[MOAB-dev] r1393 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Wed Nov 14 17:17:58 CST 2007
Author: kraftche
Date: 2007-11-14 17:17:58 -0600 (Wed, 14 Nov 2007)
New Revision: 1393
Modified:
   MOAB/trunk/MBMeshSet.cpp
   MOAB/trunk/MBMeshSet.hpp
Log:
Fix portability issue storing MBMeshSet parent/child lists (fixes bug on
Windows.)  Apparently if a bit-field value is signed, gcc treats the bits
as the lower N bits of the declared type while Microsoft's compiler
consideres them to be a signed integer of N bits.  Example:
struct S {
  int bits : 2;
int n = 2;
S s;
s.bits = n;
n = s.bits;
s.bits has the binary value 10b.  On Linux, n will finish with '2' while on
Windows it is '-1'.  10b can be either, depending on whether or
one considers it to be a unsigned value or a 2-bit 2s-compliment value.
Many thanks to Byron Hanks for disconvery this issue, helping to track down
the cause, and for testing the fix.
Modified: MOAB/trunk/MBMeshSet.cpp
--- MOAB/trunk/MBMeshSet.cpp	2007-11-14 22:13:16 UTC (rev 1392)
+++ MOAB/trunk/MBMeshSet.cpp	2007-11-14 23:17:58 UTC (rev 1393)
@@ -160,13 +160,13 @@
 int MBMeshSet::add_parent( MBEntityHandle parent )
   int result;
-  mParentCount = insert_in_vector( mParentCount, parentMeshSets, parent, result );
+  mParentCount = insert_in_vector( (Count)mParentCount, parentMeshSets, parent, result );
   return result;
 int MBMeshSet::add_child( MBEntityHandle child )
   int result;
-  mChildCount = insert_in_vector( mChildCount, childMeshSets, child, result );
+  mChildCount = insert_in_vector( (Count)mChildCount, childMeshSets, child, result );
   return result;
@@ -240,13 +240,13 @@
 int MBMeshSet::remove_parent( MBEntityHandle parent )
   int result;
-  mParentCount = remove_from_vector( mParentCount, parentMeshSets, parent, result );
+  mParentCount = remove_from_vector( (Count)mParentCount, parentMeshSets, parent, result );
   return result;
 int MBMeshSet::remove_child( MBEntityHandle child )
   int result;
-  mChildCount = remove_from_vector( mChildCount, childMeshSets, child, result );
+  mChildCount = remove_from_vector( (Count)mChildCount, childMeshSets, child, result );
   return result;
Modified: MOAB/trunk/MBMeshSet.hpp
--- MOAB/trunk/MBMeshSet.hpp	2007-11-14 22:13:16 UTC (rev 1392)
+++ MOAB/trunk/MBMeshSet.hpp	2007-11-14 23:17:58 UTC (rev 1393)
@@ -252,12 +252,12 @@
   //! parentMeshSets.hnd.  If MANY, then parentMeshSets.ptr contains
   //! array begin and end pointers for a dynamically allocated array
   //! of parent handles.
-  Count mParentCount : 2;
+  unsigned mParentCount : 2;
   //! If less than MANY, the number of children stored inline in
   //! childMeshSets.hnd.  If MANY, then childMeshSets.ptr contains
   //! of child handles.
-  Count mChildCount : 2;
+  unsigned mChildCount : 2;
 private:
   //! Storage for parent and child lists
   CompactList parentMeshSets, childMeshSets;
