[MOAB-dev] r2303 - in MOAB/trunk: . parallel
kraftche at mcs.anl.gov
Wed Dec 3 12:15:50 CST 2008
Author: kraftche
Date: 2008-12-03 12:15:50 -0600 (Wed, 03 Dec 2008)
New Revision: 2303
Modified:
MOAB/trunk/MBWriterIface.hpp
MOAB/trunk/WriteAns.cpp
MOAB/trunk/WriteAns.hpp
MOAB/trunk/WriteGMV.cpp
MOAB/trunk/WriteGMV.hpp
MOAB/trunk/WriteHDF5.cpp
MOAB/trunk/WriteHDF5.hpp
MOAB/trunk/WriteNCDF.cpp
MOAB/trunk/WriteNCDF.hpp
MOAB/trunk/WriteSLAC.cpp
MOAB/trunk/WriteSLAC.hpp
MOAB/trunk/WriteSTL.cpp
MOAB/trunk/WriteSTL.hpp
MOAB/trunk/WriteTemplate.cpp
MOAB/trunk/WriteTemplate.hpp
MOAB/trunk/WriteVtk.cpp
MOAB/trunk/WriteVtk.hpp
MOAB/trunk/parallel/WriteHDF5Parallel.cpp
MOAB/trunk/parallel/WriteHDF5Parallel.hpp
Log:
make qa_list argument to writers const
Modified: MOAB/trunk/MBWriterIface.hpp
--- MOAB/trunk/MBWriterIface.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/MBWriterIface.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -60,7 +60,7 @@
const FileOptions& opts,
const MBEntityHandle* meshset_list,
const int num_sets,
- std::vector<std::string>& qa_records,
+ const std::vector<std::string>& qa_records,
int requested_output_dimension = 0 ) = 0;
Modified: MOAB/trunk/WriteAns.cpp
--- MOAB/trunk/WriteAns.cpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteAns.cpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -90,7 +90,7 @@
const FileOptions&,
const MBEntityHandle *ent_handles,
const int num_sets,
- std::vector<std::string>&, int )
+ const std::vector<std::string>&, int )
assert(0 != mMaterialSetTag &&
0 != mNeumannSetTag &&
Modified: MOAB/trunk/WriteAns.hpp
--- MOAB/trunk/WriteAns.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteAns.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -62,7 +62,7 @@
const MBEntityHandle *output_list,
const int num_sets,
- std::vector<std::string>& qa_list,
+ const std::vector<std::string>& qa_list,
int export_dimension);
//! struct used to hold data for each block to be output; used by
Modified: MOAB/trunk/WriteGMV.cpp
--- MOAB/trunk/WriteGMV.cpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteGMV.cpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -135,7 +135,7 @@
const MBEntityHandle* output_sets,
const int num_output_sets,
- std::vector<std::string>& ,
+ const std::vector<std::string>& ,
int dimension )
MBEntityHandle output_set = 0;
Modified: MOAB/trunk/WriteGMV.hpp
--- MOAB/trunk/WriteGMV.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteGMV.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -52,7 +52,7 @@
int requested_dimension );
//! writes out a mesh file
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteHDF5.cpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -329,7 +329,7 @@
const MBEntityHandle* set_array,
const int num_sets,
int user_dimension )
mhdf_Status status;
@@ -384,7 +384,7 @@
const int num_sets,
MBErrorCode result;
@@ -1822,7 +1822,7 @@
return MB_SUCCESS;
-MBErrorCode WriteHDF5::write_qa( std::vector<std::string>& list )
+MBErrorCode WriteHDF5::write_qa( const std::vector<std::string>& list )
const char* app = "MOAB";
const char* vers = MB_VERSION;
@@ -2019,7 +2019,7 @@
// then MOAB was not built with support for parallel HDF5 I/O.
