[MOAB-dev] r1973 - in MOAB/trunk: . parallel
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Jul 1 16:34:03 CDT 2008
Author: kraftche
Date: 2008-07-01 16:34:03 -0500 (Tue, 01 Jul 2008)
New Revision: 1973
Modified:
   MOAB/trunk/TestTypeSequenceManager.cpp
   MOAB/trunk/moab.make.in
   MOAB/trunk/parallel/Makefile.am
   MOAB/trunk/parallel/WriteHDF5Parallel.cpp
   MOAB/trunk/parallel/WriteHDF5Parallel.hpp
Log:
back out a whole bunch of stuff I didn't intend to check in yet.  Sorry about the noise
Modified: MOAB/trunk/TestTypeSequenceManager.cpp
--- MOAB/trunk/TestTypeSequenceManager.cpp	2008-07-01 21:31:19 UTC (rev 1972)
+++ MOAB/trunk/TestTypeSequenceManager.cpp	2008-07-01 21:34:03 UTC (rev 1973)
@@ -19,10 +19,6 @@
 void test_is_free_sequence();
 void test_is_free_handle();
-void regression_svn1952();
-void regression_svn1958();
-void regression_svn1960();
 /* Construct sequence of vertex handles containing
    the ID ranges: { [3,7], [100,111], [1001] }
    referencing a SequnceData with the range [1,22000]
@@ -70,10 +66,6 @@
   error_count += RUN_TEST( test_find_free_handle );
   error_count += RUN_TEST( test_find_free_sequence );
   error_count += RUN_TEST( test_is_free_sequence );
-  error_count += RUN_TEST( regression_svn1952 );
-  error_count += RUN_TEST( regression_svn1958 );
-  error_count += RUN_TEST( regression_svn1960 );
   if (!error_count)
     printf( "ALL TESTS PASSED\n");
@@ -980,80 +972,3 @@
   CHECK_EQUAL( (MBEntityHandle)3001, first );
   CHECK_EQUAL( (MBEntityHandle)MB_END_ID, last );
-// Regression test for bug fixed in SVN revision 1952.
-// SVN checkin message:
-//  Fixing a bug in allocation of sequences.  Before this commit, when:
-//  - Existing sequence starts at one place, e.g. 41686, but its
-//  sequenceData starts earlier, e.g. 41673, and
-//  - You try to allocate a new sequence at a lower handle but with a
-//  range which is more than the room available in the sequenceData,
-//  then
-//  - the code wants to allocate right up against the lower end of the
-//  existing sequence, and sizes the new sequenceData accordingly
-//  (i.e. with a max of 41685).
-//  In this case, that new sequenceData will overlap the existing
-//  sequenceData (which starts at 41673, even though it has an empty chunk
-//  in front).
-//  So, this change passes back a sequence data size from the code which
-//  computes where to put the start handle when allocating the new
-//  sequence.
-  const MBEntityHandle last_handle = 50000;
-  TypeSequenceManager seqman;
-  SequenceData* data = new SequenceData( 0, 41673, last_handle );
-  CHECK( insert_seq( seqman, 41686, 1000, data, true  ) );
-  SequenceData* result_data;
-  MBEntityID result_size;
-  MBEntityHandle result_handle;
-  result_handle = seqman.find_free_sequence( 1686, 4000, 2*last_handle, result_data, result_size );
-  CHECK( result_handle > last_handle );
-  CHECK( result_handle + result_size <= 2*last_handle );
-// Regression test for bug fixed in SVN revision 1958.
-//  Another fix to SequenceManager.  This time:
-//  - there was no sequence data allocated for the target range
-//  - there was exactly enough room in unallocated sequence data for the target range
-//  - the next data sequence up had a couple of empty slots, so the first occupied handle was a couple spaces from the start of the sequence data
-//  - the upper end of the range of the allocated sequence data was computed based on the first handle in the next sequence data
-//  Fixed by setting the size using the parameter I added before.
