itaps-parallel /usr/local/itaps on mesh.ep.wisc.edu
Mark Miller
miller86 at llnl.gov
Thu Sep 11 17:59:11 CDT 2008
Hi Ting,
Ok, I commented out the references to M_writeVTKFile and re-compiled.
That worked. And, it produces the correct connectivity, too!
So, now, all three implementations plugins have been installed for VisIt
in /usr/local/itaps/visit. They are named, ITAPS_MOAB, ITAPS_GRUMMP and
ITAPS_FMDB.
To use them you would either pass '-assume_format <plugin-name>' on the
command line to launch VisIt or use File->Open As from the GUI and then
select the plugin type from the pull down menu there.
On Thu, 2008-09-11 at 15:30 -0700, Mark Miller wrote:
> Hi Ting,
> When I use ONLY the FMDB_iMesh.cc file in my old source tree, I get the
> following error...
> iMesh/iMesh_FMDB.cc: In function ‘void imesh_save_(void*, void*, const char*, const char*, int*, int, int)’:
> iMesh/iMesh_FMDB.cc:157: error: ‘M_writeVTKFile’ was not declared in this scope
> And compilation stops.
> On Tim's machine, I just did './configure --enable-iMesh' in my copy of
> FMDB_iMeshP source tree to compile and build it.
> Mark
> On Thu, 2008-09-11 at 18:05 -0400, txie at scorec.rpi.edu wrote:
> > Questions:
> > 1. If you only change FMDB_iMesh.cc file in the old FMDB version you had,
> > what is the result?
> > 2. May you let me know how you configure and compile FMDB_iMeshP on Tim's
> > machine?
> > Please let me know if you find any problems.
> > Thanks,
> > Ting
> > > Hi All,
> > > Ok, I copied /usr/local/itaps/FMDB_iMeshP to my home dir, re-configured
> > > and compiled it and 'installed' it to /usr/local/itaps/visit/fmdb.
> > > Then, I build VisIt's plugin against it and installed the resulting
> > > plugin /usr/local/itaps/visit.
> > > However, it does not draw the test files correctly. It looks like there
> > > is a problem with connectivity. A picture is attached.
> > > Mark
> > > On Thu, 2008-09-11 at 14:58 -0400, txie at scorec.rpi.edu wrote:
> > >> Yes. It is located in Tim's machine:
> > >> /usr/local/itaps/FMDB_iMeshP/FMDB/FMDB/iMesh/iMesh_FMDB.cc
> > >> > I am almost certain I did NOT use most up to date version. I probably
> > >> > don't know where to go to get the most up to date. Any chance you
> > >> could
> > >> > either email direct to me (miller86 at llnl.gov) or make it available on
> > >> > Tim's machine and then email me where you put it?
> > >> > Mark
> > >> > On Thu, 2008-09-11 at 14:46 -0400, txie at scorec.rpi.edu wrote:
> > >> >> I am not sure that you used the updated version. But in current
> > >> >> iMesh_FMDB.cc file, we use:
> > >> >> pMeshDataId tag_id = (uintptr_t)tag_handle;
> > >> >> Ting
> > >> >> >> iMesh/iMesh_FMDB.cc: In function ¡void imesh_destroytag_(void*,
> > >> >> void*,
> > >> >> >> int, int*)¢:
> > >> >> >> iMesh/iMesh_FMDB.cc:3575: error: cast from ¡void*¢ to
> > >> ¡pMeshDataId¢
> > >> >> >> loses
> > >> >> >> precision
> > >> >> > This is something Ting should be able to fix quickly in FMDB.
> > >> >> > - Onkar
> > >> > Mark C. Miller, Lawrence Livermore National Laboratory
> > >> > email: mailto:miller86 at llnl.gov
> > >> > (M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
> > >> > (Th/F) (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel
