->currentPos = new_it->iteratorRange.begin();
+ iMesh_LAST_ERROR.error_type = iBase_SUCCESS;
* Method: getEntArrNextIter[]
-void iMesh_getNextEntArrIter (iMesh_Instance instance,
- /*in*/ iMesh_EntityIterator entArr_iterator,
- int *is_end, int *err)
- RangeIterator *this_it = RANGE_ITERATOR(entArr_iterator);
+ void iMesh_getNextEntArrIter (iMesh_Instance instance,
+ /*in*/ iMesh_EntityIterator entArr_iterator,
+ int *is_end, int *err)
+ RangeIterator *this_it = RANGE_ITERATOR(entArr_iterator);
- // check the size of the destination array
- int expected_size = (this_it->requestedSize < (int)this_it->iteratorRange.size() ?
- this_it->requestedSize : this_it->iteratorRange.size());
- CHECK_SIZE(*entity_handles, *entity_handles_allocated, expected_size,
- iBase_EntityHandle, false);
+ // check the size of the destination array
+ int expected_size = (this_it->requestedSize < (int)this_it->iteratorRange.size() ?
+ this_it->requestedSize : this_it->iteratorRange.size());
+ CHECK_SIZE(*entity_handles, *entity_handles_allocated, expected_size,
+ iBase_EntityHandle, false);
- int& i = *entity_handles_size;
- for (i = 0; i < this_it->requestedSize; ++i, ++this_it->currentPos)
- if (this_it->currentPos == this_it->iteratorRange.end()) {
- *is_end = false;
+ int& i = *entity_handles_size;
+ for (i = 0; i < this_it->requestedSize; ++i, ++this_it->currentPos)
+ if (this_it->currentPos == this_it->iteratorRange.end()) {
+ *is_end = false;
- (*entity_handles)[i] = (iBase_EntityHandle)*this_it->currentPos;
+ (*entity_handles)[i] = (iBase_EntityHandle)*this_it->currentPos;
- *is_end = true;
+ *is_end = true;
* Method: resetEntArrIter[]
-void iMesh_resetEntArrIter (iMesh_Instance instance,
- /*in*/ iMesh_EntityIterator entArr_iterator, int *err)
+ void iMesh_resetEntArrIter (iMesh_Instance instance,
+ /*in*/ iMesh_EntityIterator entArr_iterator, int *err)
- this_it->currentPos = this_it->iteratorRange.begin();
+ this_it->currentPos = this_it->iteratorRange.begin();
-void iMesh_endEntArrIter (iMesh_Instance instance,
+ void iMesh_endEntArrIter (iMesh_Instance instance,
- this_it->currentPos = this_it->iteratorRange.end();
+ this_it->currentPos = this_it->iteratorRange.end();
-void iMesh_getEntArrTopo(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle* entity_handles,
- /*in*/ const int entity_handles_size,
- /*inout*/ int** topology,
- /*inout*/ int* topology_allocated,
- /*out*/ int* topology_size, int *err)
- // go through each entity and look up its type
- CHECK_SIZE(*topology, *topology_allocated, entity_handles_size,
- int, iBase_MEMORY_ALLOCATION_FAILED);
+ void iMesh_getEntArrTopo(iMesh_Instance instance,
+ /*in*/ const iBase_EntityHandle* entity_handles,
+ /*inout*/ int** topology,
+ /*inout*/ int* topology_allocated,
+ /*out*/ int* topology_size, int *err)
+ // go through each entity and look up its type
+ CHECK_SIZE(*topology, *topology_allocated, entity_handles_size,
+ int, iBase_MEMORY_ALLOCATION_FAILED);
- for (int i = 0; i < entity_handles_size; i++)
- (*topology)[i] =
- tstt_topology_table[MBI->type_from_handle(ENTITY_HANDLE(entity_handles[i]))];
+ (*topology)[i] =
+ tstt_topology_table[MBI->type_from_handle(ENTITY_HANDLE(entity_handles[i]))];
- *topology_size = entity_handles_size;
+ *topology_size = entity_handles_size;
-void iMesh_getEntArrType(iMesh_Instance instance,
- /*inout*/ int** etype,
- /*inout*/ int* etype_allocated,
- /*out*/ int* etype_size, int *err)
- CHECK_SIZE(*etype, *etype_allocated, entity_handles_size,
+ void iMesh_getEntArrType(iMesh_Instance instance,
+ /*inout*/ int** etype,
+ /*inout*/ int* etype_allocated,
+ /*out*/ int* etype_size, int *err)
+ CHECK_SIZE(*etype, *etype_allocated, entity_handles_size,
- (*etype)[i] =
- tstt_type_table[MBI->type_from_handle(ENTITY_HANDLE(entity_handles[i]))];
+ (*etype)[i] =
+ tstt_type_table[MBI->type_from_handle(ENTITY_HANDLE(entity_handles[i]))];
- *etype_size = entity_handles_size;
+ *etype_size = entity_handles_size;
-void iMesh_getEntArrAdj(iMesh_Instance instance,
- /*inout*/ iBase_EntityHandle** adjacentEntityHandles,
- /*inout*/ int* adjacentEntityHandles_allocated,
- /*out*/ int* adjacentEntityHandles_size,
- /*out*/ int* offset_size, int *err)
- MBErrorCode result = MB_SUCCESS;
+ void iMesh_getEntArrAdj(iMesh_Instance instance,
+ /*inout*/ iBase_EntityHandle** adjacentEntityHandles,
+ /*inout*/ int* adjacentEntityHandles_allocated,
+ /*out*/ int* adjacentEntityHandles_size,
+ /*out*/ int* offset_size, int *err)
+ MBErrorCode result = MB_SUCCESS;
- CHECK_SIZE(*offset, *offset_allocated, entity_handles_size+1,
+ CHECK_SIZE(*offset, *offset_allocated, entity_handles_size+1,
- const MBEntityHandle* entity_iter = (const MBEntityHandle*)entity_handles;
- const MBEntityHandle* const entity_end = entity_iter + entity_handles_size;
- int* off_iter = *offset;
- int prev_off = 0;
+ const MBEntityHandle* entity_iter = (const MBEntityHandle*)entity_handles;
+ const MBEntityHandle* const entity_end = entity_iter + entity_handles_size;
+ int* off_iter = *offset;
+ int prev_off = 0;
- std::vector<MBEntityHandle> all_adj_ents;
+ std::vector<MBEntityHandle> all_adj_ents;
- for ( ; entity_iter != entity_end; ++entity_iter)
- *off_iter = prev_off;
- off_iter++;
+ for ( ; entity_iter != entity_end; ++entity_iter)
+ *off_iter = prev_off;
+ off_iter++;
- result = MBI->get_adjacencies( entity_iter, 1,
- entity_type_requested, false, adj_ents );
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntArrAdj: trouble getting adjacency list.");
+ result = MBI->get_adjacencies( entity_iter, 1,
+ entity_type_requested, false, adj_ents );
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntArrAdj: trouble getting adjacency list.");
+ std::copy(adj_ents.begin(), adj_ents.end(), std::back_inserter(all_adj_ents));
+ prev_off += adj_ents.size();
- std::copy(adj_ents.begin(), adj_ents.end(), std::back_inserter(all_adj_ents));
- prev_off += adj_ents.size();
+ CHECK_SIZE(*adjacentEntityHandles, *adjacentEntityHandles_allocated,
+ (int)all_adj_ents.size(),
+ iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ memcpy(*adjacentEntityHandles, &all_adj_ents[0], sizeof(MBEntityHandle) * all_adj_ents.size() );
+ *adjacentEntityHandles_size = all_adj_ents.size();
+ *offset_size = entity_handles_size+1;
- CHECK_SIZE(*adjacentEntityHandles, *adjacentEntityHandles_allocated,
- (int)all_adj_ents.size(),
- iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
- memcpy(*adjacentEntityHandles, &all_adj_ents[0], sizeof(MBEntityHandle) * all_adj_ents.size() );
+ void iMesh_getEntArr2ndAdj( iMesh_Instance instance,
+ iBase_EntityHandle const* entity_handles,
+ int entity_handles_size,
+ int order_adjacent_key,
+ int requested_entity_type,
+ iBase_EntityHandle** adj_entity_handles,
+ int* adj_entity_handles_allocated,
+ int* adj_entity_handles_size,
+ int** offset,
+ int* offset_allocated,
+ int* offset_size,
+ int* err )
- *adjacentEntityHandles_size = all_adj_ents.size();
- *offset_size = entity_handles_size+1;
-void iMesh_getEntArr2ndAdj( iMesh_Instance instance,
- iBase_EntityHandle const* entity_handles,
- int entity_handles_size,
- int order_adjacent_key,
- int requested_entity_type,
- iBase_EntityHandle** adj_entity_handles,
- int* adj_entity_handles_allocated,
- int* adj_entity_handles_size,
- int** offset,
- int* offset_allocated,
- int* offset_size,
- int* err )
- int prev_off = 0;
+ int prev_off = 0;
- MeshTopoUtil mtu(MBI);
+ MeshTopoUtil mtu(MBI);
+ off_iter++;
+ MBRange adj_ents;
+ result = mtu.get_bridge_adjacencies( *entity_iter,
+ order_adjacent_key,
+ requested_entity_type, adj_ents );
- off_iter++;
- MBRange adj_ents;
- result = mtu.get_bridge_adjacencies( *entity_iter,
- order_adjacent_key,
- requested_entity_type, adj_ents );
+ memcpy(*adj_entity_handles, &all_adj_ents[0],
+ sizeof(MBEntityHandle)*all_adj_ents.size() );
+ *adj_entity_handles_size = all_adj_ents.size();
+ void iMesh_createEntSet(iMesh_Instance instance,
+ /*in*/ const int isList,
+ /*out*/ iBase_EntitySetHandle* entity_set_created, int *err)
+ // create the entity set
+ MBEntityHandle meshset;
+ MBErrorCode result;
+ if (isList)
+ result = MBI->create_meshset(MESHSET_ORDERED, meshset);
+ else
+ result = MBI->create_meshset(MESHSET_SET, meshset);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_createEntSet: ERROR creating a entityset instance");
+ // return EntitySet_Handle
+ *entity_set_created = (iBase_EntityHandle)meshset;
- memcpy(*adj_entity_handles, &all_adj_ents[0],
- sizeof(MBEntityHandle)*all_adj_ents.size() );
+ void iMesh_destroyEntSet (iMesh_Instance instance,
+ /*in*/ iBase_EntitySetHandle entity_set, int *err)
+ MBErrorCode result = MBI->delete_entities(HANDLE_ARRAY_PTR(&entity_set), 1);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_destroyEntSet: couldn't delete the set.");
- *adj_entity_handles_size = all_adj_ents.size();
-void iMesh_createEntSet(iMesh_Instance instance,
- /*in*/ const int isList,
- /*out*/ iBase_EntitySetHandle* entity_set_created, int *err)
- // create the entity set
- MBEntityHandle meshset;
- if (isList)
- result = MBI->create_meshset(MESHSET_ORDERED, meshset);
- else
- result = MBI->create_meshset(MESHSET_SET, meshset);
+ void iMesh_isList (iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle entity_set,
+ int *is_list, int *err)
+ unsigned int options;
+ MBErrorCode result = MBI->get_meshset_options(ENTITY_HANDLE(entity_set), options);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_isList: couldn't query set.");
+ if (options & MESHSET_ORDERED)
+ *is_list = true;
+ else *is_list = false;
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_createEntSet: ERROR creating a entityset instance");
- // return EntitySet_Handle
- *entity_set_created = (iBase_EntityHandle)meshset;
-void iMesh_destroyEntSet (iMesh_Instance instance,
- /*in*/ iBase_EntitySetHandle entity_set, int *err)
- MBErrorCode result = MBI->delete_entities(HANDLE_ARRAY_PTR(&entity_set), 1);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_destroyEntSet: couldn't delete the set.");
