[MOAB-dev] problem with configure.in
Tim Tautges
tautges at mcs.anl.gov
Mon Jul 21 08:47:06 CDT 2008
Hi Ryuta,
The only time I've seen that, doing an 'autoreconf -fi' fixed it.
Did you start clean for all the subdirectories too, or just for the
top-level dir? I'll try a clean checkout today just in case.
- tim
Ryuta Suzuki wrote:
> Hi,
> Recently, I clean up MOAB source directory by removing every files and
> then re-retrieved fresh from svn repository. I followed the instruction
> to prepare build procedure but I got the following error:
> autoreconf -fi
> configure.in:61: error: AC_SUBST: `MOAB_CXX_LDFLAGS ' is not a valid
> shell variable name
> configure.in:61: the top level
> autom4te: /usr/bin/m4 failed with exit status: 1
> aclocal: autom4te failed with exit status: 1
> autoreconf: aclocal failed with exit status: 1
> My autoconf version is 2.62
> New autoconf may be more stringent...
> Thanks,
> ryuta
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
