[MOAB-dev] r1972 - in MOAB/trunk: . parallel
kraftche at mcs.anl.gov
Tue Jul 1 16:31:20 CDT 2008
Author: kraftche
Date: 2008-07-01 16:31:19 -0500 (Tue, 01 Jul 2008)
New Revision: 1972
Modified:
MOAB/trunk/README.CONFIGURE
MOAB/trunk/TestTypeSequenceManager.cpp
MOAB/trunk/TypeSequenceManager.cpp
MOAB/trunk/moab.make.in
MOAB/trunk/parallel/MBParallelComm.hpp
MOAB/trunk/parallel/Makefile.am
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/parallel/WriteHDF5Parallel.hpp
Log:
remove unnecessary std::min (start_handle of SequenceData is less than or equal to start_handle of all containted SequenceDatas)
Modified: MOAB/trunk/README.CONFIGURE
--- MOAB/trunk/README.CONFIGURE 2008-07-01 06:31:18 UTC (rev 1971)
+++ MOAB/trunk/README.CONFIGURE 2008-07-01 21:31:19 UTC (rev 1972)
@@ -11,9 +11,9 @@
autoheader
aclocal -I m4
- libtoolize
+ libtoolize -f
+ autoconf
automake -a
- autoconf
Why aren't the configure script and other generated files in the
Modified: MOAB/trunk/TestTypeSequenceManager.cpp
--- MOAB/trunk/TestTypeSequenceManager.cpp 2008-07-01 06:31:18 UTC (rev 1971)
+++ MOAB/trunk/TestTypeSequenceManager.cpp 2008-07-01 21:31:19 UTC (rev 1972)
@@ -19,6 +19,10 @@
void test_is_free_sequence();
void test_is_free_handle();
+void regression_svn1952();
+void regression_svn1958();
+void regression_svn1960();
/* Construct sequence of vertex handles containing
the ID ranges: { [3,7], [100,111], [1001] }
referencing a SequnceData with the range [1,22000]
@@ -66,6 +70,10 @@
error_count += RUN_TEST( test_find_free_handle );
error_count += RUN_TEST( test_find_free_sequence );
error_count += RUN_TEST( test_is_free_sequence );
+ error_count += RUN_TEST( regression_svn1952 );
+ error_count += RUN_TEST( regression_svn1958 );
+ error_count += RUN_TEST( regression_svn1960 );
if (!error_count)
printf( "ALL TESTS PASSED\n");
@@ -972,3 +980,80 @@
CHECK_EQUAL( (MBEntityHandle)3001, first );
CHECK_EQUAL( (MBEntityHandle)MB_END_ID, last );
+// Regression test for bug fixed in SVN revision 1952.
+// SVN checkin message:
+// Fixing a bug in allocation of sequences. Before this commit, when:
+// - Existing sequence starts at one place, e.g. 41686, but its
+// sequenceData starts earlier, e.g. 41673, and
+// - You try to allocate a new sequence at a lower handle but with a
+// range which is more than the room available in the sequenceData,
+// then
+// - the code wants to allocate right up against the lower end of the
+// existing sequence, and sizes the new sequenceData accordingly
+// (i.e. with a max of 41685).
+// In this case, that new sequenceData will overlap the existing
+// sequenceData (which starts at 41673, even though it has an empty chunk
+// in front).
+// So, this change passes back a sequence data size from the code which
+// computes where to put the start handle when allocating the new
+// sequence.
+ const MBEntityHandle last_handle = 50000;
+ TypeSequenceManager seqman;
+ SequenceData* data = new SequenceData( 0, 41673, last_handle );
+ CHECK( insert_seq( seqman, 41686, 1000, data, true ) );
+ SequenceData* result_data;
+ MBEntityID result_size;
+ MBEntityHandle result_handle;
+ result_handle = seqman.find_free_sequence( 1686, 4000, 2*last_handle, result_data, result_size );
+ CHECK( result_handle > last_handle );
+ CHECK( result_handle + result_size <= 2*last_handle );
+// Regression test for bug fixed in SVN revision 1958.
+// Another fix to SequenceManager. This time:
+// - there was no sequence data allocated for the target range
+// - there was exactly enough room in unallocated sequence data for the target range
+// - the next data sequence up had a couple of empty slots, so the first occupied handle was a couple spaces from the start of the sequence data
+// - the upper end of the range of the allocated sequence data was computed based on the first handle in the next sequence data
+// Fixed by setting the size using the parameter I added before.
