[MOAB-dev] r2302 - MOAB/trunk/tools/dagmc
Tim Tautges
tautges at mcs.anl.gov
Wed Dec 3 12:05:10 CST 2008
Ok, I'll add that to the list for CGM, that's definitely something that
needs to be fixed.
- tim
Jason Kraftcheck wrote:
> Tim Tautges wrote:
>> Why is it necessary to know that it's an occ file, e.g. why the brep
>> file type stuff? Shouldn't this be down in cgm somewhere?
> Perhaps, but CGM isn't implemented that way. A string file type must be
> specified. If CGM is built with ACIS and the ACIS STEP importer, reading in
> step file will fail if the file type is not "STEP" and reading a SAT file
> will fail if the file type is not "ACIS" (or whatever it is supposed to be.)
> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
