[MOAB-dev] r1993 - in MOAB/trunk: parallel test/h5file
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Jul 8 10:42:04 CDT 2008
Author: kraftche
Date: 2008-07-08 10:42:04 -0500 (Tue, 08 Jul 2008)
New Revision: 1993
Added:
   MOAB/trunk/parallel/mhdf_parallel.c
Removed:
   MOAB/trunk/test/h5file/mhdf_parallel.c
Modified:
   MOAB/trunk/parallel/Makefile.am
   MOAB/trunk/test/h5file/Makefile.am
Log:
move last parallel I/O  test from test/h5file/ to parallel/
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am	2008-07-08 15:33:58 UTC (rev 1992)
+++ MOAB/trunk/parallel/Makefile.am	2008-07-08 15:42:04 UTC (rev 1993)
@@ -8,8 +8,8 @@
 noinst_LTLIBRARIES = libMOABpar.la
 # Some variables
-DEFS = $(DEFINES) -DIS_BUILDING_MB
-INCLUDES += -I$(top_srcdir) -I$(top_builddir)
+DEFS = $(DEFINES) -DIS_BUILDING_MB -DSRCDIR=$(srcdir)
+INCLUDES += -I$(top_srcdir) -I$(top_builddir) -I$(srcdir)/../mhdf/inc
 # The directory in which to install headers
 libMOABpar_la_includedir = $(includedir)
@@ -43,7 +43,7 @@
   MOAB_PARALLEL_SRCS += WriteHDF5Parallel.cpp
   MOAB_PARALLEL_HDRS += WriteHDF5Parallel.hpp
-  MOAB_PARALLEL_TEST += parallel_hdf5_test
+  MOAB_PARALLEL_TEST += parallel_hdf5_test mhdf_parallel
 endif
   MOAB_PARALLEL_CHECK += mbparallelcomm_test
@@ -70,5 +70,9 @@
 pcomm_unit_LDADD = $(top_builddir)/libMOAB.la
 parallel_hdf5_test_SOURCES = parallel_hdf5_test.cc
 parallel_hdf5_test_LDADD = ../libMOAB.la
-parallel_hdf5_test_CPPFLAGS = -DSRCDIR=$(srcdir)
+mhdf_parallel_SOURCES = mhdf_parallel.c
+mhdf_parallel_LDADD = ../mhdf/libmhdf.la
+# Other files to clean up (e.g. output from tests)
+MOSTLYCLEANFILES = mhdf_ll.h5m
Copied: MOAB/trunk/parallel/mhdf_parallel.c (from rev 1990, MOAB/trunk/test/h5file/mhdf_parallel.c)
--- MOAB/trunk/parallel/mhdf_parallel.c	                        (rev 0)
+++ MOAB/trunk/parallel/mhdf_parallel.c	2008-07-08 15:42:04 UTC (rev 1993)
@@ -0,0 +1,272 @@
+/* Test mhdf library on top of Parallel HDF5.
+ * Call mhdf API similar to how WriteHDF5Parallel does,
+ * but avoid any of our own parallel communiation.
+ * Output will be composed of:
+ *  a 1-D array of hexes, one per processor, where the first
+ *    process writes all the nodes for its hex and every other
+ *    process writes the right 4 nodes of its hex.
+ *  a set containing all of the hexes
+ *  a set containing all of the nodes
+ *  a set per processor containing all of the entities written by that proc
+ *  a tag specifying the process ID that wrote each entity.
