itaps-parallel A couple of proposals for new iMesh functions
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Fri Sep 12 12:33:23 CDT 2008
Here are a couple of things that came up while I was working on
swapping, and came across a couple of missing things in the interface.
Mark S and Onkar should pay particular attention to this, as the other
major stakeholders were present for a bootcamp discussion of this.
I'm proposing that we add this function:
/**\brief Get information about how this implementation can create
entities
* Get information about the types of low-dimensional entities that
an implementation can use to create high-dimensional entities. The
result is an adjacency table-style array. This table is a 4x4 array,
with indices 0-based, where A(i,j) (i=row, j=column) is lower triangular
(i < j), where a non-zero values states that the implementation can
create entities of type j from entities of type i.
* \param instance iMesh instance handle
* \param *adjacency_table Array representing adjacency table
* passed to function
* \param adjacency_table_size Size of adjacency table (should be 16)
* \param *err Pointer to error type returned from function
void iMesh_getEntCreateTable (iMesh_Instance instance,
/*in*/ int* adjacency_table,
/*in*/ int adjacency_table_size,
/*out*/ int *err);
Also, I suggest that we add an ENTITY_IN_USE error code, to be used when
an entity deletion is requested for an entity that is still in use as a
downward adjacency. This is currently spec'ed as an error, but
INVALID_ARGUMENT is a fairly non-diagnostic error code for this..... I
don't expect to add this to iBase.h until we start adding error codes
for parallel.
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the itaps-parallel
