itaps-parallel Questions about iMeshP
Mark Beall
mbeall at simmetrix.com
Mon Dec 21 20:09:08 CST 2009
For the known examples of needing multiple partitionings is there
generally any correlation between the partitions (meaning that
entities in one partitioning end up on the same processors as entities
in the other partitioning)? I assuming there is a very low correlation
between the partitionings, almost by definition (since, otherwise, why
have the other partitioning). Is that correct?
mark
On Dec 21, 2009, at 11:56 AM, Tim Tautges wrote:
> Interesting. I've thought about PIC codes in the context, but
> always wondered whether apps would consider it overkill to do the
> particles with vertices (which I think is what you're implying
> below? Or not?)
> - tim
> Devine, Karen D wrote:
>> Thanks, Tim, for providing a good example. Here's another: a
>> particle-in-cell code can partition the mesh one way for force
>> calculations
>> and a different way for particle calculations. The force
>> calculations use a
>> static partitioning; the particle calculations use a dynamic
>> partitioning
>> that attempts to maintain particle balance.
>> Karen
>> On 12/18/09 9:54 AM, "Tim Tautges" <tautges at mcs.anl.gov> wrote:
>>> The best example, brought up by both Karen and me IIRC, is of
>>> large-deformation transient dynamics with contact, where
>>> the FE solution of the dynamics is solved on 3d elements on one
>>> partition, and
>>> the contact solution is solved on faces
>>> on a different partition. Many believe it was this capability
>>> that made truly
>>> scalable parallel FEM with contact even
>>> possible. See e.g.
>>> Transient dynamics simulations: parallel algorithms for contact
>>> detection and
>>> smoothed particle hydrodynamics,
>>> Proceedings of the 1996 ACM/IEEE conference on Supercomputing, 1996.
>>> That's just one reference, there are many others for that
>>> particular work.
>>> I think the details of multiple *active* partitions still need
>>> some work, both
>>> in use cases and in how they behave under
>>> iMeshP. Normally I wouldn't advocate such an unexplored thing
>>> being part of
>>> the initial interface definition, but in
>>> this case I think it's an important enough capability that it's
>>> justified.
>>> - tim
>>> Mark Beall wrote:
>>>> As a more general context to the questions that Saurabh asked,
>>>> the main
>>>> questions we have about iMeshP are issues related to having
>>>> multiple
>>>> partitions. Although we won't be supporting that for now (since our
>>>> software doesn't support that), it would be helpful in
>>>> understanding
>>>> that need if someone could give some examples of how this
>>>> functionality
>>>> would be used.
>>>> mark
>>> "You will keep in perfect peace him whose mind is
>>> steadfast, because he trusts in you." Isaiah 26:3
>>> Tim Tautges Argonne National Laboratory
>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>> phone: (608) 263-8485 1500 Engineering Dr.
>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