+#include "mhdf.h"
+#include "MBTypes.h"
+#include <time.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <assert.h>
+#include <H5Ppublic.h>
+#include <H5Tpublic.h>
+const char* filename = "mhdf_ll.h5m";
+const char* proc_tag_name = "proc_id";
+const char* elem_handle = "hex";
+int RANK;
+int NUM_PROC;
+#define CHECK( A ) check( &(A), __LINE__ )
+void check( mhdf_Status* status, int line )
+  if (mhdf_isError( status )) {
+    fprintf(stderr,"%d: ERROR at line %d: \"%s\"\n", RANK, line, mhdf_message( status ) );
+    abort();
+/* create file layout in serial */
+void create_file()
+  const char* elem_types[] = { elem_handle };
+  const int num_elem_types = sizeof(elem_types)/sizeof(elem_types[0]);
+  const int num_nodes = 4+4*NUM_PROC;
+  const int num_hexes = NUM_PROC;
+  const int num_sets = 2+NUM_PROC;
+  const int set_data_size = num_hexes + num_nodes + num_hexes + num_nodes;
+  const int num_tag_vals = num_hexes + num_nodes + num_sets - 2;
+  const char* history[] = { __FILE__, NULL };
+  const int history_size = sizeof(history) / sizeof(history[0]);
+  int default_tag_val = NUM_PROC;
+  hid_t data, tagdata[2];
+  long junk;
+  time_t t = time(NULL);
+  history[1] = ctime(&t);
+  mhdf_Status status;
+  mhdf_FileHandle file;
+  file = mhdf_createFile( filename, 1, elem_types, num_elem_types, &status );
+  CHECK(status);
+  mhdf_writeHistory( file, history, history_size, &status );
+  CHECK(status);
+  data = mhdf_createNodeCoords( file, 3, num_nodes, &junk, &status );
+  CHECK(status);
+  mhdf_closeData( file, data, &status );
+  CHECK(status);
+  mhdf_addElement( file, elem_types[0], 0, &status );
+  CHECK(status);
+  data = mhdf_createConnectivity( file, elem_handle, 8, num_hexes, &junk, &status );
+  CHECK(status);
+  CHECK(status);
+  data = mhdf_createSetMeta( file, num_sets, &junk, &status );
+  CHECK(status);
+  CHECK(status);
+  data = mhdf_createSetData( file, set_data_size, &status );
+  CHECK(status);
+  CHECK(status);
+  mhdf_createTag( file, proc_tag_name, mhdf_INTEGER, 1, mhdf_DENSE_TYPE,
+                  &default_tag_val, &default_tag_val, 0, 0, &status );
+  CHECK(status);
+  mhdf_createSparseTagData( file, proc_tag_name, num_tag_vals, tagdata, &status );
+  CHECK(status);
+  mhdf_closeData( file, tagdata[0], &status );
+  CHECK(status);
+  mhdf_closeData( file, tagdata[1], &status );
+  CHECK(status);
+  mhdf_closeFile( file, &status );
+  CHECK(status);
+void write_file_data()
+  const int total_num_nodes = 4+4*NUM_PROC;
+  const int total_num_hexes = NUM_PROC;
+  long first_node, first_elem, first_set, count, ntag;
+  long set_desc[4] = { 0, -1, -1, MESHSET_SET };
+  hid_t handle, handles[2];
+  double coords[3*8] = { 0.0, 0.0, 0.0,
+                         0.0, 1.0, 0.0,
+                         0.0, 1.0, 1.0,
+                         0.0, 0.0, 1.0,
+                         0.0, 0.0, 0.0,
+                         0.0, 1.0, 0.0,
+                         0.0, 1.0, 1.0,
+                         0.0, 0.0, 1.0 };
+  int i, list[10], tagdata[10] = {RANK,RANK,RANK,RANK,RANK,RANK,RANK,RANK,RANK,RANK};
+  int num_node, offset, dim;
+    /* open file */
