[MOAB-dev] r1324 - in MOAB/trunk: . mhdf
    dcthomp at mcs.anl.gov
    Tue Oct 23 14:03:32 CDT 2007
Author: dcthomp
Date: 2007-10-23 14:03:32 -0500 (Tue, 23 Oct 2007)
New Revision: 1324
Added:
   MOAB/trunk/mhdf/CMakeLists.txt
Modified:
   MOAB/trunk/CMakeLists.txt
   MOAB/trunk/MBEntityHandle.h.in
   MOAB/trunk/WriteHDF5.cpp
   MOAB/trunk/config.h.cmake
Log:
ENH: Move the FindHDF CMake check inside MOAB_USE_HDF so we don't even
     look for HDF if not required. Add the mhdf library when MOAB_USE_HDF
     is turned on. Add HDF5 I/O classes to MOAB when building w/ HDF.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt	2007-10-23 18:54:21 UTC (rev 1323)
+++ MOAB/trunk/CMakeLists.txt	2007-10-23 19:03:32 UTC (rev 1324)
@@ -76,11 +76,6 @@
     find_package( MPI )
   endif ( MOAB_USE_MPI )
-  # HDF5
-  find_package( HDF5 )
-  if ( HDF5_FOUND )
-    check_function_exists( H5Pset_fapl_mpio MOAB_HDF_HAVE_PARALLEL )
-  endif ( HDF5_FOUND )
   # NetCDF
   # Documentation
   # Optional tools
@@ -96,24 +91,12 @@
   option ( MOAB_BUILD_MBSURFPLOT   "Build the mbsurfplot application?"    ON )
   option ( MOAB_BUILD_MBZOLTAN     "Build the mbzoltan partitioner?"      OFF )
   option ( MOAB_BUILD_DAGMC        "Build the dagmc tool?"                ON )
+  option ( MOAB_USE_HDF            "Include HDF I/O in the build?"        OFF )
   # iMesh
   option ( MOAB_BUILD_IMESH        "Build the iMesh interface?"           ON )
-  include( ${MOAB_SOURCE_DIR}/cmake/AutoconfHeader.cmake )
-  # Define some more variables so they will be substituted properly in the autoconf files.
-  set( MB_VERSION_MAJOR  ${MOAB_VERSION_MAJOR} )
-  set( MB_VERSION_MINOR  ${MOAB_VERSION_MINOR} )
-  set( MB_VERSION_PATCH  ${MOAB_VERSION_PATCH} )
-  set( MB_VERSION_STRING "\"${MOAB_VERSION_STRING}\"" )
-  # Best we can do for now since there's no config.h.in in the repository...
-  configure_file( ${MOAB_SOURCE_DIR}/config.h.cmake      ${MOAB_BINARY_DIR}/config.h )
-  # ... but the line below is what should *really* happen
-  #autoconf_header( ${MOAB_SOURCE_DIR}/config.h.in ${MOAB_BINARY_DIR}/config.h )
-  autoconf_header( ${MOAB_SOURCE_DIR}/MBVersion.h.in ${MOAB_BINARY_DIR}/MBVersion.h )
-  autoconf_header( ${MOAB_SOURCE_DIR}/MBEntityHandle.h.in ${MOAB_BINARY_DIR}/MBEntityHandle.h )
   # MOAB Library
   set ( MOAB_LIB_SRCS
     AEntityFactory.cpp
@@ -168,33 +151,41 @@
     WriteTemplate.cpp
     WriteVtk.cpp
-  set_source_files_properties( ${MOAB_LIB_SRCS}
-    COMPILE_FLAGS "-DIS_BUILDING_MB"
   include_directories(
     ${MOAB_SOURCE_DIR}
     ${MOAB_BINARY_DIR}
+  if ( MOAB_USE_HDF )
+    # HDF5
+    find_package( HDF5 )
+    if ( HDF5_FOUND )
+      check_function_exists( H5Pset_fapl_mpio MOAB_HDF_HAVE_PARALLEL )
+      set ( MOAB_LIB_SRCS
+        ${MOAB_LIB_SRCS}
+        ReadHDF5.cpp
+        WriteHDF5.cpp
+      include_directories(
+        ${HDF5_INCLUDE_DIRECTORIES}
+        ${MOAB_SOURCE_DIR}/mhdf/include
+      add_subdirectory( mhdf )
+    endif ( HDF5_FOUND )
+  endif ( MOAB_USE_HDF )
+  set_source_files_properties( ${MOAB_LIB_SRCS}
+    COMPILE_FLAGS "-DIS_BUILDING_MB"
   add_library( moab
     ${MOAB_LIB_SRCS}
-  if ( MOAB_USE_HDF )
-    set ( MOAB_MHDF_LIB_SRCS
-      ReadHDF5.cpp
-      WriteHDF5.cpp
-    include_directories(
-      ${HDF5_INCLUDE_DIRECTORIES}
-      ${MOAB_SOURCE_DIR}/mhdf/include
-    add_library( mhdf
-      ${MOAB_MHDF_LIB_SRCS}
-    target_link_libraries( mdf
+  if ( MOAB_USE_HDF AND HDF5_FOUND )
+    target_link_libraries( moab
+      mhdf
       ${HDF5_LIBRARIES}
-  endif ( MOAB_USE_HDF )
+  endif ( MOAB_USE_HDF AND HDF5_FOUND )
   ## Tools/libraries dependent on MOAB:
@@ -213,4 +204,19 @@
   # iMesh Babel
+  include( ${MOAB_SOURCE_DIR}/cmake/AutoconfHeader.cmake )
+  # Define some more variables so they will be substituted properly in the autoconf files.
