[MOAB-dev] r1553 - MOAB/trunk
tautges at mcs.anl.gov
Tue Jan 22 20:12:34 CST 2008
Author: tautges
Date: 2008-01-22 20:12:34 -0600 (Tue, 22 Jan 2008)
New Revision: 1553
Modified:
MOAB/trunk/Tqdcfr.cpp
MOAB/trunk/Tqdcfr.hpp
Log:
Re-did (yet again) parsing of ids on import. Passes many tests on 32- and 64-bit, but not the large abtr problem on 64bit (but does on 32bit).
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2008-01-22 20:44:12 UTC (rev 1552)
+++ MOAB/trunk/Tqdcfr.cpp 2008-01-23 02:12:34 UTC (rev 1553)
@@ -23,6 +23,10 @@
#include "MBInternals.hpp"
#include "FileOptions.hpp"
+#ifdef USE_MPI
+#include "mpi.h"
+#endif
#include <iostream>
#include <assert.h>
@@ -35,13 +39,20 @@
MBENTITYSET, MBENTITYSET, MBENTITYSET, // surface, curve, vertex
MBHEX, MBTET, MBPYRAMID, MBQUAD, MBTRI, MBEDGE, MBVERTEX};
const MBEntityType Tqdcfr::block_type_to_mb_type[] = {
- MBVERTEX,
- MBEDGE, MBEDGE, MBEDGE, MBEDGE, MBEDGE, MBEDGE, MBEDGE, MBEDGE, MBEDGE, MBEDGE,
- MBTRI, MBTRI, MBTRI, MBTRI, MBTRI, MBTRI, MBTRI, MBTRI,
- MBQUAD, MBQUAD, MBQUAD, MBQUAD, MBQUAD,
- MBTET, MBTET, MBTET, MBTET, MBTET,
- MBPYRAMID, MBPYRAMID, MBPYRAMID, MBPYRAMID, MBPYRAMID,
- MBHEX, MBHEX, MBHEX, MBHEX, MBHEX, MBHEX, MBMAXTYPE
+ MBVERTEX, // sphere
+ MBEDGE, MBEDGE, MBEDGE, // bars
+ MBEDGE, MBEDGE, MBEDGE, // beams
+ MBEDGE, MBEDGE, MBEDGE, // truss
+ MBEDGE, // spring
+ MBTRI, MBTRI, MBTRI, MBTRI, // tri
+ MBTRI, MBTRI, MBTRI, MBTRI, // trishell
+ MBQUAD, MBQUAD, MBQUAD, MBQUAD, // shell
+ MBQUAD, MBQUAD, MBQUAD, MBQUAD, MBQUAD, // quad
+ MBTET, MBTET, MBTET, MBTET, MBTET, // tet
+ MBPYRAMID, MBPYRAMID, MBPYRAMID, MBPYRAMID, MBPYRAMID, // pyramid
+ MBHEX, MBHEX, MBHEX, MBHEX, MBHEX, // hex
+ MBHEX, // hexshell
+ MBMAXTYPE // last
// mapping from mesh packet type to moab type
@@ -95,8 +106,11 @@
void Tqdcfr::FREADI( unsigned num_ents ) {
- int_buf.resize( num_ents );
- FREADIA( num_ents, &int_buf[0] );
+ if (uint_buf.size() < num_ents) {
+ uint_buf.resize( num_ents );
+ int_buf = (int*)&uint_buf[0];
+ FREADIA( num_ents, &uint_buf[0] );
void Tqdcfr::FREADD( unsigned num_ents ) {
@@ -124,6 +138,12 @@
IO_ASSERT( rval == num_ents );
+void Tqdcfr::CONVERT_TO_INTS(unsigned int num_ents)
+ for (unsigned int i = 0; i < num_ents; i++)
+ int_buf[i] = uint_buf[i];
MBReaderIface* Tqdcfr::factory( MBInterface* iface )
{ return new Tqdcfr( iface ); }
@@ -138,7 +158,7 @@
impl->query_interface(iface_name, reinterpret_cast<void**>(&readUtilIface));
assert(NULL != readUtilIface);
- currNodeIdOffset = -1;
+ currVHandleOffset = -1;
for (MBEntityType this_type = MBVERTEX; this_type < MBMAXTYPE; this_type++)
currElementIdOffset[this_type] = -1;
@@ -169,25 +189,35 @@
// open file
cubFile = fopen(file_name, "rb");
- if (NULL == cubFile) return MB_FAILURE;
+ if (NULL == cubFile) {
+ readUtilIface->report_error("File not found.");
+ return MB_FAILURE;
// verify magic string
FREADC(4);
if (!(char_buf[0] == 'C' && char_buf[1] == 'U' &&
- char_buf[2] == 'B' && char_buf[3] == 'E'))
+ char_buf[2] == 'B' && char_buf[3] == 'E')) {
+ readUtilIface->report_error("This doesn't appear to be a .cub file.");
return MB_FAILURE;
// create meshset to contain file
result = mdbImpl->create_meshset( MESHSET_SET, file_set );
- if (MB_SUCCESS != result)
+ if (MB_SUCCESS != result) {
+ readUtilIface->report_error("Problems creating mesh set for file contents.");
return result;
mFileSet = file_set;
// get "before" entities
MBRange before_ents;
result = mdbImpl->get_entities_by_handle(0, before_ents);
+ readUtilIface->report_error("Couldn't get \"before\" entities.");
return result;
// read model header type information...
