[MOAB-dev] problem with configure.in
Ryuta Suzuki suzu0037 at aem.umn.edu
Mon Jul 21 03:14:09 CDT 2008
Recently, I clean up MOAB source directory by removing every files and
then re-retrieved fresh from svn repository. I followed the instruction
to prepare build procedure but I got the following error:
autoreconf -fi
configure.in:61: error: AC_SUBST: `MOAB_CXX_LDFLAGS ' is not a valid
shell variable name
configure.in:61: the top level
autom4te: /usr/bin/m4 failed with exit status: 1
aclocal: autom4te failed with exit status: 1
autoreconf: aclocal failed with exit status: 1
My autoconf version is 2.62
New autoconf may be more stringent...
ryuta