+ void iMesh_getNumEntSets(iMesh_Instance instance,
+ /*in*/ const int num_hops,
+ int *num_sets, int *err)
+ if (num_hops > 1) {
+ iMesh_processError(iBase_ERROR_MAP[iBase_NOT_SUPPORTED],
+ "iMesh_getNumEntSets: not currently implemented for num_hops > 1.");
+ *num_sets = 0;
+ RETURN(iBase_ERROR_MAP[iBase_NOT_SUPPORTED]);
+ MBErrorCode result = MBI->get_number_entities_by_type
+ (ENTITY_HANDLE(entity_set_handle), MBENTITYSET,
+ *num_sets, (num_hops == -1 ? true : false));
+ std::string msg("iMesh_entitysetGetNumberEntitySets:ERROR getting number of entitysets "
+ "in EntitySet, with error type: ");
-void iMesh_isList (iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set,
- int *is_list, int *err)
- unsigned int options;
- MBErrorCode result = MBI->get_meshset_options(ENTITY_HANDLE(entity_set), options);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_isList: couldn't query set.");
- if (options & MESHSET_ORDERED)
- *is_list = true;
- else *is_list = false;
-void iMesh_getNumEntSets(iMesh_Instance instance,
+ void iMesh_getEntSets(iMesh_Instance instance,
- int *num_sets, int *err)
- if (num_hops > 1) {
- iMesh_processError(iBase_ERROR_MAP[iBase_NOT_SUPPORTED],
- "iMesh_getNumEntSets: not currently implemented for num_hops > 1.");
- *num_sets = 0;
- RETURN(iBase_ERROR_MAP[iBase_NOT_SUPPORTED]);
+ /*inout*/ iBase_EntitySetHandle** contained_entset_handles,
+ /*inout*/ int* contained_entset_handles_allocated,
+ /*inout*/ int* contained_entset_handles_size, int *err)
+ iMesh_processError(iBase_NOT_SUPPORTED, "iMesh_getEntSets: not currently implemented for num_hops > 1.");
- MBErrorCode result = MBI->get_number_entities_by_type
- (ENTITY_HANDLE(entity_set_handle), MBENTITYSET,
- *num_sets, (num_hops == -1 ? true : false));
+ MBRange sets;
+ MBErrorCode result = MBI->get_entities_by_type
+ (ENTITY_HANDLE(entity_set_handle), MBENTITYSET, sets, (num_hops == -1 ? true : false));
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_entitysetGetEntitySets: problem getting entities by type.");
- std::string msg("iMesh_entitysetGetNumberEntitySets:ERROR getting number of entitysets "
- "in EntitySet, with error type: ");
+ CHECK_SIZE(*contained_entset_handles, *contained_entset_handles_allocated,
+ (int)sets.size(), iBase_EntitySetHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ MBRange::iterator iter = sets.begin();
+ MBRange::iterator end_iter = sets.end();
+ int k = 0;
-void iMesh_getEntSets(iMesh_Instance instance,
- /*in*/ const int num_hops,
- /*inout*/ iBase_EntitySetHandle** contained_entset_handles,
- /*inout*/ int* contained_entset_handles_allocated,
- /*inout*/ int* contained_entset_handles_size, int *err)
- iMesh_processError(iBase_NOT_SUPPORTED, "iMesh_getEntSets: not currently implemented for num_hops > 1.");
+ for (; iter != end_iter; iter++)
+ (*contained_entset_handles)[k++] = (iBase_EntityHandle)*iter;
+ *contained_entset_handles_size = sets.size();
- MBRange sets;
- MBErrorCode result = MBI->get_entities_by_type
- (ENTITY_HANDLE(entity_set_handle), MBENTITYSET, sets, (num_hops == -1 ? true : false));
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_entitysetGetEntitySets: problem getting entities by type.");
+ void iMesh_addEntArrToSet(iMesh_Instance instance,
+ /*inout*/ iBase_EntitySetHandle* entity_set, int *err)
+ const MBEntityHandle *ents = CONST_HANDLE_ARRAY_PTR(entity_handles);
+ MBErrorCode result = MBI->add_entities(ENTITY_HANDLE(*entity_set),
+ ents, entity_handles_size);
+ std::string msg("iMesh_addEntArrToSet:ERROR adding entities in EntitySet, "
- CHECK_SIZE(*contained_entset_handles, *contained_entset_handles_allocated,
- (int)sets.size(), iBase_EntitySetHandle, iBase_MEMORY_ALLOCATION_FAILED);
- MBRange::iterator iter = sets.begin();
- MBRange::iterator end_iter = sets.end();
- int k = 0;
- for (; iter != end_iter; iter++)
- (*contained_entset_handles)[k++] = (iBase_EntityHandle)*iter;
- *contained_entset_handles_size = sets.size();
-void iMesh_addEntArrToSet(iMesh_Instance instance,
+ void iMesh_addEntToSet(iMesh_Instance instance,
- const MBEntityHandle *ents = CONST_HANDLE_ARRAY_PTR(entity_handles);
- MBErrorCode result = MBI->add_entities(ENTITY_HANDLE(*entity_set),
- ents, entity_handles_size);
- std::string msg("iMesh_addEntArrToSet:ERROR adding entities in EntitySet, "
+ iMesh_addEntArrToSet(instance, &entity_handle, 1, entity_set, err);
-void iMesh_addEntToSet(iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle entity_handle,
- /*inout*/ iBase_EntitySetHandle* entity_set, int *err)
- iMesh_addEntArrToSet(instance, &entity_handle, 1, entity_set, err);
+ void iMesh_rmvEntArrFromSet(iMesh_Instance instance,
-void iMesh_rmvEntArrFromSet(iMesh_Instance instance,
- MBErrorCode result = MBI->remove_entities
- (ENTITY_HANDLE(*entity_set), ents, entity_handles_size);
+ MBErrorCode result = MBI->remove_entities
+ (ENTITY_HANDLE(*entity_set), ents, entity_handles_size);
- std::string msg("iMesh_rmvEntArrFromSet:ERROR removing entities in EntitySet, "
+ std::string msg("iMesh_rmvEntArrFromSet:ERROR removing entities in EntitySet, "
-void iMesh_rmvEntFromSet(iMesh_Instance instance,
- iMesh_rmvEntArrFromSet(instance, &entity_handle, 1, entity_set, err);
-void iMesh_addEntSet(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set_to_add,
- /*inout*/ iBase_EntitySetHandle* entity_set_handle, int *err)
- MBErrorCode result = MBI->add_entities(ENTITY_HANDLE(*entity_set_handle),
- CONST_HANDLE_ARRAY_PTR(&entity_set_to_add), 1);
- std::string msg("iMesh_addEntSet:ERROR adding entitysets, with error type: ");
+ void iMesh_rmvEntFromSet(iMesh_Instance instance,
+ iMesh_rmvEntArrFromSet(instance, &entity_handle, 1, entity_set, err);
+ void iMesh_addEntSet(iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle entity_set_to_add,
+ /*inout*/ iBase_EntitySetHandle* entity_set_handle, int *err)
+ MBErrorCode result = MBI->add_entities(ENTITY_HANDLE(*entity_set_handle),
+ CONST_HANDLE_ARRAY_PTR(&entity_set_to_add), 1);
-void iMesh_rmvEntSet(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set_to_remove,
- /*inout*/ iBase_EntitySetHandle *entity_set_handle, int *err)
- (ENTITY_HANDLE(*entity_set_handle), CONST_HANDLE_ARRAY_PTR(&entity_set_to_remove), 1);
+ std::string msg("iMesh_addEntSet:ERROR adding entitysets, with error type: ");
- std::string msg("iMesh_rmvEntSet:ERROR removing entitysets in EntitySet, "
-void iMesh_isEntContained (iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle containing_entity_set,
- /*in*/ const iBase_EntitySetHandle contained_entity,
- int *is_contained, int *err)
- MBRange all_ents;
- MBErrorCode result = MBI->get_entities_by_handle(ENTITY_HANDLE(containing_entity_set),
- all_ents);
- std::string msg("iMesh_isContainedIn:ERROR getting entities in EntitySet, "
+ void iMesh_rmvEntSet(iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle entity_set_to_remove,
+ /*inout*/ iBase_EntitySetHandle *entity_set_handle, int *err)
+ (ENTITY_HANDLE(*entity_set_handle), CONST_HANDLE_ARRAY_PTR(&entity_set_to_remove), 1);
- if (all_ents.find(ENTITY_HANDLE(contained_entity)) == all_ents.end())
- *is_contained = false;
+ std::string msg("iMesh_rmvEntSet:ERROR removing entitysets in EntitySet, "
- else
- *is_contained = true;
-void iMesh_isEntSetContained (iMesh_Instance instance,
+ void iMesh_isEntContained (iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle contained_entity_set,
+ /*in*/ const iBase_EntitySetHandle contained_entity,
- iMesh_isEntContained(instance, containing_entity_set, contained_entity_set,
- is_contained, err);
+ MBRange all_ents;
+ MBErrorCode result = MBI->get_entities_by_handle(ENTITY_HANDLE(containing_entity_set),
+ all_ents);
+ std::string msg("iMesh_isContainedIn:ERROR getting entities in EntitySet, "
+ if (all_ents.find(ENTITY_HANDLE(contained_entity)) == all_ents.end())
+ *is_contained = false;
+ else
+ *is_contained = true;
-void iMesh_addPrntChld(iMesh_Instance instance,
- /*inout*/ iBase_EntitySetHandle* parent_entity_set,
- /*inout*/ iBase_EntitySetHandle* child_entity_set, int *err)
- MBErrorCode result = MBI->add_parent_child
- (ENTITY_HANDLE(*parent_entity_set),
- ENTITY_HANDLE(*child_entity_set));
- std::string msg("MB Mesh::addPrntChld: ERROR addParentChild failed, with error type: ");
+ void iMesh_isEntSetContained (iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle containing_entity_set,
+ /*in*/ const iBase_EntitySetHandle contained_entity_set,
+ int *is_contained, int *err)
+ iMesh_isEntContained(instance, containing_entity_set, contained_entity_set,
+ is_contained, err);
+ void iMesh_addPrntChld(iMesh_Instance instance,
+ /*inout*/ iBase_EntitySetHandle* parent_entity_set,
+ /*inout*/ iBase_EntitySetHandle* child_entity_set, int *err)
+ MBErrorCode result = MBI->add_parent_child
+ (ENTITY_HANDLE(*parent_entity_set),
+ ENTITY_HANDLE(*child_entity_set));
-void iMesh_rmvPrntChld(iMesh_Instance instance,
- MBErrorCode result = MBI->remove_parent_child
+ std::string msg("MB Mesh::addPrntChld: ERROR addParentChild failed, with error type: ");
- std::string msg("iMesh_rmvPrntChld: ERROR RemoveParentChild failed, with error type: ");
+ void iMesh_rmvPrntChld(iMesh_Instance instance,
+ MBErrorCode result = MBI->remove_parent_child
+ std::string msg("iMesh_rmvPrntChld: ERROR RemoveParentChild failed, with error type: ");
-void iMesh_isChildOf(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle parent_entity_set,
- /*in*/ const iBase_EntitySetHandle child_entity_set,
- int *is_child, int *err)
- std::vector<MBEntityHandle> children;
- MBErrorCode result = MBI->get_child_meshsets
- (ENTITY_HANDLE(parent_entity_set), children);
- std::string msg("iMesh_isChildOf: ERROR IsParentChildRelated failed, with error type: ");
- *is_child = false;
- if (std::find(children.begin(), children.end(), ENTITY_HANDLE(child_entity_set))
- != children.end())
- *is_child = true;
