itaps-parallel Changed imesh make vars
Tim Tautges
tautges at mcs.anl.gov
Thu Sep 11 17:30:49 CDT 2008
Hi all,
FYI, in MOAB on mesh.ep, I've changed the imesh make variables in
iMesh-Defs.inc to be upper case, and installed this in /usr/local/itaps
there. You may have to change your customized MOAB-based build
procedure to whatever you're using with GRUUMP or FMDB.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
