[MOAB-dev] r1992 - in MOAB/trunk: parallel test/h5file
    kraftche at mcs.anl.gov
    Tue Jul  8 10:33:59 CDT 2008
Author: kraftche
Date: 2008-07-08 10:33:58 -0500 (Tue, 08 Jul 2008)
New Revision: 1992
Removed:
   MOAB/trunk/test/h5file/varlen_ll.cpp
Modified:
   MOAB/trunk/parallel/parallel_hdf5_test.cc
   MOAB/trunk/test/h5file/Makefile.am
Log:
move test for I/O of var-len tags into new parallel hdf5 tests
Modified: MOAB/trunk/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/parallel/parallel_hdf5_test.cc	2008-07-08 15:24:09 UTC (rev 1991)
+++ MOAB/trunk/parallel/parallel_hdf5_test.cc	2008-07-08 15:33:58 UTC (rev 1992)
@@ -4,6 +4,7 @@
 #include "MBParallelComm.hpp"
 #include "MBTagConventions.hpp"
 #include "MBCN.hpp"
+#include "MBParallelConventions.h"
 #include <iostream>
 #include <mpi.h>
@@ -24,8 +25,8 @@
 void check_identical_mesh( MBInterface& moab1, MBInterface& moab2 );
 void test_write_elements();
 void test_write_shared_sets();
+void test_var_length_parallel();
 bool KeepTmpFiles = false;
@@ -44,6 +45,7 @@
   int result = 0;
   result += RUN_TEST( test_write_elements );
   result += RUN_TEST( test_write_shared_sets );
+  result += RUN_TEST( test_var_length_parallel );
   MPI_Finalize();
   return result;
@@ -288,7 +290,119 @@
     CHECK( check_sets_sizes( moab2, *i, moab, tmpents.front() ) );
+  MBRange::const_iterator i;
+  MBErrorCode rval;
+  MBCore moab;
+  MBInterface &mb = moab;
+  MBRange verts;
+  MBTag vartag;
+  const char* filename = "var-len-para.h5m";
+  const char* tagname = "ParVar";
+  // If this tag doesn't exist, writer will fail
+  MBTag junk_tag;
+  mb.tag_create( PARALLEL_GID_TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER, junk_tag, 0 );
+  int numproc, rank;
+  MPI_Comm_size( MPI_COMM_WORLD, &numproc );
+  MPI_Comm_rank( MPI_COMM_WORLD, &rank    );
+  // Create N+1 vertices on each processor, where N is the rank
+  std::vector<double> coords( 3*rank+3, (double)rank );
+  rval = mb.create_vertices( &coords[0], rank+1, verts );
+  CHECK_ERR(rval);
+  // Create a var-len tag
+  rval = mb.tag_create_variable_length( tagname, MB_TAG_DENSE, MB_TYPE_INTEGER, vartag );
+  CHECK_ERR(rval);
+  // Write data on each vertex:
+  // { n, rank, rank+1, ..., rank+n-1 } where n >= 1
+  std::vector<int> data;
+  rval = MB_SUCCESS;
+  for (i = verts.begin(); i != verts.end(); ++i) {
+    MBEntityHandle h = *i;
+    const int n = h % 7 + 1;
+    data.resize( n+1 );
+    data[0] = n;
+    for (int j = 0; j < n; ++j)
+      data[j+1] = rank + j;
+    const int s = (n + 1) * sizeof(int);
+    const void* ptrarr[] = { &data[0] };
+    MBErrorCode tmperr = mb.tag_set_data( vartag, &h, 1, ptrarr, &s );
+    if (MB_SUCCESS != tmperr)
+      rval = tmperr;
+  CHECK_ERR(rval);
+  // Write file
+  rval = mb.write_file( filename, "MOAB", "PARALLEL=FORMAT" );
+  CHECK_ERR(rval);
+  // Read file.  We only reset and re-read the file on the
+  // root processsor.  All other processors keep the pre-write
+  // mesh.  This allows many of the tests to be run on all
+  // processors.  Running the tests on the pre-write mesh on
+  // non-root processors allows us to verify that any problems
+  // are due to the file API rather than some other bug.
