itaps-parallel Tutorial slides
Devine, Karen D
kddevin at sandia.gov
Fri Nov 14 11:28:29 CST 2008
OK; I'm done (again). The changes to the slides are committed.
Karen
On 11/14/08 10:22 AM, "Devine, Karen D" <kddevin at sandia.gov> wrote:
> OK; I will make this change in the 1_Hello tutorial and in the slides.
> I claim right-to-modify the slides for the next few minutes; I¹ll let you
> know when it is your turn.
> Karen
> On 11/14/08 9:51 AM, "Tim Tautges" <tautges at mcs.anl.gov> wrote:
>> One other change I think would be very useful would be to use a make
>> variable IMESH_DIR instead of conditional blocks which depend on
>> implementation. That makes the makefile completely generic; the
>> IMESH_DIR can be specified on the make line, e.g.
>> make IMESH_DIR=/usr/local/itaps/FMDB
>> or can be set as an env variable.
>> - tim
>> Devine, Karen D wrote:
>>> I am going to update the tutorial slides to reflect the iMesh-Defs.inc
>>> changes to the Makefiles. So that we can avoid any conflicts, I will do the
>>> update now and let you know when I have committed my changes.
>>> Karen
>> "You will keep in perfect peace him whose mind is
>> steadfast, because he trusts in you." Isaiah 26:3
>> Tim Tautges Argonne National Laboratory
>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>> phone: (608) 263-8485 1500 Engineering Dr.
>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
