[MOAB-dev] r1272 - MOAB/trunk
tautges at mcs.anl.gov
Thu Sep 13 11:13:20 CDT 2007
Author: tautges
Date: 2007-09-13 11:13:20 -0500 (Thu, 13 Sep 2007)
New Revision: 1272
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBTypes.h
MOAB/trunk/README
MOAB/trunk/RELEASE_NOTES
MOAB/trunk/ReadParallel.cpp
MOAB/trunk/TagServer.cpp
MOAB/trunk/TagServer.hpp
MOAB/trunk/internals_test.cpp
Log:
ReadParallel.cpp: filter entities better so that it keeps
lower-dimensional entities adj to partition entities, and sets
containing sets containing kept entities
Updated RELEASE_NOTES for v2 - v3 changes
Changed MB_TAG_LAST to be equal to MB_TAG_MESH, following Jason's
suggestion; also reverted changes to TagServer for extra switch cases
accordingly.
Tests pass as before.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2007-09-13 14:29:07 UTC (rev 1271)
+++ MOAB/trunk/MBCore.cpp 2007-09-13 16:13:20 UTC (rev 1272)
@@ -1589,7 +1589,7 @@
MBErrorCode MBCore::tag_get_type(const MBTag tag_handle, MBTagType &tag_type) const
tag_type = PROP_FROM_TAG_HANDLE(tag_handle);
- return tag_type < MB_TAG_LAST ? MB_SUCCESS : MB_TAG_NOT_FOUND;
+ return tag_type < MB_TAG_LAST+1 ? MB_SUCCESS : MB_TAG_NOT_FOUND;
//! get handles for all tags defined
Modified: MOAB/trunk/MBTypes.h
--- MOAB/trunk/MBTypes.h 2007-09-13 14:29:07 UTC (rev 1271)
+++ MOAB/trunk/MBTypes.h 2007-09-13 16:13:20 UTC (rev 1272)
@@ -58,7 +58,7 @@
MB_TAG_SPARSE, /**< tags stored in (entity handle, tag value) pairs */
MB_TAG_DENSE, /**< tags stored in vectors directly on entity sequences, cheaper for tags which go on lots of entities */
MB_TAG_MESH,
- MB_TAG_LAST};
+ MB_TAG_LAST=MB_TAG_MESH};
/** Specify data type for tags. */
enum MBDataType {
Modified: MOAB/trunk/README
--- MOAB/trunk/README 2007-09-13 14:29:07 UTC (rev 1271)
+++ MOAB/trunk/README 2007-09-13 16:13:20 UTC (rev 1272)
@@ -77,6 +77,7 @@
1.00 (2/1/04): Initial release (woo-hoo!)
Implementation:
+3.00 (9/1/07): Move to Argonne, various assorted changes
2.00 (11/1/06): LOTS of bug fixes & improvements
Modified: MOAB/trunk/RELEASE_NOTES
--- MOAB/trunk/RELEASE_NOTES 2007-09-13 14:29:07 UTC (rev 1271)
+++ MOAB/trunk/RELEASE_NOTES 2007-09-13 16:13:20 UTC (rev 1272)
@@ -1,5 +1,28 @@
Version beta:
+- Fixed bug in get_entities_by_type_and_tag for cases with non-zero
+input set which has or doesn't have entities
+Version 3.0.0 (SVN tag 3.0.0):
+- Updated QVDual to work with new versions of VTK and removed
+dependence on graphviz
+- Move ITAPS/TSTT interface implementation into tools/iMesh and make
+it work with configure system
+- Implement new version number system
+- Incorporate DagMC library (does fast facet-based
+ray tracing) into tools/dagmc
+- Prefer g++ to pgCC in configure scripts
+- Many improvements in kd tree functionality, performance
+- Move entity sets to be stored in sequences, better performance &
+functionality
+- Improved various file writers/readers, including:
+. Better performance of HDF5 file reader
+. Configuration with/without HDF5, netcdf
+. Vtk writer improvements
+- Added functions to MBInterface to get memory usage of MOAB
+- Fixes to various MBCN functions for 64-bit builds
+- Small changes to #defines of some tag names in MBTagConventions.hpp
Version 2.00 (CVS tag version_200):
- New MBInterface method to get blocked coordinate data for vertices.