+ void iMesh_isChildOf(iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle parent_entity_set,
+ /*in*/ const iBase_EntitySetHandle child_entity_set,
+ int *is_child, int *err)
+ std::vector<MBEntityHandle> children;
- else
+ MBErrorCode result = MBI->get_child_meshsets
+ (ENTITY_HANDLE(parent_entity_set), children);
+ std::string msg("iMesh_isChildOf: ERROR IsParentChildRelated failed, with error type: ");
+ *is_child = false;
-void iMesh_getNumChld(iMesh_Instance instance,
- int *num_child, int *err)
- *num_child = 0;
- MBErrorCode result = MBI->num_child_meshsets
- (ENTITY_HANDLE(entity_set), num_child, num_hops);
+ if (std::find(children.begin(), children.end(), ENTITY_HANDLE(child_entity_set))
+ != children.end())
+ *is_child = true;
- std::string msg("iMesh_getNumChld: ERROR GetNumChildren failed, with error type: ");
- *num_child = 0;
+ else
+ void iMesh_getNumChld(iMesh_Instance instance,
+ int *num_child, int *err)
+ *num_child = 0;
+ MBErrorCode result = MBI->num_child_meshsets
+ (ENTITY_HANDLE(entity_set), num_child, num_hops);
-void iMesh_getNumPrnt(iMesh_Instance instance,
- int *num_parent, int *err)
- *num_parent = 0;
- MBErrorCode result = MBI->num_parent_meshsets
- (ENTITY_HANDLE(entity_set), num_parent, num_hops);
+ std::string msg("iMesh_getNumChld: ERROR GetNumChildren failed, with error type: ");
+ *num_child = 0;
- std::string msg("iMesh_getNumPrnt:\
- ERROR GetNumParents failed, with error type: ");
+ void iMesh_getNumPrnt(iMesh_Instance instance,
+ int *num_parent, int *err)
+ *num_parent = 0;
+ MBErrorCode result = MBI->num_parent_meshsets
+ (ENTITY_HANDLE(entity_set), num_parent, num_hops);
-void iMesh_getChldn(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle from_entity_set,
- /*out*/ iBase_EntitySetHandle** entity_set_handles,
- /*out*/ int* entity_set_handles_allocated,
- /*out*/ int* entity_set_handles_size, int *err)
+ std::string msg("iMesh_getNumPrnt:\
+ ERROR GetNumParents failed, with error type: ");
- (ENTITY_HANDLE(from_entity_set), children, num_hops);
- std::string msg("iMesh_getChldn:\
- ERROR getChildren failed, with error type: ");
- CHECK_SIZE(*entity_set_handles, *entity_set_handles_allocated,
- (int)children.size(), iBase_EntitySetHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ void iMesh_getChldn(iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle from_entity_set,
+ /*out*/ iBase_EntitySetHandle** entity_set_handles,
+ /*out*/ int* entity_set_handles_allocated,
+ /*out*/ int* entity_set_handles_size, int *err)
- MBEntityHandle *ents = HANDLE_ARRAY_PTR(*entity_set_handles);
- // use a memcpy for efficiency
- memcpy(ents, &children[0], children.size()*sizeof(MBEntityHandle));
+ (ENTITY_HANDLE(from_entity_set), children, num_hops);
- *entity_set_handles_size = children.size();
+ std::string msg("iMesh_getChldn:\
+ ERROR getChildren failed, with error type: ");
+ CHECK_SIZE(*entity_set_handles, *entity_set_handles_allocated,
+ (int)children.size(), iBase_EntitySetHandle, iBase_MEMORY_ALLOCATION_FAILED);
-void iMesh_getPrnts(iMesh_Instance instance,
- std::vector<MBEntityHandle> parents;
+ MBEntityHandle *ents = HANDLE_ARRAY_PTR(*entity_set_handles);
+ // use a memcpy for efficiency
+ memcpy(ents, &children[0], children.size()*sizeof(MBEntityHandle));
- MBErrorCode result = MBI->get_parent_meshsets
- (ENTITY_HANDLE(from_entity_set), parents, num_hops);
+ *entity_set_handles_size = children.size();
- std::string msg("iMesh_getPrnts:\
- ERROR getParents failed, with error type: ");
- (int)parents.size(), iBase_EntitySetHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ void iMesh_getPrnts(iMesh_Instance instance,
+ std::vector<MBEntityHandle> parents;
- memcpy(ents, &parents[0], parents.size()*sizeof(MBEntityHandle));
+ MBErrorCode result = MBI->get_parent_meshsets
+ (ENTITY_HANDLE(from_entity_set), parents, num_hops);
- *entity_set_handles_size = parents.size();
+ std::string msg("iMesh_getPrnts:\
+ ERROR getParents failed, with error type: ");
+ (int)parents.size(), iBase_EntitySetHandle, iBase_MEMORY_ALLOCATION_FAILED);
-void iMesh_setVtxArrCoords (iMesh_Instance instance,
- /*in*/ iBase_EntityHandle* vertex_handles,
- /*in*/ const int storage_order,
- /*in*/ const double* new_coords,
- /*in*/ const int new_coords_size, int *err)
- MBErrorCode result = MB_SUCCESS, tmp_result;
- if (storage_order == iBase_INTERLEAVED) {
- result = MBI->set_coords(HANDLE_ARRAY_PTR(vertex_handles),
- vertex_handles_size, new_coords);
+ memcpy(ents, &parents[0], parents.size()*sizeof(MBEntityHandle));
+ *entity_set_handles_size = parents.size();
- else {
- MBEntityHandle *verts = HANDLE_ARRAY_PTR(vertex_handles);
- double dummy[3];
- for (int i = 0; i < vertex_handles_size; i++) {
- dummy[0] = new_coords[i]; dummy[1] = new_coords[vertex_handles_size+i];
- dummy[2] = new_coords[2*vertex_handles_size+i];
- tmp_result = MBI->set_coords(&verts[i], 1, dummy);
- if (MB_SUCCESS != tmp_result) result = tmp_result;
+ void iMesh_setVtxArrCoords (iMesh_Instance instance,
+ /*in*/ iBase_EntityHandle* vertex_handles,
+ /*in*/ const int storage_order,
+ /*in*/ const double* new_coords,
+ /*in*/ const int new_coords_size, int *err)
+ MBErrorCode result = MB_SUCCESS, tmp_result;
+ if (storage_order == iBase_INTERLEAVED) {
+ result = MBI->set_coords(HANDLE_ARRAY_PTR(vertex_handles),
+ vertex_handles_size, new_coords);
+ else {
+ MBEntityHandle *verts = HANDLE_ARRAY_PTR(vertex_handles);
+ double dummy[3];
+ for (int i = 0; i < vertex_handles_size; i++) {
+ dummy[0] = new_coords[i]; dummy[1] = new_coords[vertex_handles_size+i];
+ dummy[2] = new_coords[2*vertex_handles_size+i];
+ tmp_result = MBI->set_coords(&verts[i], 1, dummy);
+ if (MB_SUCCESS != tmp_result) result = tmp_result;
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_setVtxArrCoords: problem setting coordinates.");
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_setVtxArrCoords: problem setting coordinates.");
-void iMesh_createVtxArr(iMesh_Instance instance,
- /*in*/ const int num_verts,
- /*inout*/ iBase_EntityHandle** new_vertex_handles,
- /*inout*/ int* new_vertex_handles_allocated,
- /*inout*/ int* new_vertex_handles_size, int *err)
- // if there aren't any elements in the array, allocate it
- CHECK_SIZE(*new_vertex_handles, *new_vertex_handles_allocated,
- num_verts, iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ void iMesh_createVtxArr(iMesh_Instance instance,
+ /*in*/ const int num_verts,
+ /*inout*/ iBase_EntityHandle** new_vertex_handles,
+ /*inout*/ int* new_vertex_handles_allocated,
+ /*inout*/ int* new_vertex_handles_size, int *err)
+ // if there aren't any elements in the array, allocate it
+ CHECK_SIZE(*new_vertex_handles, *new_vertex_handles_allocated,
+ num_verts, iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
- // make the entities
- MBEntityHandle *new_verts = HANDLE_ARRAY_PTR(*new_vertex_handles);
+ // make the entities
+ MBEntityHandle *new_verts = HANDLE_ARRAY_PTR(*new_vertex_handles);
- for (int i = 0; i < num_verts; i++) {
- MBErrorCode result = MBI->create_vertex(&new_coords[3*i], new_verts[i]);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_createVtxArr: couldn't create vertex.");
+ for (int i = 0; i < num_verts; i++) {
+ MBErrorCode result = MBI->create_vertex(&new_coords[3*i], new_verts[i]);
+ if (MB_SUCCESS != result) {
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_createVtxArr: couldn't create vertex.");
+ RETURN(iBase_ERROR_MAP[result]);
- *new_vertex_handles_size = new_coords_size/3;
+ *new_vertex_handles_size = new_coords_size/3;
+ RETURN(iBase_SUCCESS);
-void iMesh_createEntArr(iMesh_Instance instance,
- /*in*/ const int new_entity_topology,
- /*in*/ const iBase_EntityHandle* lower_order_entity_handles,
- /*in*/ const int lower_order_entity_handles_size,
- /*out*/ iBase_EntityHandle** new_entity_handles,
- /*out*/ int* new_entity_handles_allocated,
- /*out*/ int* new_entity_handles_size,
- /*inout*/ int** status,
- /*inout*/ int* status_allocated,
- /*out*/ int* status_size, int *err)
- // for now, throw an error if lower order entity handles aren't vertices
- MBEntityType this_type = mb_topology_table[new_entity_topology];
- int num_ents = 0, num_verts;
- const MBEntityHandle *lower_ents;
- if (MBVERTEX != this_type) {
- num_verts = MBCN::VerticesPerEntity(this_type);
- num_ents = lower_order_entity_handles_size / num_verts;
- lower_ents = CONST_HANDLE_ARRAY_PTR(lower_order_entity_handles);
- // check that we have the right number of lower order entity handles
- if (lower_order_entity_handles_size % MBCN::VerticesPerEntity(this_type) != 0) {
- iMesh_processError(iBase_ERROR_MAP[iBase_INVALID_ENTITY_COUNT], "iMesh_createEntArr: wrong # vertices for this entity type.");
- RETURN(iBase_ERROR_MAP[iBase_INVALID_ENTITY_COUNT]);
+ void iMesh_createEntArr(iMesh_Instance instance,
+ /*in*/ const int new_entity_topology,
+ /*in*/ const iBase_EntityHandle* lower_order_entity_handles,
+ /*in*/ const int lower_order_entity_handles_size,
+ /*out*/ iBase_EntityHandle** new_entity_handles,
+ /*out*/ int* new_entity_handles_allocated,
+ /*out*/ int* new_entity_handles_size,
+ /*inout*/ int** status,
+ /*inout*/ int* status_allocated,
+ /*out*/ int* status_size, int *err)
+ // for now, throw an error if lower order entity handles aren't vertices
+ MBEntityType this_type = mb_topology_table[new_entity_topology];
+ int num_ents = 0, num_verts;
+ const MBEntityHandle *lower_ents;
+ if (MBVERTEX != this_type) {
+ num_verts = MBCN::VerticesPerEntity(this_type);
+ num_ents = lower_order_entity_handles_size / num_verts;
+ lower_ents = CONST_HANDLE_ARRAY_PTR(lower_order_entity_handles);
+ // check that we have the right number of lower order entity handles
+ if (lower_order_entity_handles_size % MBCN::VerticesPerEntity(this_type) != 0) {
+ iMesh_processError(iBase_ERROR_MAP[iBase_INVALID_ENTITY_COUNT], "iMesh_createEntArr: wrong # vertices for this entity type.");
+ RETURN(iBase_ERROR_MAP[iBase_INVALID_ENTITY_COUNT]);
- else {
