[MOAB-dev] r1395 - MOAB/branches/3.0
kraftche at mcs.anl.gov
Thu Nov 15 09:26:17 CST 2007
Author: kraftche
Date: 2007-11-15 09:26:17 -0600 (Thu, 15 Nov 2007)
New Revision: 1395
Modified:
MOAB/branches/3.0/MBMeshSet.cpp
MOAB/branches/3.0/MBMeshSet.hpp
MOAB/branches/3.0/MBOrientedBox.hpp
MOAB/branches/3.0/ReadSTL.cpp
MOAB/branches/3.0/SparseTagCollections.cpp
MOAB/branches/3.0/WriteSTL.cpp
MOAB/branches/3.0/WriteVtk.cpp
MOAB/branches/3.0/configure.in
Log:
Backport bug fixes to 3.0 branch:
o Make 'expr' syntax portable in configure.in (svn r1298)
o Windows build issues
- svn r1326: WriteVTk.cpp
- svn r1327: ReadSTL.cpp, WriteSTL.cpp
- svn r1328: MBOrientedBox.hpp
o Fix SparseTagCollection::get_number_entities bug (svn r1356)
o Fix non-portable bitfield usage in MBMeshSet (svn r1393)
Modified: MOAB/branches/3.0/MBMeshSet.cpp
--- MOAB/branches/3.0/MBMeshSet.cpp 2007-11-15 15:02:15 UTC (rev 1394)
+++ MOAB/branches/3.0/MBMeshSet.cpp 2007-11-15 15:26:17 UTC (rev 1395)
@@ -160,13 +160,13 @@
int MBMeshSet::add_parent( MBEntityHandle parent )
int result;
- mParentCount = insert_in_vector( mParentCount, parentMeshSets, parent, result );
+ mParentCount = insert_in_vector( (Count)mParentCount, parentMeshSets, parent, result );
return result;
int MBMeshSet::add_child( MBEntityHandle child )
int result;
- mChildCount = insert_in_vector( mChildCount, childMeshSets, child, result );
+ mChildCount = insert_in_vector( (Count)mChildCount, childMeshSets, child, result );
return result;
@@ -240,13 +240,13 @@
int MBMeshSet::remove_parent( MBEntityHandle parent )
int result;
- mParentCount = remove_from_vector( mParentCount, parentMeshSets, parent, result );
+ mParentCount = remove_from_vector( (Count)mParentCount, parentMeshSets, parent, result );
return result;
int MBMeshSet::remove_child( MBEntityHandle child )
int result;
- mChildCount = remove_from_vector( mChildCount, childMeshSets, child, result );
+ mChildCount = remove_from_vector( (Count)mChildCount, childMeshSets, child, result );
return result;
Modified: MOAB/branches/3.0/MBMeshSet.hpp
--- MOAB/branches/3.0/MBMeshSet.hpp 2007-11-15 15:02:15 UTC (rev 1394)
+++ MOAB/branches/3.0/MBMeshSet.hpp 2007-11-15 15:26:17 UTC (rev 1395)
@@ -239,12 +239,12 @@
//! parentMeshSets.hnd. If MANY, then parentMeshSets.ptr contains
//! array begin and end pointers for a dynamically allocated array
//! of parent handles.
- Count mParentCount : 2;
+ unsigned mParentCount : 2;
//! If less than MANY, the number of children stored inline in
//! childMeshSets.hnd. If MANY, then childMeshSets.ptr contains
//! of child handles.
- Count mChildCount : 2;
+ unsigned mChildCount : 2;
private:
//! Storage for parent and child lists
CompactList parentMeshSets, childMeshSets;
Modified: MOAB/branches/3.0/MBOrientedBox.hpp
--- MOAB/branches/3.0/MBOrientedBox.hpp 2007-11-15 15:02:15 UTC (rev 1394)
+++ MOAB/branches/3.0/MBOrientedBox.hpp 2007-11-15 15:26:17 UTC (rev 1395)
@@ -35,8 +35,9 @@
/**\brief Oriented bounding box
-struct MBOrientedBox
+class MBOrientedBox
+public:
MBCartVect center; //!< Box center
MBCartVect axis[3]; //!< Box axes, unit vectors sorted by extent of box along axis
#if MB_ORIENTED_BOX_UNIT_VECTORS
Modified: MOAB/branches/3.0/ReadSTL.cpp
--- MOAB/branches/3.0/ReadSTL.cpp 2007-11-15 15:02:15 UTC (rev 1394)
+++ MOAB/branches/3.0/ReadSTL.cpp 2007-11-15 15:26:17 UTC (rev 1395)
@@ -25,8 +25,23 @@
#include "MBInterface.hpp"
#include "MBReadUtilIface.hpp"
#include "MBRange.hpp"
+#include "MBEntityHandle.h"
-#include <inttypes.h> // for int32_t
+#ifdef MOAB_HAVE_INTTYPES_H
+#include <inttypes.h>
