[MOAB-dev] r1273 - MOAB/trunk/tools/converter
kraftche at mcs.anl.gov
Fri Sep 14 11:01:06 CDT 2007
Author: kraftche
Date: 2007-09-14 11:01:06 -0500 (Fri, 14 Sep 2007)
New Revision: 1273
Modified:
MOAB/trunk/tools/converter/convert.cpp
Log:
print last reported error message if file read or write files
Modified: MOAB/trunk/tools/converter/convert.cpp
--- MOAB/trunk/tools/converter/convert.cpp 2007-09-13 16:13:20 UTC (rev 1272)
+++ MOAB/trunk/tools/converter/convert.cpp 2007-09-14 16:01:06 UTC (rev 1273)
@@ -268,7 +268,11 @@
result = gMB->load_file( in, read_meshset, read_options.c_str() );
if (MB_SUCCESS != result)
- std::cerr << "Failed to load \"" << in << "\"." << std::endl;
+ std::cerr << "Failed to load \"" << in << "\"." << std::endl;
+ std::cerr << "Error code: " << gMB->get_error_string(result) << " (" << result << ")" << std::endl;
+ std::string message;
+ if (MB_SUCCESS == gMB->get_last_error(message) && !message.empty())
+ std::cerr << "Error message: " << message << std::endl;
return READ_ERROR;
std::cerr << "Read \"" << in << "\"" << std::endl;
@@ -492,6 +496,10 @@
std::cerr << "Failed to write \"" << out << "\"." << std::endl;
return WRITE_ERROR;
std::cerr << "Wrote \"" << out << "\"" << std::endl;
