[MOAB-dev] "Obj_unknown" when building mbzoltan
de Almeida, Valmor F.
dealmeidav at ornl.gov
Wed Aug 27 14:50:13 CDT 2008
During the install phase of moab I have a problem with
-L/usr/local/zoltan/Obj_unknown
Why is Obj_unknown appearing and how do I change it?
See below for full command. The Zoltan library has no "install"
mechanism therefore I have it installed on my system in
/usr/local/zoltan
which has /include /bin /lib subdirectories. During the moab
.configure step, zoltan.h is correctly found in
/usr/local/zoltan/include. The full .configure I am using for moab is:
./configure --prefix=$HOME/projects/scidac/itaps/moab-usr
--enable-doxygen --with-mpi=/usr/local/ompi --with-hdf5=/usr/local/hdf5
--with-zoltan=/usr/local/zoltan --with-parmetis=/usr/local/parmetis
--enable-mbzoltan
Any help appreciated. Thanks,
Valmor
/usr/local/ompi_gnu/bin/mpicxx -Wall -pipe -O2 -DNDEBUG -o mbzoltan
MBZoltan.o main.o -L/usr/local/hdf5/lib ../../.libs/libMOAB.a
/usr/lib/libnetcdf_c++.so /usr/lib/libnetcdf.so
/usr/local/packages/hdf5-1.8.1_gcc-4.1.2/lib/libhdf5.a -L//lib -lsz -lz
/usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libmpi_cxx.so
/usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libmpi.so
/usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libopen-rte.so
/usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib/libopen-pal.so
-L/usr/local/zoltan/Obj_unknown -lzoltan -L/usr/local/parmetis
-lparmetis -lmetis -lm -Wl,--rpath
-Wl,/usr/local/packages/openmpi-1.2.6_gcc-4.1.2/lib -Wl,--rpath
/usr/lib/gcc/i686-pc-linux-gnu/4.1.2/../../../../i686-pc-linux-gnu/bin/l
d: cannot find -lzoltan
Valmor de Almeida, Ph.D.
Oak Ridge National Laboratory
1 Bethel Valley Road
PO Box 2008
Oak Ridge TN 37831-6181
url: dealmeidav.ornl.gov
tel: 865-241-2906
fax: 865-241-4829