+  MBErrorCode rval2 = rval = MB_SUCCESS;
+  if (!rank) {
+    moab.~MBCore();
+    new (&moab) MBCore;
+    rval = mb.load_mesh( filename );
+    if (!KeepTmpFiles)
+      remove( filename );
+    rval2 = mb.tag_get_handle( tagname, vartag );
+  CHECK_ERR(rval);
+  CHECK_ERR(rval2);
+  // Check that tag is correct
+  int tag_size;
+  rval = mb.tag_get_size( vartag, tag_size );
+  CHECK_EQUAL( MB_VARIABLE_DATA_LENGTH, rval );
+  MBTagType storage;
+  rval = mb.tag_get_type( vartag, storage );
+  CHECK_EQUAL( MB_TAG_DENSE, storage );
+  MBDataType type;
+  rval = mb.tag_get_data_type( vartag, type);
+  CHECK_EQUAL( MB_TYPE_INTEGER, type );
+  // get vertices
+  verts.clear();
+  rval = mb.get_entities_by_type( 0, MBVERTEX, verts );
+  CHECK_ERR(rval);
+  // Check consistency of tag data on each vertex
+  // and count the number of vertices for each rank.
+  std::vector<int> vtx_counts( numproc, 0 );
+    int size = -1;
+    const void* ptrarr[1] = { 0 };
+    rval = mb.tag_get_data( vartag, &h, 1, ptrarr, &size );
+    size /= sizeof(int);
+    CHECK_ERR( rval );
+    const int* data = reinterpret_cast<const int*>(ptrarr[0]);
+    CHECK( size >= 2 );
+    CHECK( NULL != data );
+    CHECK_EQUAL( size-1, data[0] );
+    CHECK( data[1] >= 0 && data[1] < numproc );
+    ++vtx_counts[data[1]];
+    for (int j = 1; j < size-1; ++j)
+      CHECK_EQUAL( data[1]+j, data[1+j] );
+  // Check number of vertices for each rank
+  for (int j = 0; j < numproc; ++j) {
+    // Only root should have data for other processors.
+    if (rank == 0 || rank == j)
+      CHECK_EQUAL( j+1, vtx_counts[j] );
+    else
+      CHECK_EQUAL( 0, vtx_counts[j] );
Modified: MOAB/trunk/test/h5file/Makefile.am
--- MOAB/trunk/test/h5file/Makefile.am	2008-07-08 15:24:09 UTC (rev 1991)
+++ MOAB/trunk/test/h5file/Makefile.am	2008-07-08 15:33:58 UTC (rev 1992)
@@ -1,7 +1,7 @@
 DEFS = $(DEFINES)
 INCLUDES += -I$(top_srcdir) -I$(top_srcdir)/mhdf/include -I$(top_builddir)
 check_PROGRAMS = h5test h5legacy h5varlen h5sets_test
-parallel_programs = varlen_ll mhdf_parallel
+parallel_programs = mhdf_parallel
 if PARALLEL_HDF5
   check_PROGRAMS += $(parallel_programs)
@@ -14,6 +14,5 @@
 h5test_SOURCES = h5file_test.cpp
 h5legacy_SOURCES = h5legacy.cpp
 h5varlen_SOURCES = h5varlen.cpp
-parallel_SOURCES = parallel.cpp
-varlen_ll_SOURCES = varlen_ll.cpp
+mhdf_parallel_SOURCES = mhdf_parallel.c
 h5sets_test_SOURCES = h5sets_test.cpp
Deleted: MOAB/trunk/test/h5file/varlen_ll.cpp
--- MOAB/trunk/test/h5file/varlen_ll.cpp	2008-07-08 15:24:09 UTC (rev 1991)
+++ MOAB/trunk/test/h5file/varlen_ll.cpp	2008-07-08 15:33:58 UTC (rev 1992)
@@ -1,162 +0,0 @@
-/**\file varlen_ll.cpp
- * \brief Test HDF5 parallel I/O of variable-length tag data.
