[MOAB-dev] "Obj_unknown" when building mbzoltan
de Almeida, Valmor F.
dealmeidav at ornl.gov
Wed Aug 27 15:06:15 CDT 2008
I start with a Config.generic and modify to fit my system so I call it
Config.xeon0. Then I set ZOLTAN_ARCH to xeon0. Since there is no
"install" phase in zoltan, I copy the libraries and header files, and
organize them in a place all users can access as I mentioned in my
previous e-mail. I've tested zoltan with the given examples and all
work.
Is MOAB trying to access the Obj_"arch" directory created during the
zoltan install? If so why aren't the libraries enough?
Valmor
> -----Original Message-----
> From: Tim Tautges [mailto:tautges at mcs.anl.gov]
> Sent: Wednesday, August 27, 2008 3:59 PM
> To: de Almeida, Valmor F.
> Cc: moab-dev at mcs.anl.gov
> Subject: Re: [MOAB-dev] "Obj_unknown" when building mbzoltan
> I think the _unknown part is because you're not setting the
ZOLTAN_ARCH
> or ARCH variable in the zoltan install. On my linux machine, the
value
> I set is "linux".
> - tim
> de Almeida, Valmor F. wrote:
> > During the install phase of moab I have a problem with
> > -L/usr/local/zoltan/Obj_unknown
> > Why is Obj_unknown appearing and how do I change it?
> > See below for full command. The Zoltan library has no "install"
> > mechanism therefore I have it installed on my system in
> > /usr/local/zoltan
> > which has /include /bin /lib subdirectories. During the moab
> > .configure step, zoltan.h is correctly found in
> > /usr/local/zoltan/include. The full .configure I am using for moab
is:
> > ./configure --prefix=$HOME/projects/scidac/itaps/moab-usr
> > --enable-doxygen --with-mpi=/usr/local/ompi
--with-hdf5=/usr/local/hdf5
> > --with-zoltan=/usr/local/zoltan --with-parmetis=/usr/local/parmetis
> > --enable-mbzoltan
> > Any help appreciated. Thanks,
> > Valmor
> > /usr/local/ompi_gnu/bin/mpicxx -Wall -pipe -O2 -DNDEBUG -o mbzoltan
> > MBZoltan.o main.o -L/usr/local/hdf5/lib ../../.libs/libMOAB.a
> > /usr/lib/libnetcdf_c++.so /usr/lib/libnetcdf.so
> > /usr/local/packages/hdf5-1.8.1_gcc-4.1.2/lib/libhdf5.a -L//lib -lsz
-lz
> > /usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libmpi_cxx.so
> > /usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libmpi.so
> > /usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libopen-rte.so
> > /usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libopen-pal.so
> > -L/usr/local/zoltan/Obj_unknown -lzoltan -L/usr/local/parmetis
> > -lparmetis -lmetis -lm -Wl,--rpath
> > -Wl,/usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib -Wl,--rpath
/usr/lib/gcc/i686-pc-linux-gnu/4.1.2/../../../../i686-pc-linux-gnu/bin/l
> > d: cannot find -lzoltan
> > Valmor de Almeida, Ph.D.
> > Oak Ridge National Laboratory
> > 1 Bethel Valley Road
> > PO Box 2008
> > Oak Ridge TN 37831-6181
> > url: dealmeidav.ornl.gov
> > tel: 865-241-2906
> > fax: 865-241-4829
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