+ const int data_size = 100;
+ const MBEntityHandle data_start = 100;
+ const MBEntityHandle data_end = data_start + data_size - 1;
+ const int seq_offset = 2;
+ SequenceData* data = new SequenceData( 0, data_start, data_end );
+ CHECK( insert_seq( seqman, data_start+seq_offset, data_size-seq_offset, data, true ) );
+ result_handle = seqman.find_free_sequence( data_start-1, 1, 100000, result_data, result_size );
+ CHECK( result_handle > data_end || result_handle + result_size <= data_start );
+// Regression test for bug fixed in SVN revision 1960.
+// Third time pays for all. This time, in TSM::is_free_sequence was true,
+// so there was a free sequence; SM::create_entity_sequence then called
+// SM::new_sequence_size, which used the first handle of the next higher
+// sequence to compute the size, when the start handle of the data on
+// which that first handle was allocated was smaller. Sigh.
Modified: MOAB/trunk/TypeSequenceManager.cpp
--- MOAB/trunk/TypeSequenceManager.cpp 2008-07-01 06:31:18 UTC (rev 1971)
+++ MOAB/trunk/TypeSequenceManager.cpp 2008-07-01 21:31:19 UTC (rev 1972)
@@ -578,7 +578,7 @@
return CREATE_HANDLE( TYPE_FROM_HANDLE(after_this), MB_END_ID, junk );
else if ((*it)->start_handle() > after_this) {
// need to check against the sequence data first
- MBEntityHandle rhandle = std::min((*it)->start_handle(), (*it)->data()->start_handle());
+ MBEntityHandle rhandle = (*it)->data()->start_handle();
return rhandle - 1;
else
Modified: MOAB/trunk/moab.make.in
--- MOAB/trunk/moab.make.in 2008-07-01 06:31:18 UTC (rev 1971)
+++ MOAB/trunk/moab.make.in 2008-07-01 21:31:19 UTC (rev 1972)
@@ -7,7 +7,7 @@
MOAB_INCLUDES = -I$(MOAB_INCLUDEDIR)
-MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB @LIBS@ @HDF5_LIBS@ @NETCDF_LIBS@
+MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB @HDF5_LIBS@ @NETCDF_LIBS@ @LIBS@
DAGMC_CONFIG_OPTIONS = @DAGMC_CONFIG_OPTIONS@
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2008-07-01 06:31:18 UTC (rev 1971)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2008-07-01 21:31:19 UTC (rev 1972)
@@ -490,7 +490,8 @@
MBErrorCode update_iface_sets(MBRange &sent_ents,
std::vector<MBEntityHandle> &remote_handles,
int from_proc);
+public:
//! replace handles in from_vec with corresponding handles on
//! to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag;
//! if no remote handle and new_ents is non-null, substitute
@@ -516,7 +517,8 @@
MBEntityHandle *to_vec,
int to_proc,
const MBRange &new_ents);
+private:
//! goes through from_vec, and for any with type MBMAXTYPE, replaces with
//! new_ents value at index corresponding to id of entity in from_vec
MBErrorCode get_local_handles(MBEntityHandle *from_vec,
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am 2008-07-01 06:31:18 UTC (rev 1971)
+++ MOAB/trunk/parallel/Makefile.am 2008-07-01 21:31:19 UTC (rev 1972)
@@ -11,6 +11,10 @@
DEFS = $(DEFINES) -DIS_BUILDING_MB
INCLUDES += -I$(top_srcdir) -I$(top_builddir)
+# Let tests know where the source directory is in case they
+# need to load input files
+CPPFLAGS += '-DSRCDIR=$(srcdir)'
# The directory in which to install headers
libMOABpar_la_includedir = $(includedir)
@@ -19,6 +23,7 @@
MOAB_PARALLEL_SRCS =
MOAB_PARALLEL_HDRS =
MOAB_PARALLEL_TEST =
+HDF5_PARALLEL_TEST =
if PARALLEL
MOAB_PARALLEL_SRCS += \
MBParallelComm.cpp \
@@ -41,13 +46,10 @@
INCLUDES += -I$(top_srcdir)/mhdf/include
MOAB_PARALLEL_SRCS += WriteHDF5Parallel.cpp
MOAB_PARALLEL_HDRS += WriteHDF5Parallel.hpp