@@ -216,8 +246,12 @@
// first the header & metadata info
if (debug) std::cout << "Reading mesh model header and metadata." << std::endl;
- result = mesh_model->read_header_info(this, data_version); RR;
- result = mesh_model->read_metadata_info(this); RR;
+ result = mesh_model->read_header_info(this, data_version);
+ return result;
+ result = mesh_model->read_metadata_info(this);
+ return result;
// now read in mesh for each geometry entity
for (unsigned int gindex = 0;
@@ -227,11 +261,15 @@
// read nodes
if (debug) std::cout << "Reading geom index " << gindex << " mesh: nodes... ";
- result = read_nodes(gindex, mesh_model, geom_header); RR;
+ result = read_nodes(gindex, mesh_model, geom_header);
+ return result;
// read elements
if (debug) std::cout << "elements... ";
- result = read_elements(mesh_model, geom_header); RR;
+ result = read_elements(mesh_model, geom_header);
+ return result;
if (debug) std::cout << std::endl;
@@ -251,7 +289,9 @@
grindex < mesh_model->feModelHeader.groupArray.numEntities;
grindex++) {
GroupHeader *group_header = &mesh_model->feGroupH[grindex];
- result = read_group(grindex, mesh_model, group_header); RR;
+ result = read_group(grindex, mesh_model, group_header);
+ return result;
if (debug) std::cout << mesh_model->feModelHeader.groupArray.numEntities
<< " read successfully." << std::endl;;
@@ -264,7 +304,9 @@
blindex < mesh_model->feModelHeader.blockArray.numEntities;
blindex++) {
BlockHeader *block_header = &mesh_model->feBlockH[blindex];
- result = read_block(data_version, mesh_model, block_header); RR;
+ result = read_block(data_version, mesh_model, block_header);
+ return result;
if (debug) std::cout << mesh_model->feModelHeader.blockArray.numEntities
@@ -278,7 +320,9 @@
nsindex < mesh_model->feModelHeader.nodesetArray.numEntities;
nsindex++) {
NodesetHeader *nodeset_header = &mesh_model->feNodeSetH[nsindex];
- result = read_nodeset(mesh_model, nodeset_header); RR;
+ result = read_nodeset(mesh_model, nodeset_header);
+ return result;
if (debug) std::cout << mesh_model->feModelHeader.nodesetArray.numEntities
@@ -291,7 +335,9 @@
ssindex < mesh_model->feModelHeader.sidesetArray.numEntities;
ssindex++) {
SidesetHeader *sideset_header = &mesh_model->feSideSetH[ssindex];
- result = read_sideset(data_version, mesh_model, sideset_header); RR;
+ result = read_sideset(data_version, mesh_model, sideset_header);
+ return result;
if (debug) std::cout << mesh_model->feModelHeader.sidesetArray.numEntities
@@ -318,7 +364,7 @@
after_ents = after_ents.subtract(before_ents);
result = mdbImpl->add_entities(mFileSet, after_ents);
return result;
@@ -422,16 +468,17 @@
FSEEK(model->modelOffset+nodeseth->memOffset);
// read ids for each entity type
- int this_type, num_ents;
+ unsigned int this_type, num_ents;
std::vector<MBEntityHandle> ns_entities, excl_entities;
for (unsigned int i = 0; i < nodeseth->memTypeCt; i++) {
// get how many and what type
FREADI(2);
- this_type = int_buf[0];
- num_ents = int_buf[1];
+ this_type = uint_buf[0];
+ num_ents = uint_buf[1];
// now get the ids
FREADI(num_ents);
+ CONVERT_TO_INTS(num_ents);
MBErrorCode result = get_entities(this_type+2, &int_buf[0], num_ents,
ns_entities, excl_entities);
@@ -463,12 +510,13 @@
for (unsigned int i = 0; i < sideseth->memTypeCt; i++) {
FREADI(3);
- sense_size = int_buf[2];
+ sense_size = uint_buf[2];
// now get the ids
FREADI(num_ents);
ss_entities, excl_entities);
@@ -495,13 +543,18 @@
FREADI(1);
- num_ents = int_buf[0];
+ num_ents = uint_buf[0];
// get the types, and ids
std::vector<unsigned int> mem_types(num_ents), mem_ids(num_ents);
FREADIA(num_ents, &mem_types[0]);
- FREADIA(num_ents, &mem_ids[0]);
+ FREADI(num_ents);
+ std::vector<MBEntityHandle> ss_entities;
+ MBErrorCode result = get_entities(&mem_types[0], &int_buf[0], num_ents, false,
+ ss_entities);
+ if (MB_SUCCESS != result) return result;
// byte-size sense flags; make sure read ends aligned...
unsigned int read_length = (num_ents / 8) * 8;
if (read_length < num_ents) read_length += 8;
@@ -509,17 +562,11 @@
// wrt entities
FREADI(1);
- int num_wrts = int_buf[0];
- std::vector<unsigned int> wrt_ents(num_wrts);
- FREADIA(num_wrts, &wrt_ents[0]);
+ int num_wrts = uint_buf[0];
+ FREADI(num_wrts);
- std::vector<MBEntityHandle> ss_entities;
- MBErrorCode result = get_entities(&mem_types[0], &mem_ids[0], num_ents, false,
- ss_entities);
+ result = process_sideset_11(ss_entities, num_wrts, sideseth);
- result = process_sideset_11(ss_entities, wrt_ents, sideseth);
- if (MB_SUCCESS != result) return result;
@@ -565,9 +612,9 @@
&& sense_size == 2 // int32 size
for (int i = 0; i < num_ents; i++) {
- if (int_buf[i] == 0) forward.push_back(ss_entities[i]);
- else if (int_buf[i] == 1) reverse.push_back(ss_entities[i]);
- if (*((int*)&int_buf[i]) == -1) { // -1 means "unknown", which means both
+ if (uint_buf[i] == 0) forward.push_back(ss_entities[i]);
+ else if (uint_buf[i] == 1) reverse.push_back(ss_entities[i]);
+ if (*((int*)&uint_buf[i]) == -1) { // -1 means "unknown", which means both
@@ -603,20 +650,19 @@
MBErrorCode Tqdcfr::process_sideset_11(std::vector<MBEntityHandle> &ss_entities,
- std::vector<unsigned int> &wrt_ents,
+ int num_wrts,
Tqdcfr::SidesetHeader *sideseth)
std::vector<MBEntityHandle> forward, reverse;
