itaps-parallel Questions about iMeshP
Tim Tautges
tautges at mcs.anl.gov
Mon Dec 21 23:36:40 CST 2009
That is correct, and is the reason for using a completely different one (and was the key element of the breakthough on
parallel contact, as I understand it).
- tim
Mark Beall wrote:
> For the known examples of needing multiple partitionings is there
> generally any correlation between the partitions (meaning that entities
> in one partitioning end up on the same processors as entities in the
> other partitioning)? I assuming there is a very low correlation between
> the partitionings, almost by definition (since, otherwise, why have the
> other partitioning). Is that correct?
> mark
> On Dec 21, 2009, at 11:56 AM, Tim Tautges wrote:
>> Interesting. I've thought about PIC codes in the context, but always
>> wondered whether apps would consider it overkill to do the particles
>> with vertices (which I think is what you're implying below? Or not?)
>> - tim
>> Devine, Karen D wrote:
>>> Thanks, Tim, for providing a good example. Here's another: a
>>> particle-in-cell code can partition the mesh one way for force
>>> calculations
>>> and a different way for particle calculations. The force
>>> calculations use a
>>> static partitioning; the particle calculations use a dynamic
>>> partitioning
>>> that attempts to maintain particle balance.
>>> Karen
>>> On 12/18/09 9:54 AM, "Tim Tautges" <tautges at mcs.anl.gov> wrote:
>>>> The best example, brought up by both Karen and me IIRC, is of
>>>> large-deformation transient dynamics with contact, where
>>>> the FE solution of the dynamics is solved on 3d elements on one
>>>> partition, and
>>>> the contact solution is solved on faces
>>>> on a different partition. Many believe it was this capability that
>>>> made truly
>>>> scalable parallel FEM with contact even
>>>> possible. See e.g.
>>>> Transient dynamics simulations: parallel algorithms for contact
>>>> detection and
>>>> smoothed particle hydrodynamics,
>>>> Proceedings of the 1996 ACM/IEEE conference on Supercomputing, 1996.
>>>> That's just one reference, there are many others for that particular
>>>> work.
>>>> I think the details of multiple *active* partitions still need some
>>>> work, both
>>>> in use cases and in how they behave under
>>>> iMeshP. Normally I wouldn't advocate such an unexplored thing being
>>>> part of
>>>> the initial interface definition, but in
>>>> this case I think it's an important enough capability that it's
>>>> justified.
>>>> - tim
>>>> Mark Beall wrote:
>>>>> As a more general context to the questions that Saurabh asked, the
>>>>> main
>>>>> questions we have about iMeshP are issues related to having multiple
>>>>> partitions. Although we won't be supporting that for now (since our
>>>>> software doesn't support that), it would be helpful in understanding
>>>>> that need if someone could give some examples of how this
>>>>> functionality
>>>>> would be used.
>>>>> mark
>>>> "You will keep in perfect peace him whose mind is
>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>> Tim Tautges Argonne National Laboratory
>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
