itaps-parallel /usr/local/itaps on mesh.ep.wisc.edu
txie at scorec.rpi.edu txie at scorec.rpi.edu
Thu Sep 11 17:05:22 CDT 2008
Questions:
1. If you only change FMDB_iMesh.cc file in the old FMDB version you had,
what is the result?
2. May you let me know how you configure and compile FMDB_iMeshP on Tim's
machine?
Please let me know if you find any problems.
Ting
> Hi All,
> Ok, I copied /usr/local/itaps/FMDB_iMeshP to my home dir, re-configured
> and compiled it and 'installed' it to /usr/local/itaps/visit/fmdb.
> Then, I build VisIt's plugin against it and installed the resulting
> plugin /usr/local/itaps/visit.
> However, it does not draw the test files correctly. It looks like there
> is a problem with connectivity. A picture is attached.
> Mark
> On Thu, 2008-09-11 at 14:58 -0400, txie at scorec.rpi.edu wrote:
>> Yes. It is located in Tim's machine:
>> /usr/local/itaps/FMDB_iMeshP/FMDB/FMDB/iMesh/iMesh_FMDB.cc
>> > I am almost certain I did NOT use most up to date version. I probably
>> > don't know where to go to get the most up to date. Any chance you
>> could
>> > either email direct to me (miller86 at llnl.gov) or make it available on
>> > Tim's machine and then email me where you put it?
>> > Mark
>> > On Thu, 2008-09-11 at 14:46 -0400, txie at scorec.rpi.edu wrote:
>> >> I am not sure that you used the updated version. But in current
>> >> iMesh_FMDB.cc file, we use:
>> >> pMeshDataId tag_id = (uintptr_t)tag_handle;
>> >> Ting
>> >> >> iMesh/iMesh_FMDB.cc: In function ¡void imesh_destroytag_(void*,
>> >> void*,
>> >> >> int, int*)¢:
>> >> >> iMesh/iMesh_FMDB.cc:3575: error: cast from ¡void*¢ to
>> ¡pMeshDataId¢
>> >> >> loses
>> >> >> precision
>> >> >   This is something Ting should be able to fix quickly in FMDB.
>> >> > - Onkar
>> > Mark C. Miller, Lawrence Livermore National Laboratory
>> > email: mailto:miller86 at llnl.gov
>> > (M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
>> > (Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