+  handle = H5Pcreate( H5P_FILE_ACCESS );
+  H5Pset_fapl_mpio( handle, MPI_COMM_WORLD, MPI_INFO_NULL );
+  file = mhdf_openFileWithOpt( filename, 1, &count, handle, &status );
+  CHECK(status);
+  H5Pclose( handle );
+    /* write node coordinates */
+  if (0 == RANK) {
+    num_node = 8;
+    offset = 0;
+    coords[12] = coords[15] = coords[18] = coords[21] = 1.0;
+  else {
+    num_node = 4;
+    offset = 4 + 4*RANK;
+    coords[0] = coords[3] = coords[6] = coords[9] = 1.0 + RANK;
+  handle = mhdf_openNodeCoords( file, &count, &dim, &first_node, &status );
+  CHECK(status);
+  assert( count == total_num_nodes );
+  assert( dim == 3 );
+  mhdf_writeNodeCoords( handle, offset, num_node, coords, &status );
+  CHECK(status);
+  mhdf_closeData( file, handle, &status );
+  CHECK(status);
+    /* write hex connectivity */
+  for (i = 0; i < 8; ++i)
+    list[i] = 4*RANK + i;
+  handle = mhdf_openConnectivity( file, elem_handle, &dim, &count, &first_elem, &status );
+  CHECK(status);
+  assert( count == total_num_hexes );
+  assert( 8 == dim );
+  mhdf_writeConnectivity( handle, RANK, 1, H5T_NATIVE_INT, list, &status );
+  CHECK(status);
+  CHECK(status);
+    /* write set descriptions */
+  handle = mhdf_openSetMeta( file, &count, &first_set, &status );
+  CHECK(status);
+  assert( count == 2+NUM_PROC );
+    /* write set descriptions for per-proc sets */
+  set_desc[0] = total_num_nodes + total_num_hexes + 9 + 5*RANK - 1;
+  mhdf_writeSetMeta( handle, 2+RANK, 1, H5T_NATIVE_LONG, set_desc, &status );
+  CHECK(status);
+    /* write set descriptions for multi-proc sets */
+  if (0 == RANK) {
+    set_desc[0] = total_num_nodes - 1;
+    mhdf_writeSetMeta( handle, 0, 1, H5T_NATIVE_LONG, set_desc, &status );
+    CHECK(status);
+    set_desc[0] += total_num_hexes;
+    mhdf_writeSetMeta( handle, 1, 1, H5T_NATIVE_LONG, set_desc, &status );
+    CHECK(status);
+  CHECK(status);
+    /* write set contents */
+  handle = mhdf_openSetData( file, &count, &status );
+  CHECK(status);
+  assert( 2*total_num_nodes + 2*total_num_hexes == count );
+    /* write per-proc sets */
+  if (0 == RANK) {
+    count = 9;
+    offset = total_num_nodes + total_num_hexes;
+      list[i] = first_node + i;
+    list[8] = first_elem;
+  else {
+    count = 5;
+    offset = total_num_nodes + total_num_hexes + 4 + 5*RANK;
+    for (i = 0; i < 4; ++i)
+      list[i] = 4 + 4*RANK + first_node + i;
+    list[4] = RANK + first_elem;
+  mhdf_writeSetData( handle, offset, count, H5T_NATIVE_INT, list, &status );
+  CHECK(status);
+    /* write multi-proc sets */
+    /* write nodes */
+  offset = (0 == RANK) ? 0 : 4 + 4*RANK;
+  mhdf_writeSetData( handle, offset, count-1, H5T_NATIVE_INT, list, &status );
+  CHECK(status);
+    /* write hex */
+  offset = total_num_nodes + RANK;
+  mhdf_writeSetData( handle, offset, 1, H5T_NATIVE_INT, list + count - 1, &status );
+  CHECK(status);
+  CHECK(status);
+    /* write tag data */
+  offset += 2*RANK;
+  list[count++] = first_set + 2 + RANK;
+  mhdf_openSparseTagData( file, proc_tag_name, &ntag, &ntag, handles, &status );
+  CHECK(status);