+  set( MB_VERSION_MAJOR  ${MOAB_VERSION_MAJOR} )
+  set( MB_VERSION_MINOR  ${MOAB_VERSION_MINOR} )
+  set( MB_VERSION_PATCH  ${MOAB_VERSION_PATCH} )
+  set( MB_VERSION_STRING "\"${MOAB_VERSION_STRING}\"" )
+  # Best we can do for now since there's no config.h.in in the repository...
+  configure_file( ${MOAB_SOURCE_DIR}/config.h.cmake      ${MOAB_BINARY_DIR}/config.h )
+  # ... but the line below is what should *really* happen
+  #autoconf_header( ${MOAB_SOURCE_DIR}/config.h.in ${MOAB_BINARY_DIR}/config.h )
+  autoconf_header( ${MOAB_SOURCE_DIR}/MBVersion.h.in ${MOAB_BINARY_DIR}/MBVersion.h )
+  autoconf_header( ${MOAB_SOURCE_DIR}/MBEntityHandle.h.in ${MOAB_BINARY_DIR}/MBEntityHandle.h )
Modified: MOAB/trunk/MBEntityHandle.h.in
--- MOAB/trunk/MBEntityHandle.h.in	2007-10-23 18:54:21 UTC (rev 1323)
+++ MOAB/trunk/MBEntityHandle.h.in	2007-10-23 19:03:32 UTC (rev 1324)
@@ -1,6 +1,17 @@
 #ifndef MB_ENTITY_HANDLE_H
 #define MB_ENTITY_HANDLE_H
+/* Are we building with HDF? */
+/* autoconf may only set HAVE_HDF5_H and not HDF5_FOUND. */
+/* CMake may only set HDF5_FOUND. Having either implies HDF5_FILE */
+#undef HDF5_FOUND
+#undef HAVE_HDF5_H
+#ifdef HDF5_FOUND
+#  define HAVE_HDF5_H
+#endif
+#ifdef HAVE_HDF5_H
+#  define HDF5_FILE
+#endif
 /* MOAB qualified HAVE_INTTYPES_H */
 #undef MOAB_HAVE_INTTYPES_H
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp	2007-10-23 18:54:21 UTC (rev 1323)
+++ MOAB/trunk/WriteHDF5.cpp	2007-10-23 19:03:32 UTC (rev 1324)
@@ -25,6 +25,7 @@
 // Creation Date : 04/01/04
+#include "MBEntityHandle.h"
 #ifndef HDF5_FILE
 #  error Attempt to compile WriteHDF5 with HDF5 support disabled
 #endif
Modified: MOAB/trunk/config.h.cmake
--- MOAB/trunk/config.h.cmake	2007-10-23 18:54:21 UTC (rev 1323)
+++ MOAB/trunk/config.h.cmake	2007-10-23 19:03:32 UTC (rev 1324)
@@ -24,6 +24,7 @@
 #cmakedefine HDF5_FOUND
 #ifdef HDF5_FOUND
+#  define HDF5_FILE
 #endif /* HDF5_FOUND */
 /* Define to 1 if you have the <inttypes.h> header file. */
Added: MOAB/trunk/mhdf/CMakeLists.txt
--- MOAB/trunk/mhdf/CMakeLists.txt	                        (rev 0)
+++ MOAB/trunk/mhdf/CMakeLists.txt	2007-10-23 19:03:32 UTC (rev 1324)
@@ -0,0 +1,31 @@
+project(mhdf)
+include_directories(
+set ( mhdf_LIB_SRCS
+  src/adjacency.c
+  src/connectivity.c
+  src/file-handle.c
+  src/file.c
+  src/nodes.c
+  src/sets.c
+  src/status.c
+  src/status.h
+  src/tags.c
+  src/util.c
+add_library( mhdf
+  ${mhdf_LIB_SRCS}
+target_link_libraries(
+  ${HDF5_LIBRARIES}
+#include/mhdf.h \
+#src/file-handle.h \
+#src/names-and-paths.h \
+#src/util.h