- Speed up reading of entity sets in .h5m files.
Modified: MOAB/trunk/ReadParallel.cpp
--- MOAB/trunk/ReadParallel.cpp 2007-09-13 14:29:07 UTC (rev 1271)
+++ MOAB/trunk/ReadParallel.cpp 2007-09-13 16:13:20 UTC (rev 1272)
@@ -5,6 +5,7 @@
#include "MBError.hpp"
#include "MBReaderWriterSet.hpp"
#include "MBParallelComm.hpp"
+#include "MBCN.hpp"
#define RR if (MB_SUCCESS != result) return result
@@ -175,15 +176,21 @@
// merge partition ents into pre-existing entities
exist_ents.merge(partition_ents);
- // gather adjacent verts and add to existing ents
+ // gather adjacent ents of lower dimension and add to existing ents
MBRange tmp_ents;
- MBRange::iterator bit = exist_ents.lower_bound(MBEDGE),
- eit = exist_ents.upper_bound(MBENTITYSET);
- MBRange from_ents(*bit, *eit);
- from_ents = from_ents.intersect(exist_ents);
- result = mbImpl->get_adjacencies(from_ents, 0, false, tmp_ents,
- MBInterface::UNION); RR;
- exist_ents.merge(tmp_ents);
+ for (int dim = 2; dim >= 0; dim--) {
+ MBEntityType lower_type = MBVERTEX, upper_type = MBENTITYSET;
+ while (MBMAXTYPE != lower_type && MBCN::Dimension(lower_type) < dim+1) lower_type++;
+ MBRange::iterator bit = exist_ents.lower_bound(lower_type),
+ eit = exist_ents.upper_bound(upper_type);
+ MBRange from_ents(*bit, *eit);
+ from_ents = from_ents.intersect(exist_ents);
+ tmp_ents.clear();
+ result = mbImpl->get_adjacencies(from_ents, dim, false, tmp_ents,
+ MBInterface::UNION); RR;
+ exist_ents.merge(tmp_ents);
// subtract from all ents to get deletable ents
all_ents = all_ents.subtract(exist_ents);
@@ -193,7 +200,7 @@
result = mbImpl->get_entities_by_type(0, MBENTITYSET, all_sets);
for (MBRange::iterator rit = all_sets.begin(); rit != all_sets.end(); rit++) {
tmp_ents.clear();
- result = mbImpl->get_entities_by_handle(*rit, tmp_ents); RR;
+ result = mbImpl->get_entities_by_handle(*rit, tmp_ents, true); RR;
tmp_ents = tmp_ents.intersect(exist_ents);
// if the intersection is empty, set is deletable
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp 2007-09-13 14:29:07 UTC (rev 1271)
+++ MOAB/trunk/TagServer.cpp 2007-09-13 16:13:20 UTC (rev 1272)
@@ -155,9 +155,6 @@
case MB_TAG_MESH:
result = MB_SUCCESS;
break;
- case MB_TAG_LAST:
- assert(false);
- break;
@@ -189,9 +186,6 @@
case MB_TAG_MESH:
status = MB_SUCCESS;
break;
- case MB_TAG_LAST:
- assert(false);
- break;
mTagTable[tag_type][tag_idx].invalidate();
@@ -272,8 +266,6 @@
return mDenseData->set_data(id, entity_handle, data);
case MB_TAG_MESH:
return MB_FAILURE;
- case MB_TAG_LAST:
- return MB_FAILURE;
return MB_FAILURE;
@@ -430,10 +422,6 @@
case MB_TAG_MESH:
result = MB_FAILURE;
break;
- case MB_TAG_LAST:
- assert(false);
- result = MB_FAILURE;
- break;
// if we couldn't get a value
@@ -585,7 +573,7 @@
