[MOAB-dev] r1479 - MOAB/trunk/parallel
tautges at mcs.anl.gov
Wed Dec 19 14:38:29 CST 2007
Author: tautges
Date: 2007-12-19 14:38:26 -0600 (Wed, 19 Dec 2007)
New Revision: 1479
Modified:
MOAB/trunk/parallel/ReadParallel.cpp
Log:
Adding some error reporting and some code to cut the partition in half if running on one processor. Helps profile the code on a single processor.
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2007-12-19 17:59:01 UTC (rev 1478)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2007-12-19 20:38:26 UTC (rev 1479)
@@ -266,10 +266,13 @@
return MB_FAILURE;
- if (MB_SUCCESS != tmp_result) {
+ if (MB_SUCCESS != tmp_result &&
+ (*vit != PA_BROADCAST || mbImpl->proc_size() != 1)) {
result = tmp_result;
std::ostringstream ostr;
ostr << "Failed in step " << ParallelActionsNames[*vit] << std::endl;
+ std::string tmp_str;
+ if (MB_SUCCESS == mbImpl->get_last_error(tmp_str)) ostr << tmp_str << std::endl;
RR(ostr.str().c_str());
@@ -296,6 +299,7 @@
int proc_sz = mbImpl->proc_size();
int proc_rk = mbImpl->proc_rank();
+ unsigned int num_partsets = partition_sets.size();
if (!ptag_vals.empty()) {
// values input, get sets with those values
@@ -320,6 +324,9 @@
int num_sets = partition_sets.size() / proc_sz, orig_numsets = num_sets;
if (proc_rk < partition_sets.size() % proc_sz) num_sets++;
+ // cut them in half if we're on one proc
+ if (proc_sz == 1 && num_partsets == num_sets) num_sets /= 2;
for (int i = 0; i < num_sets; i++)
tmp_sets.insert(partition_sets[i*proc_sz + proc_rk]);
@@ -373,11 +380,13 @@
// delete sets, then ents
- result = mbImpl->delete_entities(deletable_sets);
+ if (!deletable_sets.empty())
+ result = mbImpl->delete_entities(deletable_sets);
RR("Failure deleting sets in delete_nonlocal_entities.");
deletable_ents = deletable_ents.subtract(deletable_sets);
- result = mbImpl->delete_entities(deletable_ents);
+ if (!deletable_ents.empty())
+ result = mbImpl->delete_entities(deletable_ents);
RR("Failure deleting entities in delete_nonlocal_entities.");
// if (debug)