+  assert( ntag == total_num_nodes + total_num_hexes + NUM_PROC );
+  mhdf_writeSparseTagEntities( handles[0], offset, count, H5T_NATIVE_INT, list, &status );
+  CHECK(status);
+  mhdf_writeSparseTagValues( handles[1], offset, count, H5T_NATIVE_INT, tagdata, &status );
+  CHECK(status);
+  mhdf_closeData( file, handles[0], &status );
+  CHECK(status);
+  mhdf_closeData( file, handles[1], &status );
+  CHECK(status);
+    /* done */
+  CHECK(status);
+int main( int argc, char* argv[] )
+  int rval;
+  rval = MPI_Init( &argc, &argv );
+  if (rval)
+    return rval;
+  rval = MPI_Comm_rank( MPI_COMM_WORLD, &RANK );
+  if (rval)
+    return rval;
+  rval = MPI_Comm_size( MPI_COMM_WORLD, &NUM_PROC );
+  if (rval)
+    return rval;
+  if (RANK == 0)
+    create_file();
+  write_file_data();
+  MPI_Finalize();
+  return 0;
Modified: MOAB/trunk/test/h5file/Makefile.am
--- MOAB/trunk/test/h5file/Makefile.am	2008-07-08 15:33:58 UTC (rev 1992)
+++ MOAB/trunk/test/h5file/Makefile.am	2008-07-08 15:42:04 UTC (rev 1993)
@@ -1,18 +1,11 @@
 DEFS = $(DEFINES)
 INCLUDES += -I$(top_srcdir) -I$(top_srcdir)/mhdf/include -I$(top_builddir)
 check_PROGRAMS = h5test h5legacy h5varlen h5sets_test
-parallel_programs = mhdf_parallel
-if PARALLEL_HDF5
-  check_PROGRAMS += $(parallel_programs)
-  INCLUDES += -I$(top_srcdir)/parallel
-endif
 TESTS = $(check_PROGRAMS)
 h5test_SOURCES = h5file_test.cpp
 h5legacy_SOURCES = h5legacy.cpp
 h5varlen_SOURCES = h5varlen.cpp
-mhdf_parallel_SOURCES = mhdf_parallel.c
 h5sets_test_SOURCES = h5sets_test.cpp
Deleted: MOAB/trunk/test/h5file/mhdf_parallel.c
--- MOAB/trunk/test/h5file/mhdf_parallel.c	2008-07-08 15:33:58 UTC (rev 1992)
+++ MOAB/trunk/test/h5file/mhdf_parallel.c	2008-07-08 15:42:04 UTC (rev 1993)
@@ -1,272 +0,0 @@
-/* Test mhdf library on top of Parallel HDF5.
- * Call mhdf API similar to how WriteHDF5Parallel does,
- * but avoid any of our own parallel communiation.
- * Output will be composed of:
- *  a 1-D array of hexes, one per processor, where the first
- *    process writes all the nodes for its hex and every other
- *    process writes the right 4 nodes of its hex.
- *  a set containing all of the hexes
- *  a set containing all of the nodes
- *  a set per processor containing all of the entities written by that proc
- *  a tag specifying the process ID that wrote each entity.
-#include "mhdf.h"
-#include "MBTypes.h"
-#include <time.h>
-#include <stdlib.h>
-#include <stdio.h>
-#include <assert.h>
-#include <H5Ppublic.h>
-#include <H5Tpublic.h>
-const char* filename = "mhdf_ll.h5m";
-const char* proc_tag_name = "proc_id";
-const char* elem_handle = "hex";
-int RANK;
-int NUM_PROC;
-#define CHECK( A ) check( &(A), __LINE__ )
-void check( mhdf_Status* status, int line )
-  if (mhdf_isError( status )) {
-    fprintf(stderr,"%d: ERROR at line %d: \"%s\"\n", RANK, line, mhdf_message( status ) );
-    abort();
-/* create file layout in serial */
-void create_file()
-  const char* elem_types[] = { elem_handle };
-  const int num_elem_types = sizeof(elem_types)/sizeof(elem_types[0]);
-  const int num_nodes = 4+4*NUM_PROC;
-  const int num_hexes = NUM_PROC;
-  const int num_sets = 2+NUM_PROC;