unsigned int num_ents = ss_entities.size();
- std::vector<unsigned int>::iterator wrt_it = wrt_ents.begin();
+ unsigned int *wrt_it = &uint_buf[0];
for (unsigned int i = 0; i < num_ents; i++) {
unsigned int num_wrt = 0;
- if (!wrt_ents.empty()) num_wrt = *wrt_it++;
+ if (0 != num_wrts) num_wrt = *wrt_it++;
for (unsigned int j = 0; j < num_wrt; j++) wrt_it += 2;
- forward.push_back(ss_entities[i]);
// assume here that if it's in the list twice, we get both senses
if (num_wrt > 1) {
@@ -676,11 +722,12 @@
for (unsigned int i = 0; i < blockh->memTypeCt; i++) {
FREADI(2);
// now get the ids
FREADI(num_ents);
block_entities, excl_entities);
@@ -722,11 +769,12 @@
for (unsigned int i = 0; i < grouph->memTypeCt; i++) {
FREADI(2);
// now get the ids
FREADI(num_ents);
// get the entities in this group
MBErrorCode result = get_entities(this_type, &int_buf[0], num_ents, grp_entities, excl_entities);
@@ -808,7 +856,7 @@
MBErrorCode Tqdcfr::get_entities(const unsigned int *mem_types,
- unsigned int *id_buf, const unsigned int id_buf_size,
+ int *id_buf, const unsigned int id_buf_size,
const bool is_group,
std::vector<MBEntityHandle> &entities)
@@ -827,7 +875,7 @@
MBErrorCode Tqdcfr::get_entities(const unsigned int this_type,
std::vector<MBEntityHandle> &entities,
std::vector<MBEntityHandle> &excl_entities)
@@ -842,7 +890,7 @@
MBErrorCode Tqdcfr::get_ref_entities(const unsigned int this_type,
for (unsigned int i = 0; i < id_buf_size; i++)
@@ -852,7 +900,7 @@
MBErrorCode Tqdcfr::get_mesh_entities(const unsigned int this_type,
@@ -873,12 +921,12 @@
// use either vertex offset or cubMOABVertexMap
if (NULL == cubMOABVertexMap) {
- ent_list->push_back(int_buf[i]+currNodeIdOffset);
+ ent_list->push_back((MBEntityHandle)(id_buf[i]+currVHandleOffset));
else {
for (unsigned int i = 0; i < id_buf_size; i++) {
- assert(0 != (*cubMOABVertexMap)[int_buf[i]]);
- ent_list->push_back((*cubMOABVertexMap)[int_buf[i]]);
+ assert(0 != (*cubMOABVertexMap)[id_buf[i]]);
+ ent_list->push_back((*cubMOABVertexMap)[id_buf[i]]);
@@ -894,7 +942,8 @@
// now go through id list, finding each entity by id
- std::vector<int>::iterator vit = std::find(cub_ids.begin(), cub_ids.end(), id_buf[i]);
+ std::vector<int>::iterator vit =
+ std::find(cub_ids.begin(), cub_ids.end(), id_buf[i]);
if (vit != cub_ids.end()) {
MBEntityHandle this_ent = tmp_ents[vit-cub_ids.begin()];
if (mdbImpl->type_from_handle(this_ent) != MBMAXTYPE) ent_list->push_back(this_ent);
@@ -921,16 +970,16 @@
// get the ids & coords in separate calls to minimize memory usage
// position the file
FSEEK(model->modelOffset+entity->nodeOffset);
- // get node ids in int_buf
+ // get node ids in uint_buf
FREADI(entity->nodeCt);
// get a space for reading nodal data directly into MB, and read that data
- MBEntityHandle node_handle = 0;
+ MBEntityHandle vhandle = 0;
std::vector<double*> arrays;
readUtilIface->get_node_arrays(3, entity->nodeCt,
- int_buf[0],
+ uint_buf[0],
readUtilIface->parallel_rank(),
- node_handle, arrays);
+ vhandle, arrays);
// get node x's in arrays[0]
FREADDA(entity->nodeCt, arrays[0]);
// get node y's in arrays[1]
@@ -939,69 +988,77 @@
FREADDA(entity->nodeCt, arrays[2]);
// add these nodes into the entity's set
- MBRange dum_range(node_handle,
- node_handle+entity->nodeCt-1);
+ MBRange dum_range(vhandle,
+ vhandle+entity->nodeCt-1);
MBErrorCode result = mdbImpl->add_entities(entity->setHandle, dum_range);
- // set global ids on nodes
- result = mdbImpl->tag_set_data(globalIdTag, dum_range, &int_buf[0]);
+ // check for id contiguity; know that cid's will never be > 32bit, so
+ // ids can be unsigned int
+ unsigned int max_cid, min_cid;
+ int contig;
+ check_contiguous(entity->nodeCt, contig, min_cid, max_cid);
- // check for id contiguity; long because we subtract 1st index later, which
- // might make this offset negative
- long node_offset = mdbImpl->id_from_handle( node_handle);
+ // compute the offset we get in this batch and compare to any previous one
+ long vhandle_offset = vhandle - min_cid;
- long max_id = -1;
- long contig;
- check_contiguous(entity->nodeCt, contig, max_id);
- if (NULL == cubMOABVertexMap) {
- // haven't needed one yet, see if we need to keep a map to orig cub ids
- // contiguous - offset is start handle minus 1st node index
- if (contig == 1) node_offset -= int_buf[0];
- // reverse contiguous - offset is start handle minus last node index
- else if (contig == -1) node_offset -= int_buf[entity->nodeCt-1];
+ // first case: no previous offset; set one
+ if (!cubMOABVertexMap && -1 == currVHandleOffset)
+ currVHandleOffset = vhandle_offset;
- if (contig && -1 == currNodeIdOffset)
- currNodeIdOffset = node_offset;
- else if ((contig && currNodeIdOffset != node_offset) ||
- !contig) {
- // node offsets no longer valid - need to build cub id - vertex handle map
- MBRange vrange;
- result = mdbImpl->get_entities_by_type(0, MBVERTEX, vrange); RR;
+ // second case: this offset same as previous
+ else if (!cubMOABVertexMap && -1 != currVHandleOffset &&
+ currVHandleOffset == vhandle_offset) {
+ assert(true);
+ // third case: this offset different from previous and no
+ // map yet
+ else if (currVHandleOffset != vhandle_offset && !cubMOABVertexMap) {
+ // get all vertices, removing ones in this batch
+ MBRange vrange;