- iMesh_processError(iBase_ERROR_MAP[iBase_INVALID_ARGUMENT], "iMesh_createEntArr: can't create vertices with this function, use createVtxArr instead.");
- RETURN(iBase_ERROR_MAP[iBase_INVALID_ARGUMENT]);
+ else {
+ iMesh_processError(iBase_ERROR_MAP[iBase_INVALID_ARGUMENT], "iMesh_createEntArr: can't create vertices with this function, use createVtxArr instead.");
+ RETURN(iBase_ERROR_MAP[iBase_INVALID_ARGUMENT]);
- if (num_ents == 0) {
- iMesh_processError(iBase_INVALID_ENTITY_COUNT,
- "iMesh_createEntArr: called to create 0 entities.");
+ if (num_ents == 0) {
+ iMesh_processError(iBase_INVALID_ENTITY_COUNT,
+ "iMesh_createEntArr: called to create 0 entities.");
- CHECK_SIZE(*new_entity_handles, *new_entity_handles_allocated,
- num_ents, iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ CHECK_SIZE(*new_entity_handles, *new_entity_handles_allocated,
+ num_ents, iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
- CHECK_SIZE(*status, *status_allocated, num_ents,
+ CHECK_SIZE(*status, *status_allocated, num_ents,
- MBEntityHandle *new_ents = HANDLE_ARRAY_PTR(*new_entity_handles);
- static double dum_coords[] = {0.0, 0.0, 0.0};
+ MBEntityHandle *new_ents = HANDLE_ARRAY_PTR(*new_entity_handles);
+ static double dum_coords[] = {0.0, 0.0, 0.0};
- MBErrorCode tmp_result, result = MB_SUCCESS;
+ MBErrorCode tmp_result, result = MB_SUCCESS;
- if (this_type == MBVERTEX) {
- for (int i = 0; i < num_ents; i++) {
- tmp_result = MBI->create_vertex(dum_coords, new_ents[i]);
- if (MB_SUCCESS != tmp_result) {
- (*status)[i] = iBase_CREATION_FAILED;
- result = tmp_result;
- else
- (*status)[i] = iBase_NEW;
- else {
- tmp_result = MBI->create_element(this_type, lower_ents, num_verts,
- new_ents[i]);
- else
+ if (this_type == MBVERTEX) {
+ for (int i = 0; i < num_ents; i++) {
+ tmp_result = MBI->create_vertex(dum_coords, new_ents[i]);
+ if (MB_SUCCESS != tmp_result) {
+ (*status)[i] = iBase_CREATION_FAILED;
+ result = tmp_result;
+ else
+ (*status)[i] = iBase_NEW;
+ else {
+ tmp_result = MBI->create_element(this_type, lower_ents, num_verts,
+ new_ents[i]);
+ else
- lower_ents += num_verts;
+ lower_ents += num_verts;
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_createEntArr: couldn't create one of the entities.");
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_createEntArr: couldn't create one of the entities.");
- *new_entity_handles_size = num_ents;
- *status_size = num_ents;
+ *new_entity_handles_size = num_ents;
+ *status_size = num_ents;
-void iMesh_deleteEntArr(iMesh_Instance instance,
- /*in*/ iBase_EntityHandle* entity_handles,
- /*in*/ const int entity_handles_size, int *err)
- if (0 == entity_handles_size) {
- RETURN(iBase_SUCCESS);
+ void iMesh_deleteEntArr(iMesh_Instance instance,
+ /*in*/ iBase_EntityHandle* entity_handles,
+ /*in*/ const int entity_handles_size, int *err)
+ if (0 == entity_handles_size) {
- MBErrorCode result = MBI->delete_entities(HANDLE_ARRAY_PTR(entity_handles),
- entity_handles_size);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_deleteEntArr: trouble deleting entities.");
+ MBErrorCode result = MBI->delete_entities(HANDLE_ARRAY_PTR(entity_handles),
+ entity_handles_size);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_deleteEntArr: trouble deleting entities.");
-void iMesh_createTag(iMesh_Instance instance,
- /*in*/ const char* tag_name,
- /*in*/ const int tag_size,
- /*in*/ const int tag_type,
- /*out*/ iBase_TagHandle* tag_handle,
- int *err,
- const int tag_name_size)
- MBTag new_tag;
- int this_size = tag_size;
+ void iMesh_createTag(iMesh_Instance instance,
+ /*in*/ const char* tag_name,
+ /*in*/ const int tag_size,
+ /*in*/ const int tag_type,
+ /*out*/ iBase_TagHandle* tag_handle,
+ int *err,
+ const int tag_name_size)
+ MBTag new_tag;
+ int this_size = tag_size;
- std::string tmp_tagname(tag_name);
- eatwhitespace(tmp_tagname);
+ std::string tmp_tagname(tag_name);
+ eatwhitespace(tmp_tagname);
- switch (tag_type) {
- case iBase_INTEGER:
- this_size *= sizeof(int);
- break;
- case iBase_DOUBLE:
- this_size *= sizeof(double);
- break;
- case iBase_ENTITY_HANDLE:
- this_size *= sizeof(iBase_EntityHandle);
- break;
- case iBase_BYTES:
- break;
+ switch (tag_type) {
+ case iBase_INTEGER:
+ this_size *= sizeof(int);
+ break;
+ case iBase_DOUBLE:
+ this_size *= sizeof(double);
+ break;
+ case iBase_ENTITY_HANDLE:
+ this_size *= sizeof(iBase_EntityHandle);
+ break;
+ case iBase_BYTES:
+ break;
- MBErrorCode result = MBI->tag_create(tmp_tagname.c_str(), this_size,
- MB_TAG_SPARSE,
- mb_data_type_table[tag_type],
- new_tag,
- NULL);
+ MBErrorCode result = MBI->tag_create(tmp_tagname.c_str(), this_size,
+ MB_TAG_SPARSE,
+ mb_data_type_table[tag_type],
+ new_tag,
+ NULL);
- if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) {
- std::string msg = std::string("iMesh_createTag: error creating tag with name '") +
- std::string(tag_name) + std::string("'.");
- else if (MB_ALREADY_ALLOCATED == result) {
- std::string msg = std::string("iMesh_createTag: tag with name '") +
- std::string(tag_name) + std::string("' already created.");
+ if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) {
+ std::string msg = std::string("iMesh_createTag: error creating tag with name '") +
+ std::string(tag_name) + std::string("'.");
+ else if (MB_ALREADY_ALLOCATED == result) {
+ std::string msg = std::string("iMesh_createTag: tag with name '") +
+ std::string(tag_name) + std::string("' already created.");
- *tag_handle = (iBase_TagHandle) new_tag;
+ *tag_handle = (iBase_TagHandle) new_tag;
-void iMesh_destroyTag(iMesh_Instance instance,
- /*in*/ iBase_TagHandle tag_handle,
- /*in*/ const int forced, int *err)
- // might need to check if it's used first
- if (false == forced) {
- MBRange ents;
- MBTag this_tag = TAG_HANDLE(tag_handle);
- for (MBEntityType this_type = MBVERTEX; this_type != MBMAXTYPE; this_type++) {
- result = MBI->get_entities_by_type_and_tag(0, this_type, &this_tag, NULL, 1,
- ents, MBInterface::UNION);
- std::string msg("iMesh_destroyTag: problem finding tag., with error type: ");
- msg += MBI->get_error_string(result);
- msg.c_str());
+ void iMesh_destroyTag(iMesh_Instance instance,
+ /*in*/ iBase_TagHandle tag_handle,
+ /*in*/ const int forced, int *err)
+ // might need to check if it's used first
+ if (false == forced) {
+ MBRange ents;
+ MBTag this_tag = TAG_HANDLE(tag_handle);
+ for (MBEntityType this_type = MBVERTEX; this_type != MBMAXTYPE; this_type++) {
+ result = MBI->get_entities_by_type_and_tag(0, this_type, &this_tag, NULL, 1,
+ ents, MBInterface::UNION);
+ std::string msg("iMesh_destroyTag: problem finding tag., with error type: ");
+ msg += MBI->get_error_string(result);
+ msg.c_str());
+ else if (!ents.empty()) {
+ iMesh_processError(iBase_FAILURE, "iMesh_destroyTag: forced=false and entities"
+ " are still assigned this tag.");
+ RETURN(iBase_FAILURE);
- else if (!ents.empty()) {
- iMesh_processError(iBase_FAILURE, "iMesh_destroyTag: forced=false and entities"
- " are still assigned this tag.");
- RETURN(iBase_FAILURE);
- // ok, good to go - either forced or no entities with this tag
- MBErrorCode result = MBI->tag_delete(TAG_HANDLE(tag_handle));
- if (MB_SUCCESS != result && MB_TAG_NOT_FOUND != result)
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_destroyTag: problem deleting tag.");
+ // ok, good to go - either forced or no entities with this tag
+ MBErrorCode result = MBI->tag_delete(TAG_HANDLE(tag_handle));
+ if (MB_SUCCESS != result && MB_TAG_NOT_FOUND != result)
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_destroyTag: problem deleting tag.");
- RETURN(iBase_ERROR_MAP[result]);
-void iMesh_getTagName(iMesh_Instance instance,
- /*in*/ const iBase_TagHandle tag_handle,
- char *out_data, int *err,
- int out_data_len)
- static ::std::string name;
- MBErrorCode result = MBI->tag_get_name(TAG_HANDLE(tag_handle), name);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagName: problem getting name.")
- else
+ void iMesh_getTagName(iMesh_Instance instance,
+ /*in*/ const iBase_TagHandle tag_handle,
+ char *out_data, int *err,
+ int out_data_len)
+ static ::std::string name;
+ MBErrorCode result = MBI->tag_get_name(TAG_HANDLE(tag_handle), name);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagName: problem getting name.")
+ else
- strncpy(out_data, name.c_str(), out_data_len);
+ strncpy(out_data, name.c_str(), out_data_len);
-void iMesh_getTagType (iMesh_Instance instance,
- int *value_type, int *err)
- MBDataType this_type;
- MBErrorCode result = MBI->tag_get_data_type(TAG_HANDLE(tag_handle),
- this_type);
- if (MB_SUCCESS != result) {
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagType: problem getting type.");
- *value_type = iBase_BYTES;
- else
+ void iMesh_getTagType (iMesh_Instance instance,
+ int *value_type, int *err)
- *value_type = tstt_data_type_table[this_type];
+ MBDataType this_type;
+ MBErrorCode result = MBI->tag_get_data_type(TAG_HANDLE(tag_handle),
+ this_type);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagType: problem getting type.");
+ *value_type = iBase_BYTES;
+ else
+ *value_type = tstt_data_type_table[this_type];
-void iMesh_getTagSizeValues(iMesh_Instance instance,
- int *tag_size_val, int *err)
- MBErrorCode result = MBI->tag_get_size(TAG_HANDLE(tag_handle), *tag_size_val);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagSize: problem getting size.")
- else {
- int this_type;
- int success;
- iMesh_getTagType(instance, tag_handle, &this_type, &success);
- if (iBase_ERROR_MAP[success] != iBase_SUCCESS)
- return;
- switch (this_type) {
- *tag_size_val /= sizeof(int);
- break;
- *tag_size_val /= sizeof(double);
- break;
- *tag_size_val /= sizeof(MBEntityHandle);
- break;
- case iBase_BYTES:
- break;
+ void iMesh_getTagSizeValues(iMesh_Instance instance,
+ int *tag_size_val, int *err)
+ MBErrorCode result = MBI->tag_get_size(TAG_HANDLE(tag_handle), *tag_size_val);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagSize: problem getting size.")
