[MOAB-dev] r1480 - MOAB/trunk
tautges at mcs.anl.gov tautges at mcs.anl.gov
Wed Dec 19 14:41:47 CST 2007
Author: tautges
Date: 2007-12-19 14:41:46 -0600 (Wed, 19 Dec 2007)
New Revision: 1480
Modified:
   MOAB/trunk/MBMeshSet.cpp
Log:
Change implementation of range-based entity removal from range-based sets, to use range booleans instead of individual element removal from ranges.  This speeds up one of my applications by an order of magnitude.
Passes make check.
Modified: MOAB/trunk/MBMeshSet.cpp
--- MOAB/trunk/MBMeshSet.cpp	2007-12-19 20:38:26 UTC (rev 1479)
+++ MOAB/trunk/MBMeshSet.cpp	2007-12-19 20:41:46 UTC (rev 1480)
@@ -347,20 +347,18 @@
                                                 MBEntityHandle mEntityHandle,
                                                 AEntityFactory* mAdjFact )
-  MBRange::const_iterator iter = entities.begin();
-  for(; iter != entities.end(); ++iter)
-    MBRange::iterator found = mRange.find(*iter);
-    if(found != mRange.end())
-      mRange.erase(found);
-      if(tracking() && mAdjFact)
-        mAdjFact->remove_adjacency(*iter, mEntityHandle);
+  MBRange common_ents = mRange.intersect(entities);
+  MBRange tmp_range = mRange.subtract(common_ents);
+  mRange.swap(tmp_range);
+  if(tracking() && mAdjFact) {
+    for(MBRange::const_iterator iter = common_ents.begin();
+        iter != common_ents.end(); iter++) {
+      mAdjFact->remove_adjacency(*iter, mEntityHandle);
   return MB_SUCCESS;
 MBErrorCode MBMeshSet_MBRange::remove_entities( const MBEntityHandle *entities,