-  const int data_size = 100;
-  const MBEntityHandle data_start = 100;
-  const MBEntityHandle data_end = data_start + data_size - 1;
-  const int seq_offset = 2;
-  SequenceData* data = new SequenceData( 0, data_start, data_end );
-  CHECK( insert_seq( seqman, data_start+seq_offset, data_size-seq_offset, data, true  ) );
-  result_handle = seqman.find_free_sequence( data_start-1, 1, 100000, result_data, result_size );
-  CHECK( result_handle > data_end || result_handle + result_size <= data_start );
-// Regression test for bug fixed in SVN revision 1960.
-//  Third time pays for all.  This time, in TSM::is_free_sequence was true,
-//  so there was a free sequence; SM::create_entity_sequence then called
-//  SM::new_sequence_size, which used the first handle of the next higher
-//  sequence to compute the size, when the start handle of the data on
-//  which that first handle was allocated was smaller.  Sigh.
Modified: MOAB/trunk/moab.make.in
--- MOAB/trunk/moab.make.in	2008-07-01 21:31:19 UTC (rev 1972)
+++ MOAB/trunk/moab.make.in	2008-07-01 21:34:03 UTC (rev 1973)
@@ -7,7 +7,7 @@
 MOAB_INCLUDES = -I$(MOAB_INCLUDEDIR)
-MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB @HDF5_LIBS@ @NETCDF_LIBS@ @LIBS@
+MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB @LIBS@ @HDF5_LIBS@ @NETCDF_LIBS@
 DAGMC_CONFIG_OPTIONS = @DAGMC_CONFIG_OPTIONS@
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am	2008-07-01 21:31:19 UTC (rev 1972)
+++ MOAB/trunk/parallel/Makefile.am	2008-07-01 21:34:03 UTC (rev 1973)
@@ -11,10 +11,6 @@
 DEFS = $(DEFINES) -DIS_BUILDING_MB
 INCLUDES += -I$(top_srcdir) -I$(top_builddir)
-# Let tests know where the source directory is in case they
-# need to load input files
-CPPFLAGS += '-DSRCDIR=$(srcdir)'
 # The directory in which to install headers
 libMOABpar_la_includedir = $(includedir)
@@ -23,7 +19,6 @@
 MOAB_PARALLEL_SRCS =
 MOAB_PARALLEL_HDRS =
 MOAB_PARALLEL_TEST =
-HDF5_PARALLEL_TEST =
 if PARALLEL
   MOAB_PARALLEL_SRCS += \
      MBParallelComm.cpp \
@@ -46,10 +41,13 @@
   INCLUDES += -I$(top_srcdir)/mhdf/include
   MOAB_PARALLEL_SRCS += WriteHDF5Parallel.cpp
   MOAB_PARALLEL_HDRS += WriteHDF5Parallel.hpp
-  HDF5_PARALLEL_TEST = parallel_hdf5_test
 endif
-  MOAB_PARALLEL_TEST += mbparallelcomm_test
+  bin_PROGRAMS = mbparallelcomm_test
+  mbparallelcomm_test_SOURCES = mbparallelcomm_test.cpp
+  mbparallelcomm_test_LDADD = $(top_builddir)/libMOAB.la
+  mbparallelcomm_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
   MOAB_PARALLEL_TEST += pcomm_unit
 endif
@@ -64,14 +62,8 @@
 # Tests and such
-check_PROGRAMS = $(MOAB_PARALLEL_TEST) $(HDF5_PARALLEL_TEST)
-TESTS = $(check_PROGRAMS)
+check_PROGRAMS = $(MOAB_PARALLEL_TEST)
+TESTS = $(MOAB_PARALLEL_TEST)
 pcomm_unit_SOURCES = pcomm_unit.cpp
 pcomm_unit_LDADD = $(top_builddir)/libMOAB.la
-parallel_hdf5_test_SOURCES = parallel_hdf5_test.cc
-parallel_hdf5_test_LDADD = $(top_builddir)/libMOAB.la