- * \author Jason Kraftcheck <kraftche at cae.wisc.edu>
-#include "MBCore.hpp"
-#include "TestUtil.hpp"
-#include "MBParallelConventions.h"
-#include <mpi.h>
-bool keep_files = false; // controllable with -k flag
-bool wait_on_start = false; // start all procs and wait for input on root node
-void test_var_length_parallel();
-int main(int argc, char* argv[])
-  MPI_Init( &argc, &argv );
-  for (int i = 1; i < argc; ++i) {
-    if (!strcmp(argv[i], "-k"))
-      keep_files = true;
-    else if (!strcmp(argv[i], "-w"))
-      wait_on_start = true;
-    else {
-      fprintf( stderr, "Usage: %s [-k] [-w]\n", argv[0] );
-      abort();
-  if (wait_on_start) {
-    int rank;
-    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
-    if (0 == rank) {
-      puts( "Press <enter> to begin: ");
-      fflush( stdout );
-      getchar();
-    MPI_Barrier(MPI_COMM_WORLD);
-  int err_count = 0;
-  err_count += RUN_TEST( test_var_length_parallel );
-  return err_count;
-  MBRange::const_iterator i;
-  MBErrorCode rval;
-  MBCore moab;
-  MBInterface &mb = moab;
-  MBRange verts;
-  MBTag vartag;
-  const char* filename = "var-len-para.h5m";
-  const char* tagname = "ParVar";
-  // If this tag doesn't exist, writer will fail
-  MBTag junk_tag;
-  mb.tag_create( PARALLEL_GID_TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER, junk_tag, 0 );
-  int numproc, rank;
-  MPI_Comm_size( MPI_COMM_WORLD, &numproc );
-  // Create N+1 vertices on each processor, where N is the rank
-  std::vector<double> coords( 3*rank+3, (double)rank );
-  rval = mb.create_vertices( &coords[0], rank+1, verts );
-  CHECK_ERR(rval);
-  // Create a var-len tag
-  rval = mb.tag_create_variable_length( tagname, MB_TAG_DENSE, MB_TYPE_INTEGER, vartag );
-  CHECK_ERR(rval);
-  // Write data on each vertex:
-  // { n, rank, rank+1, ..., rank+n-1 } where n >= 1
-  std::vector<int> data;
-  rval = MB_SUCCESS;
-  for (i = verts.begin(); i != verts.end(); ++i) {
-    MBEntityHandle h = *i;
-    const int n = h % 7 + 1;
-    data.resize( n+1 );
-    data[0] = n;
-    for (int j = 0; j < n; ++j)
-      data[j+1] = rank + j;
-    const int s = (n + 1) * sizeof(int);
-    const void* ptrarr[] = { &data[0] };
-    MBErrorCode tmperr = mb.tag_set_data( vartag, &h, 1, ptrarr, &s );
-    if (MB_SUCCESS != tmperr)
-      rval = tmperr;
-  CHECK_ERR(rval);
-  // Write file
-  rval = mb.write_file( filename, "MOAB", "PARALLEL=FORMAT" );
-  CHECK_ERR(rval);
-  // Read file.  We only reset and re-read the file on the
-  // root processsor.  All other processors keep the pre-write
-  // mesh.  This allows many of the tests to be run on all
-  // processors.  Running the tests on the pre-write mesh on
-  // non-root processors allows us to verify that any problems
-  // are due to the file API rather than some other bug.
-  MBErrorCode rval2 = rval = MB_SUCCESS;
-  if (!rank) {
-    moab.~MBCore();
-    new (&moab) MBCore;
-    rval = mb.load_mesh( filename );
-    if (!keep_files)
-      remove( filename );
-    rval2 = mb.tag_get_handle( tagname, vartag );
-  CHECK_ERR(rval);
-  CHECK_ERR(rval2);
-  // Check that tag is correct
-  int tag_size;
-  rval = mb.tag_get_size( vartag, tag_size );
-  CHECK_EQUAL( MB_VARIABLE_DATA_LENGTH, rval );
-  MBTagType storage;
-  rval = mb.tag_get_type( vartag, storage );
-  CHECK_EQUAL( MB_TAG_DENSE, storage );
-  MBDataType type;
-  rval = mb.tag_get_data_type( vartag, type);
-  CHECK_EQUAL( MB_TYPE_INTEGER, type );
-  // get vertices
-  verts.clear();
-  rval = mb.get_entities_by_type( 0, MBVERTEX, verts );
-  CHECK_ERR(rval);
-  // Check consistency of tag data on each vertex
-  // and count the number of vertices for each rank.
-  std::vector<int> vtx_counts( numproc, 0 );
-    int size = -1;
-    const void* ptrarr[1] = { 0 };
-    rval = mb.tag_get_data( vartag, &h, 1, ptrarr, &size );
-    size /= sizeof(int);
-    CHECK_ERR( rval );
-    const int* data = reinterpret_cast<const int*>(ptrarr[0]);
-    CHECK( size >= 2 );
-    CHECK( NULL != data );
-    CHECK_EQUAL( size-1, data[0] );
-    CHECK( data[1] >= 0 && data[1] < numproc );
-    ++vtx_counts[data[1]];
-    for (int j = 1; j < size-1; ++j)
-      CHECK_EQUAL( data[1]+j, data[1+j] );
-  // Check number of vertices for each rank
-  for (int j = 0; j < numproc; ++j) {
-    // Only root should have data for other processors.
-    if (rank == 0 || rank == j)
-      CHECK_EQUAL( j+1, vtx_counts[j] );
-    else
-      CHECK_EQUAL( 0, vtx_counts[j] );