+ HDF5_PARALLEL_TEST = parallel_hdf5_test
endif
- bin_PROGRAMS = mbparallelcomm_test
- mbparallelcomm_test_SOURCES = mbparallelcomm_test.cpp
- mbparallelcomm_test_LDADD = $(top_builddir)/libMOAB.la
- mbparallelcomm_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
+ MOAB_PARALLEL_TEST += mbparallelcomm_test
MOAB_PARALLEL_TEST += pcomm_unit
endif
@@ -62,8 +64,14 @@
# Tests and such
-check_PROGRAMS = $(MOAB_PARALLEL_TEST)
-TESTS = $(MOAB_PARALLEL_TEST)
+check_PROGRAMS = $(MOAB_PARALLEL_TEST) $(HDF5_PARALLEL_TEST)
+TESTS = $(check_PROGRAMS)
pcomm_unit_SOURCES = pcomm_unit.cpp
pcomm_unit_LDADD = $(top_builddir)/libMOAB.la
+parallel_hdf5_test_SOURCES = parallel_hdf5_test.cc
+parallel_hdf5_test_LDADD = $(top_builddir)/libMOAB.la
+parallel_hdf5_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
+mbparallelcomm_test_SOURCES = mbparallelcomm_test.cpp
+mbparallelcomm_test_LDADD = $(top_builddir)/libMOAB.la
+mbparallelcomm_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-07-01 06:31:18 UTC (rev 1971)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-07-01 21:31:19 UTC (rev 1972)
@@ -1,5 +1,5 @@
-#undef DEBUG
+#define DEBUG
#ifdef DEBUG
# include <stdio.h>
@@ -41,7 +41,7 @@
#ifdef DEBUG
# define START_SERIAL \
- for (int _x = 0; _x < myPcomm->proc_config().proc_size(); ++_x) {\
+ for (unsigned _x = 0; _x < myPcomm->proc_config().proc_size(); ++_x) {\
MPI_Barrier( MPI_COMM_WORLD ); \
if (_x != myPcomm->proc_config().proc_rank()) continue
# define END_SERIAL \
@@ -122,20 +122,19 @@
#ifndef DEBUG
static void print_type_sets( MBInterface* , int , int , MBRange& ) {}
#else
-static void print_type_sets( MBInterface* iFace, int myPcomm->proc_config().proc_rank(), int myPcomm->proc_config().proc_size(), MBRange& sets )
+static void print_type_sets( MBInterface* iFace, int rank, int size, MBRange& sets )
- MBTag gid, did, bid, sid, nid, iid;
+ MBTag gid, did, bid, sid, nid;
iFace->tag_get_handle( GLOBAL_ID_TAG_NAME, gid );
iFace->tag_get_handle( GEOM_DIMENSION_TAG_NAME, did );
iFace->tag_get_handle( MATERIAL_SET_TAG_NAME, bid );
iFace->tag_get_handle( DIRICHLET_SET_TAG_NAME, nid );
iFace->tag_get_handle( NEUMANN_SET_TAG_NAME, sid );
- iFace->tag_get_handle( PARALLEL_PARTITION_TAG_NAME, iid );
MBRange typesets[10];
- const char* typenames[] = {"Block", "Sideset", "NodeSet", "Vertex", "Curve", "Surface", "Volume", "Body", "Partition", "Other"};
+ const char* typenames[] = {"Block", "Sideset", "NodeSet", "Vertex", "Curve", "Surface", "Volume", "Body", "Other"};
for (MBRange::iterator riter = sets.begin(); riter != sets.end(); ++riter)
- unsigned dim, id, proc[2], oldsize;
+ unsigned dim, id, oldsize;
if (MB_SUCCESS == iFace->tag_get_data(bid, &*riter, 1, &id))
dim = 0;
else if (MB_SUCCESS == iFace->tag_get_data(sid, &*riter, 1, &id))
@@ -147,11 +146,6 @@
iFace->tag_get_data(gid, &*riter, 1, &id);
dim += 3;
- else if (MB_SUCCESS == iFace->tag_get_data(iid, &*riter, 1, proc)) {
- assert(proc[0] == (unsigned)myPcomm->proc_config().proc_rank() || proc[1] == (unsigned)myPcomm->proc_config().proc_rank());
- id = proc[proc[0] == (unsigned)myPcomm->proc_config().proc_rank()];
- dim = 8;
else {
id = *riter;
dim = 9;
@@ -161,7 +155,7 @@
typesets[dim].insert( id );
assert( typesets[dim].size() - oldsize == 1 );
- for (int ii = 0; ii < 10; ++ii)
+ for (int ii = 0; ii < 9; ++ii)
char num[16];
std::string line(typenames[ii]);
@@ -329,7 +323,7 @@
// For the 'remoteMesh' list for this processor, just remove
// entities we aren't writing.