+ else {
+ int this_type;
+ int success;
+ iMesh_getTagType(instance, tag_handle, &this_type, &success);
+ if (iBase_ERROR_MAP[success] != iBase_SUCCESS)
+ return;
+ switch (this_type) {
+ *tag_size_val /= sizeof(int);
+ break;
+ *tag_size_val /= sizeof(double);
+ break;
+ *tag_size_val /= sizeof(MBEntityHandle);
+ break;
+ case iBase_BYTES:
+ break;
-void iMesh_getTagSizeBytes(iMesh_Instance instance,
- int *tag_size_bytes, int *err)
- MBErrorCode result = MBI->tag_get_size(TAG_HANDLE(tag_handle), *tag_size_bytes);
- else {
+ void iMesh_getTagSizeBytes(iMesh_Instance instance,
+ int *tag_size_bytes, int *err)
+ MBErrorCode result = MBI->tag_get_size(TAG_HANDLE(tag_handle), *tag_size_bytes);
+ else {
-void iMesh_getTagHandle(iMesh_Instance instance,
- iBase_TagHandle *tag_handle, int *err,
- const int tag_name_len)
- MBErrorCode result = MBI->tag_get_handle(tag_name, (MBTag&)*tag_handle);
+ void iMesh_getTagHandle(iMesh_Instance instance,
+ iBase_TagHandle *tag_handle, int *err,
+ const int tag_name_len)
+ MBErrorCode result = MBI->tag_get_handle(tag_name, (MBTag&)*tag_handle);
- std::string msg("iMesh_getTagHandle: problem getting handle for tag named '");
- msg += std::string(tag_name) + std::string("'");
- iMesh_processError(iBase_ERROR_MAP[result], msg.c_str());
- *tag_handle = 0;
- return;
+ std::string msg("iMesh_getTagHandle: problem getting handle for tag named '");
+ msg += std::string(tag_name) + std::string("'");
+ iMesh_processError(iBase_ERROR_MAP[result], msg.c_str());
+ *tag_handle = 0;
+ return;
+ void iMesh_setEntSetData (iMesh_Instance instance,
+ /*in*/ iBase_EntitySetHandle entity_set_handle,
+ /*in*/ const char* tag_value,
+ /*in*/ const int , int *err)
-void iMesh_setEntSetData (iMesh_Instance instance,
- /*in*/ iBase_EntitySetHandle entity_set_handle,
- /*in*/ const char* tag_value,
- /*in*/ const int , int *err)
- if (entity_set_handle == 0)
- // set the tag data on this entity set
- result = MBI->tag_set_data(TAG_HANDLE(tag_handle),
- NULL, 0, tag_value);
- else
- HANDLE_ARRAY_PTR(&entity_set_handle), 1, tag_value);
+ if (entity_set_handle == 0)
+ // set the tag data on this entity set
+ result = MBI->tag_set_data(TAG_HANDLE(tag_handle),
+ NULL, 0, tag_value);
+ else
+ HANDLE_ARRAY_PTR(&entity_set_handle), 1, tag_value);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_setEntSetData: error");
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_setEntSetData: error");
-void iMesh_setEntSetIntData (iMesh_Instance instance,
- /*in*/ const int tag_value, int *err)
- iMesh_setEntSetData(instance, entity_set, tag_handle,
- reinterpret_cast<const char*>(&tag_value),
- sizeof(int), err);
+ void iMesh_setEntSetIntData (iMesh_Instance instance,
+ /*in*/ const int tag_value, int *err)
+ iMesh_setEntSetData(instance, entity_set, tag_handle,
+ reinterpret_cast<const char*>(&tag_value),
+ sizeof(int), err);
-void iMesh_setEntSetDblData (iMesh_Instance instance,
- /*in*/ const double tag_value, int *err)
- sizeof(double), err);
+ void iMesh_setEntSetDblData (iMesh_Instance instance,
+ /*in*/ const double tag_value, int *err)
+ sizeof(double), err);
-void iMesh_setEntSetBoolData (iMesh_Instance instance,
- /*in*/ const bool tag_value, int *err)
- sizeof(bool), err);
+ void iMesh_setEntSetBoolData (iMesh_Instance instance,
+ /*in*/ const bool tag_value, int *err)
+ sizeof(bool), err);
-void iMesh_setEntSetEHData (iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle tag_value, int *err)
- sizeof(iBase_EntityHandle), err);
+ void iMesh_setEntSetEHData (iMesh_Instance instance,
+ /*in*/ const iBase_EntityHandle tag_value, int *err)
+ sizeof(iBase_EntityHandle), err);
-void iMesh_getEntSetData (iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set_handle,
- /*inout*/ char** tag_value,
- /*inout*/ int* tag_value_allocated,
- /*inout*/ int* tag_value_size, int *err)
- MBEntityHandle eh = ENTITY_HANDLE(entity_set_handle);
- MBTag tag = TAG_HANDLE(tag_handle);
+ void iMesh_getEntSetData (iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle entity_set_handle,
+ /*inout*/ char** tag_value,
+ /*inout*/ int* tag_value_allocated,
+ /*inout*/ int* tag_value_size, int *err)
+ MBEntityHandle eh = ENTITY_HANDLE(entity_set_handle);
+ MBTag tag = TAG_HANDLE(tag_handle);
- int tag_size;
- MBErrorCode result = MBI->tag_get_size(tag, tag_size);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntSetData: couldn't get tag size.");
+ int tag_size;
+ MBErrorCode result = MBI->tag_get_size(tag, tag_size);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntSetData: couldn't get tag size.");
- else {
- TAG_CHECK_SIZE(*tag_value, *tag_value_allocated, tag_size);
+ else {
+ TAG_CHECK_SIZE(*tag_value, *tag_value_allocated, tag_size);
- if (eh == 0)
- result = MBI->tag_get_data(tag, NULL, 0, *tag_value);
- else
- result = MBI->tag_get_data(tag, &eh, 1, *tag_value);
+ if (eh == 0)
+ result = MBI->tag_get_data(tag, NULL, 0, *tag_value);
+ else
+ result = MBI->tag_get_data(tag, &eh, 1, *tag_value);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntSetData didn't succeed.");
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntSetData didn't succeed.");
+ else
+ *tag_value_size = tag_size;
- else
- *tag_value_size = tag_size;
-void iMesh_getEntSetIntData (iMesh_Instance instance,
- int *out_data, int *err)
- char *tag_ptr = reinterpret_cast<char*>(out_data);
- int dum_size = sizeof(int);
- iMesh_getEntSetData(instance, entity_set, tag_handle, &tag_ptr,
- &dum_size, &dum_size, err);
+ void iMesh_getEntSetIntData (iMesh_Instance instance,
+ int *out_data, int *err)
+ char *tag_ptr = reinterpret_cast<char*>(out_data);
+ int dum_size = sizeof(int);
+ iMesh_getEntSetData(instance, entity_set, tag_handle, &tag_ptr,
+ &dum_size, &dum_size, err);
-void iMesh_getEntSetDblData (iMesh_Instance instance,
- double *out_data, int *err)
- int tag_size = sizeof(double);
- &tag_size, &tag_size, err);
+ void iMesh_getEntSetDblData (iMesh_Instance instance,
+ double *out_data, int *err)
+ int tag_size = sizeof(double);
+ &tag_size, &tag_size, err);
-void iMesh_getEntSetBoolData (iMesh_Instance instance,
- int tag_size = sizeof(bool);
+ void iMesh_getEntSetBoolData (iMesh_Instance instance,
+ int tag_size = sizeof(bool);
-void iMesh_getEntSetEHData (iMesh_Instance instance,
- iBase_EntityHandle *out_data, int *err)
- int tag_size = sizeof(MBEntityHandle);
+ void iMesh_getEntSetEHData (iMesh_Instance instance,
+ iBase_EntityHandle *out_data, int *err)
+ int tag_size = sizeof(MBEntityHandle);
-void iMesh_getAllEntSetTags (iMesh_Instance instance,
- /*out*/ iBase_TagHandle** tag_handles,
- /*out*/ int* tag_handles_allocated,
- /*out*/ int* tag_handles_size, int *err)
- std::vector<MBTag> all_tags;
+ void iMesh_getAllEntSetTags (iMesh_Instance instance,
+ /*out*/ iBase_TagHandle** tag_handles,
+ /*out*/ int* tag_handles_allocated,
+ /*out*/ int* tag_handles_size, int *err)
+ std::vector<MBTag> all_tags;
- MBErrorCode result = MBI->tag_get_tags_on_entity(eh, all_tags);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_entitysetGetAllTagHandles failed.");
+ MBErrorCode result = MBI->tag_get_tags_on_entity(eh, all_tags);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_entitysetGetAllTagHandles failed.");
- // now put those tag handles into sidl array
- CHECK_SIZE(*tag_handles, *tag_handles_allocated,
- (int)all_tags.size(), iBase_TagHandle, iBase_MEMORY_ALLOCATION_FAILED);
- memcpy(*tag_handles, &all_tags[0], all_tags.size()*sizeof(MBTag));
+ // now put those tag handles into sidl array
+ CHECK_SIZE(*tag_handles, *tag_handles_allocated,
+ (int)all_tags.size(), iBase_TagHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ memcpy(*tag_handles, &all_tags[0], all_tags.size()*sizeof(MBTag));
- if (MB_SUCCESS == result)
- *tag_handles_size = (int) all_tags.size();
+ if (MB_SUCCESS == result)
+ *tag_handles_size = (int) all_tags.size();
-void iMesh_rmvEntSetTag (iMesh_Instance instance,
- /*in*/ const iBase_TagHandle tag_handle, int *err)
- if (0 == entity_set_handle) {
- int success;
- iMesh_getRootSet(instance, &entity_set_handle, &success);
- if (iBase_ERROR_MAP[success] != iBase_SUCCESS) RETURN(iBase_ERROR_MAP[success]);
- MBErrorCode result = MBI->tag_delete_data(TAG_HANDLE(tag_handle),
- HANDLE_ARRAY_PTR(&entity_set_handle), 1);
+ void iMesh_rmvEntSetTag (iMesh_Instance instance,
+ /*in*/ const iBase_TagHandle tag_handle, int *err)
+ if (0 == entity_set_handle) {
+ int success;
+ iMesh_getRootSet(instance, &entity_set_handle, &success);
+ if (iBase_ERROR_MAP[success] != iBase_SUCCESS) RETURN(iBase_ERROR_MAP[success]);
+ MBErrorCode result = MBI->tag_delete_data(TAG_HANDLE(tag_handle),
+ HANDLE_ARRAY_PTR(&entity_set_handle), 1);
- // don't check return; this tag may have never been set on the entity set
+ // don't check return; this tag may have never been set on the entity set
-void iMesh_setVtxCoords (iMesh_Instance instance,
- /*in*/ iBase_EntityHandle vertex_handle,
- /*in*/ const double x, /*in*/ const double y,
- /*in*/ const double z, int *err)
+ void iMesh_setVtxCoords (iMesh_Instance instance,
+ /*in*/ iBase_EntityHandle vertex_handle,
+ /*in*/ const double x, /*in*/ const double y,
+ /*in*/ const double z, int *err)
- const double xyz[3] = {x, y, z};
+ const double xyz[3] = {x, y, z};
- iMesh_setVtxArrCoords(instance, &vertex_handle, 1, iBase_BLOCKED,
- xyz, 3, err);
-void iMesh_createVtx(iMesh_Instance instance,
- /*out*/ iBase_EntityHandle* new_vertex_handle, int *err)
- int dum = 1;
- iMesh_createVtxArr(instance, 1, iBase_BLOCKED,
- xyz, 3, &new_vertex_handle, &dum, &dum, err);
-void iMesh_createEnt(iMesh_Instance instance,
- /*out*/ iBase_EntityHandle* new_entity_handle,
- /*out*/ int* status, int *err)
- if (0 == lower_order_entity_handles_size) {
- "iMesh_createEnt: need more than zero lower order entities.");
- RETURN(iBase_INVALID_ENTITY_COUNT);
+ iMesh_setVtxArrCoords(instance, &vertex_handle, 1, iBase_BLOCKED,
+ xyz, 3, err);
- int dum = 1;
- iMesh_createEntArr(instance, new_entity_topology,
- lower_order_entity_handles,
- lower_order_entity_handles_size,
- &new_entity_handle,
- &dum, &dum,
- &status, &dum, &dum, err);
-void iMesh_deleteEnt(iMesh_Instance instance,
- /*in*/ iBase_EntityHandle entity_handle, int *err)
- iMesh_deleteEntArr(instance, &entity_handle, 1, err);
-void iMesh_getArrData (iMesh_Instance instance,
- /*inout*/ char** tag_values,
- /*inout*/int* tag_values_allocated,
- /*out*/ int* tag_values_size, int *err)
- const MBEntityHandle *ents = reinterpret_cast<const MBEntityHandle *>(entity_handles);
- int tag_size;
- int nerr=-1; char tagn[64], msg[256];
- iMesh_getTagName(instance, tag_handle, tagn, &nerr, sizeof(tagn));
- snprintf(msg, sizeof(msg), "iMesh_getArrData: couldn't get size for tag \"%s\"",
- nerr==0?tagn:"unknown");
- iMesh_processError(iBase_ERROR_MAP[result], msg);
+ void iMesh_createVtx(iMesh_Instance instance,
+ /*out*/ iBase_EntityHandle* new_vertex_handle, int *err)
