[MOAB-dev] r1555 - MOAB/trunk
tautges at mcs.anl.gov
Tue Jan 22 22:58:24 CST 2008
Author: tautges
Date: 2008-01-22 22:58:24 -0600 (Tue, 22 Jan 2008)
New Revision: 1555
Modified:
MOAB/trunk/Tqdcfr.cpp
Log:
Yet another tweak to handle non-contiguous ids properly on 64-bit machines.
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2008-01-23 03:46:03 UTC (rev 1554)
+++ MOAB/trunk/Tqdcfr.cpp 2008-01-23 04:58:24 UTC (rev 1555)
@@ -1015,13 +1015,19 @@
// compute the max cid; map is indexed by cid, so size is max_cid+1
#define MAX(a,b) (a > b ? a : b)
#define MIN(a,b) (a < b ? a : b)
- max_cid = MAX(max_cid, ((unsigned int) *vrange.rbegin()-currVHandleOffset));
+ // sanity check that max vhandle is larger than offset
+ long new_max = *vrange.rbegin()-currVHandleOffset;
+ assert(new_max >= 0 && *vrange.begin() - currVHandleOffset >= 0);
+ max_cid = MAX(max_cid, ((unsigned int) new_max));
cubMOABVertexMap = new std::vector<MBEntityHandle>(max_cid+1);
// initialize to zero then put previous vertices into the map
std::fill(cubMOABVertexMap->begin(), cubMOABVertexMap->end(), 0);
MBRange::iterator rit;
- for (rit = vrange.begin(); rit != vrange.end(); rit++)
+ for (rit = vrange.begin(); rit != vrange.end(); rit++) {
+ assert(*rit-currVHandleOffset >= 0 &&
+ *rit-currVHandleOffset <= max_cid);
(*cubMOABVertexMap)[*rit - currVHandleOffset] = *rit;
// case B: there is a map and we need to resize it
else if (cubMOABVertexMap && max_cid+1 > cubMOABVertexMap->size()) {
@@ -2132,7 +2138,7 @@
MBErrorCode Tqdcfr::reset_record(AcisRecord &this_record)
this_record.rec_type = Tqdcfr::UNKNOWN;
- static std::string blank;
+ static const std::string blank;
this_record.att_string = blank;
this_record.first_attrib = this_record.att_prev =
this_record.att_next = this_record.att_ent_num = -1;