-parallel_hdf5_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
-mbparallelcomm_test_SOURCES = mbparallelcomm_test.cpp
-mbparallelcomm_test_LDADD = $(top_builddir)/libMOAB.la
-mbparallelcomm_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp	2008-07-01 21:31:19 UTC (rev 1972)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp	2008-07-01 21:34:03 UTC (rev 1973)
@@ -1,5 +1,5 @@
-#define DEBUG
+#undef DEBUG
 #ifdef DEBUG
 #  include <stdio.h>
@@ -41,7 +41,7 @@
 #ifdef DEBUG
 #  define START_SERIAL                     \
-     for (unsigned _x = 0; _x < myPcomm->proc_config().proc_size(); ++_x) {\
+     for (int _x = 0; _x < myPcomm->proc_config().proc_size(); ++_x) {\
        MPI_Barrier( MPI_COMM_WORLD );      \
        if (_x != myPcomm->proc_config().proc_rank()) continue
 #  define END_SERIAL                       \
@@ -122,19 +122,20 @@
 #ifndef DEBUG
 static void print_type_sets( MBInterface* , int , int , MBRange& ) {}
 #else
-static void print_type_sets( MBInterface* iFace, int rank, int size, MBRange& sets )
+static void print_type_sets( MBInterface* iFace, int myPcomm->proc_config().proc_rank(), int myPcomm->proc_config().proc_size(), MBRange& sets )
-  MBTag gid, did, bid, sid, nid;
+  MBTag gid, did, bid, sid, nid, iid;
   iFace->tag_get_handle( GLOBAL_ID_TAG_NAME, gid );
   iFace->tag_get_handle( GEOM_DIMENSION_TAG_NAME, did );
   iFace->tag_get_handle( MATERIAL_SET_TAG_NAME, bid );
   iFace->tag_get_handle( DIRICHLET_SET_TAG_NAME, nid );
   iFace->tag_get_handle( NEUMANN_SET_TAG_NAME, sid );
+  iFace->tag_get_handle( PARALLEL_PARTITION_TAG_NAME, iid );
   MBRange typesets[10];
-  const char* typenames[] = {"Block", "Sideset", "NodeSet", "Vertex", "Curve", "Surface", "Volume", "Body", "Other"};
+  const char* typenames[] = {"Block", "Sideset", "NodeSet", "Vertex", "Curve", "Surface", "Volume", "Body", "Partition", "Other"};
   for (MBRange::iterator riter = sets.begin(); riter != sets.end(); ++riter)
-    unsigned dim, id, oldsize;
+    unsigned dim, id, proc[2], oldsize;
     if (MB_SUCCESS == iFace->tag_get_data(bid, &*riter, 1, &id))
       dim = 0;
     else if (MB_SUCCESS == iFace->tag_get_data(sid, &*riter, 1, &id))
@@ -146,6 +147,11 @@
       iFace->tag_get_data(gid, &*riter, 1, &id);
       dim += 3;
+    else if (MB_SUCCESS == iFace->tag_get_data(iid, &*riter, 1, proc)) {
+      assert(proc[0] == (unsigned)myPcomm->proc_config().proc_rank() || proc[1] == (unsigned)myPcomm->proc_config().proc_rank());
+      id = proc[proc[0] == (unsigned)myPcomm->proc_config().proc_rank()];
+      dim = 8;
     else {
       id = *riter;
       dim = 9;
@@ -155,7 +161,7 @@
     typesets[dim].insert( id );
     assert( typesets[dim].size() - oldsize == 1 );
-  for (int ii = 0; ii < 9; ++ii)
+  for (int ii = 0; ii < 10; ++ii)
     char num[16];
     std::string line(typenames[ii]);
@@ -323,7 +329,7 @@
     // For the 'remoteMesh' list for this processor, just remove
     // entities we aren't writing.