+ int dum = 1;
+ iMesh_createVtxArr(instance, 1, iBase_BLOCKED,
+ xyz, 3, &new_vertex_handle, &dum, &dum, err);
+ void iMesh_createEnt(iMesh_Instance instance,
+ /*out*/ iBase_EntityHandle* new_entity_handle,
+ /*out*/ int* status, int *err)
+ if (0 == lower_order_entity_handles_size) {
+ "iMesh_createEnt: need more than zero lower order entities.");
+ RETURN(iBase_INVALID_ENTITY_COUNT);
- RETURN(iBase_ERROR_MAP[MB_SUCCESS]);
+ int dum = 1;
+ iMesh_createEntArr(instance, new_entity_topology,
+ lower_order_entity_handles,
+ lower_order_entity_handles_size,
+ &new_entity_handle,
+ &dum, &dum,
+ &status, &dum, &dum, err);
- TAG_CHECK_SIZE(*tag_values, *tag_values_allocated,
- tag_size * entity_handles_size);
- result = MBI->tag_get_data(tag, ents, entity_handles_size,
- *tag_values);
- if (MB_SUCCESS != result && MB_TAG_NOT_FOUND != result) {
- snprintf(msg, sizeof(msg), "iMesh_getArrData: didn't succeed for tag \"%s\"",
+ void iMesh_deleteEnt(iMesh_Instance instance,
+ /*in*/ iBase_EntityHandle entity_handle, int *err)
+ iMesh_deleteEntArr(instance, &entity_handle, 1, err);
- else if (MB_TAG_NOT_FOUND == result) {
- snprintf(msg, sizeof(msg), "iMesh_getArrData: tag \"%s\" not found",
- *tag_values_size = tag_size * entity_handles_size;
-void iMesh_getIntArrData (iMesh_Instance instance,
+ void iMesh_getArrData (iMesh_Instance instance,
- /*inout*/ int** tag_values,
- /*inout*/ int* tag_values_allocated,
+ /*inout*/ char** tag_values,
+ /*inout*/int* tag_values_allocated,
- *tag_values_allocated *= sizeof(int);
- *tag_values_size *= sizeof(int);
- iMesh_getArrData(instance, entity_handles,
- entity_handles_size, tag_handle,
- reinterpret_cast<char**>(tag_values),
- tag_values_allocated,
- tag_values_size, err);
- *tag_values_allocated /= sizeof(int);
- *tag_values_size /= sizeof(int);
+ const MBEntityHandle *ents = reinterpret_cast<const MBEntityHandle *>(entity_handles);
+ int tag_size;
+ int nerr=-1; char tagn[64], msg[256];
+ iMesh_getTagName(instance, tag_handle, tagn, &nerr, sizeof(tagn));
+ snprintf(msg, sizeof(msg), "iMesh_getArrData: couldn't get size for tag \"%s\"",
+ nerr==0?tagn:"unknown");
+ iMesh_processError(iBase_ERROR_MAP[result], msg);
-void iMesh_getDblArrData (iMesh_Instance instance,
- /*inout*/ double** tag_values,
- *tag_values_allocated *= sizeof(double);
- *tag_values_size *= sizeof(double);
- tag_values_allocated, tag_values_size, err);
- *tag_values_allocated /= sizeof(double);
- *tag_values_size /= sizeof(double);
+ RETURN(iBase_ERROR_MAP[MB_SUCCESS]);
+ TAG_CHECK_SIZE(*tag_values, *tag_values_allocated,
+ tag_size * entity_handles_size);
-void iMesh_getBoolArrData (iMesh_Instance instance,
- /*inout*/ bool** tag_value,
- /*out*/ int* tag_value_size, int *err)
- *tag_value_allocated *= sizeof(bool);
- *tag_value_size *= sizeof(bool);
- reinterpret_cast<char**>(tag_value),
- tag_value_allocated, tag_value_size, err);
- *tag_value_allocated /= sizeof(bool);
- *tag_value_size /= sizeof(bool);
+ result = MBI->tag_get_data(tag, ents, entity_handles_size,
+ *tag_values);
-void iMesh_getEHArrData (iMesh_Instance instance,
- /*inout*/ iBase_EntityHandle** tag_value,
- *tag_value_allocated *= sizeof(iBase_EntityHandle);
- *tag_value_size *= sizeof(iBase_EntityHandle);
- tag_value_size, err);
- *tag_value_allocated /= sizeof(iBase_EntityHandle);
- *tag_value_size /= sizeof(iBase_EntityHandle);
+ if (MB_SUCCESS != result && MB_TAG_NOT_FOUND != result) {
+ snprintf(msg, sizeof(msg), "iMesh_getArrData: didn't succeed for tag \"%s\"",
+ else if (MB_TAG_NOT_FOUND == result) {
+ snprintf(msg, sizeof(msg), "iMesh_getArrData: tag \"%s\" not found",
-void iMesh_setArrData (iMesh_Instance instance,
- /*in*/ const char* tag_values,
- /*in*/ const int tag_values_size, int *err)
+ *tag_values_size = tag_size * entity_handles_size;
- MBErrorCode result = MBI->tag_set_data(TAG_HANDLE(tag_handle),
- HANDLE_ARRAY_PTR(entity_handles),
- tag_values);
- std::string msg("iMesh_setArrData didn't succeed, with error type: ");
+ void iMesh_getIntArrData (iMesh_Instance instance,
+ /*inout*/ int** tag_values,
+ /*inout*/ int* tag_values_allocated,
+ /*out*/ int* tag_values_size, int *err)
+ *tag_values_allocated *= sizeof(int);
+ *tag_values_size *= sizeof(int);
+ iMesh_getArrData(instance, entity_handles,
+ entity_handles_size, tag_handle,
+ reinterpret_cast<char**>(tag_values),
+ tag_values_allocated,
+ tag_values_size, err);
+ *tag_values_allocated /= sizeof(int);
+ *tag_values_size /= sizeof(int);
-void iMesh_setIntArrData (iMesh_Instance instance,
- /*in*/ const int* tag_values,
- iMesh_setArrData(instance, entity_handles,
- reinterpret_cast<const char*>(tag_values),
- sizeof(int)*tag_values_size, err);
+ void iMesh_getDblArrData (iMesh_Instance instance,
+ /*inout*/ double** tag_values,
+ *tag_values_allocated *= sizeof(double);
+ *tag_values_size *= sizeof(double);
+ tag_values_allocated, tag_values_size, err);
+ *tag_values_allocated /= sizeof(double);
+ *tag_values_size /= sizeof(double);
-void iMesh_setDblArrData (iMesh_Instance instance,
+ void iMesh_getBoolArrData (iMesh_Instance instance,
+ /*inout*/ bool** tag_value,
+ /*out*/ int* tag_value_size, int *err)
+ *tag_value_allocated *= sizeof(bool);
+ *tag_value_size *= sizeof(bool);
+ reinterpret_cast<char**>(tag_value),
+ tag_value_allocated, tag_value_size, err);
+ *tag_value_allocated /= sizeof(bool);
+ *tag_value_size /= sizeof(bool);
+ void iMesh_getEHArrData (iMesh_Instance instance,
+ /*inout*/ iBase_EntityHandle** tag_value,
+ *tag_value_allocated *= sizeof(iBase_EntityHandle);
+ *tag_value_size *= sizeof(iBase_EntityHandle);
+ tag_value_size, err);
+ *tag_value_allocated /= sizeof(iBase_EntityHandle);
+ *tag_value_size /= sizeof(iBase_EntityHandle);
+ void iMesh_setArrData (iMesh_Instance instance,
- /*in*/ const double* tag_values,
+ /*in*/ const char* tag_values,
- sizeof(double)*tag_values_size, err);
-void iMesh_setBoolArrData (iMesh_Instance instance,
- /*in*/ const bool* tag_values,
- sizeof(bool)*tag_values_size, err);
+ MBErrorCode result = MBI->tag_set_data(TAG_HANDLE(tag_handle),
+ HANDLE_ARRAY_PTR(entity_handles),
+ tag_values);
+ std::string msg("iMesh_setArrData didn't succeed, with error type: ");
-void iMesh_setEHArrData (iMesh_Instance instance,
+ void iMesh_setIntArrData (iMesh_Instance instance,
+ /*in*/ const int* tag_values,
+ /*in*/ const int tag_values_size, int *err)
+ iMesh_setArrData(instance, entity_handles,
+ reinterpret_cast<const char*>(tag_values),
+ sizeof(int)*tag_values_size, err);
+ void iMesh_setDblArrData (iMesh_Instance instance,
+ /*in*/ const double* tag_values,
+ sizeof(double)*tag_values_size, err);
+ void iMesh_setBoolArrData (iMesh_Instance instance,
+ /*in*/ const bool* tag_values,
+ sizeof(bool)*tag_values_size, err);
+ void iMesh_setEHArrData (iMesh_Instance instance,
+ /*in*/ const iBase_EntityHandle* tag_values,
+ sizeof(iBase_EntityHandle)*tag_values_size, err);
+ void iMesh_rmvArrTag (iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle* tag_values,
- sizeof(iBase_EntityHandle)*tag_values_size, err);
-void iMesh_rmvArrTag (iMesh_Instance instance,
-void iMesh_getData (iMesh_Instance instance,
- /*out*/ char** tag_value,
- /*inout*/ int *tag_value_allocated,
- /*out*/ int *tag_value_size, int *err)
- iMesh_getArrData(instance, &entity_handle, 1,
- tag_handle, tag_value, tag_value_allocated,
-void iMesh_getIntData (iMesh_Instance instance,
+ void iMesh_getData (iMesh_Instance instance,
- char *val_ptr = reinterpret_cast<char*>(out_data);
- int val_size = sizeof(int);
- tag_handle, &val_ptr, &val_size, &val_size, err);
+ /*out*/ char** tag_value,
+ /*inout*/ int *tag_value_allocated,
+ /*out*/ int *tag_value_size, int *err)
+ iMesh_getArrData(instance, &entity_handle, 1,
+ tag_handle, tag_value, tag_value_allocated,
-void iMesh_getDblData (iMesh_Instance instance,
- int val_size = sizeof(double);
+ void iMesh_getIntData (iMesh_Instance instance,
+ /*in*/ const iBase_EntityHandle entity_handle,
+ char *val_ptr = reinterpret_cast<char*>(out_data);
+ int val_size = sizeof(int);
+ tag_handle, &val_ptr, &val_size, &val_size, err);
-void iMesh_getBoolData (iMesh_Instance instance,
- // make the data size a full word, because of sidl needing at least a full word
+ void iMesh_getDblData (iMesh_Instance instance,
+ int val_size = sizeof(double);
-void iMesh_getEHData (iMesh_Instance instance,
- int dum = sizeof(iBase_EntityHandle);
- tag_handle, &val_ptr, &dum, &dum, err);
+ void iMesh_getBoolData (iMesh_Instance instance,
+ // make the data size a full word, because of sidl needing at least a full word
-void iMesh_setData (iMesh_Instance instance,
- /*in*/ const int tag_value_size, int *err)
- iMesh_setArrData(instance, &entity_handle, 1,
- tag_handle, tag_value, tag_value_size, err);
+ void iMesh_getEHData (iMesh_Instance instance,
+ int dum = sizeof(iBase_EntityHandle);
+ tag_handle, &val_ptr, &dum, &dum, err);
-void iMesh_setIntData (iMesh_Instance instance,
+ void iMesh_setData (iMesh_Instance instance,
- tag_handle,
+ /*in*/ const int tag_value_size, int *err)
+ iMesh_setArrData(instance, &entity_handle, 1,
+ tag_handle, tag_value, tag_value_size, err);
-void iMesh_setDblData (iMesh_Instance instance,
+ void iMesh_setIntData (iMesh_Instance instance,
+ tag_handle,
+ void iMesh_setDblData (iMesh_Instance instance,
- tag_handle,
+ tag_handle,
-void iMesh_setBoolData (iMesh_Instance instance,
- tag_handle,
+ void iMesh_setBoolData (iMesh_Instance instance,
+ tag_handle,
-void iMesh_setEHData (iMesh_Instance instance,
- tag_handle,
+ void iMesh_setEHData (iMesh_Instance instance,
+ tag_handle,
-void iMesh_getAllTags (iMesh_Instance instance,
- /*inout*/ iBase_TagHandle** tag_handles,
- /*inout*/ int* tag_handles_allocated,
+ void iMesh_getAllTags (iMesh_Instance instance,
+ /*inout*/ iBase_TagHandle** tag_handles,
+ /*inout*/ int* tag_handles_allocated,
- MBErrorCode result = MBI->tag_get_tags_on_entity(ENTITY_HANDLE(entity_handle), all_tags);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getAllTags failed.");
+ MBErrorCode result = MBI->tag_get_tags_on_entity(ENTITY_HANDLE(entity_handle), all_tags);
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getAllTags failed.");
- *tag_handles_size = all_tags.size();
+ *tag_handles_size = all_tags.size();
-void iMesh_rmvTag (iMesh_Instance instance,
- iMesh_rmvArrTag(instance, &entity_handle, 1, tag_handle, err);
+ void iMesh_rmvTag (iMesh_Instance instance,
+ iMesh_rmvArrTag(instance, &entity_handle, 1, tag_handle, err);
-void iMesh_initEntIter (iMesh_Instance instance,
- /*in*/ const int requested_entity_type,
- /*in*/ const int requested_entity_topology,
- /*out*/ iMesh_EntityIterator* entity_iterator,
- int *err)
- iMesh_initEntArrIter(instance, entity_set_handle, requested_entity_type,
- requested_entity_topology, 1, entity_iterator,
- err);
+ void iMesh_initEntIter (iMesh_Instance instance,
+ /*in*/ const int requested_entity_type,
