itaps-parallel /usr/local/itaps on mesh.ep.wisc.edu
txie at scorec.rpi.edu txie at scorec.rpi.edu
Thu Sep 11 13:58:33 CDT 2008
Yes. It is located in Tim's machine:
/usr/local/itaps/FMDB_iMeshP/FMDB/FMDB/iMesh/iMesh_FMDB.cc
> I am almost certain I did NOT use most up to date version. I probably
> don't know where to go to get the most up to date. Any chance you could
> either email direct to me (miller86 at llnl.gov) or make it available on
> Tim's machine and then email me where you put it?
> Mark
> On Thu, 2008-09-11 at 14:46 -0400, txie at scorec.rpi.edu wrote:
>> I am not sure that you used the updated version. But in current
>> iMesh_FMDB.cc file, we use:
>> pMeshDataId tag_id = (uintptr_t)tag_handle;
>> Ting
>> >> iMesh/iMesh_FMDB.cc: In function ¡void imesh_destroytag_(void*,
>> void*,
>> >> int, int*)¢:
>> >> iMesh/iMesh_FMDB.cc:3575: error: cast from ¡void*¢ to ¡pMeshDataId¢
>> >> loses
>> >> precision
>> >   This is something Ting should be able to fix quickly in FMDB.
>> > - Onkar
> Mark C. Miller, Lawrence Livermore National Laboratory
> email: mailto:miller86 at llnl.gov
> (M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
> (Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