+ result = mdbImpl->get_entities_by_type(0, MBVERTEX, vrange); RR;
+ vrange = vrange.subtract(dum_range);
+ // compute the max cid; map is indexed by cid, so size is max_cid+1
#define MAX(a,b) (a > b ? a : b)
- int map_size = MAX((node_offset+entity->nodeCt), (*vrange.rbegin()+1));
- cubMOABVertexMap = new std::vector<MBEntityHandle>(map_size);
- std::fill(cubMOABVertexMap->begin(), cubMOABVertexMap->end(), 0);
- // now fill the missing values for vertices which already exist
- for (MBRange::iterator rit = vrange.begin(); rit != vrange.end(); rit++)
- (*cubMOABVertexMap)[*rit] = *rit;
+#define MIN(a,b) (a < b ? a : b)
+ max_cid = MAX(max_cid, ((unsigned int) *vrange.rbegin()-currVHandleOffset));
+ cubMOABVertexMap = new std::vector<MBEntityHandle>(max_cid+1);
+ // initialize to zero then put previous vertices into the map
+ std::fill(cubMOABVertexMap->begin(), cubMOABVertexMap->end(), 0);
+ MBRange::iterator rit;
+ for (rit = vrange.begin(); rit != vrange.end(); rit++)
+ (*cubMOABVertexMap)[*rit - currVHandleOffset] = *rit;
- if (NULL != cubMOABVertexMap) {
- // expand the size if necessary
- if (max_id > (int) cubMOABVertexMap->size()-1) {
+ // fourth case: there is a map and we need to resize it
+ else if (cubMOABVertexMap && max_cid+1 > cubMOABVertexMap->size()) {
unsigned int old_size = cubMOABVertexMap->size();
- cubMOABVertexMap->resize(max_id+1);
- std::fill(&(*cubMOABVertexMap)[old_size], &(*cubMOABVertexMap)[0]+cubMOABVertexMap->size(), 0);
+ cubMOABVertexMap->resize(max_cid+1);
+ std::fill(&(*cubMOABVertexMap)[old_size],
+ &(*cubMOABVertexMap)[0]+cubMOABVertexMap->size(), 0);
+ // ok, we have a map or don't need one
+ if (NULL == cubMOABVertexMap) {
+ // if not contiguous, re-order coordinates for handles so that they are
+ if (!contig) assert(false);
+ else {
+ // put new vertices into the map
// now set the new values
- std::vector<unsigned int>::iterator vit;
- MBRange::iterator rit;
- for (vit = int_buf.begin(), rit = dum_range.begin(); rit != dum_range.end(); vit++, rit++) {
- assert(0 < *vit && *vit < cubMOABVertexMap->size());
+ unsigned int *vit = &uint_buf[0];
+ MBRange::iterator rit = dum_range.begin();
+ for (; rit != dum_range.end(); vit++, rit++) {
+ assert(*vit < cubMOABVertexMap->size());
(*cubMOABVertexMap)[*vit] = *rit;
- if (debug)
- std::cout << "(currOffset=" << currNodeIdOffset << ",nodeh=" << node_handle
- << ",nodect=" << entity->nodeCt << ") ";
+ // no longer need to use uint_buf; convert in-place to ints, so we
+ // can assign gid tag
+ CONVERT_TO_INTS(entity->nodeCt);
+ result = mdbImpl->tag_set_data(globalIdTag, dum_range, &int_buf[0]);
// set the dimension to at least zero (entity has at least nodes) on the geom tag
int max_dim = 0;
@@ -1012,8 +1069,6 @@
&geom_categories[0]);
- // don't need cub ids for vertices because of cubMOABVertexMap
// get fixed node data and assign
int md_index = model->nodeMD.get_md_entry(gindex, "FixedNodes");
if (-1 == md_index) return MB_SUCCESS;
@@ -1022,34 +1077,23 @@
std::vector<int> fixed_flags(entity->nodeCt);
std::fill(fixed_flags.begin(), fixed_flags.end(), 0);
if (md_entry->mdDataType != 3) return MB_FAILURE;
- // if contiguous, we can use the node id as an offset
- if (1 == contig) {
- for (std::vector<unsigned int>::iterator vit = md_entry->mdIntArrayValue.begin();
- vit != md_entry->mdIntArrayValue.end(); vit++) {
- if (*vit - int_buf[0] < entity->nodeCt) return MB_FAILURE;
- fixed_flags[*vit - int_buf[0]] = 1;
+ for (std::vector<unsigned int>::iterator vit = md_entry->mdIntArrayValue.begin();
+ vit != md_entry->mdIntArrayValue.end(); vit++) {
+ MBEntityHandle fixed_v = (cubMOABVertexMap ?
+ (*cubMOABVertexMap)[*vit] :
+ (MBEntityHandle) currVHandleOffset+*vit);
+ assert(fixed_v >= *dum_range.begin() && fixed_v <= *dum_range.rbegin());
+ fixed_flags[*vit - *dum_range.begin()] = 1;
- // else we have to find the position of each node in the node ids, then set the
- // equivalent position in the fixed flags
- else {
- unsigned int *buf_end = &int_buf[0]+entity->nodeCt;
- unsigned int *vit2 = std::find(&int_buf[0], buf_end, *vit);
- if (vit2 != buf_end) fixed_flags[vit2 - &int_buf[0]] = 1;
- static MBTag fixedFlagTag = 0;
- if (0 == fixedFlagTag) {
- result = mdbImpl->tag_get_handle("NodeFixed", fixedFlagTag);
- if (MB_SUCCESS != result || 0 == fixedFlagTag) {
- int dum_val = 0;
- result = mdbImpl->tag_create("NodeFixed", sizeof(int), MB_TAG_SPARSE,
- MB_TYPE_INTEGER, fixedFlagTag, &dum_val);
+ MBTag fixedFlagTag;
+ result = mdbImpl->tag_get_handle("NodeFixed", fixedFlagTag);
+ if (MB_SUCCESS != result || 0 == fixedFlagTag) {
+ int dum_val = 0;
+ result = mdbImpl->tag_create("NodeFixed", sizeof(int), MB_TAG_SPARSE,
+ MB_TYPE_INTEGER, fixedFlagTag, &dum_val);
result = mdbImpl->tag_set_data(fixedFlagTag, dum_range, &fixed_flags[0]);
@@ -1071,9 +1115,9 @@
for (unsigned int i = 0; i < entity->elemTypeCt; i++) {
// for this elem type, get the type, nodes per elem, num elems
FREADI(3);
- int_type = int_buf[0];
- nodes_per_elem = int_buf[1];
- num_elem = int_buf[2];
+ int_type = uint_buf[0];
+ nodes_per_elem = uint_buf[1];
+ num_elem = uint_buf[2];
// get MB element type from cub file's
MBEntityType elem_type = mp_type_to_mb_type[int_type];
@@ -1083,8 +1127,9 @@
FREADI(num_elem);
// check to see if ids are contiguous...
