[MOAB-dev] r1396 - MOAB/trunk
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Nov 15 15:12:59 CST 2007
Author: tautges
Date: 2007-11-15 15:12:59 -0600 (Thu, 15 Nov 2007)
New Revision: 1396
Modified:
   MOAB/trunk/AEntityFactory.cpp
Log:
Fix for notify delete  on polygons.
Modified: MOAB/trunk/AEntityFactory.cpp
--- MOAB/trunk/AEntityFactory.cpp	2007-11-15 15:26:17 UTC (rev 1395)
+++ MOAB/trunk/AEntityFactory.cpp	2007-11-15 21:12:59 UTC (rev 1396)
@@ -423,22 +423,32 @@
                                                    const bool delete_adj_list)
   MBErrorCode result;
+  MBEntityType base_type = TYPE_FROM_HANDLE(base_entity);
-  if (TYPE_FROM_HANDLE(base_entity) == MBENTITYSET)
+  if (base_type == MBENTITYSET)
     return thisMB->clear_meshset(&base_entity, 1);
-  const int base_ent_dim = MBCN::Dimension( TYPE_FROM_HANDLE( base_entity ) );
+  const int base_ent_dim = MBCN::Dimension( base_type );
     // Remove adjacencies from element vertices back to
     // this element.  Also check any elements adjacent
     // to the vertex and of higher dimension than this
     // element for downward adjacencies to this element.
-  if (vert_elem_adjacencies() && TYPE_FROM_HANDLE(base_entity) != MBVERTEX) {
+  if (vert_elem_adjacencies() && base_type != MBVERTEX) {
     MBEntityHandle const *connvect = 0, *adjvect = 0;
     int numconn = 0, numadj = 0;
     std::vector<MBEntityHandle> connstorage;
-    result = thisMB->get_connectivity( base_entity, connvect, numconn, false, &connstorage );
-    if (MB_SUCCESS != result)
-      return result;
+    if (base_type != MBPOLYGON) {
+      result = thisMB->get_connectivity( base_entity, connvect, numconn, false, &connstorage );
+      if (MB_SUCCESS != result)
+        return result;
+    else {
+      result = thisMB->get_adjacencies(&base_entity, 1, 0, false, connstorage);
+        return result;
+      connvect = &connstorage[0];
+      numconn = connstorage.size();
     for (int i = 0; i < numconn; ++i) {
       result = get_adjacencies( connvect[i], adjvect, numadj );