+ /*in*/ const int requested_entity_topology,
+ /*out*/ iMesh_EntityIterator* entity_iterator,
+ int *err)
+ iMesh_initEntArrIter(instance, entity_set_handle, requested_entity_type,
+ requested_entity_topology, 1, entity_iterator,
+ err);
-void iMesh_getNextEntIter (iMesh_Instance instance,
- /*in*/ iMesh_EntityIterator entity_iterator,
- /*out*/ iBase_EntityHandle* entity_handle,
- int *is_end, int *err)
- int eh_size = 1;
- iMesh_getNextEntArrIter(instance,
- entity_iterator, &entity_handle, &eh_size, &eh_size, is_end, err);
+ void iMesh_getNextEntIter (iMesh_Instance instance,
+ /*in*/ iMesh_EntityIterator entity_iterator,
+ /*out*/ iBase_EntityHandle* entity_handle,
+ int *is_end, int *err)
+ int eh_size = 1;
+ iMesh_getNextEntArrIter(instance,
+ entity_iterator, &entity_handle, &eh_size, &eh_size, is_end, err);
-void iMesh_resetEntIter (iMesh_Instance instance,
- /*in*/ iMesh_EntityIterator entity_iterator, int *err)
- iMesh_resetEntArrIter(instance, entity_iterator, err);
+ void iMesh_resetEntIter (iMesh_Instance instance,
+ /*in*/ iMesh_EntityIterator entity_iterator, int *err)
+ iMesh_resetEntArrIter(instance, entity_iterator, err);
-void iMesh_endEntIter (iMesh_Instance instance,
- iMesh_endEntArrIter(instance, entity_iterator, err);
+ void iMesh_endEntIter (iMesh_Instance instance,
+ iMesh_endEntArrIter(instance, entity_iterator, err);
-void iMesh_getEntTopo (iMesh_Instance instance,
- int *out_topo, int *err)
- *out_topo = tstt_topology_table[MBI->type_from_handle(ENTITY_HANDLE(entity_handle))];
+ void iMesh_getEntTopo (iMesh_Instance instance,
+ int *out_topo, int *err)
+ *out_topo = tstt_topology_table[MBI->type_from_handle(ENTITY_HANDLE(entity_handle))];
-void iMesh_getEntType (iMesh_Instance instance,
- int *out_type, int *err)
- *out_type = tstt_type_table[MBI->type_from_handle(ENTITY_HANDLE(entity_handle))];
+ void iMesh_getEntType (iMesh_Instance instance,
+ int *out_type, int *err)
+ *out_type = tstt_type_table[MBI->type_from_handle(ENTITY_HANDLE(entity_handle))];
-void iMesh_getVtxCoord (iMesh_Instance instance,
- /*in*/ const iBase_EntityHandle vertex_handle,
- /*out*/ double *x, /*out*/ double *y, /*out*/ double *z, int *err)
- int order = iBase_BLOCKED;
- double xyz[3], *tmp_xyz = xyz;
- int dum = 3;
+ void iMesh_getVtxCoord (iMesh_Instance instance,
+ /*in*/ const iBase_EntityHandle vertex_handle,
+ /*out*/ double *x, /*out*/ double *y, /*out*/ double *z, int *err)
+ int order = iBase_BLOCKED;
+ double xyz[3], *tmp_xyz = xyz;
+ int dum = 3;
- iMesh_getVtxArrCoords(instance,
- &vertex_handle, 1, &order,
- &tmp_xyz, &dum, &dum, err);
- if (iBase_SUCCESS == *err) {
- *x = xyz[0]; *y = xyz[1]; *z = xyz[2];
+ iMesh_getVtxArrCoords(instance,
+ &vertex_handle, 1, &order,
+ &tmp_xyz, &dum, &dum, err);
+ if (iBase_SUCCESS == *err) {
+ *x = xyz[0]; *y = xyz[1]; *z = xyz[2];
-void iMesh_getEntAdj(iMesh_Instance instance,
- /*in*/ const int entity_type_requested,
- /*inout*/ iBase_EntityHandle** adj_entity_handles,
- /*inout*/ int* adj_entity_handles_allocated,
- /*out*/ int* adj_entity_handles_size, int *err)
- int offsets[2];
- int *offsets_ptr = offsets;
- int offset_size, offset_allocated = 2;
+ void iMesh_getEntAdj(iMesh_Instance instance,
+ /*in*/ const int entity_type_requested,
+ /*inout*/ iBase_EntityHandle** adj_entity_handles,
+ /*inout*/ int* adj_entity_handles_allocated,
+ /*out*/ int* adj_entity_handles_size, int *err)
+ int offsets[2];
+ int *offsets_ptr = offsets;
+ int offset_size, offset_allocated = 2;
- iMesh_getEntArrAdj(instance,
- &entity_handle, 1, entity_type_requested,
- adj_entity_handles, adj_entity_handles_allocated,
- adj_entity_handles_size, &offsets_ptr, &offset_allocated,
- &offset_size, err);
+ iMesh_getEntArrAdj(instance,
+ &entity_handle, 1, entity_type_requested,
+ adj_entity_handles, adj_entity_handles_allocated,
+ adj_entity_handles_size, &offsets_ptr, &offset_allocated,
+ &offset_size, err);
-void iMesh_getEnt2ndAdj( iMesh_Instance instance,
- iBase_EntityHandle entity_handle,
- iBase_EntityHandle** adj_entities,
- int* adj_entities_allocated,
- int* adj_entities_size,
- int* err )
- int offsets[2];
+ void iMesh_getEnt2ndAdj( iMesh_Instance instance,
+ iBase_EntityHandle entity_handle,
+ iBase_EntityHandle** adj_entities,
+ int* adj_entities_allocated,
+ int* adj_entities_size,
+ int* err )
+ int offsets[2];
- iMesh_getEntArr2ndAdj(instance,
- &entity_handle, 1, order_adjacent_key,
- adj_entities, adj_entities_allocated,
- adj_entities_size, &offsets_ptr, &offset_allocated,
+ iMesh_getEntArr2ndAdj(instance,
+ &entity_handle, 1, order_adjacent_key,
+ adj_entities, adj_entities_allocated,
+ adj_entities_size, &offsets_ptr, &offset_allocated,
-void iMesh_subtract(iMesh_Instance instance,
- /*in*/ const iBase_EntitySetHandle entity_set_1,
- /*in*/ const iBase_EntitySetHandle entity_set_2,
- /*out*/ iBase_EntitySetHandle* result_entity_set, int *err)
- MBEntityHandle temp_set;
- MBEntityHandle set1 = ENTITY_HANDLE(entity_set_1),
- set2 = ENTITY_HANDLE(entity_set_2);
- MBErrorCode result = MBI->create_meshset(MESHSET_SET, temp_set);
- if (MB_SUCCESS == result) result = MBI->unite_meshset(temp_set, set1);
- if (MB_SUCCESS == result) result = MBI->subtract_meshset(temp_set, set2);
+ void iMesh_subtract(iMesh_Instance instance,
+ /*in*/ const iBase_EntitySetHandle entity_set_1,
+ /*in*/ const iBase_EntitySetHandle entity_set_2,
+ /*out*/ iBase_EntitySetHandle* result_entity_set, int *err)
+ MBEntityHandle temp_set;
+ MBEntityHandle set1 = ENTITY_HANDLE(entity_set_1),
+ set2 = ENTITY_HANDLE(entity_set_2);
+ MBErrorCode result = MBI->create_meshset(MESHSET_SET, temp_set);
+ if (MB_SUCCESS == result) result = MBI->unite_meshset(temp_set, set1);
+ if (MB_SUCCESS == result) result = MBI->subtract_meshset(temp_set, set2);
- if (result != MB_SUCCESS) {
- std::string msg("iMesh_entitysetSubtract:\
+ if (result != MB_SUCCESS) {
+ std::string msg("iMesh_entitysetSubtract:\
ERROR subtract failed, with error type: ");
- MBI->delete_entities(&temp_set, 1);
+ MBI->delete_entities(&temp_set, 1);
- *result_entity_set = (iBase_EntitySetHandle)temp_set;
+ *result_entity_set = (iBase_EntitySetHandle)temp_set;
-void iMesh_intersect(iMesh_Instance instance,
- if (MB_SUCCESS == result) result = MBI->intersect_meshset(temp_set, set2);
- std::string msg("iMesh_entitysetIntersect:\
- ERROR subtract failed, with error type: ");
+ void iMesh_intersect(iMesh_Instance instance,
+ if (MB_SUCCESS == result) result = MBI->intersect_meshset(temp_set, set2);
-void iMesh_unite(iMesh_Instance instance,
- if (MB_SUCCESS == result) result = MBI->unite_meshset(temp_set, set2);
+ std::string msg("iMesh_entitysetIntersect:\
-void iMesh_free(iBase_EntityHandle *ptr, int *err)
- free(ptr);
-#ifdef __cplusplus
-} // extern "C"
-#endif
-MBErrorCode iMesh_tag_set_vertices(iMesh_Instance instance,
- MBEntityHandle in_set,
- const int req_dimension,
- const MBEntityType req_type,
- MBTag &tag, MBRange &req_entities,
- int &num_verts, int *err)
- // get all the entities then vertices
- MBRange vertices, entities;
- entities.clear();
- MBErrorCode result = MBI->get_entities_by_handle(in_set, entities, false);
- std::string msg("MBMesh::tag_set_vertices: getting entities didn't succeed., with error type: ");
- return result;
- // remove any sets
- entities.erase(entities.lower_bound(MBENTITYSET),
- entities.upper_bound(MBENTITYSET));
+ void iMesh_unite(iMesh_Instance instance,
+ if (MB_SUCCESS == result) result = MBI->unite_meshset(temp_set, set2);
- // get vertices
- result = MBI->get_adjacencies(entities, 0, false, vertices,
- MBInterface::UNION);
- std::string msg("MBMesh::tag_set_vertices: getting vertices didn't succeed., with error type: ");
- return result;
- // tag each vertex with its index in this list
- int i = 0;
- if (tag == 0) {
- result = MBI->tag_create("__position_tag", 4, MB_TAG_DENSE, tag, &i);
- if (0 == tag) {
- std::string msg("MBMesh::tag_set_vertices: couldn't make tag., with error type: ");
+ ERROR subtract failed, with error type: ");
- return result;
- MBRange::iterator vit;
- for (vit = vertices.begin(), i = 0; vit != vertices.end(); vit++, i++) {
- result = MBI->tag_set_data(tag, &(*vit), 1, &i);
- std::string msg("MBMesh::tag_set_vertices: couldn't set pos_tag., with error type: ");
- return result;
- if (req_dimension == -1 && req_type == MBMAXTYPE) return MB_SUCCESS;
- // winnow the list for entities of the desired type and/or topology
- num_verts = 0;
- MBRange::iterator ent_it;
- MBEntityType this_type;
- for (ent_it = entities.begin(); ent_it != entities.end(); ent_it++) {
- this_type = MBI->type_from_handle(*ent_it);
- if (req_dimension == MBCN::Dimension(this_type) ||
- this_type == req_type) {
- req_entities.insert(*ent_it);
- num_verts += MBCN::VerticesPerEntity(this_type);
- return result;
-void iMesh_getEntitiesRec(iMesh_Instance instance,
- /*in*/ const int entity_type,
- /*in*/ const int entity_topology,
- /*in*/ const int recursive,
- /*out*/ iBase_EntityHandle** entity_handles,
- /*out*/ int* entity_handles_allocated,
- /*out*/ int* entity_handles_size,
- /*out*/ int *err)
- bool use_top = false;
- bool use_type = false;
- // initialize just to get rid of compiler warning
- MBEntityType type = mb_topology_table[iMesh_ALL_TOPOLOGIES];
- MBRange out_entities;
+ void iMesh_getEntitiesRec(iMesh_Instance instance,
+ /*in*/ const int entity_type,
+ /*in*/ const int entity_topology,
+ /*in*/ const int recursive,
+ /*out*/ iBase_EntityHandle** entity_handles,
+ /*out*/ int* entity_handles_allocated,
+ /*out*/ int* entity_handles_size,
+ /*out*/ int *err)
+ bool use_top = false;
+ bool use_type = false;
+ // initialize just to get rid of compiler warning
+ MBEntityType type = mb_topology_table[iMesh_ALL_TOPOLOGIES];
+ MBRange out_entities;
- if (entity_topology >= iMesh_POINT
- && entity_topology < iMesh_ALL_TOPOLOGIES) {
- type = mb_topology_table[entity_topology];
- use_top = true;
- else if (entity_type >= iBase_VERTEX
- && entity_type <= iBase_ALL_TYPES)
- use_type = true;
- else {
- iMesh_processError(iBase_ERROR_MAP[iBase_BAD_TYPE_AND_TOPO],
- "iMesh_getEntities:ERROR not valid entity type or topology");
- RETURN(iBase_ERROR_MAP[iBase_BAD_TYPE_AND_TOPO]);
+ if (entity_topology >= iMesh_POINT
+ && entity_topology < iMesh_ALL_TOPOLOGIES) {
+ type = mb_topology_table[entity_topology];
+ use_top = true;
+ else if (entity_type >= iBase_VERTEX
+ && entity_type <= iBase_ALL_TYPES)
+ use_type = true;
+ else {
+ iMesh_processError(iBase_ERROR_MAP[iBase_BAD_TYPE_AND_TOPO],
+ "iMesh_getEntities:ERROR not valid entity type or topology");
+ RETURN(iBase_ERROR_MAP[iBase_BAD_TYPE_AND_TOPO]);
- MBEntityHandle handle = ENTITY_HANDLE(entity_set_handle);
- MBErrorCode result;
+ MBEntityHandle handle = ENTITY_HANDLE(entity_set_handle);
+ MBErrorCode result;
- if (use_top) {
- if (entity_topology == iMesh_SEPTAHEDRON)
- result = MB_SUCCESS; // MOAB doesn't do septahedrons, so there are never any.