-  MBRange& my_remote_mesh = remoteMesh[myPcomm->proc_config().proc_rank()];
+  MBRange& my_remote_mesh = remoteMesh[myPcomm->proc_config().proc_size()];
   tmpset = my_remote_mesh.subtract( nodeSet.range );
   if (!tmpset.empty())
     my_remote_mesh = my_remote_mesh.subtract( tmpset );
@@ -610,7 +616,7 @@
       return MB_FAILURE;
     mhdf_closeData( filePtr, handle, &status );
     // send id offset to every proc
   result = MPI_Bcast( &first_id, 1, MPI_LONG, 0, MPI_COMM_WORLD );
@@ -631,13 +637,13 @@
     // send each proc it's offset in the node table
-  long offset;
-  result = MPI_Scatter( &node_counts[0], 1, MPI_LONG,
-                        &offset, 1, MPI_LONG,
+  int offset;
+  result = MPI_Scatter( &node_counts[0], 1, MPI_INT,
+                        &offset, 1, MPI_INT,
   assert(MPI_SUCCESS == result);
   nodeSet.offset = offset;
   return assign_ids( nodeSet.range, nodeSet.first_id + nodeSet.offset );
@@ -1899,35 +1905,27 @@
 MBErrorCode WriteHDF5Parallel::communicate_remote_ids( MBEntityType type )
+  int result;
+  MBErrorCode rval;
     // Get the export set for the specified type
+  ExportSet* export_set = 0;
   if (type == MBVERTEX)
-    return communicate_remote_ids( &nodeSet );
+    export_set = &nodeSet;
   else if(type == MBENTITYSET)
-    return communicate_remote_ids( &setSet );
+    export_set = &setSet;
   else
     for (std::list<ExportSet>::iterator esiter = exportList.begin();
          esiter != exportList.end(); ++esiter)
       if (esiter->type == type)
-        MBErrorCode rval = communicate_remote_ids( &*esiter );
-        if (MB_SUCCESS != rval)
-          return rval;
+        export_set = &*esiter;
+        break;
-    return MB_SUCCESS;
+  assert(export_set != NULL);
-MBErrorCode WriteHDF5Parallel::communicate_remote_ids( ExportSet* export_set )
-  RangeMap<MBEntityHandle,id_t>::iterator ri;
-  std::vector<MBEntityHandle> remote_handles;
-  MBErrorCode rval;
-  int result;
-  const MBEntityType type = export_set->type;
-  assert(export_set != NULL);
     // Get the ranges in the set
   std::vector<unsigned long> myranges;
   MBRange::const_pair_iterator p_iter = export_set->range.const_pair_begin();
@@ -1971,56 +1969,60 @@
     // Set file IDs for each communicated entity
     // For each processor
-  for (unsigned int proc = 0; proc < myPcomm->proc_config().proc_size(); ++proc) {
-    if (proc == myPcomm->proc_config().proc_rank() || remoteMesh[proc].empty())
+  for (unsigned int proc = 0; proc < myPcomm->proc_config().proc_size(); ++proc)
+    if (proc == myPcomm->proc_config().proc_rank())
       continue;
-      // constuct RangeMap to map from handles on remote processor
-      // to file IDs
-    RangeMap<MBEntityHandle,id_t> remote_ids;
-    unsigned long* i = &allranges[displs[proc]];
-    unsigned long* const e = i + counts[proc];
-    unsigned long file_id = offsets[proc];
-    while (i < e) {
-      MBEntityHandle start_handle = (MBEntityHandle)*i; ++i;
-      MBEntityHandle end_handle = (MBEntityHandle)*i; ++i;
-      MBEntityHandle count = end_handle - start_handle + 1;
-      ri = remote_ids.insert( (MBEntityHandle)start_handle, file_id, count );
-      assert( ri != remote_ids.end() );
-      file_id += count;
+      // Get data for corresponding processor
+    const int offset = offsets[proc];
+    const int count = counts[proc];
+    const unsigned long* const ranges = &allranges[displs[proc]];
-      // for entities on other processor that we must reference from this
-      // processor, get the handle on the remote proc and from there
-      // look up the file id in the map constructed above
-    std::pair<MBRange::iterator,MBRange::iterator> iters = remoteMesh[proc].equal_range(type);
-    MBRange subrange, empty;
-    subrange.merge( iters.first, iters.second );