- long contig, max_id;
- check_contiguous(num_elem, contig, max_id);
+ int contig;
+ unsigned int max_id, min_id;
+ check_contiguous(num_elem, contig, min_id, max_id);
if (0 == contig)
std::cout << "Element ids are not contiguous!" << std::endl;
@@ -1095,37 +1140,36 @@
elem_type, int_buf[0],
start_handle, conn);
+ MBRange dum_range(start_handle, start_handle+num_elem-1);
long elem_offset;
- elem_offset = mdbImpl->id_from_handle( start_handle) - int_buf[0];
+ elem_offset = start_handle - int_buf[0];
if (-1 == currElementIdOffset[elem_type])
currElementIdOffset[elem_type] = elem_offset;
- // now do something with them...
- // get the connectivity array; be careful, the connectivity is stored
- // in the file as ints, while the connect array is handles, which may
- // be long; this will lead to problems on 64-bit machines
+ // set the gids on elements
+ CONVERT_TO_INTS(num_elem);
+ // get the connectivity array
unsigned int total_conn = num_elem * nodes_per_elem;
- unsigned int *tmp_conn = reinterpret_cast<unsigned int*>(conn);
- if (sizeof(MBEntityHandle) != sizeof(unsigned int))
- tmp_conn = new unsigned int[total_conn];
- FREADIA(total_conn, tmp_conn);
+ FREADI(total_conn);
// post-process connectivity into handles
MBEntityHandle new_handle, dum_handle;
- int dum_err;
for (unsigned int j = 0; j < total_conn; j++) {
- new_handle = CREATE_HANDLE(MBVERTEX, currNodeIdOffset+tmp_conn[j], dum_err);
+ new_handle = (MBEntityHandle) currVHandleOffset+uint_buf[j];
else {
if (debug) {
if (0 == i) std::cout << "Conn";
- std::cout << ", " << tmp_conn[j];
+ std::cout << ", " << uint_buf[j];
- assert(0 != (*cubMOABVertexMap)[tmp_conn[j]]);
- new_handle = (*cubMOABVertexMap)[tmp_conn[j]];
+ assert(uint_buf[j] < cubMOABVertexMap->size() &&
+ 0 != (*cubMOABVertexMap)[uint_buf[j]]);
+ new_handle = (*cubMOABVertexMap)[uint_buf[j]];
assert(MB_SUCCESS ==
mdbImpl->handle_from_id(MBVERTEX, mdbImpl->id_from_handle(new_handle),
@@ -1133,17 +1177,10 @@
conn[j] = new_handle;
- if (sizeof(MBEntityHandle) != sizeof(int))
- delete [] tmp_conn;
// add these elements into the entity's set
- MBRange dum_range(start_handle, start_handle+num_elem-1);
- // set global ids
// set the dimension on the geom tag
@@ -1158,59 +1195,45 @@
return MB_SUCCESS;
-void Tqdcfr::check_contiguous(const unsigned int num_ents, long &contig, long &max_id)
+void Tqdcfr::check_contiguous(const unsigned int num_ents, int &contig,
+ unsigned int &min_id, unsigned int &max_id)
- std::vector<unsigned int>::iterator id_it;
- unsigned int curr_id, i;
- max_id = -1;
+ unsigned int *id_it, curr_id, i;
+ max_id = min_id = 0;
// check in forward-contiguous direction
- id_it = int_buf.begin();
+ id_it = &uint_buf[0];
curr_id = *id_it++ + 1;
- for (i = 1; id_it != int_buf.end() && i < num_ents; id_it++, i++) {
+ contig = 1;
+ min_id = uint_buf[0];
+ max_id = uint_buf[0];
+ for (i = 1; i < num_ents; id_it++, i++, curr_id++) {
if (*id_it != curr_id) {
- i = 0;
- break;
+ contig = 0;
- curr_id++;
+ min_id = MIN(min_id, uint_buf[i]);
+ max_id = MAX(max_id, uint_buf[i]);
// if we got here and we're at the end of the loop, it's forward-contiguous
- if (i == num_ents) {
- max_id = int_buf[i-1];
- contig = 1;
- return;
+ if (1 == contig) return;
// check in reverse-contiguous direction
+ contig = -1;
curr_id = *id_it++ - 1;
+ for (i = 1; i < num_ents; id_it++, i++, curr_id--) {
- i = 0;
+ contig = 0;
break;
- curr_id--;
// if we got here and we're at the end of the loop, it's reverse-contiguous
- max_id = int_buf[0];
- contig = -1;
- return;
+ if (-1 == contig) return;
// one final check, for contiguous but out of order
- int min_id = -1;
- max_id = -1;
- // need to loop over i, b/c int_buf is bigger than num_ents
- for (id_it = int_buf.begin(), i = 0; i < num_ents; id_it++, i++) {
- if (((int)(*id_it)) < min_id || -1 == min_id) min_id = *id_it;
- if (((int) *id_it) > max_id || -1 == max_id) max_id = *id_it;
- if (max_id - min_id + 1 == (int) num_ents) contig = min_id;
+ if (max_id - min_id + 1 == num_ents) contig = -2;
// else it's not contiguous at all
contig = 0;
@@ -1220,18 +1243,18 @@
instance->FSEEK(offset);
instance->FREADI(4);
- feEndian = instance->int_buf[0];
- feSchema = instance->int_buf[1];
- feCompressFlag = instance->int_buf[2];
- feLength = instance->int_buf[3];
- instance->FREADI(3); geomArray.init(instance->int_buf);
+ feEndian = instance->uint_buf[0];
+ feSchema = instance->uint_buf[1];
+ feCompressFlag = instance->uint_buf[2];
+ feLength = instance->uint_buf[3];
+ instance->FREADI(3); geomArray.init(instance->uint_buf);
instance->FREADI(2);
- nodeArray.metaDataOffset = instance->int_buf[0];
- elementArray.metaDataOffset = instance->int_buf[1];
- instance->FREADI(3); groupArray.init(instance->int_buf);
- instance->FREADI(3); blockArray.init(instance->int_buf);
- instance->FREADI(3); nodesetArray.init(instance->int_buf);
- instance->FREADI(3); sidesetArray.init(instance->int_buf);