- else
- result = MBI->get_entities_by_type(handle, type, out_entities, recursive);
- else if (use_type && entity_type != iBase_ALL_TYPES)
- result = MBI->get_entities_by_dimension(handle, entity_type, out_entities, recursive);
- else
- result = MBI->get_entities_by_handle(handle, out_entities, recursive);
+ if (use_top) {
+ if (entity_topology == iMesh_SEPTAHEDRON)
+ result = MB_SUCCESS; // MOAB doesn't do septahedrons, so there are never any.
+ else
+ result = MBI->get_entities_by_type(handle, type, out_entities, recursive);
+ else if (use_type && entity_type != iBase_ALL_TYPES)
+ result = MBI->get_entities_by_dimension(handle, entity_type, out_entities, recursive);
+ else
+ result = MBI->get_entities_by_handle(handle, out_entities, recursive);
- std::string msg("iMesh_GetEntities:ERROR getting entities, with error type: ");
+ std::string msg("iMesh_GetEntities:ERROR getting entities, with error type: ");
- CHECK_SIZE(*entity_handles, *entity_handles_allocated,
- (int)out_entities.size(), iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
+ CHECK_SIZE(*entity_handles, *entity_handles_allocated,
+ (int)out_entities.size(), iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
- MBRange::iterator iter = out_entities.begin();
- MBRange::iterator end_iter = out_entities.end();
- int k = 0;
+ MBRange::iterator iter = out_entities.begin();
+ MBRange::iterator end_iter = out_entities.end();
+ int k = 0;
- // filter out entity sets here
- if (iBase_ALL_TYPES == entity_type && iMesh_ALL_TOPOLOGIES == entity_topology) {
- for (; iter != end_iter && MBI->type_from_handle(*iter) != MBENTITYSET; iter++)
- (*entity_handles)[k++] = (iBase_EntityHandle)*iter;
- else {
- for (; iter != end_iter; iter++)
+ // filter out entity sets here
+ if (iBase_ALL_TYPES == entity_type && iMesh_ALL_TOPOLOGIES == entity_topology) {
+ for (; iter != end_iter && MBI->type_from_handle(*iter) != MBENTITYSET; iter++)
+ (*entity_handles)[k++] = (iBase_EntityHandle)*iter;
+ else {
+ for (; iter != end_iter; iter++)
- // now it's safe to set the size; set it to k, not out_entities.size(), to
- // account for sets which might have been removed
- *entity_handles_size = k;
+ // now it's safe to set the size; set it to k, not out_entities.size(), to
+ // account for sets which might have been removed
+ *entity_handles_size = k;
/**\brief Get the number of entities with the specified type in the instance or set, recursive
@@ -2713,35 +2630,35 @@
* \param num_type Pointer to number of entities, returned from function
* \param *err Pointer to error type returned from function
-void iMesh_getNumOfTypeRec(iMesh_Instance instance,
- /*out*/ int *num_type,
- /*out*/ int *err)
- *num_type = 0;
- if (entity_type == iBase_ALL_TYPES)
- result = MBI->get_number_entities_by_handle
+ void iMesh_getNumOfTypeRec(iMesh_Instance instance,
+ /*out*/ int *num_type,
+ /*out*/ int *err)
+ *num_type = 0;
+ if (entity_type == iBase_ALL_TYPES)
+ result = MBI->get_number_entities_by_handle
(ENTITY_HANDLE(entity_set_handle), *num_type, recursive);
- else
- result = MBI->get_number_entities_by_dimension
+ else
+ result = MBI->get_number_entities_by_dimension
(ENTITY_HANDLE(entity_set_handle), entity_type, *num_type, recursive);
- std::string msg("iMesh_entitysetGetNumberEntityOfType: ERROR getting number of entities"
- " by type, with error type: ");
- *num_type = 0;
+ std::string msg("iMesh_entitysetGetNumberEntityOfType: ERROR getting number of entities"
+ " by type, with error type: ");
+ *num_type = 0;
/**\brief Get the number of entities with the specified topology in the instance or set
* Get the number of entities with the specified topology in the instance
@@ -2757,35 +2674,35 @@
* \param num_topo Pointer to number of entities, returned from function
-void iMesh_getNumOfTopoRec(iMesh_Instance instance,
- /*out*/ int *num_topo,
- /*out*/ int *err)
- if (entity_topology == iMesh_SEPTAHEDRON) {
- *num_topo = 0;
+ void iMesh_getNumOfTopoRec(iMesh_Instance instance,
+ /*out*/ int *num_topo,
+ /*out*/ int *err)
+ if (entity_topology == iMesh_SEPTAHEDRON) {
+ *num_topo = 0;
- *num_topo = 0;
+ *num_topo = 0;
MBI->get_number_entities_by_type(ENTITY_HANDLE(entity_set_handle),
mb_topology_table[entity_topology],
*num_topo, recursive);
- std::string msg("iMesh_entitysetGetNumberEntityOfTopology: ERROR getting "
- "number of entities by topology., with error type: ");
- *num_topo = -1;
+ std::string msg("iMesh_entitysetGetNumberEntityOfTopology: ERROR getting "
+ "number of entities by topology., with error type: ");
+ *num_topo = -1;
+ else {
- else {
/**\brief Get entities with specified type, topology, tag(s) and (optionally) tag value(s)
@@ -2807,150 +2724,227 @@
* \param *entity_handles_size Pointer to occupied size of entity_handles array
-void iMesh_getEntsByTagsRec(iMesh_Instance instance,
- /*in*/ const iBase_TagHandle *tag_handles,
- /*in*/ const char * const *tag_vals,
- /*in*/ const int num_tags_vals,
- /*out*/ int *err)
+ void iMesh_getEntsByTagsRec(iMesh_Instance instance,
+ /*in*/ const iBase_TagHandle *tag_handles,
+ /*in*/ const char * const *tag_vals,
+ /*in*/ const int num_tags_vals,
+ /*out*/ int *err)
- use_top = true;
- use_type = true;
- else {
+ use_top = true;
+ use_type = true;
+ else {
- if (use_top) {
- else
+ if (use_top) {
+ else
+ result = MBI->get_entities_by_type_and_tag(handle, type, (MBTag*)tag_handles,
+ (const void* const *)tag_vals,
+ num_tags_vals, out_entities,
+ MBInterface::INTERSECT, recursive);
+ else if (use_type && entity_type != iBase_ALL_TYPES) {
+ // need to loop over all types of this dimension
+ for (MBEntityType tp = MBCN::TypeDimensionMap[entity_type].first;
+ tp <= MBCN::TypeDimensionMap[entity_type].second; tp++) {
+ MBRange tmp_range;
+ MBErrorCode tmp_result = MBI->get_entities_by_type_and_tag(handle, type, (MBTag*)tag_handles,
+ num_tags_vals, tmp_range,
+ else out_entities.merge(tmp_range);
+ else
- num_tags_vals, out_entities,
- else if (use_type && entity_type != iBase_ALL_TYPES) {
- // need to loop over all types of this dimension
- for (MBEntityType tp = MBCN::TypeDimensionMap[entity_type].first;
- tp <= MBCN::TypeDimensionMap[entity_type].second; tp++) {
- MBRange tmp_range;
- MBErrorCode tmp_result = MBI->get_entities_by_type_and_tag(handle, type, (MBTag*)tag_handles,
- (const void* const *)tag_vals,
- num_tags_vals, tmp_range,
- MBInterface::INTERSECT, recursive);
- else out_entities.merge(tmp_range);
+ int k = 0;
+ else {
- else
- result = MBI->get_entities_by_type_and_tag(handle, type, (MBTag*)tag_handles,
+ void iMesh_getEntSetsByTagsRec(iMesh_Instance instance,
+ /*out*/ iBase_EntityHandle** set_handles,
+ /*out*/ int* set_handles_allocated,
+ /*out*/ int* set_handles_size,
+ /*out*/ int *err)
+ result = MBI->get_entities_by_type_and_tag(handle, MBENTITYSET, (MBTag*)tag_handles,
+ std::string msg("ERROR getting entities, with error type: ");
+ CHECK_SIZE(*set_handles, *set_handles_allocated,
+ std::copy(out_entities.begin(), out_entities.end(), ((MBEntityHandle*) *set_handles));
- int k = 0;
+ *set_handles_size = out_entities.size();
- else {
+ void iMesh_MBCNType(/*in*/ const int imesh_entity_topology,
+ /*out*/ int *mbcn_type)
+ if (iMesh_POINT > imesh_entity_topology ||
+ iMesh_ALL_TOPOLOGIES <= imesh_entity_topology)
+ *mbcn_type = -1;
+ else
+ *mbcn_type = mb_topology_table[imesh_entity_topology];
+#ifdef __cplusplus
+} // extern "C"
+#endif
-void iMesh_getEntSetsByTagsRec(iMesh_Instance instance,
- /*out*/ iBase_EntityHandle** set_handles,
- /*out*/ int* set_handles_allocated,
- /*out*/ int* set_handles_size,
- /*out*/ int *err)
+MBErrorCode iMesh_tag_set_vertices(iMesh_Instance instance,
+ MBEntityHandle in_set,
+ const int req_dimension,
+ const MBEntityType req_type,
+ MBTag &tag, MBRange &req_entities,
+ int &num_verts, int *err)
- result = MBI->get_entities_by_type_and_tag(handle, MBENTITYSET, (MBTag*)tag_handles,
- std::string msg("ERROR getting entities, with error type: ");
+ // get all the entities then vertices
+ MBRange vertices, entities;
+ entities.clear();
+ MBErrorCode result = MBI->get_entities_by_handle(in_set, entities, false);
+ std::string msg("MBMesh::tag_set_vertices: getting entities didn't succeed., with error type: ");
+ return result;
- CHECK_SIZE(*set_handles, *set_handles_allocated,
+ // remove any sets
+ entities.erase(entities.lower_bound(MBENTITYSET),
+ entities.upper_bound(MBENTITYSET));
- std::copy(out_entities.begin(), out_entities.end(), ((MBEntityHandle*) *set_handles));
+ // get vertices
+ result = MBI->get_adjacencies(entities, 0, false, vertices,
+ MBInterface::UNION);
+ std::string msg("MBMesh::tag_set_vertices: getting vertices didn't succeed., with error type: ");
+ return result;
- *set_handles_size = out_entities.size();
+ // tag each vertex with its index in this list
+ int i = 0;
+ if (tag == 0) {
+ result = MBI->tag_create("__position_tag", 4, MB_TAG_DENSE, tag, &i);
+ if (0 == tag) {
+ std::string msg("MBMesh::tag_set_vertices: couldn't make tag., with error type: ");
+ return result;
+ MBRange::iterator vit;
+ for (vit = vertices.begin(), i = 0; vit != vertices.end(); vit++, i++) {
+ result = MBI->tag_set_data(tag, &(*vit), 1, &i);
+ std::string msg("MBMesh::tag_set_vertices: couldn't set pos_tag., with error type: ");
+ return result;
+ if (req_dimension == -1 && req_type == MBMAXTYPE) return MB_SUCCESS;
+ // winnow the list for entities of the desired type and/or topology
+ num_verts = 0;
+ MBRange::iterator ent_it;
+ MBEntityType this_type;
+ for (ent_it = entities.begin(); ent_it != entities.end(); ent_it++) {
+ this_type = MBI->type_from_handle(*ent_it);
+ if (req_dimension == MBCN::Dimension(this_type) ||
+ this_type == req_type) {
+ req_entities.insert(*ent_it);
+ num_verts += MBCN::VerticesPerEntity(this_type);
-void iMesh_MBCNType(/*in*/ const int imesh_entity_topology,
- /*out*/ int *mbcn_type)
- if (iMesh_POINT > imesh_entity_topology ||
- iMesh_ALL_TOPOLOGIES <= imesh_entity_topology)
- *mbcn_type = -1;
- else
- *mbcn_type = mb_topology_table[imesh_entity_topology];
+ return result;
void eatwhitespace(std::string &this_string)
std::string::size_type len = this_string.find_last_not_of(" ");
