[MOAB-dev] r1325 - MOAB/trunk/tools/dagmc
bmsmith at mcs.anl.gov bmsmith at mcs.anl.gov
Tue Oct 23 14:37:46 CDT 2007
Author: bmsmith
Date: 2007-10-23 14:37:46 -0500 (Tue, 23 Oct 2007)
New Revision: 1325
Modified:
   MOAB/trunk/tools/dagmc/DagMC.cpp
Log:
Added function that uses uvw to determine if a particle is entering or leaving a volume if xyz is on the boundary of a volume.
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2007-10-23 19:03:32 UTC (rev 1324)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2007-10-23 19:37:46 UTC (rev 1325)
@@ -38,7 +38,7 @@
       moabMCNPSourceCell(0), moabMCNPUseDistLimit(false)
   options[0] = Option( "source_cell",        "source cell ID, or zero if unknown", "0" );
-  options[1] = Option( "distance_tolerance", "positive real value", "0.000001" );
+  options[1] = Option( "distance_tolerance", "positive real value", "0.001" );
   options[2] = Option( "use_distance_limit", "one to enable distance limit optimization, zero otherwise", "0" );
   options[3] = Option( "use_cad", "one to ray-trace to cad, zero for just facets", "0" );
   options[4] = Option( "faceting_tolerance", "graphics faceting tolerance", "0.001" );
@@ -382,7 +382,63 @@
   return MB_SUCCESS;
+// If point is on boundary, then this function is called to
+// discriminate cases in which the ray is entering or leaving.
+// result= 1 -> inside volume or entering volume
+// result= 0 -> outside volume or leaving volume
+// result=-1 -> on boundary with null or tangent uvw
+MBErrorCode DagMC::boundary_case( MBEntityHandle volume, int& result,
+				  double u, double v, double w,
+				  MBEntityHandle facet,
+				  MBEntityHandle surface)
+  MBErrorCode rval;
+  // test to see if uvx is provided
+  if ( u <= 1.0 && v <= 1.0 && w <= 1.0 ) {
+    const MBCartVect ray_vector(u, v, w);
+    MBCartVect coords[3], normal(0.0);
+    const MBEntityHandle *conn;
+    int len, sense_out;
+    rval = mbImpl->get_connectivity( facet, conn, len );
+      assert( MB_SUCCESS == rval );
+      assert( 3 == len );
+    rval = mbImpl->get_coords( conn, 3, coords[0].array() );
+      assert(MB_SUCCESS == rval);
+    rval = surface_sense( volume, surface, sense_out );
+      assert( MB_SUCCESS == rval);
+    coords[1] -= coords[0];
+    coords[2] -= coords[0];
+    normal = sense_out * (coords[1] * coords[2]);
+    double sense = ray_vector % normal;
+    if ( sense < 0.0 ) {
+      result = 1;     // inside or entering
+    } else  if ( sense > 0.0 ) {
+      result = 0;     // outside or leaving
+    } else  if ( sense == 0.0 ) {
+      result = -1;    // tangent, therefore on boundary
+    } else {
+      result = -1;    // failure
+      return MB_FAILURE;
+  // if uvw not provided, return on_boundary.
+  } else {
+    result = -1;      // on boundary
+    return MB_SUCCESS;
 // Fast point_in_volume code.  This function assumes that there is an
 // OBB tree containing only manifold surfaces in the volume, such that
 // the closest facet to the input position found using the OBB tree is
@@ -398,7 +454,8 @@
 // vertex cannot be a saddle: it must be a strict concavity or convexity.
 MBErrorCode DagMC::point_in_volume( MBEntityHandle volume,
                              double x, double y, double z,
-                             int& result )
+                             int& result,
+			     double u, double v, double w)
   MBErrorCode rval;
   const double epsilon = distanceTolerance;
@@ -409,15 +466,15 @@
     // Get closest point in triangulation
   const MBCartVect point(x,y,z);
-  MBEntityHandle facet;
+  MBEntityHandle facet, surface;
   MBCartVect closest, diff;
-  rval = obbTree.closest_to_location( point.array(), root, closest.array(), facet );
+  rval = obbTree.closest_to_location( point.array(), root, closest.array(), facet, &surface );
   if (MB_SUCCESS != rval)  return rval;
     // Check for on-boundary case
   diff = closest - point;
   if (diff%diff <= epsilon*epsilon) {
-    result = -1;
+    return boundary_case( volume, result, u, v, w, facet, surface );
     return MB_SUCCESS;
