[MOAB-dev] problem with configure.in
Tim Tautges tautges at mcs.anl.gov
Mon Jul 21 12:21:54 CDT 2008
Ok.  In the future, I think just doing 'make distclean' will work just
as well; that deletes all the autotools-generated files in all directories.
- tim
Ryuta Suzuki wrote:
> I basically did a clean checkout, removing all the subdirectories as well.
> Then I had to autoreconf to create configure file from configure.in
> ryuta
> Tim Tautges wrote:
>> Hi Ryuta,
>>   The only time I've seen that, doing an 'autoreconf -fi' fixed it.
>> Did you start clean for all the subdirectories too, or just for the
>> top-level dir?  I'll try a clean checkout today just in case.
>> - tim
>> Ryuta Suzuki wrote:
>>> Hi,
>>> Recently, I clean up MOAB source directory by removing every files
>>> and then re-retrieved fresh from svn repository. I followed the
>>> instruction to prepare build procedure but I got the following error:
>>> autoreconf -fi
>>> configure.in:61: error: AC_SUBST: `MOAB_CXX_LDFLAGS ' is not a valid
>>> shell variable name
>>> configure.in:61: the top level
>>> autom4te: /usr/bin/m4 failed with exit status: 1
>>> aclocal: autom4te failed with exit status: 1
>>> autoreconf: aclocal failed with exit status: 1
>>> My autoconf version is 2.62
>>> New autoconf may be more stringent...
>>> Thanks,
>>> ryuta
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