MBErrorCode WriteHDF5::parallel_create_file( const char* ,
bool ,
int ,
int )
@@ -2028,7 +2028,7 @@
MBErrorCode WriteHDF5::serial_create_file( const char* filename,
bool overwrite,
int dimension )
long first_id;
Modified: MOAB/trunk/WriteHDF5.hpp
--- MOAB/trunk/WriteHDF5.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteHDF5.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -65,7 +65,7 @@
const MBEntityHandle* export_sets,
const int export_set_count,
int user_dimension = 3 );
/** Create attributes holding the HDF5 type handle for the
@@ -77,7 +77,7 @@
MBErrorCode serial_create_file( const char* filename,
bool overwrite,
int dimension = 3 );
/** Function to create the file. Virtual to allow override
@@ -85,7 +85,7 @@
virtual MBErrorCode parallel_create_file( const char* filename,
bool overwrite,
int dimension = 3,
int pcomm_no = 0 );
@@ -147,7 +147,7 @@
long parents_length );
//! Write exodus-type QA info
- MBErrorCode write_qa( std::vector<std::string>& list );
+ MBErrorCode write_qa( const std::vector<std::string>& list );
//! Range of entities, grouped by type, to export
@@ -252,7 +252,7 @@
MBErrorCode init();
Modified: MOAB/trunk/WriteNCDF.cpp
--- MOAB/trunk/WriteNCDF.cpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteNCDF.cpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -151,7 +151,7 @@
const FileOptions&,
const int num_sets,
- std::vector<std::string> &qa_records,
+ const std::vector<std::string> &qa_records,
int user_dimension)
@@ -308,7 +308,7 @@
return MB_FAILURE;
// copy the qa records into the argument
- mesh_info.qaRecords.swap(qa_records);
+ //mesh_info.qaRecords.swap(qa_records);
return MB_SUCCESS;
Modified: MOAB/trunk/WriteNCDF.hpp
--- MOAB/trunk/WriteNCDF.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteNCDF.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -101,7 +101,7 @@
const int num_sets,
int user_dimension);
protected:
Modified: MOAB/trunk/WriteSLAC.cpp
--- MOAB/trunk/WriteSLAC.cpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteSLAC.cpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -128,7 +128,7 @@
const FileOptions&,
const int num_sets,
Modified: MOAB/trunk/WriteSLAC.hpp
--- MOAB/trunk/WriteSLAC.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteSLAC.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -64,7 +64,7 @@
const int num_sets,
Modified: MOAB/trunk/WriteSTL.cpp
--- MOAB/trunk/WriteSTL.cpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteSTL.cpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -82,7 +82,7 @@
const int num_sets,
int )
char header[81];
@@ -183,12 +183,13 @@
return result;
-MBErrorCode WriteSTL::make_header( char header[81], std::vector<std::string>& qa_list )
+MBErrorCode WriteSTL::make_header( char header[81],
+ const std::vector<std::string>& qa_list )
memset( header, 0, 81 );
std::string result;
- for (std::vector<std::string>::iterator i = qa_list.begin(); i != qa_list.end(); ++i)
+ for (std::vector<std::string>::const_iterator i = qa_list.begin(); i != qa_list.end(); ++i)
result += " ";
result += *i;
Modified: MOAB/trunk/WriteSTL.hpp
--- MOAB/trunk/WriteSTL.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteSTL.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -59,7 +59,7 @@
const int num_sets,
protected:
@@ -94,7 +94,7 @@
//! Construct 80-byte, null-terminated description string from
//! qa_list. Unused space in header will be null-char padded.
- MBErrorCode make_header( char header[82], std::vector<std::string>& qa_list );
+ MBErrorCode make_header( char header[82], const std::vector<std::string>& qa_list );
//! Get triangles to write from input array of entity sets. If
//! no sets, gets all triangles.
Modified: MOAB/trunk/WriteTemplate.cpp
--- MOAB/trunk/WriteTemplate.cpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteTemplate.cpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -122,7 +122,7 @@
const int num_sets,
Modified: MOAB/trunk/WriteTemplate.hpp
--- MOAB/trunk/WriteTemplate.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteTemplate.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -63,7 +63,7 @@
const int num_sets,
Modified: MOAB/trunk/WriteVtk.cpp
--- MOAB/trunk/WriteVtk.cpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteVtk.cpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -79,7 +79,7 @@
const int num_sets,
int )
MBErrorCode rval;
Modified: MOAB/trunk/WriteVtk.hpp
--- MOAB/trunk/WriteVtk.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/WriteVtk.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -44,7 +44,7 @@
const int num_sets,
private:
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -353,7 +353,7 @@
MBErrorCode WriteHDF5Parallel::parallel_create_file( const char* filename,
bool overwrite,
int dimension,
int pcomm_no)
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.hpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-12-03 17:29:55 UTC (rev 2302)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.hpp 2008-12-03 18:15:50 UTC (rev 2303)
@@ -102,7 +102,7 @@
//! necessary data for parallel write.
bool overwrite,
int dimension = 3,
int pcomm_no = 0);
