itaps-parallel New unit tests on mesh.ep.wisc.edu
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Wed Sep 3 16:12:25 CDT 2008
Hello, all.
I've got the new unit test code installed on Tim's test machine. It's
in /usr/local/itaps/unitTest. While you could in principle compile and
run it there, I recommend that you copy the tar file to your own
directory, and work with it there. You'll need to type
./configure --with-iBase=AAA --with-Mesh=BBB
where AAA and BBB are the pathnames where iBase-Defs.inc and
iMesh-Defs.inc can be found. Assuming those files have the correct make
variables in them, the unit test should build correctly.
Currently, there is no dependence on a particular input file, so you can
use any file your implementation will read. (Yes, this means that
adjacencies can only be checked for consistency, not strictly for
correctness; but it's hard to imagine a consistent result being too
badly incorrect.) Also, note that the mesh values for testing must --
currently -- have at least 55 vertices in it. (Don't ask.)
When you have questions, let me know.
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the itaps-parallel