- MBRange& my_remote_mesh = remoteMesh[myPcomm->proc_config().proc_size()];
+ MBRange& my_remote_mesh = remoteMesh[myPcomm->proc_config().proc_rank()];
tmpset = my_remote_mesh.subtract( nodeSet.range );
if (!tmpset.empty())
my_remote_mesh = my_remote_mesh.subtract( tmpset );
@@ -616,7 +610,7 @@
return MB_FAILURE;
mhdf_closeData( filePtr, handle, &status );
// send id offset to every proc
result = MPI_Bcast( &first_id, 1, MPI_LONG, 0, MPI_COMM_WORLD );
@@ -637,13 +631,13 @@
// send each proc it's offset in the node table
- int offset;
- result = MPI_Scatter( &node_counts[0], 1, MPI_INT,
- &offset, 1, MPI_INT,
+ long offset;
+ result = MPI_Scatter( &node_counts[0], 1, MPI_LONG,
+ &offset, 1, MPI_LONG,
assert(MPI_SUCCESS == result);
nodeSet.offset = offset;
return assign_ids( nodeSet.range, nodeSet.first_id + nodeSet.offset );
@@ -1905,27 +1899,35 @@
MBErrorCode WriteHDF5Parallel::communicate_remote_ids( MBEntityType type )
- int result;
- MBErrorCode rval;
// Get the export set for the specified type
- ExportSet* export_set = 0;
if (type == MBVERTEX)
- export_set = &nodeSet;
+ return communicate_remote_ids( &nodeSet );
else if(type == MBENTITYSET)
- export_set = &setSet;
+ return communicate_remote_ids( &setSet );
else
for (std::list<ExportSet>::iterator esiter = exportList.begin();
esiter != exportList.end(); ++esiter)
if (esiter->type == type)
- export_set = &*esiter;
- break;
+ MBErrorCode rval = communicate_remote_ids( &*esiter );
+ if (MB_SUCCESS != rval)
+ return rval;
+ return MB_SUCCESS;
- assert(export_set != NULL);
+MBErrorCode WriteHDF5Parallel::communicate_remote_ids( ExportSet* export_set )
+ RangeMap<MBEntityHandle,id_t>::iterator ri;
+ std::vector<MBEntityHandle> remote_handles;
+ MBErrorCode rval;
+ int result;
+ const MBEntityType type = export_set->type;
+ assert(export_set != NULL);
// Get the ranges in the set
std::vector<unsigned long> myranges;
MBRange::const_pair_iterator p_iter = export_set->range.const_pair_begin();
@@ -1969,60 +1971,56 @@
// Set file IDs for each communicated entity
// For each processor
- for (unsigned int proc = 0; proc < myPcomm->proc_config().proc_size(); ++proc)
- if (proc == myPcomm->proc_config().proc_rank())
+ for (unsigned int proc = 0; proc < myPcomm->proc_config().proc_size(); ++proc) {
+ if (proc == myPcomm->proc_config().proc_rank() || remoteMesh[proc].empty())
continue;
- // Get data for corresponding processor
- const int offset = offsets[proc];
- const int count = counts[proc];
- const unsigned long* const ranges = &allranges[displs[proc]];
+ // constuct RangeMap to map from handles on remote processor
+ // to file IDs
+ RangeMap<MBEntityHandle,id_t> remote_ids;
+ unsigned long* i = &allranges[displs[proc]];
+ unsigned long* const e = i + counts[proc];
+ unsigned long file_id = offsets[proc];
+ while (i < e) {
+ MBEntityHandle start_handle = (MBEntityHandle)*i; ++i;
+ MBEntityHandle end_handle = (MBEntityHandle)*i; ++i;
+ MBEntityHandle count = end_handle - start_handle + 1;
+ ri = remote_ids.insert( (MBEntityHandle)start_handle, file_id, count );
+ assert( ri != remote_ids.end() );
+ file_id += count;
- // For each geometry meshset in the interface
- MBRange::iterator r_iter = MBRange::lower_bound( remoteMesh[proc].begin(),
- remoteMesh[proc].end(),
- CREATE_HANDLE(type,0,result) );
- MBRange::iterator r_stop = MBRange::lower_bound( r_iter,
- CREATE_HANDLE(type+1,0,result) );
- for ( ; r_iter != r_stop; ++r_iter)
- MBEntityHandle entity = *r_iter;
- // Get handle on other processor
- MBEntityHandle global;
- rval = iFace->tag_get_data( global_id_tag, &entity, 1, &global );
- assert(MB_SUCCESS == rval);
- // Find corresponding fileid on other processor.
