[MOAB-dev] r1394 - MOAB/trunk
kraftche at mcs.anl.gov
Thu Nov 15 09:02:16 CST 2007
Author: kraftche
Date: 2007-11-15 09:02:15 -0600 (Thu, 15 Nov 2007)
New Revision: 1394
Modified:
MOAB/trunk/TypeSequenceManager.cpp
Log:
fix memory leaks
Modified: MOAB/trunk/TypeSequenceManager.cpp
--- MOAB/trunk/TypeSequenceManager.cpp 2007-11-14 23:17:58 UTC (rev 1393)
+++ MOAB/trunk/TypeSequenceManager.cpp 2007-11-15 15:02:15 UTC (rev 1394)
@@ -570,8 +570,12 @@
return MB_ENTITY_NOT_FOUND;
if (seq->start_handle() == h) {
- if (seq->end_handle() != h)
- return seq->pop_front(1);
+ if (seq->end_handle() != h) {
+ if (seq->using_entire_data())
+ availableList.insert( seq->data() );
+ seq->pop_front(1);
+ return MB_SUCCESS;
SequenceData* data = seq->data();
bool delete_data;
MBErrorCode rval = remove_sequence( seq, delete_data );
@@ -582,14 +586,21 @@
delete data;
return MB_SUCCESS;
- else if (seq->end_handle() == h)
- return seq->pop_back(1);
+ else if (seq->end_handle() == h) {
+ seq->pop_back(1);
else {
iterator i = lower_bound( h );
+ if ((*i)->using_entire_data())
+ availableList.insert( (*i)->data() );
i = split_sequence( i, h );
seq = *i;
assert(seq->start_handle() == h);
@@ -605,7 +616,7 @@
// get first sequence intersecting range
iterator i = lower_bound( first );
- if (i == end()) // shouuldn't be possible given check_valid_handles call above.
+ if (i == end()) // shouldn't be possible given check_valid_handles call above.
// if range is entirely in interior of sequence, need to split sequence.
