itaps-parallel /usr/local/itaps on mesh.ep.wisc.edu
Mark Miller miller86 at llnl.gov
Thu Sep 11 17:30:25 CDT 2008
Hi Ting,
When I use ONLY the FMDB_iMesh.cc file in my old source tree, I get the
following error...
iMesh/iMesh_FMDB.cc: In function ‘void imesh_save_(void*, void*, const char*, const char*, int*, int, int)’:
iMesh/iMesh_FMDB.cc:157: error: ‘M_writeVTKFile’ was not declared in this scope
And compilation stops.
On Tim's machine, I just did './configure --enable-iMesh' in my copy of
FMDB_iMeshP source tree to compile and build it.
On Thu, 2008-09-11 at 18:05 -0400, txie at scorec.rpi.edu wrote:
> Questions:
> 1. If you only change FMDB_iMesh.cc file in the old FMDB version you had,
> what is the result?
> 2. May you let me know how you configure and compile FMDB_iMeshP on Tim's
> machine?
> Please let me know if you find any problems.
> Thanks,
> Ting
> > Hi All,
> > Ok, I copied /usr/local/itaps/FMDB_iMeshP to my home dir, re-configured
> > and compiled it and 'installed' it to /usr/local/itaps/visit/fmdb.
> > Then, I build VisIt's plugin against it and installed the resulting
> > plugin /usr/local/itaps/visit.
> > However, it does not draw the test files correctly. It looks like there
> > is a problem with connectivity. A picture is attached.
> > Mark
> > On Thu, 2008-09-11 at 14:58 -0400, txie at scorec.rpi.edu wrote:
> >> Yes. It is located in Tim's machine:
> >> /usr/local/itaps/FMDB_iMeshP/FMDB/FMDB/iMesh/iMesh_FMDB.cc
> >> > I am almost certain I did NOT use most up to date version. I probably
> >> > don't know where to go to get the most up to date. Any chance you
> >> could
> >> > either email direct to me (miller86 at llnl.gov) or make it available on
> >> > Tim's machine and then email me where you put it?
> >> > Mark
> >> > On Thu, 2008-09-11 at 14:46 -0400, txie at scorec.rpi.edu wrote:
> >> >> I am not sure that you used the updated version. But in current
> >> >> iMesh_FMDB.cc file, we use:
> >> >> pMeshDataId tag_id = (uintptr_t)tag_handle;
> >> >> Ting
> >> >> >> iMesh/iMesh_FMDB.cc: In function ¡void imesh_destroytag_(void*,
> >> >> void*,
> >> >> >> int, int*)¢:
> >> >> >> iMesh/iMesh_FMDB.cc:3575: error: cast from ¡void*¢ to
> >> ¡pMeshDataId¢
> >> >> >> loses
> >> >> >> precision
> >> >> >   This is something Ting should be able to fix quickly in FMDB.
> >> >> > - Onkar
> >> > Mark C. Miller, Lawrence Livermore National Laboratory
> >> > email: mailto:miller86 at llnl.gov
> >> > (M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
> >> > (Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
