[MOAB-dev] problem with configure.in
Ryuta Suzuki
suzu0037 at aem.umn.edu
Mon Jul 21 10:39:48 CDT 2008
I basically did a clean checkout, removing all the subdirectories as well.
Then I had to autoreconf to create configure file from configure.in
ryuta
Tim Tautges wrote:
> Hi Ryuta,
> The only time I've seen that, doing an 'autoreconf -fi' fixed it.
> Did you start clean for all the subdirectories too, or just for the
> top-level dir? I'll try a clean checkout today just in case.
> - tim
> Ryuta Suzuki wrote:
>> Hi,
>> Recently, I clean up MOAB source directory by removing every files
>> and then re-retrieved fresh from svn repository. I followed the
>> instruction to prepare build procedure but I got the following error:
>> autoreconf -fi
>> configure.in:61: error: AC_SUBST: `MOAB_CXX_LDFLAGS ' is not a valid
>> shell variable name
>> configure.in:61: the top level
>> autom4te: /usr/bin/m4 failed with exit status: 1
>> aclocal: autom4te failed with exit status: 1
>> autoreconf: aclocal failed with exit status: 1
>> My autoconf version is 2.62
>> New autoconf may be more stringent...
>> Thanks,
>> ryuta
