[MOAB-dev] r1975 - MOAB/trunk/refiner
dcthomp at mcs.anl.gov
Tue Jul 1 23:06:20 CDT 2008
Author: dcthomp
Date: 2008-07-01 23:06:20 -0500 (Tue, 01 Jul 2008)
New Revision: 1975
Modified:
MOAB/trunk/refiner/MBMeshOutputFunctor.hpp
MOAB/trunk/refiner/test_mesh_refiner.cpp
Log:
ENH: Checkpoint. When a "split vertex" (i.e., one that splits an
edge or triangle) is added to the mesh, the set of processes
that vertex must be shared with is generated. Right now, we
just print out the results.
Modified: MOAB/trunk/refiner/MBMeshOutputFunctor.hpp
--- MOAB/trunk/refiner/MBMeshOutputFunctor.hpp 2008-07-01 21:56:39 UTC (rev 1974)
+++ MOAB/trunk/refiner/MBMeshOutputFunctor.hpp 2008-07-02 04:06:20 UTC (rev 1975)
@@ -8,6 +8,8 @@
#include <iostream>
#include <set>
#include <map>
+#include <iterator>
+#include <algorithm>
template< int _n >
class MBSplitVertexIndex
@@ -43,28 +45,92 @@
this->mesh_in = tag_mgr->get_input_mesh();
this->mesh_out = tag_mgr->get_output_mesh();
this->shared_procs_val.resize( MAX_SHARING_PROCS );
+ MBParallelComm* ipcomm = MBParallelComm::get_pcomm( this->mesh_in, 0 );
+ this->rank = ipcomm ? ipcomm->proc_config().proc_rank() : 0;
virtual ~MBSplitVerticesBase() { }
virtual bool find_or_create( const MBEntityHandle* split_src, const double* coords, MBEntityHandle& vert_handle ) = 0;
- void print_sharing_procs( MBEntityHandle vert_in )
+ /// Prepare to compute the processes on which a new split-vertex will live.
+ void begin_vertex_procs()
- if ( this->mesh_in->tag_get_data( this->tag_manager->shared_proc(), &vert_in, 1, &this->shared_procs_val[0] ) != MB_TAG_NOT_FOUND )
+ this->first_vertex = true;
+ /// Call this for each existing corner vertex used to define a split-vertex.
+ void add_vertex_procs( MBEntityHandle vert_in )
+ std::set<int> current_shared_procs;
+ if ( ! this->first_vertex )
- std::cout << " s" << this->shared_procs_val[0];
+ current_shared_procs = this->common_shared_procs;
- if ( this->mesh_in->tag_get_data( this->tag_manager->shared_procs(), &vert_in, 1, &this->shared_procs_val[0] ) != MB_TAG_NOT_FOUND )
+ this->common_shared_procs.clear();
+ int stat;
+ bool got = false;
+ stat = this->mesh_in->tag_get_data(
+ this->tag_manager->shared_proc(), &vert_in, 1, &this->shared_procs_val[0] );
+ std::cout << "sstat: " << stat;
+ if ( stat == MB_SUCCESS && this->shared_procs_val[0] != -1 )
- for ( int i = 0; i < MAX_SHARING_PROCS && this->shared_procs_val[i]; ++ i )
+ got = true;
+ std::cout << " s" << this->rank << " s" << this->shared_procs_val[0] << " | ";
+ this->shared_procs_val.resize( 1 );
+ this->tag_manager->shared_procs(), &vert_in, 1, &this->shared_procs_val[0] );
+ std::cout << "mstat: " << stat;
+ got = true;
+ int i;
+ for ( i = 0; i < MAX_SHARING_PROCS && this->shared_procs_val[i] != -1; ++ i )
std::cout << " m" << this->shared_procs_val[i];
+ this->shared_procs_val.resize( i );
+ std::cout << " | ";
+ if ( got )
+ if ( this->first_vertex )
+ std::copy(
+ this->shared_procs_val.begin(), this->shared_procs_val.end(),
+ std::insert_iterator< std::set<int> >( this->common_shared_procs, this->common_shared_procs.begin() ) );
+ this->first_vertex = false;
+ else
+ std::set_intersection(
+ current_shared_procs.begin(), current_shared_procs.end(),
+ else
+ std::cout << " not shared | ";
+ /// Call this once after all the add_vertex_procs() calls for a split-vertex to prepare queues for the second stage MPI send.
+ void end_vertex_procs()
+ std::cout << " Common procs ";
+ std::copy(
+ this->common_shared_procs.begin(), this->common_shared_procs.end(),
+ std::ostream_iterator<int>( std::cout, " " ) );
+ std::cout << " " << this->rank;
+ std::cout << "\n";
+ // FIXME: Here is where we add the vertex to the appropriate queues.
MBInterface* mesh_in; // Input mesh. Needed to determine tag values on split_src verts
MBInterface* mesh_out; // Output mesh. Needed for new vertex set in vert_handle
MBRefinerTagManager* tag_manager;
- std::vector<MBEntityHandle> shared_procs_val; // Used to hold procs sharing an input vert.
- std::set<MBEntityHandle> common_shared_procs; // Holds intersection of several shared_procs_vals.
+ std::vector<int> shared_procs_val; // Used to hold procs sharing an input vert.
+ std::set<int> common_shared_procs; // Holds intersection of several shared_procs_vals.
+ int rank; // This process' rank.
+ bool first_vertex; // True just after begin_vertex_procs() is called.
template< int _n >
@@ -77,6 +143,7 @@
MBSplitVertices( MBRefinerTagManager* tag_mgr )
: MBSplitVerticesBase( tag_mgr )
+ this->shared_procs_val.resize( _n * MAX_SHARING_PROCS );
virtual ~MBSplitVertices() { }
@@ -91,11 +158,13 @@
(*this)[key] = vert_handle;
std::cout << "New vertex " << vert_handle << " shared with ";
+ this->begin_vertex_procs();
for ( int i = 0; i < _n; ++ i )
- this->print_sharing_procs( split_src[i] );
+ this->add_vertex_procs( split_src[i] );
std::cout << "\n";
+ this->end_vertex_procs();
// Decide whether local process owns new vert.
// Add to the appropriate queues for transmitting handles.
return true;
Modified: MOAB/trunk/refiner/test_mesh_refiner.cpp
--- MOAB/trunk/refiner/test_mesh_refiner.cpp 2008-07-01 21:56:39 UTC (rev 1974)
+++ MOAB/trunk/refiner/test_mesh_refiner.cpp 2008-07-02 04:06:20 UTC (rev 1975)
@@ -58,7 +58,7 @@
MBEntityHandle set_handle;
std::ostringstream parallel_options;
parallel_options
- << "PARALLEL=BCAST_DELETE" << ";"
+ << "PARALLEL=BCAST_DELETE" << ";" // NB: You can also use READ_DELETE here.
<< "PARTITION=MATERIAL_SET" << ";"
//<< "PARTITION_DISTRIBUTE" << ";"
<< "PARTITION_VAL=" << ( rank + 1 ) << ";"