- // This could potentially be n**2, but we will assume that
- // the range list from each processor is short (typically 1).
- int j, steps = 0;
- unsigned long low, high;
- for (j = 0; j < count; j += 2)
- low = ranges[j];
- high = ranges[j+1];
- if (low <= global && high >= global)
- break;
- steps += (high - low) + 1;
+ // for entities on other processor that we must reference from this
+ // processor, get the handle on the remote proc and from there
+ // look up the file id in the map constructed above
+ std::pair<MBRange::iterator,MBRange::iterator> iters = remoteMesh[proc].equal_range(type);
+ MBRange subrange, empty;
+ subrange.merge( iters.first, iters.second );
+ remote_handles.resize( subrange.size() );
+ rval = myPcomm->get_remote_handles( true, subrange, &remote_handles[0], proc, empty );
+ if (MB_SUCCESS != rval) {
+ printdebug( "Query for remote handles for type %s on proc %d failed with error code %d\n",
+ MBCN::EntityTypeName(type), (int)proc, (int)rval );
+ return rval;
+ std::vector<MBEntityHandle>::const_iterator rem = remote_handles.begin();
+ MBRange::const_iterator loc = subrange.begin();
+ for( ; rem != remote_handles.end(); ++rem, ++loc) {
+ id_t id = remote_ids.find( *rem );
+ if (!id) {
+ printdebug( "Invalid remote handle (0x%lx, %s) on proc %d.\n",
+ (unsigned long)*rem, MBCN::EntityTypeName(type), (int)proc );
+ return MB_FAILURE;
- if (j >= count) {
- printdebug("*** handle = %u, type = %d, id = %d, proc = %d\n",
- (unsigned)global, (int)(iFace->type_from_handle(global)), (int)(iFace->id_from_handle(global)), proc);
- for (int ii = 0; ii < count; ii+=2)
- printdebug("*** %u to %u\n", (unsigned)ranges[ii], (unsigned)ranges[ii+1] );
- MBRange junk; junk.insert( global );
- print_type_sets( iFace, myPcomm->proc_config().proc_rank(), myPcomm->proc_config().proc_size(), junk );
+ ri = idMap.insert( *loc, id, 1 );
+ if (ri == idMap.end()) {
+ printdebug( "Conflicting file ID (%ul) for remote handle (0x%lx, %s) on proc %d.\n",
+ (unsigned long)id, (unsigned long)*rem, MBCN::EntityTypeName(type), (int)proc );
- assert(j < count);
- int fileid = offset + steps + (global - low);
- RangeMap<MBEntityHandle,id_t>::iterator ri = idMap.insert( entity, fileid, 1 );
- assert( ri != idMap.end() );
- } // for(r_iter->range)
- } // for(each processor)
return MB_SUCCESS;
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.hpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-07-01 06:31:18 UTC (rev 1971)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-07-01 21:31:19 UTC (rev 1972)
@@ -117,6 +117,12 @@
//! entities to be written on this processor.
MBErrorCode communicate_remote_ids(MBEntityType type);
+ //! For entities that will be written by another
+ //! processor, get the file Ids that will be assigned
+ //! to those so they can be referenced by
+ //! entities to be written on this processor.
+ MBErrorCode communicate_remote_ids(ExportSet* ents);
//! Sort the list of tag information in the parent
//! class by name so all procs have them in the same
//! order.