+ nodeArray.metaDataOffset = instance->uint_buf[0];
+ elementArray.metaDataOffset = instance->uint_buf[1];
+ instance->FREADI(3); groupArray.init(instance->uint_buf);
+ instance->FREADI(3); blockArray.init(instance->uint_buf);
+ instance->FREADI(3); nodesetArray.init(instance->uint_buf);
+ instance->FREADI(3); sidesetArray.init(instance->uint_buf);
instance->FREADI(1);
@@ -1240,12 +1263,12 @@
// read file header
FSEEK(4);
FREADI(6);
- fileTOC.fileEndian = int_buf[0];
- fileTOC.fileSchema = int_buf[1];
- fileTOC.numModels = int_buf[2];
- fileTOC.modelTableOffset = int_buf[3];
- fileTOC.modelMetaDataOffset = int_buf[4];
- fileTOC.activeFEModel = int_buf[5];
+ fileTOC.fileEndian = uint_buf[0];
+ fileTOC.fileSchema = uint_buf[1];
+ fileTOC.numModels = uint_buf[2];
+ fileTOC.modelTableOffset = uint_buf[3];
+ fileTOC.modelMetaDataOffset = uint_buf[4];
+ fileTOC.activeFEModel = uint_buf[5];
if (debug) fileTOC.print();
return MB_SUCCESS;
@@ -1259,7 +1282,7 @@
FREADI(fileTOC.numModels*6);
modelEntries = new ModelEntry[fileTOC.numModels];
if (NULL == modelEntries) return MB_FAILURE;
- std::vector<unsigned int>::iterator int_it = int_buf.begin();
+ std::vector<unsigned int>::iterator int_it = uint_buf.begin();
for (unsigned int i = 0; i < fileTOC.numModels; i++) {
modelEntries[i].modelHandle = *int_it++;
modelEntries[i].modelOffset = *int_it++;
@@ -1267,7 +1290,7 @@
modelEntries[i].modelType = *int_it++;
modelEntries[i].modelOwner = *int_it++;
modelEntries[i].modelPad = *int_it++;
- if (int_it == int_buf.end() && i != fileTOC.numModels-1) return MB_FAILURE;
+ if (int_it == uint_buf.end() && i != fileTOC.numModels-1) return MB_FAILURE;
if (debug) modelEntries[i].print();
@@ -1288,9 +1311,9 @@
// read the metadata header
FSEEK(metadata_offset);
FREADI(3);
- mc.mdSchema = int_buf[0];
- mc.compressFlag = int_buf[1];
- mc.numDatums = int_buf[2];
+ mc.mdSchema = uint_buf[0];
+ mc.compressFlag = uint_buf[1];
+ mc.numDatums = uint_buf[2];
// allocate space for the entries
mc.metadataEntries =
@@ -1299,8 +1322,8 @@
// now read the metadata values
for (unsigned int i = 0; i < mc.numDatums; i++) {
FREADI(2);
- mc.metadataEntries[i].mdOwner = int_buf[0];
- mc.metadataEntries[i].mdDataType = int_buf[1];
+ mc.metadataEntries[i].mdOwner = uint_buf[0];
+ mc.metadataEntries[i].mdDataType = uint_buf[1];
// read the name string
read_md_string(mc.metadataEntries[i].mdName);
@@ -1308,7 +1331,7 @@
if (mc.metadataEntries[i].mdDataType == 0) {
// integer
FREADI(1);
- mc.metadataEntries[i].mdIntValue = int_buf[0];
+ mc.metadataEntries[i].mdIntValue = uint_buf[0];
else if (mc.metadataEntries[i].mdDataType == 1) {
// string
@@ -1322,16 +1345,16 @@
else if (mc.metadataEntries[i].mdDataType == 3) {
// int array
FREADI(1);
- mc.metadataEntries[i].mdIntArrayValue.resize(int_buf[0]);
+ mc.metadataEntries[i].mdIntArrayValue.resize(uint_buf[0]);
FREADI(mc.metadataEntries[i].mdIntArrayValue.size());
- std::copy(int_buf.begin(),
- int_buf.begin() + mc.metadataEntries[i].mdIntArrayValue.size(),
+ std::copy(uint_buf.begin(),
+ uint_buf.begin() + mc.metadataEntries[i].mdIntArrayValue.size(),
mc.metadataEntries[i].mdIntArrayValue.begin());
else if (mc.metadataEntries[i].mdDataType == 4) {
// double array
FREADI(1);
- mc.metadataEntries[i].mdDblArrayValue.resize(int_buf[0]);
+ mc.metadataEntries[i].mdDblArrayValue.resize(uint_buf[0]);
FREADD(mc.metadataEntries[i].mdDblArrayValue.size());
std::copy(dbl_buf.begin(),
dbl_buf.begin() + mc.metadataEntries[i].mdDblArrayValue.size(),
@@ -1348,7 +1371,7 @@
MBErrorCode Tqdcfr::read_md_string(std::string &name)
FREADI(1);
- int str_size = int_buf[0];
+ int str_size = uint_buf[0];
if (str_size > 0) {
FREADC(str_size);
if (char_buf.size() <= (unsigned int) str_size)
@@ -1387,13 +1410,13 @@
for (unsigned int i = 0; i < info.numEntities; i++) {
instance->FREADI(8);
- geom_headers[i].nodeCt = instance->int_buf[0];
- geom_headers[i].nodeOffset = instance->int_buf[1];
- geom_headers[i].elemCt = instance->int_buf[2];
- geom_headers[i].elemOffset = instance->int_buf[3];
- geom_headers[i].elemTypeCt = instance->int_buf[4];
- geom_headers[i].elemLength = instance->int_buf[5];
- geom_headers[i].geomID = instance->int_buf[6];
+ geom_headers[i].nodeCt = instance->uint_buf[0];
+ geom_headers[i].nodeOffset = instance->uint_buf[1];
+ geom_headers[i].elemCt = instance->uint_buf[2];
+ geom_headers[i].elemOffset = instance->uint_buf[3];
+ geom_headers[i].elemTypeCt = instance->uint_buf[4];
+ geom_headers[i].elemLength = instance->uint_buf[5];
+ geom_headers[i].geomID = instance->uint_buf[6];
// don't represent in MOAB if no mesh
if (geom_headers[i].nodeCt == 0 && geom_headers[i].elemCt == 0)
@@ -1446,12 +1469,12 @@
static const char group_category[CATEGORY_TAG_SIZE] = "Group\0";
instance->FREADI(6);
- group_headers[i].grpID = instance->int_buf[0];
- group_headers[i].grpType = instance->int_buf[1];
- group_headers[i].memCt = instance->int_buf[2];