-  const int set_data_size = num_hexes + num_nodes + num_hexes + num_nodes;
-  const int num_tag_vals = num_hexes + num_nodes + num_sets - 2;
-  const char* history[] = { __FILE__, NULL };
-  const int history_size = sizeof(history) / sizeof(history[0]);
-  int default_tag_val = NUM_PROC;
-  hid_t data, tagdata[2];
-  long junk;
-  time_t t = time(NULL);
-  history[1] = ctime(&t);
-  mhdf_Status status;
-  mhdf_FileHandle file;
-  file = mhdf_createFile( filename, 1, elem_types, num_elem_types, &status );
-  CHECK(status);
-  mhdf_writeHistory( file, history, history_size, &status );
-  CHECK(status);
-  data = mhdf_createNodeCoords( file, 3, num_nodes, &junk, &status );
-  CHECK(status);
-  mhdf_closeData( file, data, &status );
-  CHECK(status);
-  mhdf_addElement( file, elem_types[0], 0, &status );
-  CHECK(status);
-  data = mhdf_createConnectivity( file, elem_handle, 8, num_hexes, &junk, &status );
-  CHECK(status);
-  CHECK(status);
-  data = mhdf_createSetMeta( file, num_sets, &junk, &status );
-  CHECK(status);
-  CHECK(status);
-  data = mhdf_createSetData( file, set_data_size, &status );
-  CHECK(status);
-  CHECK(status);
-  mhdf_createTag( file, proc_tag_name, mhdf_INTEGER, 1, mhdf_DENSE_TYPE,
-                  &default_tag_val, &default_tag_val, 0, 0, &status );
-  CHECK(status);
-  mhdf_createSparseTagData( file, proc_tag_name, num_tag_vals, tagdata, &status );
-  CHECK(status);
-  mhdf_closeData( file, tagdata[0], &status );
-  CHECK(status);
-  mhdf_closeData( file, tagdata[1], &status );
-  CHECK(status);
-  mhdf_closeFile( file, &status );
-  CHECK(status);
-void write_file_data()
-  const int total_num_nodes = 4+4*NUM_PROC;
-  const int total_num_hexes = NUM_PROC;
-  long first_node, first_elem, first_set, count, ntag;
-  long set_desc[4] = { 0, -1, -1, MESHSET_SET };
-  hid_t handle, handles[2];
-  double coords[3*8] = { 0.0, 0.0, 0.0,
-                         0.0, 1.0, 0.0,
-                         0.0, 1.0, 1.0,
-                         0.0, 0.0, 1.0,
-                         0.0, 0.0, 0.0,
-                         0.0, 1.0, 0.0,
-                         0.0, 1.0, 1.0,
-                         0.0, 0.0, 1.0 };
-  int i, list[10], tagdata[10] = {RANK,RANK,RANK,RANK,RANK,RANK,RANK,RANK,RANK,RANK};
-  int num_node, offset, dim;
-    /* open file */
-  handle = H5Pcreate( H5P_FILE_ACCESS );
-  H5Pset_fapl_mpio( handle, MPI_COMM_WORLD, MPI_INFO_NULL );
-  file = mhdf_openFileWithOpt( filename, 1, &count, handle, &status );
-  CHECK(status);
-  H5Pclose( handle );
-    /* write node coordinates */
-  if (0 == RANK) {
-    num_node = 8;
-    offset = 0;
-    coords[12] = coords[15] = coords[18] = coords[21] = 1.0;
-  else {
-    num_node = 4;
-    offset = 4 + 4*RANK;
-    coords[0] = coords[3] = coords[6] = coords[9] = 1.0 + RANK;
-  handle = mhdf_openNodeCoords( file, &count, &dim, &first_node, &status );
-  CHECK(status);
-  assert( count == total_num_nodes );
-  assert( dim == 3 );
-  mhdf_writeNodeCoords( handle, offset, num_node, coords, &status );
-  CHECK(status);
-  mhdf_closeData( file, handle, &status );
-  CHECK(status);
