[MOAB-dev] r1974 - MOAB/trunk
    kraftche at mcs.anl.gov
    Tue Jul  1 16:56:39 CDT 2008
Author: kraftche
Date: 2008-07-01 16:56:39 -0500 (Tue, 01 Jul 2008)
New Revision: 1974
Modified:
   MOAB/trunk/TestTypeSequenceManager.cpp
Log:
regression tests for recent sequence manager fixes
Modified: MOAB/trunk/TestTypeSequenceManager.cpp
--- MOAB/trunk/TestTypeSequenceManager.cpp	2008-07-01 21:34:03 UTC (rev 1973)
+++ MOAB/trunk/TestTypeSequenceManager.cpp	2008-07-01 21:56:39 UTC (rev 1974)
@@ -19,6 +19,10 @@
 void test_is_free_sequence();
 void test_is_free_handle();
+void regression_svn1952();
+void regression_svn1958();
+void regression_svn1960();
 /* Construct sequence of vertex handles containing
    the ID ranges: { [3,7], [100,111], [1001] }
    referencing a SequnceData with the range [1,22000]
@@ -66,6 +70,10 @@
   error_count += RUN_TEST( test_find_free_handle );
   error_count += RUN_TEST( test_find_free_sequence );
   error_count += RUN_TEST( test_is_free_sequence );
+  error_count += RUN_TEST( regression_svn1952 );
+  error_count += RUN_TEST( regression_svn1958 );
+  error_count += RUN_TEST( regression_svn1960 );
   if (!error_count)
     printf( "ALL TESTS PASSED\n");
@@ -831,10 +839,10 @@
   TypeSequenceManager seqman;
   SequenceData* data1 = new SequenceData(0,   1,1000);
   SequenceData* data2 = new SequenceData(0,2001,3000);
-  CHECK( insert_seq( seqman,    1, 500, data1, true  ) );
-  CHECK( insert_seq( seqman,  601, 400, data1, false ) );
-  CHECK( insert_seq( seqman, 2500, 100, data2, true  ) );
-  CHECK( insert_seq( seqman, 2800, 200, data2, false ) );
+  CHECK_ERR( insert_seq( seqman,    1, 500, data1, true  ) );
+  CHECK_ERR( insert_seq( seqman,  601, 400, data1, false ) );
+  CHECK_ERR( insert_seq( seqman, 2500, 100, data2, true  ) );
+  CHECK_ERR( insert_seq( seqman, 2800, 200, data2, false ) );
   // Begin tests
   TypeSequenceManager::iterator seq;
@@ -972,3 +980,93 @@
   CHECK_EQUAL( (MBEntityHandle)3001, first );
   CHECK_EQUAL( (MBEntityHandle)MB_END_ID, last );
+// Regression test for bug fixed in SVN revision 1952.
+// SVN checkin message:
+//  Fixing a bug in allocation of sequences.  Before this commit, when:
+//  - Existing sequence starts at one place, e.g. 41686, but its
+//  sequenceData starts earlier, e.g. 41673, and
+//  - You try to allocate a new sequence at a lower handle but with a
+//  range which is more than the room available in the sequenceData,
+//  then
+//  - the code wants to allocate right up against the lower end of the
+//  existing sequence, and sizes the new sequenceData accordingly
+//  (i.e. with a max of 41685).
+//  In this case, that new sequenceData will overlap the existing
+//  sequenceData (which starts at 41673, even though it has an empty chunk
+//  in front).
+//  So, this change passes back a sequence data size from the code which
+//  computes where to put the start handle when allocating the new
+//  sequence.
+  const MBEntityHandle last_handle = 50000;
+  TypeSequenceManager seqman;
+  SequenceData* data = new SequenceData( 0, 41673, last_handle );
+  CHECK_ERR( insert_seq( seqman, 41686, 1000, data, true  ) );
+  SequenceData* result_data;
+  MBEntityID result_size;
+  MBEntityHandle result_handle;
+  result_handle = seqman.find_free_sequence( 1686, 4000, 2*last_handle, result_data, result_size );
+  CHECK( result_handle > last_handle || result_handle + result_size <= 41673 );
+  CHECK( result_handle + result_size <= 2*last_handle );
+// Regression test for bug fixed in SVN revision 1958.
+//  Another fix to SequenceManager.  This time:
+//  - there was no sequence data allocated for the target range
+//  - there was exactly enough room in unallocated sequence data for the target range
+//  - the next data sequence up had a couple of empty slots, so the first occupied handle was a couple spaces from the start of the sequence data
+//  - the upper end of the range of the allocated sequence data was computed based on the first handle in the next sequence data
+//  Fixed by setting the size using the parameter I added before.
+  const int data_size = 100;
+  const MBEntityHandle data_start = 100;
+  const MBEntityHandle data_end = data_start + data_size - 1;
+  const int seq_offset = 2;
+  SequenceData* data = new SequenceData( 0, data_start, data_end );
+  CHECK_ERR( insert_seq( seqman, data_start+seq_offset, data_size-seq_offset, data, true  ) );
+  result_handle = seqman.find_free_sequence( data_start-1, 1, 100000, result_data, result_size );
+  CHECK( result_handle > data_end || result_handle + result_size <= data_start );
+// Regression test for bug fixed in SVN revision 1960.
+//  Third time pays for all.  This time, in TSM::is_free_sequence was true,
+//  so there was a free sequence; SM::create_entity_sequence then called
+//  SM::new_sequence_size, which used the first handle of the next higher
+//  sequence to compute the size, when the start handle of the data on
+//  which that first handle was allocated was smaller.  Sigh.
+  const int data_size = 6000;
+  const MBEntityHandle data_start = 4000;
+  const int seq_offset = 1000;
+  result_handle = seqman.find_free_sequence( data_start-2, 1, 100000, result_data, result_size );
+  CHECK( result_handle + result_size <= data_start );