- group_headers[i].memOffset = instance->int_buf[3];
- group_headers[i].memTypeCt = instance->int_buf[4];
- group_headers[i].grpLength = instance->int_buf[5];
+ group_headers[i].grpID = instance->uint_buf[0];
+ group_headers[i].grpType = instance->uint_buf[1];
+ group_headers[i].memCt = instance->uint_buf[2];
+ group_headers[i].memOffset = instance->uint_buf[3];
+ group_headers[i].memTypeCt = instance->uint_buf[4];
+ group_headers[i].grpLength = instance->uint_buf[5];
// set the category tag to signify this is a group
result = instance->mdbImpl->tag_set_data(instance->categoryTag,
@@ -1496,18 +1519,18 @@
static const char material_category[CATEGORY_TAG_SIZE] = "Material Set\0";
instance->FREADI(12);
- block_headers[i].blockID = instance->int_buf[0];
- block_headers[i].blockElemType = instance->int_buf[1];
- block_headers[i].memCt = instance->int_buf[2];
- block_headers[i].memOffset = instance->int_buf[3];
- block_headers[i].memTypeCt = instance->int_buf[4];
- block_headers[i].attribOrder = instance->int_buf[5]; // attrib order
- block_headers[i].blockCol = instance->int_buf[6];
- block_headers[i].blockMixElemType = instance->int_buf[7]; // mixed elem type
- block_headers[i].blockPyrType = instance->int_buf[8];
- block_headers[i].blockMat = instance->int_buf[9];
- block_headers[i].blockLength = instance->int_buf[10];
- block_headers[i].blockDim = instance->int_buf[11];
+ block_headers[i].blockID = instance->uint_buf[0];
+ block_headers[i].blockElemType = instance->uint_buf[1];
+ block_headers[i].memCt = instance->uint_buf[2];
+ block_headers[i].memOffset = instance->uint_buf[3];
+ block_headers[i].memTypeCt = instance->uint_buf[4];
+ block_headers[i].attribOrder = instance->uint_buf[5]; // attrib order
+ block_headers[i].blockCol = instance->uint_buf[6];
+ block_headers[i].blockMixElemType = instance->uint_buf[7]; // mixed elem type
+ block_headers[i].blockPyrType = instance->uint_buf[8];
+ block_headers[i].blockMat = instance->uint_buf[9];
+ block_headers[i].blockLength = instance->uint_buf[10];
+ block_headers[i].blockDim = instance->uint_buf[11];
// adjust element type for data version; older element types didn't include
// 4 new trishell element types
@@ -1526,6 +1549,9 @@
material_category);
+ // if this block is empty, continue
+ if (!block_headers[i].memCt) continue;
// check the number of vertices in the element type, and set the has mid nodes tag
// accordingly
int num_verts = cub_elem_num_verts[block_headers[i].blockElemType];
@@ -1576,13 +1602,13 @@
static const char dirichlet_category[CATEGORY_TAG_SIZE] = "Dirichlet Set\0";
- nodeset_headers[i].nsID = instance->int_buf[0];
- nodeset_headers[i].memCt = instance->int_buf[1];
- nodeset_headers[i].memOffset = instance->int_buf[2];
- nodeset_headers[i].memTypeCt = instance->int_buf[3];
- nodeset_headers[i].pointSym = instance->int_buf[4]; // point sym
- nodeset_headers[i].nsCol = instance->int_buf[5];
- nodeset_headers[i].nsLength = instance->int_buf[6];
+ nodeset_headers[i].nsID = instance->uint_buf[0];
+ nodeset_headers[i].memCt = instance->uint_buf[1];
+ nodeset_headers[i].memOffset = instance->uint_buf[2];
+ nodeset_headers[i].memTypeCt = instance->uint_buf[3];
+ nodeset_headers[i].pointSym = instance->uint_buf[4]; // point sym
+ nodeset_headers[i].nsCol = instance->uint_buf[5];
+ nodeset_headers[i].nsLength = instance->uint_buf[6];
// pad
// set the dirichlet set tag and id tag both to id
@@ -1626,14 +1652,14 @@
static const char neumann_category[CATEGORY_TAG_SIZE] = "Neumann Set\0";
- sideset_headers[i].ssID = instance->int_buf[0];
- sideset_headers[i].memCt = instance->int_buf[1];
- sideset_headers[i].memOffset = instance->int_buf[2];
- sideset_headers[i].memTypeCt = instance->int_buf[3];
- sideset_headers[i].numDF = instance->int_buf[4]; // num dist factors
- sideset_headers[i].ssCol = instance->int_buf[5];
- sideset_headers[i].useShell = instance->int_buf[6];
- sideset_headers[i].ssLength = instance->int_buf[7];
+ sideset_headers[i].ssID = instance->uint_buf[0];
+ sideset_headers[i].memCt = instance->uint_buf[1];
+ sideset_headers[i].memOffset = instance->uint_buf[2];
+ sideset_headers[i].memTypeCt = instance->uint_buf[3];
+ sideset_headers[i].numDF = instance->uint_buf[4]; // num dist factors
+ sideset_headers[i].ssCol = instance->uint_buf[5];
+ sideset_headers[i].useShell = instance->uint_buf[6];
+ sideset_headers[i].ssLength = instance->uint_buf[7];
// set the neumann set tag and id tag both to id
result = instance->mdbImpl->tag_set_data(instance->ssTag, &(sideset_headers[i].setHandle), 1,
@@ -1747,8 +1773,8 @@
feModelHeader.blockArray,
instance,
feBlockH);
+ print_block_headers("Block headers:", feBlockH, feModelHeader.blockArray.numEntities);
- print_block_headers("Block headers:", feBlockH, feModelHeader.blockArray.numEntities);
if (feModelHeader.nodesetArray.numEntities > 0) {
result = instance->mdbImpl->tag_create(DIRICHLET_SET_TAG_NAME, sizeof(int), MB_TAG_SPARSE,