MBTag TagServer::get_handle(const char *tag_name) const
if (tag_name && *tag_name)
- for (int i = 0; i < MB_TAG_LAST; ++i)
+ for (int i = 0; i < MB_TAG_LAST+1; ++i)
for (MBTagId j = 0; j < mTagTable[i].size(); ++j)
if (mTagTable[i][j].is_valid() && mTagTable[i][j].get_name() == tag_name)
return TAG_HANDLE_FROM_ID( j + 1, (MBTagType)i );
@@ -595,7 +583,7 @@
MBErrorCode TagServer::get_tags(std::vector<MBTag> &all_tags)
if (mTagTable[i][j].is_valid())
all_tags.push_back( TAG_HANDLE_FROM_ID( j + 1, (MBTagType)i ) );
@@ -621,7 +609,7 @@
MBErrorCode TagServer::get_mesh_tags( std::vector<MBTag>& all_tags ) const
if (mTagTable[i][j].is_valid() && mTagTable[i][j].get_mesh_value())
@@ -691,8 +679,6 @@
return MB_FAILURE;
case MB_TAG_MESH:
return MB_FAILURE;
- case MB_TAG_LAST:
return MB_TAG_NOT_FOUND;
@@ -735,9 +721,6 @@
case MB_TAG_MESH:
result = MB_TYPE_OUT_OF_RANGE;
break;
- case MB_TAG_LAST:
- result = MB_TYPE_OUT_OF_RANGE;
- break;
return result;
@@ -763,9 +746,6 @@
case MB_TAG_MESH:
break;
- case MB_TAG_LAST:
- break;
return result;
@@ -793,9 +773,6 @@
case MB_TAG_MESH:
break;
- case MB_TAG_LAST:
- break;
return result;
@@ -825,9 +802,6 @@
case MB_TAG_MESH:
break;
- case MB_TAG_LAST:
- break;
return result;
@@ -923,8 +897,6 @@
return mBitServer->get_number_entities(id, type, num_entities);
case MB_TAG_MESH:
return MB_TYPE_OUT_OF_RANGE;
- case MB_TAG_LAST:
- return MB_TYPE_OUT_OF_RANGE;
@@ -944,8 +916,6 @@
return mBitServer->get_number_entities(range, id, type, num_entities);
case MB_TAG_MESH:
- case MB_TAG_LAST:
@@ -969,8 +939,6 @@
break;
case MB_TAG_MESH:
break;
- case MB_TAG_LAST:
- break;
// add in size of entry in mTagTable
@@ -998,8 +966,6 @@
break;
case MB_TAG_MESH:
break;
- case MB_TAG_LAST:
- break;
// size of entry in mTagTable map
Modified: MOAB/trunk/TagServer.hpp
--- MOAB/trunk/TagServer.hpp 2007-09-13 14:29:07 UTC (rev 1271)
+++ MOAB/trunk/TagServer.hpp 2007-09-13 16:13:20 UTC (rev 1272)
@@ -277,7 +277,7 @@
//! Table of tag ids and tag information
//! Primary (array) index is tag type.
//! Secondary (std::vector) index is tag id less one (tag ids begin with 1).
- std::vector<TagInfo> mTagTable[MB_TAG_LAST];
+ std::vector<TagInfo> mTagTable[MB_TAG_LAST+1];
//! container for storing the sparse data and tag ids
SparseTagSuperCollection* mSparseData;
Modified: MOAB/trunk/internals_test.cpp
--- MOAB/trunk/internals_test.cpp 2007-09-13 14:29:07 UTC (rev 1271)
+++ MOAB/trunk/internals_test.cpp 2007-09-13 16:13:20 UTC (rev 1272)
@@ -61,7 +61,7 @@
const unsigned cpus[] = { 1, 4, 16, 5, 20 };
const int num_cpus = sizeof(cpus)/sizeof(cpus[0]);
unsigned errors = 0, tests = 0;
- const int num_prop = MB_TAG_LAST;
+ const int num_prop = MB_TAG_LAST+1;
++tests;
if (MB_TAG_LAST > num_prop) {
