[MOAB-dev] problem with configure.in
Ryuta Suzuki suzu0037 at aem.umn.edu
Mon Jul 21 16:50:47 CDT 2008
Hummm, the problem still persists.
I removed the entire MOAB directory and did 'svn checkout' from the
repository.
Now in the brand new MOAB directory, autoreconf -fi gave the same error
as reported before.
I think we really need to fix configure.in for autotool of the version
2.62 or later since I didn't see such issue with the previous version of
autotool.
Unless configure.in gets fixed, we won't be able to do 'configure' to
prepare for build process, at least, for the system equipped with
autotool 2.62.
Thank you,
ryuta
Ryuta Suzuki wrote:
> Hi,
> Recently, I clean up MOAB source directory by removing every files and
> then re-retrieved fresh from svn repository. I followed the
> instruction to prepare build procedure but I got the following error:
> autoreconf -fi
> configure.in:61: error: AC_SUBST: `MOAB_CXX_LDFLAGS ' is not a valid
> shell variable name
> configure.in:61: the top level
> autom4te: /usr/bin/m4 failed with exit status: 1
> aclocal: autom4te failed with exit status: 1
> autoreconf: aclocal failed with exit status: 1
> My autoconf version is 2.62
> New autoconf may be more stringent...
> Thanks,
> ryuta