-    remote_handles.resize( subrange.size() );
-    rval = myPcomm->get_remote_handles( true, subrange, &remote_handles[0], proc, empty );
-    if (MB_SUCCESS != rval) {
-      printdebug( "Query for remote handles for type %s on proc %d failed with error code %d\n",
-                   MBCN::EntityTypeName(type), (int)proc, (int)rval );
-      return rval;
-    std::vector<MBEntityHandle>::const_iterator rem = remote_handles.begin();
-    MBRange::const_iterator loc = subrange.begin();
-    for( ; rem != remote_handles.end(); ++rem, ++loc) {
-      id_t id = remote_ids.find( *rem );
-      if (!id) {
-        printdebug( "Invalid remote handle (0x%lx, %s) on proc %d.\n",
-                     (unsigned long)*rem, MBCN::EntityTypeName(type), (int)proc );
-        return MB_FAILURE;
+      // For each geometry meshset in the interface
+    MBRange::iterator r_iter = MBRange::lower_bound( remoteMesh[proc].begin(),
+                                                     remoteMesh[proc].end(),
+                                                     CREATE_HANDLE(type,0,result) );
+    MBRange::iterator r_stop = MBRange::lower_bound( r_iter,
+                                                     CREATE_HANDLE(type+1,0,result) );
+    for ( ; r_iter != r_stop; ++r_iter)
+      MBEntityHandle entity = *r_iter;
+        // Get handle on other processor
+      MBEntityHandle global;
+      rval = iFace->tag_get_data( global_id_tag, &entity, 1, &global );
+      assert(MB_SUCCESS == rval);
+        // Find corresponding fileid on other processor.
+        // This could potentially be n**2, but we will assume that
+        // the range list from each processor is short (typically 1).
+      int j, steps = 0;
+      unsigned long low, high;
+      for (j = 0; j < count; j += 2)
+        low = ranges[j];
+        high = ranges[j+1];
+        if (low <= global && high >= global)
+          break;
+        steps += (high - low) + 1;
-      ri = idMap.insert( *loc, id, 1 );
-      if (ri == idMap.end()) {
-        printdebug( "Conflicting file ID (%ul) for remote handle (0x%lx, %s) on proc %d.\n",
-                     (unsigned long)id, (unsigned long)*rem, MBCN::EntityTypeName(type), (int)proc );
+      if (j >= count) {
+      printdebug("*** handle = %u, type = %d, id = %d, proc = %d\n",
+      (unsigned)global, (int)(iFace->type_from_handle(global)), (int)(iFace->id_from_handle(global)), proc);
+      for (int ii = 0; ii < count; ii+=2)
+      printdebug("***  %u to %u\n", (unsigned)ranges[ii], (unsigned)ranges[ii+1] );
+      MBRange junk; junk.insert( global );
+      print_type_sets( iFace, myPcomm->proc_config().proc_rank(), myPcomm->proc_config().proc_size(), junk );
+      assert(j < count);
+      int fileid = offset + steps + (global - low);
+      RangeMap<MBEntityHandle,id_t>::iterator ri = idMap.insert( entity, fileid, 1 );
+      assert( ri != idMap.end() );
+    } // for(r_iter->range)
+  } // for(each processor)
   return MB_SUCCESS;
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.hpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.hpp	2008-07-01 21:31:19 UTC (rev 1972)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.hpp	2008-07-01 21:34:03 UTC (rev 1973)
@@ -117,12 +117,6 @@
       //! entities to be written on this processor.
     MBErrorCode communicate_remote_ids(MBEntityType type);
-      //! For entities that will be written by another
-      //! processor, get the file Ids that will be assigned
-      //! to those so they can be referenced by
-      //! entities to be written on this processor.
-    MBErrorCode communicate_remote_ids(ExportSet* ents);
       //! Sort the list of tag information in the parent
       //! class by name so all procs have them in the same
       //! order.
