[MOAB-dev] r1325 - MOAB/trunk/tools/dagmc
Jason Kraftcheck
kraftche at cae.wisc.edu
Wed Oct 24 17:14:58 CDT 2007
bmsmith at mcs.anl.gov wrote:
> Author: bmsmith
> Date: 2007-10-23 14:37:46 -0500 (Tue, 23 Oct 2007)
> New Revision: 1325
> Modified:
> MOAB/trunk/tools/dagmc/DagMC.cpp
> Log:
> Added function that uses uvw to determine if a particle is entering or leaving a volume if xyz is on the boundary of a volume.
This checkin seems to have broken the DagMC build. Did you forget to
check in the corresponding header changes?
- jason
