[MOAB-dev] r1554 - MOAB/trunk
    tautges at mcs.anl.gov
    Tue Jan 22 21:46:03 CST 2008
Author: tautges
Date: 2008-01-22 21:46:03 -0600 (Tue, 22 Jan 2008)
New Revision: 1554
Modified:
   MOAB/trunk/Tqdcfr.cpp
   MOAB/trunk/Tqdcfr.hpp
Log:
Making hasMidNodesTag non-static so it can work on successive calls to the reader.
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp	2008-01-23 02:12:34 UTC (rev 1553)
+++ MOAB/trunk/Tqdcfr.cpp	2008-01-23 03:46:03 UTC (rev 1554)
@@ -150,7 +150,7 @@
 Tqdcfr::Tqdcfr(MBInterface *impl)
     : cubFile(NULL), globalIdTag(0), geomTag(0), uniqueIdTag(0),
       blockTag(0), nsTag(0), ssTag(0), attribVectorTag(0), entityNameTag(0),
-      categoryTag(0)
+      categoryTag(0), hasMidNodesTag(0)
   assert(NULL != impl);
   mdbImpl = impl;
@@ -1001,19 +1001,13 @@
     // compute the offset we get in this batch and compare to any previous one
   long vhandle_offset = vhandle - min_cid;
+  if (-1 == currVHandleOffset) currVHandleOffset = vhandle_offset;
-    // first case: no previous offset; set one
-  if (!cubMOABVertexMap && -1 == currVHandleOffset)
-    currVHandleOffset = vhandle_offset;
-    // second case: this offset same as previous
-  else if (!cubMOABVertexMap && -1 != currVHandleOffset &&
-           currVHandleOffset == vhandle_offset) {
-    assert(true);
-    // third case: this offset different from previous and no
-    // map yet
-  else if (currVHandleOffset != vhandle_offset && !cubMOABVertexMap) {
+    // In 2 situations we'll need to add/modify a cubit_id -> vhandle map:
+    // case A: no map yet, and either this offset different from
+    // previous or not contiguous
+  if (!cubMOABVertexMap &&
+      (currVHandleOffset != vhandle_offset || !contig)) {
       // get all vertices, removing ones in this batch
     MBRange vrange;
     result = mdbImpl->get_entities_by_type(0, MBVERTEX, vrange); RR;
@@ -1029,7 +1023,7 @@
     for (rit = vrange.begin(); rit != vrange.end(); rit++)
       (*cubMOABVertexMap)[*rit - currVHandleOffset] = *rit;
-    // fourth case: there is a map and we need to resize it
+    // case B: there is a map and we need to resize it
   else if (cubMOABVertexMap && max_cid+1 > cubMOABVertexMap->size()) {
       unsigned int old_size = cubMOABVertexMap->size();
       cubMOABVertexMap->resize(max_cid+1);
@@ -1038,10 +1032,30 @@
     // ok, we have a map or don't need one
   if (NULL == cubMOABVertexMap) {
-      // if not contiguous, re-order coordinates for handles so that they are
-    if (!contig) assert(false);
+      // if we're not forward-contiguous (i.e. we're reverse or
+      // out-of-order contiguous), re-order coordinates for handles
+      // so that they are
+    if (-1 == contig || -2 == contig) {
+        // in case the arrays are large, do each coord separately
+      std::vector<double> tmp_coords(entity->nodeCt);
+      for (unsigned int j = 0; j < 3; j++) {
+          // permute the coords into new order
+        for (unsigned int i = 0; i < entity->nodeCt; i++) {
+          assert(uint_buf[i]-min_cid >= 0 &&
+                 max_cid-uint_buf[i] < entity->nodeCt);
+          tmp_coords[uint_buf[i]-min_cid] = arrays[j][i];
+          // copy the permuted to storage
+        std::copy(&tmp_coords[0], &tmp_coords[0]+entity->nodeCt, arrays[j]);
+        // now re-order the ids; either way just go off min, max cid
+        uint_buf[i] = min_cid+i;
+    else if (!contig)
+        // shouldn't get here, since in non-contig case map should be there
+      assert(false);
   else {
       // put new vertices into the map
@@ -1559,17 +1573,16 @@
     if (num_verts != MBCN::VerticesPerEntity(block_headers[i].blockEntityType)) {
         // not a linear element; try to find hasMidNodes values
       int has_mid_nodes[] = {0, 0, 0, 0};
-      static MBTag hasMidNodesTag = 0;
-      if (0 == hasMidNodesTag) {
+      if (0 == instance->hasMidNodesTag) {
         result = instance->mdbImpl->tag_create(HAS_MID_NODES_TAG_NAME, 4*sizeof(int), MB_TAG_SPARSE,
-                                               MB_TYPE_INTEGER, hasMidNodesTag, has_mid_nodes);
+                                               MB_TYPE_INTEGER, instance->hasMidNodesTag, has_mid_nodes);
         if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) return result;
       MBCN::HasMidNodes(block_headers[i].blockEntityType, num_verts, has_mid_nodes);
         // now set the tag on this set
-      result = instance->mdbImpl->tag_set_data(hasMidNodesTag, &block_headers[i].setHandle, 1,
+      result = instance->mdbImpl->tag_set_data(instance->hasMidNodesTag, &block_headers[i].setHandle, 1,
                                                has_mid_nodes);
       if (MB_SUCCESS != result) return result;
Modified: MOAB/trunk/Tqdcfr.hpp
--- MOAB/trunk/Tqdcfr.hpp	2008-01-23 02:12:34 UTC (rev 1553)
+++ MOAB/trunk/Tqdcfr.hpp	2008-01-23 03:46:03 UTC (rev 1554)
@@ -277,7 +277,7 @@
   long currVHandleOffset;
   long currElementIdOffset[MBMAXTYPE];
   MBTag globalIdTag, cubIdTag, geomTag, uniqueIdTag, blockTag, nsTag, ssTag,
-    attribVectorTag, entityNameTag, categoryTag;
+    attribVectorTag, entityNameTag, categoryTag, hasMidNodesTag;
   std::map<int, MBEntityHandle> uidSetMap;
   std::map<int, MBEntityHandle> gidSetMap[6];
