[MOAB-dev] "Obj_unknown" when building mbzoltan
Tim Tautges
tautges at mcs.anl.gov
Wed Aug 27 14:59:01 CDT 2008
I think the _unknown part is because you're not setting the ZOLTAN_ARCH
or ARCH variable in the zoltan install. On my linux machine, the value
I set is "linux".
- tim
de Almeida, Valmor F. wrote:
> During the install phase of moab I have a problem with
> -L/usr/local/zoltan/Obj_unknown
> Why is Obj_unknown appearing and how do I change it?
> See below for full command. The Zoltan library has no "install"
> mechanism therefore I have it installed on my system in
> /usr/local/zoltan
> which has /include /bin /lib subdirectories. During the moab
> .configure step, zoltan.h is correctly found in
> /usr/local/zoltan/include. The full .configure I am using for moab is:
> ./configure --prefix=$HOME/projects/scidac/itaps/moab-usr
> --enable-doxygen --with-mpi=/usr/local/ompi --with-hdf5=/usr/local/hdf5
> --with-zoltan=/usr/local/zoltan --with-parmetis=/usr/local/parmetis
> --enable-mbzoltan
> Any help appreciated. Thanks,
> Valmor
> /usr/local/ompi_gnu/bin/mpicxx -Wall -pipe -O2 -DNDEBUG -o mbzoltan
> MBZoltan.o main.o -L/usr/local/hdf5/lib ../../.libs/libMOAB.a
> /usr/lib/libnetcdf_c++.so /usr/lib/libnetcdf.so
> /usr/local/packages/hdf5-1.8.1_gcc-4.1.2/lib/libhdf5.a -L//lib -lsz -lz
> /usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libmpi_cxx.so
> /usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libmpi.so
> /usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libopen-rte.so
> /usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libopen-pal.so
> -L/usr/local/zoltan/Obj_unknown -lzoltan -L/usr/local/parmetis
> -lparmetis -lmetis -lm -Wl,--rpath
> -Wl,/usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib -Wl,--rpath
> /usr/lib/gcc/i686-pc-linux-gnu/4.1.2/../../../../i686-pc-linux-gnu/bin/l
> d: cannot find -lzoltan
> Valmor de Almeida, Ph.D.
> Oak Ridge National Laboratory
> 1 Bethel Valley Road
> PO Box 2008
> Oak Ridge TN 37831-6181
> url: dealmeidav.ornl.gov
> tel: 865-241-2906
> fax: 865-241-4829
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