+#endif
+#ifdef MOAB_HAVE_STDDEF_H
+#include <stddef.h>
+#endif
+#ifdef MOAB_HAVE_STDINT_H
+#include <stdint.h>
+#endif
+#ifdef _MSC_VER /* windows */
+# include <BaseTsd.h>
+typedef ULONG32 uint32_t;
+#endif
#include <errno.h>
#include <string.h>
#include <limits.h>
Modified: MOAB/branches/3.0/SparseTagCollections.cpp
--- MOAB/branches/3.0/SparseTagCollections.cpp 2007-11-15 15:02:15 UTC (rev 1394)
+++ MOAB/branches/3.0/SparseTagCollections.cpp 2007-11-15 15:26:17 UTC (rev 1395)
@@ -335,6 +335,7 @@
//! get number of entities of type
MBErrorCode SparseTagCollection::get_number_entities(MBEntityType type, int& num_entities)
+ num_entities = 0;
std::map<MBEntityHandle, void*>::iterator iter;
for(iter = mData.begin(); iter != mData.end(); ++iter)
Modified: MOAB/branches/3.0/WriteSTL.cpp
--- MOAB/branches/3.0/WriteSTL.cpp 2007-11-15 15:02:15 UTC (rev 1394)
+++ MOAB/branches/3.0/WriteSTL.cpp 2007-11-15 15:26:17 UTC (rev 1395)
@@ -25,26 +25,30 @@
#include "MBWriteUtilIface.hpp"
+#endif
+#endif
+#endif
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <errno.h>
-#include <unistd.h>
#include <math.h>
+#include <fcntl.h>
-# include <io.h>
-# define O_BINARY _O_BINARY
-# define O_CREAT _O_CREAT
-# define O_EXCL _O_EXCL
-# define O_TRUNC _O_TRUNC
-# define O_WRONLY _O_WRONLY
-# define fdopen(A,B) _fdopen( (A), (B) )
-# define open(A,B,C) _open( (A), (B), (C) )
#else /* posix */
-# include <fcntl.h>
+# include <unistd.h>
# define _S_IREAD (S_IRUSR|S_IRGRP|S_IROTH)
# define _S_IWRITE (S_IWUSR|S_IWGRP|S_IWOTH)
#endif
Modified: MOAB/branches/3.0/WriteVtk.cpp
--- MOAB/branches/3.0/WriteVtk.cpp 2007-11-15 15:02:15 UTC (rev 1394)
+++ MOAB/branches/3.0/WriteVtk.cpp 2007-11-15 15:26:17 UTC (rev 1395)
@@ -405,29 +405,32 @@
for (unsigned j = 0; j < vals_per_tag; ++j, ++d)
- stream << *d << ' ';
+ if (sizeof(T) == 1)
+ stream << (unsigned int)*d << ' ';
+ else
+ stream << *d << ' ';
stream << std::endl;
-template <>
-void WriteVtk::write_data<unsigned char>( std::ostream& stream,
- const std::vector<unsigned char>& data,
- unsigned vals_per_tag )
- std::vector<unsigned char>::const_iterator d = data.begin();
- const unsigned long n = data.size() / vals_per_tag;
- for (unsigned long i = 0; i < n; ++i)
- for (unsigned j = 0; j < vals_per_tag; ++j, ++d)
- stream << (unsigned int)*d << ' ';
- stream << std::endl;
+//template <>
+//void WriteVtk::write_data<unsigned char>( std::ostream& stream,
+// const std::vector<unsigned char>& data,
+// unsigned vals_per_tag )
+// std::vector<unsigned char>::const_iterator d = data.begin();
+// const unsigned long n = data.size() / vals_per_tag;
+// for (unsigned long i = 0; i < n; ++i)
+// for (unsigned j = 0; j < vals_per_tag; ++j, ++d)
+// stream << (unsigned int)*d << ' ';
+// stream << std::endl;
template <typename T>
Modified: MOAB/branches/3.0/configure.in
--- MOAB/branches/3.0/configure.in 2007-11-15 15:02:15 UTC (rev 1394)
+++ MOAB/branches/3.0/configure.in 2007-11-15 15:26:17 UTC (rev 1395)
@@ -30,8 +30,8 @@
AC_DEFINE(MB_VERSION,["AC_PACKAGE_VERSION"],[MOAB Version])
-VERSION_MAJOR=`expr AC_PACKAGE_VERSION : '\([[0-9]]\+\)'`
-VERSION_MINOR=`expr AC_PACKAGE_VERSION : '[[0-9]]*\.\([[0-9]]\+\)'`
+VERSION_MAJOR=`expr AC_PACKAGE_VERSION : '\([[0-9]]*\)'`
+VERSION_MINOR=`expr AC_PACKAGE_VERSION : '[[0-9]]*\.\([[0-9]]*\)'`
VERSION_PATCH=`expr AC_PACKAGE_VERSION : '[[0-9]]*\.[[0-9]]*\.\(.*\)'`
test "x" != "x$VERSION_MAJOR" || AC_MSG_ERROR("Invalid version string: AC_PACKAGE_VERSION")
test "x" != "x$VERSION_MINOR" || AC_MSG_ERROR("Invalid version string: AC_PACKAGE_VERSION")