@@ -2230,9 +2256,9 @@
<< numEntities << ", " << tableOffset << ", " << metaDataOffset << std::endl;
-void Tqdcfr::FEModelHeader::ArrayInfo::init(const std::vector<unsigned int>& int_buf)
+void Tqdcfr::FEModelHeader::ArrayInfo::init(const std::vector<unsigned int>& uint_buf)
- numEntities = int_buf[0]; tableOffset = int_buf[1]; metaDataOffset = int_buf[2];
+ numEntities = uint_buf[0]; tableOffset = uint_buf[1]; metaDataOffset = uint_buf[2];
void Tqdcfr::FEModelHeader::print()
@@ -2447,8 +2473,13 @@
if (MB_SUCCESS == result)
std::cout << "Success." << std::endl;
- else
- std::cout << "load_file returned error." << std::endl;
+ else {
+ std::cout << "load_file returned error:" << std::endl;
+ std::string err;
+ result = my_impl->get_last_error(err);
+ if (MB_SUCCESS == result) std::cout << err << std::endl;
+ else std::cout << "(no message)" << std::endl;
delete my_tqd;
delete my_impl;
@@ -2461,12 +2492,45 @@
- else
+ else {
+ std::string err;
delete my_tqd;
delete my_impl;
+#ifdef USE_MPI
+ int err = MPI_Init(&argc, &argv);
+ int nprocs, rank;
+ err = MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+ err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+ // create MOAB instance based on that
+ my_impl = new MBCore(rank, nprocs);
+ if (NULL == my_impl) return 1;
+ std::string options = "PARALLEL=READ_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE";
+ std::cout << "Testing parallel..." << std::endl;
+ result = my_impl->load_file(file, file_set,
+ options.c_str());
+ std::cout << "Success." << std::endl;
+ else {
+ std::string err;
+#endif
return result;
#endif
Modified: MOAB/trunk/Tqdcfr.hpp
--- MOAB/trunk/Tqdcfr.hpp 2008-01-22 20:44:12 UTC (rev 1552)
+++ MOAB/trunk/Tqdcfr.hpp 2008-01-23 02:12:34 UTC (rev 1553)
@@ -44,12 +44,13 @@
public:
void FSEEK( unsigned offset ); // set cubFile offset to specified value
- void FREADI( unsigned num_ents ); // read integers into int_buf
+ void FREADI( unsigned num_ents ); // read integers into uint_buf
void FREADD( unsigned num_ents ); // read doubles into dbl_buf
void FREADC( unsigned num_ents ); // read characters into char_buf
void FREADIA( unsigned num_ents, unsigned int* array ); // read integers
void FREADDA( unsigned num_ents, double* array ); // read doubles
void FREADCA( unsigned num_ents, char* arrat ); // read bytes
+ void CONVERT_TO_INTS(unsigned int num_ents); // convert uint_buf to int_buf in-place
// class for holding the file table of contents
class FileTOC
@@ -76,7 +77,7 @@
ArrayInfo();
void print();
- void init(const std::vector<unsigned int>& int_buf);
+ void init(const std::vector<unsigned int>& uint_buf);
ArrayInfo geomArray, nodeArray, elementArray, groupArray,
@@ -273,14 +274,15 @@
FileTOC fileTOC;
ModelEntry *modelEntries;
MetaDataContainer modelMetaData;
- long currNodeIdOffset;
+ long currVHandleOffset;
long currElementIdOffset[MBMAXTYPE];
MBTag globalIdTag, cubIdTag, geomTag, uniqueIdTag, blockTag, nsTag, ssTag,
attribVectorTag, entityNameTag, categoryTag;
std::map<int, MBEntityHandle> uidSetMap;
std::map<int, MBEntityHandle> gidSetMap[6];
- std::vector<unsigned int> int_buf;
+ std::vector<unsigned int> uint_buf;
+ int *int_buf;
std::vector<double> dbl_buf;
std::vector<char> char_buf;
@@ -317,7 +319,8 @@
enum {mesh, acist, acisb, facet, exodusmesh};
MBEntityType type_from_cub_type(const unsigned int cub_type, const unsigned int nodes_per_elem);
- void check_contiguous(const unsigned int num_ents, long &contig, long &max_id);
+ void check_contiguous(const unsigned int num_ents, int &contig,
+ unsigned int &min_id, unsigned int &max_id);
Tqdcfr(MBInterface *impl);
@@ -375,28 +378,28 @@
//! get entities with individually-specified types; if is_group is false,
//! increment each mem_type by 2 since they're CSOEntityType's and not group types
MBErrorCode get_entities(const unsigned int *mem_types,
std::vector<MBEntityHandle> &entities);
//! get entities specified by type and ids, append to entities
MBErrorCode get_entities(const unsigned int this_type,
std::vector<MBEntityHandle> &excl_entities);
//! get ref entity sets with specified type and ids
MBErrorCode get_ref_entities(const unsigned int this_type,
- unsigned int *id_buf, const unsigned id_buf_size,
+ int *id_buf, const unsigned id_buf_size,
//! get mesh entities with specified type and ids
MBErrorCode get_mesh_entities(const unsigned int this_type,
- //! process entities in a sideset according to sense flags stored in int_buf
+ //! process entities in a sideset according to sense flags stored in uint_buf
//! or char_buf (depending on sense_size)
MBErrorCode process_sideset_10(const int this_type, const int num_ents,
const int sense_size,
@@ -404,7 +407,7 @@
Tqdcfr::SidesetHeader *sideseth);
MBErrorCode process_sideset_11(std::vector<MBEntityHandle> &ss_entities,
+ int num_wrts,
// put entities into the specfied set, and excluded entities into a