-    /* write hex connectivity */
-  for (i = 0; i < 8; ++i)
-    list[i] = 4*RANK + i;
-  handle = mhdf_openConnectivity( file, elem_handle, &dim, &count, &first_elem, &status );
-  CHECK(status);
-  assert( count == total_num_hexes );
-  assert( 8 == dim );
-  mhdf_writeConnectivity( handle, RANK, 1, H5T_NATIVE_INT, list, &status );
-  CHECK(status);
-  CHECK(status);
-    /* write set descriptions */
-  handle = mhdf_openSetMeta( file, &count, &first_set, &status );
-  CHECK(status);
-  assert( count == 2+NUM_PROC );
-    /* write set descriptions for per-proc sets */
-  set_desc[0] = total_num_nodes + total_num_hexes + 9 + 5*RANK - 1;
-  mhdf_writeSetMeta( handle, 2+RANK, 1, H5T_NATIVE_LONG, set_desc, &status );
-  CHECK(status);
-    /* write set descriptions for multi-proc sets */
-  if (0 == RANK) {
-    set_desc[0] = total_num_nodes - 1;
-    mhdf_writeSetMeta( handle, 0, 1, H5T_NATIVE_LONG, set_desc, &status );
-    CHECK(status);
-    set_desc[0] += total_num_hexes;
-    mhdf_writeSetMeta( handle, 1, 1, H5T_NATIVE_LONG, set_desc, &status );
-    CHECK(status);
-  CHECK(status);
-    /* write set contents */
-  handle = mhdf_openSetData( file, &count, &status );
-  CHECK(status);
-  assert( 2*total_num_nodes + 2*total_num_hexes == count );
-    /* write per-proc sets */
-  if (0 == RANK) {
-    count = 9;
-    offset = total_num_nodes + total_num_hexes;
-      list[i] = first_node + i;
-    list[8] = first_elem;
-  else {
-    count = 5;
-    offset = total_num_nodes + total_num_hexes + 4 + 5*RANK;
-    for (i = 0; i < 4; ++i)
-      list[i] = 4 + 4*RANK + first_node + i;
-    list[4] = RANK + first_elem;
-  mhdf_writeSetData( handle, offset, count, H5T_NATIVE_INT, list, &status );
-  CHECK(status);
-    /* write multi-proc sets */
-    /* write nodes */
-  offset = (0 == RANK) ? 0 : 4 + 4*RANK;
-  mhdf_writeSetData( handle, offset, count-1, H5T_NATIVE_INT, list, &status );
-  CHECK(status);
-    /* write hex */
-  offset = total_num_nodes + RANK;
-  mhdf_writeSetData( handle, offset, 1, H5T_NATIVE_INT, list + count - 1, &status );
-  CHECK(status);
-  CHECK(status);
-    /* write tag data */
-  offset += 2*RANK;
-  list[count++] = first_set + 2 + RANK;
-  mhdf_openSparseTagData( file, proc_tag_name, &ntag, &ntag, handles, &status );
-  CHECK(status);
-  assert( ntag == total_num_nodes + total_num_hexes + NUM_PROC );
-  mhdf_writeSparseTagEntities( handles[0], offset, count, H5T_NATIVE_INT, list, &status );
-  CHECK(status);
-  mhdf_writeSparseTagValues( handles[1], offset, count, H5T_NATIVE_INT, tagdata, &status );
-  CHECK(status);
-  mhdf_closeData( file, handles[0], &status );
-  CHECK(status);
-  mhdf_closeData( file, handles[1], &status );
-  CHECK(status);
-    /* done */
-  CHECK(status);
-int main( int argc, char* argv[] )
-  int rval;
-  rval = MPI_Init( &argc, &argv );
-  if (rval)
-    return rval;
-  rval = MPI_Comm_rank( MPI_COMM_WORLD, &RANK );
-  if (rval)
-    return rval;
-  rval = MPI_Comm_size( MPI_COMM_WORLD, &NUM_PROC );
-  if (rval)
-    return rval;
-  if (RANK == 0)
-    create_file();
-  write_file_data();
-  MPI_Finalize();
-  return 0;
